On this page
Database Security Service (DBSS)
Updated on 2025-02-25 GMT+08:00
The Organizations provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP policy.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by DBSS, see Resources.
  • The Condition Key column includes keys that you can specify in the Condition element of an SCP policy statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by DBSS, see Conditions.
The following table lists the actions that you can define in SCP statements for DBSS.
Table 1 Actions supported by DBSS
Item
Access Level
Resource Type (*: required)
Condition Key
dbss:auditInstance:listSqlInjectRules
Grant the permission to query SQL injection rules.
list
dbss:<region>:<account-id>:auditInstance:<instance-id>
dbss:auditInstance:listSqls
Grant the permission to obtain the audit results.
list
dbss:auditInstance:switchSqlInjectRule
Grant the permission to enable or disable the SQL injection policy.
write
dbss:auditInstance:addSqlInjectRule
Grant the permission to add custom SQL injection rules.
write
dbss:auditInstance:orderSqlInjectRule
Grant the permission to sort SQL rules by priority.
write
dbss:auditInstance:createReporter
Grant the permission to generate reports immediately.
write
dbss:auditInstance:listReporters
Grant the permission to query report information.
list
dbss:auditInstance:getRiskRuleDetail
Grant the permission to query specified risk rules.
read
dbss:auditInstance:listAlarmEmails
Grant the permission to query alarm notification email.
list
dbss:auditInstance:downloadReporter
Grant the permission to download reports.
read
dbss:auditInstance:listAuditScopeRules
Grant the permission to query the audit scope policy list.
list
dbss:auditInstance:addSensitiveRule
Grant the permission to add privacy data protection rules.
write
dbss:auditInstance:editSensitiveRule
Grant the permission to edit privacy data protection rules.
write
dbss:auditInstance:deleteReporter
Grant the permission to delete reports.
write
dbss:auditInstance:listOperateLog
Grant the permission to query user operation logs.
list
dbss:auditInstance:listMonitorInfos
Grant the permission to query the audit instance monitoring information.
list
dbss:auditInstance:listSessionInfo
Grant the permission to query the audit instance session information.
list
dbss:auditInstance:switchBackup
Grant the permission to enable or disable the backup function.
write
dbss::downloadLicense
Grant the permission to download a sales license.
read
dbss::deleteAuditInstanceJob
Grant the permission to delete tasks failed to be created for audit instances.
write
dbss::listRdsDb
Grant the permission to query RDS databases.
list
dbss:auditInstance:instanceStart
Grant the permission to enable the audit instance.
write
dbss:auditInstance:reboot
Grant the permission to restart the audit instance.
write
dbss:auditInstance:stop
Grant the permission to disable the audit instance.
write
dbss:auditInstance:upgrade
Grant the permission to upgrade the audit instance.
write
dbss::queryUpgradeStatus
Grant the permission to query the upgrade status of the audit instance.
list
dbss:auditInstance:updateSecurityGroup
Grant the permission to modify the security group of the audit instance.
write
dbss:auditInstance:modifyAttribute
Grant the permission to modify the audit attributes of the audit instance.
write
dbss:auditInstance:downloadAgent
Grant the permission to download the agent.
read
dbss:auditInstance:switchAgent
Grant the permission to enable or disable the agent.
write
dbss:auditInstance:listAgents
Grant the permission to query the agent list.
list
dbss:auditInstance:deleteAgent
Grant the permission to delete the agent.
write
dbss:auditInstance:addAgent
Grant the permission to add the agent.
write
dbss:auditInstance:previewReporter
Grant the permission to preview a report.
read
dbss:auditInstance:setAlarmConfig
Grant the permissions to configure alarm information.
write
dbss:auditInstance:configAlarmEmail
Grant the permission to configure alarm notification email.
write
dbss:auditInstance:getAlarmConfig
Grant the permission to query alarm configurations.
read
dbss:auditInstance:listRiskRules
Grant the permission to query risk rules.
list
dbss:auditInstance:exportInstancesDatabaseConfig
Grant the permission to export database configurations.
list
dbss:auditInstance:createOnPeriod
Grant the permission to create audit instances in yearly/monthly billing mode.
write
  • g:EnterpriseProjectId
  • g:RequestTag/<tag-key>
  • g:TagKeys
dbss:auditInstance:editSqlInjectRule
Grant the permission to edit custom SQL injection rules.
write
dbss:auditInstance:deleteSqlInjectRule
Grant the permission to delete custom SQL injection rules.
write
dbss:auditInstance:deleteSensitiveRule
Grant the permission to delete privacy data protection rules.
write
dbss:auditInstance:deleteAuditScopeRule
Grant the permission to delete audit scope rules.
write
dbss:auditInstance:deleteRiskRule
Grant the permission to delete risk rules.
write
dbss:auditInstance:deleteBackup
Grant the permission to delete local backup information.
write
dbss:auditInstance:listBackups
Grant the permission to query backup information.
list
dbss:auditInstance:getBackupConfig
Grant the permission to obtain backup configuration information.
read
dbss:auditInstance:editAuditScopeRule
Grant the permission to edit audit scope rules.
write
dbss:auditInstance:instanceList
Grant the permission to query audit instance information.
list
dbss:auditInstance:createOnDemand
Grant the permission to create audit instances in the pay-per-use billing mode.
write
  • g:TagKeys
dbss::listCommonInfo
Grant the permission to query public information.
list
dbss:auditInstance:listInstancesSummaryInfo
Grant the permission to query the overview of all audit instances.
list
dbss::getauditInstancesSummaryTaskStatus
Grant the permission to query the task status overview.
read
dbss::updateAuditInstancesSummaryInfo
Grant the permission to update the overview of all audit instances.
