The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by GaussDB, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by GaussDB, see Conditions.
The following table lists the actions that you can define in SCP statements for GaussDB.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
gaussdb::updateDownloadPolicy |
Grants permission to edit a download policy. |
write |
gaussdb:DownloadCategory |
gaussdb::getDownloadPolicy |
Grants permission to query a download policy. |
read |
gaussdb:backup:createBackup |
Grants permission to create a manual backup for a DB instance. |
write |
instance |
gaussdb:backup:deleteBackup |
Grants permission to delete a backup. |
write |
instance |
gaussdb:backup:listAll |
Grants permission to query backups. |
list |
instance |
gaussdb:instance:updateBackupPolicy |
Grants permission to configure a backup policy. |
write |
instance |
gaussdb:BackupEnabled |
gaussdb:param:applyParam |
Grants permission to apply a parameter template. |
write |
instance |
gaussdb:tag:create |
Grants permission to add tags. |
tagging |
instance |
gaussdb:instance:bindEIP |
Grants permission to bind an EIP. |
write |
instance |
gaussdb:instance:check |
Grants permission to check instance information. |
read |
instance |
gaussdb:instance:createInstance |
Grants permission to create a DB instance. |
write |
instance |
gaussdb:instance:createDatabase |
Grants permission to create a database. |
write |
instance |
gaussdb:instance:createDatabaseSchema |
Grants permission to create a database schema. |
write |
instance |
gaussdb:instance:createDatabaseUser |
Grants permission to create a database account. |
write |
instance |
gaussdb:instance:deleteInstance |
Grants permission to delete a DB instance. |
write |
instance |
gaussdb:instance:get |
Grants permission to query DB instance information. |
read |
instance |
gaussdb:instance:getBackupPolicy |
Grants permission to query an automated backup policy. |
read |
instance |
gaussdb:instance:getBalanceStatus |
Grants permission to check whether host load is unbalanced due to a primary/standby switchover. |
read |
instance |
gaussdb:instance:getDiskUsage |
Grants permission to query disk usage. |
read |
instance |
gaussdb:instance:getRecyclePolicy |
Grants permission to query the recycling policy. |
read |
instance |
gaussdb:instance:downloadSslCert |
Grants permission to download the SSL certificate of a DB instance. |
read |
instance |
gaussdb:instance:grantDatabasePrivilege |
Grants permission to configure permissions of database accounts. |
write |
instance |
gaussdb:instance:listAll |
Grants permission to query DB instances. |
list |
instance |
gaussdb:instance:listPublicIps |
Grants permission to query EIPs bound to DB instances. |
list |
instance |
gaussdb:instance:listComponents |
Grants permission to query instance components. |
list |
instance |
gaussdb:instance:listDatabases |
Grants permission to query databases. |
list |
instance |
gaussdb:instance:listDatabaseUsers |
Grants permission to query database users. |
list |
instance |
gaussdb:tag:listAll |
Grants permission to query resource tags. |
list |
instance |
gaussdb:quota:listAll |
Grants permission to query quotas. |
list |
instance |
gaussdb:instance:listRecoverableTimes |
Grants permission to query the restoration time range. |
list |
instance |
gaussdb:instance:listSchemas |
Grants permission to query database schemas. |
list |
instance |
gaussdb:instance:renameInstance |
Grants permission to change a DB instance name. |
write |
instance |
gaussdb:instance:resetPassword |
Grants permission to change a database password. |
write |
instance |
gaussdb:instance:resizeFlavor |
Grants permission to change vCPUs and memory of a DB instance. |
write |
instance |
gaussdb:instance:restartInstance |
Grants permission to reboot a DB instance. |
write |
instance |
gaussdb:instance:setRecyclePolicy |
Grants permission to modify the recycling policy. |
write |
instance |
gaussdb:instance:switchShard |
Grants permission to switch roles of the primary and standby DNs in shards. |
write |
instance |
gaussdb:instance:extend |
Grants permission to perform scale-out operations. |
write |
instance |
gaussdb:param:update |
Grants permission to modify a parameter template. |
write |
instance |
gaussdb:param:check |
Grants permission to check a parameter template. |
read |
instance |
gaussdb:param:copy |
Grants permission to replicate a parameter template. |
write |
instance |
gaussdb:param:createParam |
Grants permission to create a parameter template. |
write |
instance |
gaussdb:param:deleteParam |
Grants permission to delete a parameter template. |
write |
instance |
gaussdb:param:get |
Grants permission to query details about a parameter template. |
read |
instance |
gaussdb:param:compare |
Grants permission to compare two parameter templates. |
read |
instance |
gaussdb:param:listAll |
Grants permission to query parameter templates. |
list |
instance |
gaussdb:param:reset |
Grants permission to reset a parameter template. |
write |
instance |
gaussdb:quota:update |
Grants permission to modify quotas. |
write |
instance |
gaussdb:task:listAll |
Grants permission to query tasks. |
list |
instance |
gaussdb:task:delete |
Grants permission to delete a task record. |
write |
instance |
gaussdb:task:get |
Grants permission to query task details. |
read |
instance |
Each API of GaussDB usually supports one or more actions. The following table lists the supported actions and dependencies.
