Auto Scaling (AS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by AS, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by AS, see Conditions.
The following table lists the actions that you can define in SCP statements for AS.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
as:scalingGroup:create |
Grants permission to create an AS group. |
write |
as:scalingGroup:delete |
Grants permission to delete an AS group. |
write |
scalingGroup* |
as:scalingGroup:list |
Grants permission to list AS groups. |
list |
g:EnterpriseProjectId |
as:scalingGroup:get |
Grants permission to query AS group details. |
read |
scalingGroup* |
as:scalingGroup:update |
Grants permission to modify an AS group. |
write |
as:scalingGroup:resume |
Grants permission to enable an AS group. |
write |
scalingGroup* |
as:scalingGroup:pause |
Grants permission to disable an AS group. |
write |
scalingGroup* |
as:scalingConfig:create |
Grants permission to create an AS configuration. |
write |
as:scalingConfig:delete |
Grants permission to delete an AS configuration. |
write |
scalingConfig* |
as:scalingConfig:batchDelete |
Grants permission to delete AS configurations. |
write |
scalingConfig* |
as:scalingConfig:list |
Grants permission to list AS configurations. |
list |
scalingConfig* |
as:scalingConfig:get |
Grants permission to query AS configuration details. |
read |
scalingConfig* |
as:scalingGroup:batchAddInstances |
Grants permission to add instances to an AS group. |
write |
scalingGroup* |
as:scalingGroup:batchRemoveInstances |
Grants permission to delete instances from an AS group. |
write |
scalingGroup* |
as:scalingGroup:batchSetInstancesProtect |
Grants permission to enable instance protection for instances. |
write |
scalingGroup* |
as:scalingGroup:batchSetInstancesUnprotect |
Grants permission to disable instance protection for instances. |
write |
scalingGroup* |
as:scalingGroup:batchSetInstancesStandby |
Grants permission to put instances into the standby status. |
write |
scalingGroup* |
as:scalingGroup:batchSetInstancesExitStandby |
Grants permission to move instances out of the standby status. |
write |
scalingGroup* |
as:scalingGroup:deleteInstance |
write |
scalingGroup* |
as:scalingGroup:listInstances |
Grants permission to list instances in an AS group. |
list |
scalingGroup* |
as:scalingPolicy:create |
Grants permission to create an AS policy. |
write |
as:scalingPolicy:list |
Grants permission to list AS policies. |
list |
as:scalingPolicy:get |
Grants permission to query AS policy details. |
read |
scalingPolicy* |
as:scalingPolicy:update |
Grants permission to modify an AS policy. |
write |
as:scalingPolicy:delete |
Grants permission to delete an AS policy. |
write |
scalingPolicy* |
as:scalingPolicy:execute |
Grants permission to execute an AS policy. |
write |
scalingPolicy* |
as:scalingPolicy:resume |
Grants permission to enable an AS policy. |
write |
scalingPolicy* |
as:scalingPolicy:pause |
Grants permission to disable an AS policy. |
write |
scalingPolicy* |
as:scalingPolicy:batchPause |
Grants permission to disable AS policies. |
write |
scalingPolicy* |
as:scalingPolicy:batchResume |
Grants permission to enable AS policies. |
write |
scalingPolicy* |
as:scalingPolicy:batchDelete |
Grants permission to delete AS policies. |
write |
scalingPolicy* |
as:scalingPolicy:listAll |
Grants permission to list AS policies of a tenant. |
list |
as:scalingGroup:listActivityLogs |
Grants permission to query scaling action logs. |
list |
scalingGroup* |
as:scalingPolicy:listExecuteLogs |
Grants permission to query AS policy execution logs. |
list |
scalingPolicy* |
as::tagResource |
