On this page
API Gateway (APIG)
Updated on 2025-02-25 GMT+08:00
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by IAM custom identity policies and Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by APIG, see Resources.
  • The Condition Key column includes keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by APIG, see Conditions.
The following table lists the actions that you can define in SCP statements for APIG.
Table 1 Actions supported by APIG
Action
Description.
Access Level
Resource Type (*: required)
Condition Key
Alias
apig:acl:list
Grants permissions to query access control policies.
list
instance *
g:ResourceTag/<tag-key>
apig:acls:list
apig:acl:create
Grants permissions to create an access control policy.
write
instance *
apig:acls:create
apig:acl:batchDelete
Grants permissions to delete access control policies in batches.
write
instance *
apig:acls:delete
apig:acl:delete
Grants permissions to delete an access control policy.
write
instance *
apig:acls:delete
apig:acl:get
Grants permissions to query access control policy details.
read
instance *
apig:acls:get
apig:acl:update
Grants permissions to modify an access control policy.
write
instance *
apig:acls:update
apig:api:bindAcl
Grants permissions to bind APIs with access control policies.
write
instance *
apig:apis:bindAcls
apig:api:batchUnbindAcl
Grants permissions to unbind access control policies from APIs in batches.
write
instance *
apig:apis:unbindAcls
apig:api:unbindAcl
Grants permissions to unbind access control policies from APIs.
write
instance *
apig:api:listBoundAcl
Grants permissions to query access control policies bound to a specified API.
list
instance *
apig:apis:listBindedAcls
apig:acl:listBoundApi
Grants permissions to query APIs bound to a specified access control policy.
list
instance *
apig:acls:listBindedApis
apig:acl:listUnboundApi
Grants permissions to query APIs that are not bound to a specified access control policy.
list
instance *
apig:acls:listUnbindedApis
apig:api:bindRequestThrottling
Grants permissions to bind APIs with request throttling policies.
write
instance *
apig:apis:bindThrottles
apig:api:batchUnbindRequestThrottling
Grants permissions to unbind request throttling policies from APIs in batches.
write
instance *
apig:apis:unbindThrottles
apig:api:unbindRequestThrottling
Grants permissions to unbind request throttling policies from APIs.
write
instance *
apig:requestThrottling:listBoundApi
Grants permissions to query APIs bound to a specified request throttling policy.
list
instance *
apig:throttles:listBindedApis
apig:api:listBoundRequestThrottling
Grants permissions to query request throttling policies bound to a specified API.
list
instance *
apig:apis:listBindedThrottles
apig:requestThrottling:listUnboundApi
Grants permissions to query APIs that are not bound to a specified request throttling policy.
list
instance *
apig:throttles:listUnbindedApis
apig:apiGroup:list
Grants permissions to query API groups.
list
instance *
apig:groups:list
apig:apiGroup:create
Grants permissions to create an API group.
write
instance *
apig:groups:create
apig:apiGroup:delete
Grants permissions to delete an API group.
write
instance *
apig:groups:delete
apig:apiGroup:get
Grants permissions to query API group details.
read
instance *
apig:groups:get
apig:apiGroup:update
Grants permissions to modify an API group.
write
instance *
apig:groups:update
apig:apiGroup:checkApiGroupNameExistOrNot
Grants permissions to check whether the API group name exists.
read
instance *
apig:groups:get
apig:api:list
Grants permissions to query APIs.
list
instance *
apig:apis:list
apig:api:create
Grants permissions to create an API.
write
instance *
apig:apis:create
apig:api:delete
Grants permissions to delete an API.
write
instance *
apig:apis:delete
apig:api:get
Grants permissions to query API details.
read
instance *
apig:apis:get
apig:api:update
Grants permissions to modify an API.
write
instance *
apig:apis:update
apig:api:onlineOrOffline
Grants permissions to publish or take an API offline.
write
instance *
apig:apis:publish
apig:api:batchDelete
Grants permissions to delete APIs in batches.
write
instance *
apig:apis:delete
apig:api:checkApiPathOrApiNameExistOrNot
Grants permissions to verify the API definition.
read
instance *
apig:apis:get
apig:api:debug
Grants permissions to debug an API.
write
instance *
apig:apis:debug
apig:api:batchOnlineOrOffline
Grants permissions to publish or take APIs offline in batches.
write
instance *
apig:apis:publish
apig:api:listHistoryVersion
Grants permissions to query historical API versions.
list
instance *
apig:apis:get
apig:api:switchVersion
Grants permissions to switch the API version.
write
instance *
apig:apis:publish
apig:api:getRuntimeDefinition
Grants permissions to query the API runtime definition.
