Enterprise Center
SCPs allow you to use the elements described below.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to edit a custom SCP policy, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions. Actions supported by Enterprise Center are valid for all resources. You can use a wildcard (*) to indicate all resource types.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
The following table lists the actions that you can define in SCPs for Enterprise Center.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
businessUnitCenter:bill:update |
Grants permission to perform operations bills for enterprise members. |
Write |
businessUnitCenter:bill:view |
Grants permission to view bills of member accounts. |
Read |
businessUnitCenter:billDetail:update |
Grants permission to perform operations on bill details for enterprise members. |
Write |
businessUnitCenter:billDetail:view |
Grants permission to view bill details of member accounts. |
Read |
businessUnitCenter:businessUnitFinance:update |
Grants permission to modify organization accounting information. |
Write |
businessUnitCenter:businessUnitFinance:view |
Grants permission to view organization accounting information. |
Read |
businessUnitCenter:businessUnit:update |
Grants permission to modify organizations and accounts. |
Write |
businessUnitCenter:businessUnit:view |
Grants permission to view organizations and accounts. |
Read |
businessUnitCenter:businessUnitBudget:update |
Grants permission to perform operations on organization budgets. |
Write |
businessUnitCenter:businessUnitBudget:view |
Grants permission to view organization budgets. |
Read |
businessUnitCenter:businessUnitPolicy:update |
Grants permission to modify organization policies. |
Write |
businessUnitCenter::active |
Grants permission to enable and disable Enterprise Center. |
Write |
Resources
Enterprise Center does not support resource-specific permission control in SCPs. If you need to allow access to Enterprise Center, use the wildcard (*) for the Resource element to apply SCPs to all resources.
Conditions
Enterprise Center does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