Grants permission to add tags. |
tagging |
as::untagResource |
Grants permission to delete tags. |
tagging |
as::listTags |
Grants permission to query tags of all resources. |
list |
as::listTagsForResource |
Grants permission to query tags of a resource. |
list |
as::listResourcesByTag |
Grants permission to query resources by tag. |
list |
as:scalingGroup:createLifecycleHook |
Grants permission to create a lifecycle hook. |
write |
as:scalingGroup:listLifecycleHooks |
Grants permission to list lifecycle hooks. |
list |
scalingGroup* |
as:scalingGroup:getLifecycleHook |
Grants permission to query lifecycle hook details. |
read |
scalingGroup* |
as:scalingGroup:updateLifecycleHook |
Grants permission to modify a lifecycle hook. |
write |
as:scalingGroup:deleteLifecycleHook |
Grants permission to delete a lifecycle hook. |
write |
scalingGroup* |
as:scalingGroup:callbackInstanceHook |
Grants permission to call back a lifecycle hook. |
write |
scalingGroup* |
as:scalingGroup:listInstanceHooks |
Grants permission to query suspended instances. |
list |
scalingGroup* |
as:scalingGroup:createNotification |
Grants permission to create notifications. |
write |
as:scalingGroup:listNotifications |
Grants permission to query notifications. |
list |
scalingGroup* |
as:scalingGroup:deleteNotification |
Grants permission to delete notifications. |
write |
scalingGroup* |
as:scalingGroup:getQuotas |
Grants permission to query instance and AS policy quotas. |
read |
as::listQuotas |
read |
Each API of AS usually supports one or more actions. Table 2 lists the actions and dependencies supported by AS APIs.
API |
Action |
Dependencies |
POST /autoscaling-api/v1/{project_id}/scaling_group |
DELETE /autoscaling-api/v1/{project_id}/scaling_group/{scaling_group_id} |
GET /autoscaling-api/v1/{project_id}/scaling_group |
GET /autoscaling-api/v1/{project_id}/scaling_group/{scaling_group_id} |
PUT /autoscaling-api/v1/{project_id}/scaling_group/{scaling_group_id} |
POST /autoscaling-api/v1/{project_id}/scaling_group/{scaling_group_id}/action |
POST /autoscaling-api/v1/{project_id}/scaling_configurationCreateScalingConfig |
DELETE /autoscaling-api/v1/{project_id}/scaling_configuration/{scaling_configuration_id} |
POST /autoscaling-api/v1/{project_id}/scaling_configurations |
GET /autoscaling-api/v1/{project_id}/scaling_configuration |
GET /autoscaling-api/v1/{project_id}/scaling_configuration/{scaling_configuration_id} |
POST /autoscaling-api/v1/{project_id}/scaling_group_instance/{scaling_group_id}/action |
DELETE /autoscaling-api/v1/{project_id}/scaling_group_instance/{instance_id} |
GET /autoscaling-api/v1/{project_id}/scaling_group_instance/{scaling_group_id}/list |
POST /autoscaling-api/v1/{project_id}/scaling_policy |
GET /autoscaling-api/v1/{project_id}/scaling_policy/{scaling_group_id}/list |
GET /autoscaling-api/v1/{project_id}/scaling_policy/{scaling_policy_id} |
PUT /autoscaling-api/v1/{project_id}/scaling_policy/{scaling_policy_id} |
DELETE /autoscaling-api/v1/{project_id}/scaling_policy/{scaling_policy_id} |
POST /autoscaling-api/v1/{project_id}/scaling_policy/{scaling_policy_id}/action |
POST /autoscaling-api/v1/{project_id}/scaling_policies/action |
as:scalingPolicy:batchDelete as:scalingPolicy:batchPause as:scalingPolicy:batchResume |
POST /autoscaling-api/v2/{project_id}/scaling_policy |
GET /autoscaling-api/v2/{project_id}/scaling_policy |
GET /autoscaling-api/v2/{project_id}/scaling_policy/{scaling_resource_id}/list |
GET /autoscaling-api/v2/{project_id}/scaling_policy/{scaling_policy_id} |
PUT /autoscaling-api/v2/{project_id}/scaling_policy/{scaling_policy_id} |