read
instance *
apig:apis:get
apig:api:deleteHistoryVersion
Grants permissions to take an API offline based on the version ID.
write
instance *
apig:apis:offline
apig:api:getHistoryVersion
Grants permissions to query version details.
read
instance *
apig:apis:get
apig:app:list
Grants permissions to query apps.
list
instance *
apig:apps:list
apig:app:create
Grants permissions to create an app.
write
instance *
apig:apps:create
apig:app:delete
Grants permissions to delete an app.
write
instance *
apig:apps:delete
apig:app:get
Grants permissions to query app details.
read
instance *
apig:apps:get
apig:app:update
Grants permissions to modify app information.
write
instance *
apig:apis:update
apig:app:listAppCode
Grants permissions to query AppCodes.
list
instance *
apig:appCodes:list
apig:app:createAppCode
Grants permissions to create an AppCode.
write
instance *
apig:appCodes:create
apig:app:generateAppCode
Grants permissions to automatically generate AppCodes.
write
instance *
apig:appCodes:update
apig:app:deleteAppCode
Grants permissions to delete an AppCode.
write
instance *
apig:appCodes:delete
apig:app:getAppCode
Grants permissions to query AppCode details.
read
instance *
apig:appCodes:get
apig:app:resetSecret
Grants permissions to reset the AppSecret.
write
instance *
apig:apps:update
apig:app:validate
Grants permissions to check whether a specified app exists.
read
instance *
apig:apps:get
apig:app:getBoundQuota
Grants permissions to query the credential quota policies associated with a specified app.
read
instance *
apig:apps:get
apig:app:bindApi
Grants permissions to bind APIs with apps.
write
instance *
apig:apis:grantAppAccess
apig:app:unbindApi
Grants permissions to unbind APIs from apps.
write
instance *
apig:apis:relieveAppAccess
apig:app:listBoundApi
Grants permissions to query APIs bound to a specified app.
list
instance *
apig:apps:listBindedApis
apig:api:listBoundApp
Grants permissions to query apps bound to a specified API.
list
instance *
apig:apis:listBindedApps
apig:app:listUnboundApi
Grants permissions to query APIs not bound to a specified app.
list
instance *
apig:apps:listUnbindedApis
apig:api:export
Grants permissions to export APIs.
read
instance *
apig:apis:export
apig:api:import
Grants permissions to import APIs.
write
instance *
apig:apis:import
apig:asyncTask:get
Grants permission to query the result of an asynchronous task.
read
instance *
apig:apis:export
apig:certificate:list
Grants permissions to query SSL certificates.
list
instance
apig:certificate:create
Grants permissions to create an SSL certificate.
write
instance
apig:certificate:delete
Grants permissions to delete an SSL certificate.
write
instance
apig:certificate:get
Grants permissions to query SSL certificate details.
read
instance
apig:certificate:update
Grants permissions to modify an SSL certificate.
write
instance
apig:certificate:listBoundDomain
Grants permissions to query domain names bound to a specified SSL certificate.
list
instance
apig:certificate:batchBindDomain
Grants permissions to bind a domain name to an SSL certificate.
write
instance
apig:certificate:batchUnbindDomain
Grants permissions to unbind domain names from a specified SSL certificate.
write
instance
apig:apiGroup:batchBindCertificateToDomain
Grants permissions to bind an SSL certificate to a domain name.
write
instance *
apig:domains:bindCertificate
apig:apiGroup:batchUnbindCertificateFromDomain
Grants permissions to unbind certificates from a specified domain name.
write
instance *
apig:domains:unbindCertificate
apig:loadBalanceChannel:list
Grants permissions to query the load balance channels.
list
instance *
apig:vpcChannels:list
apig:loadBalanceChannel:create
Grants permissions to create a load balance channel.
write
instance *
apig:vpcChannels:create
apig:loadBalanceChannel:delete
Grants permissions to delete a load balance channel.
write
instance *
apig:vpcChannels:delete
apig:loadBalanceChannel:get
Grants permissions to query load balance channel details.
read
instance *
apig:vpcChannels:get
apig:loadBalanceChannel:update
Grants permissions to update a load balance channel.
write
instance *
apig:vpcChannels:update
apig:loadBalanceChannel:updateHealthCheckConfig
Grants permissions to modify the health check configuration of a load balance channel.
write
instance *
apig:loadBalanceChannel:listServerGroup
Grants permissions to query the backend server groups of a specified load balance channel.
list
instance *
apig:loadBalanceChannel:createServerGroup
Grants permissions to add or update backend server groups of a specified VPC channel.
