On this page
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to an organizational unit (OU) or a member account, the SCPs do not directly grant permissions to that OU or member account. Instead, the SCPs only determine what permissions are available for that member account or those member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by DataArts Studio, see Resources.
  • Condition Key contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by DataArts Studio, see Conditions.
The following table lists the actions that you can define in SCP statements for DataArts Studio.
Due to API restrictions, if the resource type is specified for an SCP, the permission configuration may not meet expectations because some operations are unavailable for specified workspace or instance resources. For example, if an operation that does not support specified resources is allowed but a specific resource is specified for the operation, all resource operations are denied. If an operation that does not support specified resources is denied but a specific resource is specified for the operation, all resource operations are allowed.
Therefore, if you want to specify the resource type for an SCP, you must exclude such operations. Instead, you can only configure SCP statements without specified resources or with global resources for such operations, and use multiple SCP statements to grant permissions to users. SCP statements without specified resources or with global resources do not contain the Resource element in the JSON content, or contain the following Resource element:
            "Resource": [
                "DataArtsStudio:*:*:workspace:*",
                "DataArtsStudio:*:*:instance:*"
The operations that cannot be performed on specified resources in DataArts Studio are as follows:
  • Operations that can be performed only on specified instance resources but not on specified workspace resources:
    • DataArtsStudio:workspace:create
    • DataArtsStudio:workspace:list
  • Operations that cannot be performed on specified instance or workspace resources:
    • DataArtsStudio:instance:create
    • DataArtsStudio:instance:get
    • DataArtsStudio:instance:list
    • DataArtsStudio:instance:resize
    • DataArtsStudio:instance:getAgency
    • DataArtsStudio:instance:createAgency
    • DataArtsStudio:instance:uploadDriver
    • DataArtsStudio:instance:deleteDriver
    • DataArtsStudio:instance:listDrivers
    • DataArtsStudio:instance:listTags
    • DataArtsStudio:workspace:listTags
Table 1 Actions supported by DataArts Studio
Action
Access Level
Resource Type (*: required)
Condition Key
Grants the permission to query all workspaces.
list
workspace *
g:ResourceTag/<tag-key>
instance *
Grants the permission to create a workspace.
write
workspace *
instance *
  • g:RequestTag/<tag-key>
  • g:TagKeys
DataArtsStudio:workspace:get
Grants the permission to query workspace information.
read
workspace *
instance *
DataArtsStudio:workspace:frozen
Grants the permission to freeze a workspace.
write
workspace *
instance *
DataArtsStudio:workspace:unfrozen
Grants the permissions to unfreeze a workspace.
write
workspace *
instance *
DataArtsStudio:workspace:update
Grants the permission to update a workspace.
write
workspace *
instance *
Grants the permission to query all instances.
list
instance *
Grants the permission to create an instance.
write
instance *
  • g:TagKeys
Grants the permission to query an instance.
read
instance *
Grants the permission to change instance specifications.
write
instance *
Grants the permission to query all driver files.
list
Grants the permission to upload a driver file.
write
Grants the permission to delete a driver file.
write
DataArtsStudio:workspace:delete
Grants the permission to delete a workspace.
write
workspace *
instance *
Grants the permission to query an agency.
read
Grants the permission to create an agency.
write
Grants the permission to delete an instance.
write
instance *
DataArtsStudio:instance:migrateBusinessModel
Grants the permission to change the business model of an instance.
write
instance *
DataArtsStudio:instance:operate
Grants the permission to operate the resources of an instance.
write
instance *
DataArtsStudio:workspace:operate
Grants the permission to operate the resources in a workspace.
write
workspace *
instance *
DataArtsStudio:instance:createRole
Grants the permission to create a custom role.
write
instance *
DataArtsStudio:instance:listRoles
Grants the permission to query custom roles.
list
instance *
DataArtsStudio:instance:getRoleType
Grants the permission to query the type of a custom role.
read
instance *
Grants the permission to query a custom role.
read
instance *
DataArtsStudio:instance:updateRole
Grants the permission to update a custom role.
write
instance *
DataArtsStudio:instance:deleteRole
Grants the permission to delete a custom role.
write
instance *
DataArtsStudio:instance:tagResource
Grants the permission to add an instance tag.
write
instance *
  • g:TagKeys
DataArtsStudio:instance:unTagResource
Grants the permission to delete an instance tag.
write
instance *
  • g:TagKeys
DataArtsStudio:instance:listIncrementalPackages
Grants the permission to query all incremental packages.
list
instance *
DataArtsStudio:workspace:createIncrementalPackage
Grants the permission to create an incremental package for a workspace.
write
workspace *
  • g:ResourceTag/<tag-key>
  • DataArtsStudio:EnablePublicAccess
instance *
DataArtsStudio:workspace:tagResource
Grants the permission to add a tag to a workspace.
write
workspace *
instance *
  • g:TagKeys
DataArtsStudio:workspace:unTagResource
Grants the permission to delete a tag from a workspace.
write
workspace *
instance *
  • g:TagKeys
DataArtsStudio:instance:createIncrementalPackage
Grants the permission to create an incremental package for an instance.
write
instance *
Grants the permission to query the tags of all instances.
list
instance *
Grants the permission to query the tags of all workspaces.
list
workspace *
instance *
DataArtsStudio:instance:listTagsForResource
Grants the permission to query the tags of an instance.
list
instance *
DataArtsStudio:workspace:listTagsForResource
Grants the permission to query the tags of a workspace.
list
workspace *
instance *
DataArtsStudio:workspace:updateDataServiceApiQuota
Grants the permission to update the DataArts DataService API quota of a workspace.
write
workspace *
instance *
DataArtsStudio:workspace:executeDataServiceInstanceAction
Grants the permission to run commands to perform operations on DataArts DataService clusters.
write
workspace *
instance *
DataArtsStudio:instance:configureDataSecurityAdministrator
Grants the permission to configure the data security administrator.
write
instance *
DataArtsStudio:instance:listResourcesByTag
Grants the permission to filter instances by tag.
list
instance *
g:TagKeys
DataArtsStudio:workspace:listResourcesByTag
Grants the permission to filter workspaces by tag.
list
workspace *
instance *
g:TagKeys
Each API of DataArts Studio usually supports one or more actions. Table 2 lists the actions and dependencies supported by DataArts Studio APIs.
Table 2 Actions and dependencies supported by DataArts Studio APIs
API
Action
Dependencies
GET /v1/{project_id}/workspaces/{instance_id}
POST /v1/{project_id}/workspaces/{instance_id}
GET /v1/{project_id}/workspaces/{instance_id}/{workspace_id}
POST /v1/{project_id}/change-resource
GET /v1/{project_id}/instances
POST /v1/{project_id}/instances/onekey-purchase
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in an SCP for DataArts Studio.
Table 3 Resource types supported by DataArts Studio
Resource Type
URN
workspace
DataArtsStudio:<region>:<account-id>:workspace:<instance-id>/<workspace-id>
instance
DataArtsStudio:<region>:<account-id>:instance:<instance-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify for an SCP statement can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name as the prefix, for example, DataArtsStudio:) apply only to DataArts Studio operations. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • An operator, a condition key, and a condition value together constitute a complete condition statement. An SCP becomes in effect only when its request conditions are met. For supported operators, see Operators.
The following table lists the condition keys that you can define in an SCP for DataArts Studio. You can include these condition keys to specify conditions for when your SCP statement is in effect.
Table 4 Service-specific condition keys supported by DataArts Studio
Service-specific Condition Key
Type
Single-valued/Multivalued
boolean
Single-valued
Whether the service is accessible over the Internet