GET /autoscaling-api/v1/{project_id}/scaling_activity_log/{scaling_group_id} |
GET /autoscaling-api/v2/{project_id}/scaling_activity_log/{scaling_group_id} |
GET /autoscaling-api/v1/{project_id}/scaling_policy_execute_log/{scaling_policy_id} |
POST /autoscaling-api/v1/{project_id}/{resource_type}/{resource_id}/tags/action |
as::tagResource |
as::untagResource |
GET /autoscaling-api/v1/{project_id}/{resource_type}/tags |
as::listTags |
GET /autoscaling-api/v1/{project_id}/{resource_type}/{resource_id}/tags |
POST /autoscaling-api/v1/{project_id}/{resource_type}/resource_instances/action |
POST /autoscaling-api/v1/{project_id}/scaling_lifecycle_hook/{scaling_group_id} |
GET /autoscaling-api/v1/{project_id}/scaling_lifecycle_hook/{scaling_group_id}/list |
GET /autoscaling-api/v1/{project_id}/scaling_lifecycle_hook/{scaling_group_id}/{lifecycle_hook_name} |
PUT /autoscaling-api/v1/{project_id}/scaling_lifecycle_hook/{scaling_group_id}/{lifecycle_hook_name} |
DELETE /autoscaling-api/v1/{project_id}/scaling_lifecycle_hook/{scaling_group_id}/{lifecycle_hook_name} |
PUT /autoscaling-api/v1/{project_id}/scaling_instance_hook/{scaling_group_id}/callback |
GET /autoscaling-api/v1/{project_id}/scaling_instance_hook/{scaling_group_id}/list |
PUT /autoscaling-api/v1/{project_id}/scaling_notification/{scaling_group_id} |
DELETE /autoscaling-api/v1/{project_id}/scaling_notification/{scaling_group_id}/{topic_urn} |
GET /autoscaling-api/v1/{project_id}/scaling_notification/{scaling_group_id} |
GET /autoscaling-api/v1/{project_id}/quotas/{scaling_group_id} |
GET /autoscaling-api/v1/{project_id}/quotas |
as::listQuotas |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for AS.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, as:) only apply to operations of the BMS service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for AS. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
as:ScalingConfigId |
String |
Single-valued |
Filters access by AS configuration ID. |
as:VpcId |
String |
Single-valued |
Filters access by VPC ID. |
as:VpcSubnetId |
String |
Multivalued |
Filters access by subnet ID. |
as:ElbPoolId |
String |
Multivalued |
Filters access by ELB backend server group ID. |
as:MaxInstanceSize |
Integer |
Single-valued |
Filters access by the maximum number of instances in an AS group. |
as:MinInstanceSize |
Integer |
Single-valued |
Filters access by the minimum number of instances in an AS group. |
as:EcsInstanceId |
String |
Single-valued |
Filters access by the ECS ID used for AS configuration creation. |
as:EcsInstanceType |
String |
Single-valued |
Filters access by the spot or pay-per-use billing mode. |
as:EcsFlavorId |
String |
Multivalued |
Filters access by the flavor ID used for ECS creation. |
as:ImageId |
String |
Single-valued |
Filters access by the image ID used for ECS creation. |
as:ImsDiskImageId |
String |
Multivalued |
Filters access by the disk image ID used for ECS creation. |
as:CbrDiskSnapshotId |
String |
Multivalued |
Filters access by the disk backup ID used for ECS creation. |
as:EcsServerGroupId |
String |
Single-valued |
Filters access by the ECS group ID used for ECS creation. |
as:EvsEncrypted |
Boolean |
Single-valued |
Filters access based on whether disk encryption is enabled. |
as:KmsKeyId |
String |
Multivalued |
Filters access by the key ID used for disk encryption. |
as:EvsVolumeType |
String |
Multivalued |
Filters access by the disk type used for ECS creation. |
as:KpsSSHKeyPairName |
String |
Single-valued |
Filters access by the key pair name used for ECS creation. |
as:AssociatePublicIp |
Boolean |
Single-valued |
Filters access based on whether auto EIP assignment is enabled. |