write
instance *
apig:vpcChannels:addOrUpdateMemberGroups
apig:loadBalanceChannel:deleteServerGroup
Grants permissions to delete the backend server groups of a specified VPC channel.
write
instance *
apig:vpcChannels:deleteMemberGroup
apig:loadBalanceChannel:getServerGroup
Grants permissions to query details about the backend server group of a specified VPC channel.
read
instance *
apig:loadBalanceChannel:updateServerGroup
Grants permissions to update the backend server groups of a specified VPC channel.
write
instance *
apig:vpcChannels:updateMemberGroup
apig:loadBalanceChannel:listBackendServerAddress
Grants permissions to query the backend instances of a specified load balance channel.
list
instance *
apig:loadBalanceChannel:createBackendServerAddress
Grants permissions to add or update backend instances of a specified load balance channel.
write
instance *
apig:vpcChannels:addInstance
apig:loadBalanceChannel:updateBackendServerAddress
Grants permissions to update backend instances of a specified load balance channel.
write
instance *
apig:loadBalanceChannel:deleteBackendServerAddress
Grants permissions to delete backend instances of a specified load balance channel.
write
instance *
apig:vpcChannels:deleteInstance
apig:loadBalanceChannel:batchDisableBackendServerAddress
Grants permissions to disable backend servers in batches.
write
instance *
apig:vpcChannels:batchDisableInstance
apig:loadBalanceChannel:batchEnableBackendServerAddress
Grants permissions to enable backend servers in batches.
write
instance *
apig:vpcChannels:batchEnableInstance
apig:instance:listTag
Grants permissions to query tags.
list
instance *
apig:tags:list
apig:api:listUnboundPlugin
Grants permissions to query plug-ins that can be bound to a specified API.
list
instance *
apig:apis:listBindedPlugins
apig:api:listBoundPlugin
Grants permissions to query plug-ins bound to a specified API.
list
instance *
apig:api:bindPlugin
Grants permissions to bind a plug-in to an API.
write
instance *
apig:apis:bindPlugins
apig:api:unbindPlugin
Grants permissions to unbind plug-ins from a specified API.
write
instance *
apig:apis:unbindPlugins
apig:plugin:list
Grants permissions to query plug-ins.
list
instance *
apig:plugins:list
apig:plugin:create
Grants permission to create extensions.
write
instance *
apig:plugins:create
apig:plugin:delete
Grants permission to delete extensions.
write
instance *
apig:plugins:delete
apig:plugin:get
Grants permissions to query plug-in details.
read
instance *
apig:plugins:get
apig:plugin:update
Grants permissions to modify a plug-in.
write
instance *
apig:plugins:update
apig:plugin:bindApi
Grants permissions to bind an API to a plug-in.
write
instance *
apig:plugin:listUnbindApi
Grants permissions to query APIs that can be bound to a specified plug-in.
list
instance *
apig:plugins:listUnbindedApis
apig:plugin:listBoundApi
Grants permissions to query APIs bound to a specified plug-in.
list
instance *
apig:plugins:listBindedApis
apig:plugin:unbindApi
Grants permissions to unbind APIs from a specified plug-in.
write
instance *
apig:apiGroup:listGatewayResponse
Grants permissions to query the responses of a specified API group.
list
instance *
apig:gatewayResponses:list
apig:apiGroup:createGatewayResponse
Grants permissions to create a group response.
write
instance *
apig:gatewayResponses:create
apig:apiGroup:deleteGatewayResponse
Grants permissions to delete a group response.
write
instance *
apig:gatewayResponses:delete
apig:apiGroup:getGatewayResponse
Grants permissions to query group response details.
read
instance *
apig:gatewayResponses:get
apig:apiGroup:updateGatewayResponse
Grants permissions to modify a group response.
write
instance *
apig:gatewayResponses:updat
apig:apiGroup:deleteGatewayResponseType
Grants permissions to delete the response of an error type defined for an API group.
write
instance *
apig:gatewayResponses:update
apig:apiGroup:getGatewayResponseType
Grants permissions to query the response of an error type defined for an API group.
read
instance *
apig:apiGroup:updateGatewayResponseType
Grants permissions to modify the response of an error type defined for an API group.
write
instance *
apig:instance:listApiOutline
Grants permissions to query API quantities.
list
instance *
apig:apis:get
apig:instance:listAppOutline
Grants permissions to query app quantities.
list
instance *
apig:apps:get
apig:instance:listApiGroupOutline
Grants permissions to query API group quantities.
list
instance *
apig:groups:get
apig:environmentVariable:list
Grants permissions to query environment variables.
list
instance *
apig:variables:list
apig:environmentVariable:create
Grants permissions to create an environment variable.
