On this page
Elastic Volume Service (EVS)
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by EVS, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by EVS, see Conditions.
The following table lists the actions that you can define in SCP statements for EVS.
Table 1 Actions supported by EVS
Action
Access Level
Resource Type (*: required)
Condition Key
evs:volumes:create
Grants permission to create disks.
write
volume *
  • g:RequestTag/<tag-key>
  • g:TagKeys
  • g:EnterpriseProjectId
  • evs:Encrypted
  • cbr:VaultId
evs:volumes:list
Grants permission to list disks.
list
evs:volumes:get
Grants permission to query disks.
read
volume *
  • g:ResourceTag/<tag-key>
evs:volumes:delete
Grants permission to delete disks.
write
volume *
evs:volumes:update
Grants permission to update disks.
write
volume *
evs:volumes:resize
Grants permission to expand disk capacities.
write
volume *
evs:volumes:modifyQos
Grants permission to modify disk QoS configurations.
write
volume *
evs:volumes:revert
Grants permission to recover disks from the recycle bin.
write
volume *
evs:recycle_policy:get
Grants permission to query the recycle bin policy.
read
evs:recycle_policy:update
Grants permissions to update the recycle bin policy.
write
evs:volumes:changeChargeMode
Grants permission to change the billing mode of disks.
write
volume *
evs:snapshots:create
Grants permission to create snapshots for disks.
write
snapshot *
volume *
evs:snapshots:list
Grants permission to list snapshots.
list
evs:snapshots:get
Grants permission to query snapshots.
read
evs:snapshots:delete
Grants permission to delete snapshots.
write
evs:snapshots:update
Grants permission to update snapshots.
write
evs:snapshots:rollback
Grants permissions to roll back data from snapshots.
write
evs:types:get
Grants permission to query disk types.
read
evs:quotas:get
Grants permission to query EVS quotas.
read
evs:volumes:tagResource
Grants permission to add tags to a disk.
write
volume *
  • g:TagKeys
evs:volumes:unTagResource
Grants permission to delete tags from a disk.
write
volume *
g:TagKeys
evs:volumes:listTags
Grants permission to query all disk tags in a project.
list
evs:volumes:listTagsForResource
Grants permission to query disk tags.
read
volume *
evs:volumes:listResourcesByTag
Grants permission to list disks by tag.
list
g:TagKeys
evs:volumes:use
Grants permission to allow ECSs and BMSs to use EVS disks.
write
Each API of EVS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by EVS APIs
API
Action
Dependencies
POST /v2.1/{project_id}/cloudvolumes
evs:volumes:create
billing:order:pay
POST /v2/{project_id}/cloudvolumes
evs:volumes:create
POST /v3/{project_id}/cloudvolumes
evs:volumes:create
GET /v2/{project_id}/cloudvolumes/detail
evs:volumes:list
GET /v2/{project_id}/cloudvolumes/{volume_id}
evs:volumes:get
DELETE /v2/{project_id}/cloudvolumes/{volume_id}
evs:volumes:delete
PUT /v2/{project_id}/cloudvolumes/{volume_id}
evs:volumes:update
POST /v2.1/{project_id}/cloudvolumes/{volume_id}/action
evs:volumes:resize
billing:order:pay
POST /v5/{project_id}/volumes/batch-extend
evs:volumes:resize
billing:order:pay
POST /v2/{project_id}/cloudvolumes/{volume_id}/action
evs:volumes:resize
PUT /v5/{project_id}/cloudvolumes/{volume_id}/qos
POST /v2/{project_id}/cloudvolumes/unsubscribe
evs:volumes:delete
billing:subscription:unsubscribe
POST /v2/{project_id}/cloudvolumes/change-charge-mode
  • billing:order:pay
  • billing:subscription:renew
POST /v2/{project_id}/cloudsnapshots
GET /v2/{project_id}/cloudsnapshots/detail
evs:snapshots:list
GET /v2/{project_id}/cloudsnapshots/{snapshot_id}
evs:snapshots:get
DELETE /v2/{project_id}/cloudsnapshots/{snapshot_id}
PUT /v2/{project_id}/cloudsnapshots/{snapshot_id}
POST /v2/{project_id}/cloudsnapshots/{snapshot_id}/rollback
POST /v2/{project_id}/cloudvolumes/{volume_id}/tags/action
POST 01 /v2/{project_id}/cloudvolumes/{volume_id}/tags/action
GET /v2/{project_id}/cloudvolumes/tags
GET /v2/{project_id}/cloudvolumes/{volume_id}/tags
POST /v2/{project_id}/cloudvolumes/resource_instances/action
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP policy to define resource types.
The following table lists the resource types that you can define in SCP statements for EVS.
Table 3 Resource types supported by EVS
Resource Type
URN
imageCache
evs:<region>:<account-id>:imageCache:<imageCache-id>
snapshot
evs:<region>:<account-id>:snapshot:<snapshot-id>
volume
evs:<region>:<account-id>:volume:<volume-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, evs:) apply only to operations of the EVS service. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
    • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in custom SCP policies for EVS. You can include these condition keys to specify conditions for when your SCP policy is in effect.
Table 4 Service-specific condition keys supported by EVS
Service-specific Condition Key
Type
Single-valued/Multivalued
evs:Encrypted
boolean
Single-valued
Filters access based on whether the disk is encrypted.
evs:KmsKeyId
string
Single-valued
Filters access based on the key ID used by the disk.
evs:ImageId
string
Single-valued
Filters access by image ID.
evs:BackupId
string
Single-valued
Filters access by backup ID.
evs:SnapshotId
string
Single-valued
Filters access by snapshot ID.
evs:AvailabilityZone
string
Single-valued
Filters access based on the AZ of the disk.
evs:SourceAvailabilityZone
string
Single-valued
Filters access by source AZ.
evs:VolumeType
string
Single-valued
Filters access based on the disk type.
evs:VolumeSize
numeric
Single-valued
Filters access based on the disk capacity.
evs:VolumeIops
numeric
Single-valued
Filters access based on the disk IOPS.
evs:VolumeThroughput
numeric
Single-valued
Filters access based on the disk throughput.
evs:ChargingMode
string
Single-valued
Filters access based on the disk billing mode.
evs:ServerServiceType
string
Single-valued
Filters access based on the service type of the cloud server.
evs:VolumeId
string
Single-valued
Filters access based on the disk ID.