write
dbss:auditInstance:setReporterConfig
Grant the permission to edit the scheduled report task configurations.
write
dbss:auditInstance:getReporterConfig
Grant the permission to obtain the scheduled report task configurations.
read
dbss:auditInstance:addBareDatabase
Grant the permission to add a user-built database.
write
dbss:auditInstance:listDatabases
Grant the permission to query the database list.
list
dbss:auditInstance:switchDatabase
Grant the permission to enable or disable the database audit function.
write
dbss:auditInstance:deleteDatabase
Grant the permission to delete a database.
write
dbss:auditInstance:addAuditScopeRule
Grant the permission to add audit scope rules.
write
dbss:auditInstance:switchAuditScopeRule
Grant the permission to enable or disable audit scope rules.
write
dbss:auditInstance:addRiskRule
Grant the permission to add risk rules.
write
dbss:auditInstance:switchRiskRule
Grant the permission to enable or disable risk rules.
write
dbss:auditInstance:editRiskRule
Grant the permission to edit risk rules.
write
dbss:auditInstance:setRiskRulePriority
Grant the permission to set risk rule priorities.
write
dbss:auditInstance:listStatistics
Grant the permission to query the overview of audit instances.
list
dbss:auditInstance:listSensitiveRules
Grant the permission to query privacy data masking rules.
list
dbss:auditInstance:modifySensitiveRuleSaveResultSwitch
Grant the permission to enable or disable result set storage.
write
dbss:auditInstance:modifySensitiveRuleAnonymizeSwitch
Grant the permission to enable or disable privacy data masking.
write
dbss:auditInstance:switchSensitiveRule
Grant the permission to enable or disable privacy data protection rules.
write
dbss:auditInstance:listAlarmItems
Grant the permission to query alarms.
list
dbss:auditInstance:markAlarm
Grant the permission to mark alarms.
write
dbss:auditInstance:deleteAlarm
Grant the permission to delete alarms.
write
dbss:auditInstance:restoreBackup
Grant the permission to restore backup information.
write
dbss:auditInstance:retryBackup
Grant the permission to retry the backup operation.
write
dbss:auditInstance:getRiskBackupConfigInfo
Grant the permission to obtain risk export configuration information.
read
dbss:auditInstance:switchRiskBackup
Grant the permission to enable or disable the risk export function.
write
dbss:auditInstance:getRiskBackupBucketInfo
Grant the permission to obtain the OBS buckets in risk export.
read
dbss:auditInstance:setRiskBackupBucketInfo
Grant the permission to configure the OBS bucket in risk export.
write
dbss:auditInstance:addRdsDatabase
Grant the permission to add RDS databases.
write
dbss::getServerInfo
Grant the permission to obtain DBSS service information.
read
dbss::getAuditInstanceJob
Grant the permission to view the created audit instance tasks.
read
dbss:auditInstance:listJobs
Grant the permission to list the created audit instance tasks.
list
dbss::listObsBuckets
Grant the permission to query the OBS bucket list.
list
dbss:auditInstance:instanceDelete
Grant the permission to delete audit instances.
write
dbss::listResourcesByTag
Grant the permission to query audit instances based on tags.
tagging
  • g:TagKeys
dbss::tagResource
Grant the permission to add instance tags in batches.
tagging
  • g:TagKeys
dbss::unTagResource
Grant the permission to delete instance tags in batches.
tagging
  • g:TagKeys
dbss::listTags
Grant the permission to query all tags in a project.
tagging
dbss::listTagsForResource
Grant the permission to query instance tags.
tagging
Each API of DBSS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies of DBSS APIs
API
Action
Dependency Item
POST /v1/{project_id}/{instance_id}/audit/rule/risk/switch
POST /v1/{project_id}/{instance_id}/audit/agent/switch
GET /v1/{project_id}/dbss/audit/quota
GET /v1/{project_id}/dbss/audit/specification
GET /v2/{project_id}/dbss/audit/availability-zone
POST /v1/{project_id}/{instance_id}/dbss/audit/operate-log
POST /v1/{project_id}/dbss/audit/security-group
GET /v1/{project_id}/dbss/audit/instances
GET /v1/{project_id}/dbss/audit/jobs/{resource_id}
POST /v2/{project_id}/dbss/audit/charge/period/order
GET /v1/{project_id}/{instance_id}/dbss/audit/databases
POST /v1/{project_id}/{instance_id}/dbss/audit/databases/rds
GET /v1/{project_id}/{resource_type}/tags
dbss::listTags
POST /v1/{project_id}/{resource_type}/resource-instances/filter
POST /v1/{project_id}/{resource_type}/resource-instances/count
POST /v1/{project_id}/{resource_type}/{resource_id}/tags/create
dbss::tagResource
DELETE /v1/{project_id}/{resource_type}/{resource_id}/tags/delete
dbss::unTagResource
GET /v1/{project_id}/{instance_id}/dbss/audit/rule/scopes
POST /v1/{project_id}/{instance_id}/dbss/audit/rule/sql-injections
GET /v1/{project_id}/{instance_id}/dbss/audit/rule/risk
GET /v1/{project_id}/{instance_id}/dbss/audit/rule/risk/{risk_id}
GET /v1/{project_id}/{instance_id}/dbss/audit/sensitive/masks
Resources
DBSS does not support resource-specific permission control in identity policies. If you want to allow access to DBSS, use the wildcard (*) for the Resource element to apply identity policies to all resources.
Table 3 Resource types supported by DBSS
Resource Type
URN
Condition Key
auditInstance
  • g:ResourceTag/<tag-key>
Conditions
DBSS does not support service-specific condition keys in identity policies. DBSS can use global condition keys applicable to all services. For details, see Global Condition Keys.