write
instance *
apig:variables:create
apig:environmentVariable:delete
Grants permissions to delete an environment variable.
write
instance *
apig:variables:delete
apig:environmentVariable:get
Grants permissions to query environment variable details.
read
instance *
apig:variables:get
apig:environmentVariable:update
Grants permissions to modify an environment variable.
write
instance *
apig:variables:update
apig:environment:list
Grants permissions to query environments.
list
instance *
apig:envs:list
apig:environment:create
Grants permissions to create an environment.
write
instance *
apig:envs:create
apig:environment:delete
Grants permissions to delete an environment.
write
instance *
apig:envs:delete
apig:environment:update
Grants permissions to modify an environment.
write
instance *
apig:envs:update
apig:instance:listMetricData
Grants permissions to query metric data of a specified gateway.
list
instance *
apig:metricData:get
apig:instance:listApiMonitoring
Grants permissions to query API calls within a specific period.
list
instance *
apig:apis:get
apig:instance:listApiGroupMonitoring
Grants permissions to query API calls under an API group in the last one hour.
list
instance *
apig:groups:get
Grants permissions to query request throttling policies.
list
instance *
apig:throttles:list
apig:requestThrottling:create
Grants permissions to create a request throttling policy.
write
instance *
apig:throttles:create
apig:requestThrottling:delete
Grants permissions to delete a request throttling policy.
write
instance *
apig:throttles:delete
apig:requestThrottling:get
Grants permissions to query request throttling policy details.
read
instance *
apig:throttles:get
apig:requestThrottling:update
Grants permissions to modify a request throttling policy.
write
instance *
apig:throttles:update
apig:requestThrottling:batchDelete
Grants permissions to delete request throttling policies in batches.
write
instance *
apig:api:bindSignatureKey
Grants permissions to bind signature keys to APIs.
write
instance *
apig:apis:bindSigns
apig:api:unbindSignatureKey
Grants permissions to unbind signature keys from APIs.
write
instance *
apig:apis:unbindSigns
apig:signatureKey:listBoundApi
Grants permissions to query APIs bound to a specified signature key.
list
instance *
apig:signs:listBindedApis
apig:api:listBoundSignatureKey
Grants permissions to query signature keys bound to a specified API.
list
instance *
apig:apis:listBindedSigns
apig:signatureKey:listUnboundApi
Grants permissions to query APIs not bound to a specified signature key.
list
instance *
apig:signs:listUnbindedApis
Grants permissions to query signature keys.
list
instance *
apig:signs:list
apig:signatureKey:create
Grants permissions to create a signature key.
write
instance *
apig:signs:create
apig:signatureKey:delete
Grants permissions to delete a signature key.
write
instance *
apig:signs:delete
apig:signatureKey:update
Grants permissions to modify a signature key.
write
instance *
apig:signs:update
apig:requestThrottling:listSpecial
Grants permissions to query excluded request throttling configurations.
list
instance *
apig:specialThrottles:get
apig:requestThrottling:createSpecial
Grants permissions to create an excluded request throttling configuration.
write
instance *
apig:specialThrottles:create
apig:requestThrottling:deleteSpecial
Grants permissions to delete an excluded request throttling configuration.
write
instance *
apig:specialThrottles:delete
apig:requestThrottling:updateSpecial
Grants permissions to modify an excluded configuration of a specified request throttling policy.
write
instance *
apig:specialThrottles:update
apig:instance:listSingleInstanceTag
Grants permissions to query tags of a specified gateway.
list
instance *
  • g:ResourceTag/<tag-key>
  • g:EnterpriseProjectId
apig:instanceTags:list
apig:instance:batchCreateOrDeleteTag
Grants permissions to add or delete gateway tags in batches.
write
instance *
apig:instanceTags:create
  • g:RequestTag/<tag-key>
  • g:TagKeys
apig::listTag
Grants permissions to query all gateway tags in the project.
list
apig:instance:getNumByTags
Grants permissions to query the number of gateways by tag.
read
instance *
g:TagKeys
apig:instance:listByTags
Grants permissions to query gateways by tag.
list
instance *
g:TagKeys
apig:instance:list
Grants permissions to query dedicated gateways.
list
apig:instances:list
apig:instance:create
Grants permissions to create a dedicated gateway.
write
  • g:TagKeys
apig:instances:create
apig:instance:delete
Grants permissions to delete a dedicated gateway.
write
instance *
apig:instances:delete
apig:instance:get
Grants permissions to query dedicated gateway details.
read
instance *
apig:instances:get
apig:instance:update
Grants permissions to update a dedicated gateway.
