- What's New
- Getting Started
User Guide
- Permissions Management
- Managing Organizations
- Managing OUs
- Managing Accounts
Managing SCPs
- Overview of an SCP
- Enabling or Disabling the SCP Type
- Creating an SCP
- Modifying or Deleting an SCP
- Attaching or Detaching an SCP
- Example SCPs
- System-defined SCPs
- Cloud Services for Using SCPs
- Regions for Using SCPs
Actions Supported by SCP-based Authorization
- Compute
- Storage
- Networking
- Containers
- Analytics
- Content Delivery & Edge Computing
- Databases
- Security & Compliance
- Internet of Things
- Middleware
- Developer Services
- Business Applications
- Simple Message Notification (SMN)
- Log Tank Service (LTS)
- Identity and Access Management (IAM)
- Security Token Service (STS)
- Resource Formation Service (RFS)
- IAM Identity Center
- Organizations
- Resource Access Manager (RAM)
- Enterprise Project Management Service (EPS)
- Tag Management Service (TMS)
- Config
- IAM Access Analyzer
- Cloud Trace Service (CTS)
- Resource Governance Center (RGC)
- Application Operations Management (AOM)
- Cloud Eye (CES)
- IAM Identity Broker
- User Support
- Migration
- Managing Tag Policies
- Managing Trusted Services
- Managing Tags
- CTS Auditing
- Adjusting Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Managing OUs
Managing Accounts
- Creating an account and adding it to your organization
- Creating an Account
- Listing Accounts in an Organization
- Closing an Account
- Getting Account Information
- Updating an Account
- Removing the Specified Account
- Moving an Account
- Inviting an Account to Join an Organization
- Querying Account Creation Requests in Specified State
- Querying Account Creation Status
- Querying CloseAccount Requests in Specified State
- Managing Invitations
- Managing Delegated Administrators
- Managing Policies
Managing Tags
- Listing Tags for the Specified Resource
- Adding Tags to the Specified Resource
- Removing Tags from the Specified Resource
- Listing Tags for the Specified Resource Type
- Adding Tags to the Specified Resource Type
- Deleting Tags with the Specified Key from the Specified Resource Type
- Querying Resource Instances by Resource Type and Tag
- Querying Number of Resource Instances by Resource Type and Tag
- Querying Resource Tags
- Others
- Appendixes
- Change History
- FAQs
Show all
The Organizations service provides Service Control Policies (SCPs) for access control.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs only determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to edit a custom SCP policy, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions. Actions supported by Account Center are valid for all resources. You can use a wildcard (*) to indicate all resource types.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
The following table lists the actions that you can define in SCPs for Account Center.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
account:accountInfo:update |
Grants permission to update account information, including real-name authentication, basic information, and preferences. |
Write |
account:cps:view |
Grants permission to view the promotion data of Recommendations and Rebates by cloud promoters. |
Read |
account:cps:update |
Grants permission to join the reward promotion program. |
Write |
account:privilege:view |
Grants permission to view my privileges and prizes. |
Read |
account::close |
Grants permission to close, disable, and restore Huawei Cloud services. |
Write |
Resources
Account Center does not support resource-specific permission control in SCPs. If you want to allow access to Account Center, use the wildcard (*) for the Resource element to apply SCPs to all resources.
Conditions
Account Center does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
