Server Migration Service (SMS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This topic describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an identity policy SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by SMS, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by SMS, see Conditions.
The following table lists the actions that you can define in SCP statements for SMS.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
sms:template:list |
Grants permission to list templates. |
list |
template |
sms:template:create |
Grants permission to create a template. |
write |
template |
sms:template:batchDelete |
Grants permission to batch delete templates. |
write |
template |
sms:template:get |
Grants permission to query the information about a template. |
read |
template |
sms:template:update |
Grants permission to modify a template. |
write |
template |
sms:template:getTargetPassword |
Grants permission to query the target server password in a template. |
read |
template |
sms:template:delete |
Grants permission to delete a template. |
write |
template |
sms:server:listErrors |
Grants permission to list failed source servers. |
list |
server |
sms:server:list |
Grants permission to list source servers. |
list |
server |
sms:server:register |
Grants permission to register a source server with SMS. |
write |
server |
sms:server:batchDelete |
Grants permission to batch delete source server records. |
write |
server |
sms:server:get |
Grants permission to query the details about a source server. |
read |
server |
sms:server:update |
Grants permission to modify a source server name. |
write |
server |
sms:server:delete |
Grants permission to delete a source server record. |
write |
server |
sms:server:updateDiskInfo |
Grants permission to update disk information. |
write |
server |
sms:server:overview |
Grants permission to obtain the summary of source servers. |
read |
server |
sms:server:updateState |
Grants permission to update the migration task status for a source server. |
write |
server |
sms:server:listTask |
Grants permission to list migration tasks. |
list |
server |
sms:server:createTask |
Grants permission to create a migration task. |
write |
server |
sms:server:batchDeleteTask |
Grants permission to batch delete migration tasks. |
write |
server |
sms:server:getTask |
Grants permission to query the details about a migration task. |
read |
server |
sms:server:updateTask |
Grants permission to update a migration task. |
write |
server |
sms:server:deleteTask |
Grants permission to delete a migration task. |
write |
server |
sms:server:manageTask |
Grants permission to manage migration tasks. |
write |
server |
sms:server:updateTaskProgress |
Grants permission to report the migration progress and rate. |
write |
server |
sms:server:unlock |
Grants permission to unlock a target server. |
write |
server |
sms:server:collectLog |
Grants permission to upload migration task logs. |
write |
server |
sms:server:getTaskPassphrase |
Grants permission to query a certificate passphrase. |
read |
server |
sms:server:checkNetwork |
Grants permission to check NICs and security groups. |
read |
server |
sms:server:getTaskSpeedLimit |
Grants permission to query the traffic limiting rules of a migration task. |
read |
server |
sms:server:updateTaskSpeedLimit |
Grants permission to set traffic limiting rules for a migration task. |
write |
server |
sms:server:getCommand |
Grants permission to obtain commands from SMS. |
read |
server |
sms:server:updateCommandResult |
Grants permission to report command execution results to SMS. |
write |
server |
sms:server:getCert |
Grants permission to obtain an SSL certificate and private key. |
read |
server |
sms:migproject:list |
Grants permission to list migration projects. |
list |
migproject |
sms:migproject:create |
Grants permission to create a migration project. |
write |
migproject |
sms:migproject:get |
Grants permission to query details about a migration project. |
read |
migproject |
sms:migproject:update |
Grants permission to update a migration project. |
write |
migproject |
sms:migproject:delete |
Grants permission to delete a migration project. |
write |
migproject |
Grants permission to change the default migration project. |
write |
migproject |
sms::getConfig |
Grants permission to obtain Agent configuration information. |
read |
sms:server:updateNetworkCheckInfo |
Grants permission to update network measurement information. |
write |
task |
sms:server:getTaskConfig |
Grants permission to query the settings of advanced migration options of a task. |
read |
task |
sms:server:updateTaskConfig |
Grants permission to set advanced migration options for a task. |
write |
task |
Each API of SMS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v3/vm/templates |
sms:template:list |
POST /v3/vm/templates |
POST /v3/vm/templates/delete |
GET /v3/vm/templates/{id} |
sms:template:get |
PUT /v3/vm/templates/{id} |
GET /v3/vm/templates/{id}/target-password |
DELETE /v3/vm/templates/{id} |
GET /v3/errors |
GET /v3/sources |
sms:server:list |
POST /v3/sources |
POST /v3/sources/delete |
GET /v3/sources/{source_id} |
sms:server:get |
PUT /v3/sources/{source_id} |
sms:server:update |
DELETE /v3/sources/{source_id} |
sms:server:delete |
PUT /v3/sources/{source_id}/diskinfo |
GET /v3/sources/overview |
PUT /v3/sources/{source_id}/changestate |
GET /v3/tasks |
POST /v3/tasks |
POST /v3/tasks/delete |
GET /v3/tasks/{task_id} |
PUT /v3/tasks/{task_id} |
DELETE /v3/tasks/{task_id} |
POST /v3/tasks/{task_id}/action |
PUT /v3/tasks/{task_id}/progress |
POST /v3/tasks/{task_id}/unlock |
sms:server:unlock |
POST /v3/tasks/{task_id}/log |
GET /v3/tasks/{task_id}/passphrase |
GET /v3/tasks/{t_project_id}/networkacl/{t_network_id}/check |
GET /v3/tasks/{task_id}/speed-limit |
POST /v3/tasks/{task_id}/speed-limit |
GET /v3/sources/{server_id}/command |
POST /v3/sources/{server_id}/command_result |
GET /v3/tasks/{task_id}/certkey |
GET /v3/migprojects |
POST /v3/migprojects |
GET /v3/migprojects/{mig_project_id} |
PUT /v3/migprojects/{mig_project_id} |
DELETE /v3/migprojects/{mig_project_id} |
PUT /v3/migprojects/{mig_project_id}/default |
GET /v3/config |
sms::getConfig |
POST /v3/{task_id}/update-network-check-info |
POST /v3/tasks/{task_id}/configuration-setting |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can specify in SCP statements for SMS.
Resource Type |
URN |
server |
sms::<account-id>:server:* |
sms::<account-id>:server:<server-id> |
Task |
sms::<account-id>:task:* |
sms::<account-id>:task:<task-id> |
template |
sms::<account-id>:template:* |
sms::<account-id>:template:<template-id> |
migproject |
sms::<account-id>:migproject:* |
sms::<account-id>:migproject:<migproject-id> |
Conditions
SMS does not support service-specific condition keys in an SCP.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