write
instance *
apig:instances:update
apig:instance:unbindEip
Grants permissions to unbind an EIP from a specified dedicated gateway.
write
instance *
apig:instance:bindOrChangeEip
Grants permissions to add or change EIPs of a specified dedicated gateway.
write
instance *
apig:instance:deleteOutboundEip
Grants permissions to disable public outbound access for a specified dedicated gateway.
write
instance *
apig:instance:createOutboundEip
Grants permissions to enable public outbound access for a specified dedicated gateway.
write
instance *
apig:instance:changeOutboundEipBandwidth
Grants permissions to modify the public outbound access bandwidth of a specified dedicated gateway.
write
instance *
apig:instance:getCreateProgress
Grants permissions to query the creation progress of a specified dedicated gateway.
read
instance *
apig:instance:deleteIngressEip
Grants permissions to disable the public inbound access for a specified dedicated gateway.
write
instance *
apig:instance:createIngressEip
Grants permissions to enable the public inbound access for a specified dedicated gateway.
write
instance *
apig:instance:changeIngressEipBindwidth
Grants permissions to update the public outbound access bandwidth of a specified dedicated gateway.
write
instance *
apig:instance:resize
Grants permissions to create a specification change order for a pay-per-use dedicated gateway.
write
instance *
apig:instance:getRestriction
Grants permissions to query gateway constraint information.
read
instance *
apig:instances:get
apig:instance:listParameter
Grants permissions to query the gateway parameters.
list
instance *
apig:features:list
apig:instance:updateParameter
Grants permissions to edit the gateway parameters.
write
instance *
apig:features:create
apig:instance:listFeature
Grants permissions to query features supported by a specified gateway.
list
instance *
apig:instance:importMicroservice
Grants permissions to import microservices to a dedicated gateway.
write
instance *
apig:apis:import
apig:apiGroup:bindDomain
Grants permissions to bind independent domain names.
write
instance *
apig:domains:create
apig:apiGroup:unbindDomain
Grants permissions to unbind independent domain names.
write
instance *
apig:domains:delete
apig:apiGroup:updateDomainConfig
Grants permissions to modify an independent domain name.
write
instance *
apig:domains:update
apig:apiGroup:createAndBindCertificateToDomain
Grants permissions to create certificates and bind them to independent domain names.
write
instance *
apig:apiGroup:unbindAndDeleteCertificateFromDomain
Grants permissions to delete certificates and delete them from independent domain names.
write
instance *
apig:apiGroup:getCertificateOfDomain
Grants permissions to query certificates of independent domain names.
read
instance *
apig:domains:getCertificate
apig:apiGroup:updateSLDomainSetting
Grants permissions to set accessibility of a debugging domain name.
write
instance *
apig:domains:updateSLDomainSetting
apig:customAuthorizer:list
Grants permissions to query custom authorizers.
list
instance *
apig:authorizers:list
apig:customAuthorizer:create
Grants permissions to create a custom authorizer.
write
instance *
apig:authorizers:create
apig:customAuthorizer:delete
Grants permissions to delete a custom authorizer.
write
instance *
apig:authorizers:delete
apig:customAuthorizer:get
Grants permissions to query custom authorizer details.
read
instance *
apig:authorizers:get
apig:customAuthorizer:update
Grants permissions to modify a custom authorizer.
write
instance *
apig:authorizers:update
apig:instance:listVpcEndpoint
Grants permissions to query the VPC endpoint connections of a specified gateway.
list
instance *
apig:instance:acceptOrRejectVpcEndpointConnection
Grants permissions to accept or reject VPC endpoint connections.
write
instance *
apig:instance:listVpcEndpointPermission
Grants permissions to query the whitelist records of a gateway's VPC endpoint service.
list
instance *
apig:instance:batchAddVpcEndpointPermission
Grants permissions to add whitelist records of a gateway's VPC endpoint service in batches.
write
instance *
apig:instance:batchDeleteVpcEndpointPermission
Grants permissions to delete whitelist records of a gateway's VPC endpoint service in batches.
write
instance *
apig:app:deleteAcl
Grants permissions to delete an access control rule of a credential.
write
instance *
apig:apps:get
apig:app:getAcl
Grants permissions to query access control rules of a credential.
read
instance *
apig:apps:get
apig:app:updateAcl
Grants permissions to set access control rules of credentials.
write
instance *
apig:apps:get
apig:clientQuota:list
Grants permissions to query credential quota policies.
list
instance *
apig:clientQuota:create
Grants permissions to create a credential quota policy.
write
instance *
apig:clientQuota:delete
Grants permissions to delete a credential quota policy.
write
instance *
apig:clientQuota:get
Grants permissions to query credential quota policy details.
read
instance *
apig:clientQuota:update
Grants permissions to modify a credential quota policy.
write
instance *
apig:clientQuota:listBoundApp
Grants permissions to query the credentials bound to quota policies.
list
instance *
apig:clientQuota:bindApp
Grants permissions to bind credential quotas with credentials.
write
instance *
apig:clientQuota:unbindApp
Grants permissions to unbind credential quotas from credentials.
write
instance *
apig:clientQuota:listUnboundApp
Grants permissions to query credentials that can be bound to a specified credential quota.
list
instance *
apig:instance:listFeatureHistory
Grants permissions to query the feature history.
list
instance *
apig:instance:addCustomIngressPort
Grants permissions to add a custom inbound port.
write
instance *
apig:instance:listCustomIngressPort
Grants permissions to query custom inbound ports.
list
instance *
apig:instance:deleteCustomIngressPort
Grants permissions to delete a custom inbound port.
write
instance *
apig:instance:listCustomIngressPortDomain
Grants permissions to query domain names bound to a custom inbound port.
list
instance *
Each API of APIG usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by APIG APIs
API
Action
Dependencies
GET /{project_id}/apigw/instances/{instance_id}/acls
apig:acl:list
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/acls
apig:acl:create
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/acls
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/acls/{acl_id}
apig:acl:delete
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/acls/{acl_id}
apig:acl:get
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/acls/{acl_id}
apig:acl:update
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/acl-bindings
apig:api:bindAcl
  • apig:instance:get
  • apig:api:get
  • apig:acl:get
PUT /{project_id}/apigw/instances/{instance_id}/acl-bindings
  • apig:instance:get
  • apig:api:get
  • apig:acl:get
DELETE /{project_id}/apigw/instances/{instance_id}/acl-bindings/{acl_bindings_id}
apig:api:unbindAcl
  • apig:instance:get
  • apig:api:get
  • apig:acl:get
GET /{project_id}/apigw/instances/{instance_id}/acl-bindings/binded-acls
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/acl-bindings/binded-apis
  • apig:instance:get
  • apig:acl:get
GET /{project_id}/apigw/instances/{instance_id}/acl-bindings/unbinded-apis
  • apig:instance:get
  • apig:acl:get
POST /{project_id}/apigw/instances/{instance_id}/throttle-bindings
  • apig:instance:get
  • apig:api:get
  • apig:requestThrottling:get
PUT /{project_id}/apigw/instances/{instance_id}/throttle-bindings
  • apig:instance:get
  • apig:api:get
DELETE /{project_id}/apigw/instances/{instance_id}/throttle-bindings/{throttle_binding_id}
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/throttle-bindings/binded-apis
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/throttle-bindings/binded-throttles
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/throttle-bindings/unbinded-apis
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups
apig:apiGroup:list
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/api-groups
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}
apig:apiGroup:get
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/api-groups/check
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/apis
apig:api:list
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/apis
apig:api:create
  • apig:instance:get
  • apig:apiGroup:get
  • apig:loadBalanceChannel:get
  • apig:customAuthorizer:get
  • functiongraph:function:getFunctionConfig
DELETE /{project_id}/apigw/instances/{instance_id}/apis/{api_id}
apig:api:delete
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/apis/{api_id}
apig:api:get
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/apis/{api_id}
apig:api:update
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/apis/action
  • apig:instance:get
  • apig:apiGroup:get
  • apig:environment:list
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/apis/check
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/apis/debug/{api_id}
apig:api:debug
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/apis/publish
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/apis/publish/{api_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/apis/publish/{api_id}
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/apis/runtime/{api_id}
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/apis/versions/{version_id}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/apis/versions/{version_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/apps
apig:app:list
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/apps
apig:app:create
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/apps/{app_id}
apig:app:delete
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/apps/{app_id}
apig:app:get
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/apps/{app_id}
apig:app:update
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-codes
  • apig:instance:get
  • apig:app:get
POST /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-codes
  • apig:instance:get
  • apig:app:get
PUT /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-codes
  • apig:instance:get
  • apig:app:get
DELETE /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-codes/{app_code_id}
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-codes/{app_code_id}
apig:app:getAppCode
  • apig:instance:get
  • apig:app:get
PUT /{project_id}/apigw/instances/{instance_id}/apps/secret/{app_id}
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/apps/validation/{app_id}
apig:app:validate
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/bound-quota
  • apig:instance:get
  • apig:app:get
POST /{project_id}/apigw/instances/{instance_id}/app-auths
apig:app:bindApi
  • apig:instance:get
  • apig:app:get
  • apig:api:get
DELETE /{project_id}/apigw/instances/{instance_id}/app-auths/{app_auth_id}
apig:app:unbindApi
  • apig:instance:get
  • apig:app:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/app-auths/binded-apis
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/app-auths/binded-apps
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/app-auths/unbinded-apis
  • apig:instance:get
  • apig:app:get
POST /{project_id}/apigw/instances/{instance_id}/openapi/export
apig:api:export
  • apig:instance:get
  • apig:api:list
  • apig:api:get
  • apig:api:listBoundAcl
  • apig:acl:get
  • apig:api:listBoundRequestThrottling
  • apig:apiGroup:get
  • apig:apiGroup:getGatewayResponse
  • apig:api:listBoundPlugin
  • apig:plugin:get
POST /{project_id}/apigw/instances/{instance_id}/openapi/async-export
apig:api:export
  • apig:instance:get
  • apig:api:list
  • apig:api:get
  • apig:acl:get
  • apig:apiGroup:get
  • apig:plugin:get
POST /{project_id}/apigw/instances/{instance_id}/openapi/import
apig:api:import
  • apig:instance:get
  • apig:api:get
  • apig:acl:get
  • apig:apiGroup:get
  • apig:plugin:get
POST /{project_id}/apigw/instances/{instance_id}/openapi/async-import
apig:api:import
  • apig:instance:get
  • apig:api:get
  • apig:acl:get
  • apig:apiGroup:get
  • apig:plugin:get
GET /{project_id}/apigw/instances/{instance_id}/async-tasks/{task_id}
apig:asyncTask:get
apig:instance:get
GET /{project_id}/apigw/certificates
POST /{project_id}/apigw/certificates
apig:instance:get
DELETE /{project_id}/apigw/certificates/{certificate_id}
GET /{project_id}/apigw/certificates/{certificate_id}
PUT /{project_id}/apigw/certificates/{certificate_id}
apig:instance:get
GET /{project_id}/apigw/certificates/{certificate_id}/attached-domains
POST /{project_id}/apigw/certificates/{certificate_id}/domains/attach
  • apig:certificate:get
  • apig:apiGroup:get
POST /{project_id}/apigw/certificates/{certificate_id}/domains/detach
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}/certificates/attach
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}/certificates/detach
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-channels
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-channels
  • apig:instance:get
  • cce:cluster:getCluster
  • ecs:cloudServers:showServer
  • cce:cluster:generateClientCredential
DELETE /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}
  • apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/health-config
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/member-groups
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/member-groups
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/member-groups/{member_group_id}
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/member-groups/{member_group_id}
  • apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/member-groups/{member_group_id}
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members
  • apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members/{member_id}
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members/batch-disable
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-channels/{vpc_channel_id}/members/batch-enable
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/tags
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/apis/{api_id}/attachable-plugins
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/apis/{api_id}/attached-plugins
  • apig:instance:get
  • apig:api:get
POST /{project_id}/apigw/instances/{instance_id}/apis/{api_id}/plugins/attach
apig:api:bindPlugin
  • apig:instance:get
  • apig:api:get
  • apig:plugin:get
PUT /{project_id}/apigw/instances/{instance_id}/apis/{api_id}/plugins/detach
  • apig:instance:get
  • apig:api:get
  • apig:plugin:get
GET /{project_id}/apigw/instances/{instance_id}/plugins
apig:plugin:list
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/plugins
apig:plugin:create
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}
apig:plugin:delete
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}
apig:plugin:get
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}
apig:plugin:update
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}/attach
apig:plugin:bindApi
  • apig:instance:get
  • apig:api:get
  • apig:plugin:get
GET /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}/attachable-apis
  • apig:instance:get
  • apig:plugin:get
GET /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}/attached-apis
  • apig:instance:get
  • apig:plugin:get
PUT /{project_id}/apigw/instances/{instance_id}/plugins/{plugin_id}/detach
  • apig:instance:get
  • apig:api:get
  • apig:plugin:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses
  • apig:instance:get
  • apig:apiGroup:get
DELETE /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}
  • apig:instance:get
  • apig:apiGroup:get
DELETE /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}/{response_type}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}/{response_type}
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/gateway-responses/{response_id}/{response_type}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/resources/outline/apis
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/resources/outline/apps
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/resources/outline/groups
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/env-variables
  • apig:instance:get
  • apig:apiGroup:get
POST /{project_id}/apigw/instances/{instance_id}/env-variables
  • apig:instance:get
  • apig:apiGroup:get
DELETE /{project_id}/apigw/instances/{instance_id}/env-variables/{env_variable_id}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/env-variables/{env_variable_id}
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/env-variables/{env_variable_id}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/envs
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/envs
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/envs/{env_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/envs/{env_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/metric-data
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/statistics/api/latest
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/statistics/group/latest
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/throttles
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/throttles
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}
apig:instance:get
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/sign-bindings
  • apig:instance:get
  • apig:api:get
  • apig:signatureKey:list
DELETE /{project_id}/apigw/instances/{instance_id}/sign-bindings/{sign_bindings_id}
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/sign-bindings/binded-apis
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/sign-bindings/binded-signs
  • apig:instance:get
  • apig:api:get
GET /{project_id}/apigw/instances/{instance_id}/sign-bindings/unbinded-apis
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/signs
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/signs
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/signs/{sign_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/signs/{sign_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}/throttle-specials
  • apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}/throttle-specials
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}/throttle-specials/{strategy_id}
  • apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/throttles/{throttle_id}/throttle-specials/{strategy_id}
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/instance-tags
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/instance-tags/action
apig:instance:get
GET /{project_id}/apigw/instance-tags
apig::listTag
apig:instance:get
POST /{project_id}/apigw/resource-instances/count
POST /{project_id}/apigw/resource-instances/filter
apig:instance:list
  • vpc:securityGroups:get
  • vpc:ports:create
  • vpc:ports:update
  • eip:publicIps:get
  • eip:publicIps:update
  • eps:enterpriseProjects:list
  • eip:publicIps:get
  • vpc:ports:delete
apig:instance:get
  • vpc:ports:update
DELETE /{project_id}/apigw/instances/{instance_id}/eip
  • apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/eip
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/nat-eip
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/nat-eip
  • apig:instance:get
  • vpc:ports:get
PUT /{project_id}/apigw/instances/{instance_id}/nat-eip
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/progress
DELETE /{project_id}/apigw/instances/{instance_id}/ingress-eip
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/ingress-eip
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/ingress-eip
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/postpaid-resize
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/restriction
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/features
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/features
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/instance-features
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/microservice/import
  • apig:instance:get
  • apig:api:create
  • apig:apiGroup:get
  • apig:apiGroup:create
  • apig:loadBalanceChannel:create
  • apig:instance:get
  • apig:apiGroup:get
DELETE /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}
  • apig:instance:get
  • apig:apiGroup:get
  • apig:instance:get
  • apig:apiGroup:get
DELETE /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}/certificate/{certificate_id}
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/domains/{domain_id}/certificate/{certificate_id}
  • apig:instance:get
  • apig:apiGroup:get
PUT /{project_id}/apigw/instances/{instance_id}/api-groups/{group_id}/sl-domain-access-settings
  • apig:instance:get
  • apig:apiGroup:get
GET /{project_id}/apigw/instances/{instance_id}/authorizers
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/authorizers
  • apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/authorizers/{authorizer_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/authorizers/{authorizer_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/authorizers/{authorizer_id}
  • apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-endpoint/connections
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-endpoint/connections/action
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/vpc-endpoint/permissions
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-endpoint/permissions/batch-add
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/vpc-endpoint/permissions/batch-delete
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-acl
apig:app:deleteAcl
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-acl
apig:app:getAcl
  • apig:instance:get
  • apig:app:get
PUT /{project_id}/apigw/instances/{instance_id}/apps/{app_id}/app-acl
apig:app:updateAcl
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/app-quotas
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/app-quotas
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}
apig:instance:get
PUT /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}/bound-apps
apig:instance:get
POST /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}/binding-apps
  • apig:instance:get
  • apig:clientQuota:get
DELETE /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}/bound-apps/{app_id}
  • apig:instance:get
  • apig:app:get
GET /{project_id}/apigw/instances/{instance_id}/app-quotas/{app_quota_id}/bindable-apps
  • apig:instance:get
  • apig:instance:get
  • apig:instance:listFeature
POST /{project_id}/apigw/instances/{instance_id}/custom-ingress-ports
apig:instance:get
GET /{project_id}/apigw/instances/{instance_id}/custom-ingress-ports
apig:instance:get
DELETE /{project_id}/apigw/instances/{instance_id}/custom-ingress-ports/{ingress_port_id}
  • apig:instance:get
  • apig:instance:listCustomIngressPort
GET /{project_id}/apigw/instances/{instance_id}/custom-ingress-ports/{ingress_port_id}/domains
  • apig:instance:get
  • apig:apiGroup:get
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for APIG.
Table 3 Resource types supported by APIG
Resource Type
URN
instance
apig:<region>:<account-id>:instance:<instance-id>
Conditions
APIG does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