Permission |
API |
Action |
Dependencies |
Creating a DB instance |
POST /v3/{project_id}/instances |
Deleting a DB instance |
DELETE /v3/{project_id}/instances/{instance_id} |
gaussdb:instance:delete |
Querying DB instances |
GET /v3/{project_id}/instances |
Changing a database password |
POST /v3/{project_id}/instances/{instance_id}/password |
Changing a DB instance name |
PUT /v3/{project_id}/instances/{instance_id}/name |
gaussdb:instance:rename |
Rebooting a DB instance |
POST /v3/{project_id}/instances/{instance_id}/restart |
gaussdb:instance:restart |
Switching roles of the primary and standby DNs in shards |
POST /v3/{project_id}/instances/{instance_id}/switch-shard |
Querying the components of a DB instance |
GET /v3/{project_id}/instances/{instance_id}/components |
Changing vCPUs and memory of a DB instance |
PUT /v3/{project_id}/instance/{instance_id}/flavor |
Checking whether host load is unbalanced due to a primary/standby switchover |
GET /v3/{project_id}/instances/{instance_id}/balance |
Querying solution template settings |
GET /v3/{project_id}/deployment-form |
Querying EIPs bound to DB instances |
GET /v3/{project_id}/instances/{instance_id}/public-ips?offset={offset}&limit={limit} |
Validating password strength |
POST /v3/{project_id}/weak-password-verification |
Binding or unbinding an EIP |
POST /v3/{project_id}/instances/{instance_id}/nodes/{node_id}/public-ip |
gaussdb:instance:bindPublicIp |
Querying the SSL certificate download address of a DB instance |
GET /v3/{project_id}/instances/{instance_id}/ssl-cert/download-link |
Querying the instance quotas of a tenant |
GET /v3/{project_id}/project-quotas?type={type} |
Configuring a download policy |
GET /v3/{project_id}/download/policy |
Querying a download policy |
POST /v3/{project_id}/update/download/policy |
Permission |
API |
Action |
Dependencies |
Obtaining parameter templates |
GET /v3/{project_id}/configurations?offset={offset}&limit={limit} |
Obtaining parameters of a specified DB instance |
GET /v3/{project_id}/instances/{instance_id}/configurations |
Modifying parameters of a specified DB instance |
PUT /v3/{project_id}/instances/{instance_id}/configurations |
Creating a parameter template |
POST /v3/{project_id}/configurations |
Deleting a parameter template |
DELETE /v3/{project_id}/configurations/{config_id} |
gaussdb:param:delete |
Querying details about a parameter template |
GET /v3/{project_id}/configurations/{config_id} |
gaussdb:param:get |
Replicating a parameter template |
POST /v3/{project_id}/configurations/{config_id}/copy |
Resetting a parameter template |
POST /v3/{project_id}/configurations/{config_id}/reset |
Comparing two parameter templates |
POST /v3/{project_id}/configurations/comparison |
Querying instances that a parameter template can be applied to |
GET /v3/{project_id}/configurations/{config_id}/applicable-instances |
Checking whether a parameter template name exists |
GET /v3/{project_id}/configurations/name-validation?name={name} |
Applying a parameter template |
PUT /v3/{project_id}/configurations/{config_id}/apply |
gaussdb:param:apply |
Querying application records of a parameter template |
GET /v3/{project_id}/configurations/{config_id}/applied-histories |
Querying the change history of a parameter template |
GET /v3/{project_id}/configurations/{config_id}/histories |
Permission |
API |
Action |
Dependencies |
Configuring an automated backup policy |
PUT /v3/{project_id}/instances/{instance_id}/backups/policy |
Querying an automated backup policy |
GET /v3/{project_id}/instances/{instance_id}/backups/policy |
Querying backups |
GET /v3/{project_id}/backups?instance_id={instance_id}&backup_id={backup_id}&backup_type={backup_type}&offset={offset}&limit={limit}&begin_time={begin_time}&end_time={end_time} |
Creating a manual backup |
POST /v3/{project_id}/backups |
gaussdb:backup:create |
Deleting a manual backup |
DELETE /v3/{project_id}/backups/{backup_id} |
gaussdb:backup:delete |
Querying the restoration time range |
GET /v3/{project_id}/instances/{instance_id}/restore-time?date={date} |
Restoring data to a new DB instance |
Querying instances that can be used for backups and restorations |
GET /v3/{project_id}/restorable-instances |
Querying the information of the original instance based on a specific point of time or a backup file |
GET /v3/{project_id}/instance-snapshot?instance_id={instance_id}&backup_id={backup_id}&restore_time={restore_time} |
Permission |
API |
Action |
Dependencies |
Querying DB engine versions |
GET /v3/{project_id}/datastore/versions |
Querying instance specifications |
GET /v3/{project_id}/flavors?limit={limit}&offset={offset}&ha_mode={ha_mode}&version={version}&spec_code={spec_code} |
Querying DB engines |
GET /v3/{project_id}/datastores |
Querying specifications that a DB instance can be changed to |
GET /v3/{project_id}/instances/{instance_id}/available-flavors |
Permission |
API |
Action |
Dependencies |
Creating a database |
POST /v3/{project_id}/instances/{instance_id}/database |
Creating a database account |
POST /v3/{project_id}/instances/{instance_id}/db-user |
Creating a database schema |
POST /v3/{project_id}/instances/{instance_id}/schema |
Configuring permissions of database accounts |
POST /v3/{project_id}/instances/{instance_id}/db-privilege |
Changing a password for a database account |
PUT /v3/{project_id}/instances/{instance_id}/db-user/password |
Querying databases |
GET /v3/{project_id}/instances/{instance_id}/databases |
Querying database users |
GET /v3/{project_id}/instances/{instance_id}/db-users |
Querying database schemas |
GET /v3/{project_id}/instances/{instance_id}/schemas |
Permission |
API |
Action |
Dependencies |
Querying tags of a specific instance |
GET /v3/{project_id}/instances/{instance_id}/tags |
Querying tags of a project |
GET /v3/{project_id}/tags |
Querying predefined tags |
GET /v3/{project_id}/predefined-tags |
Adding tags for a DB instance |
POST /v3/{project_id}/instances/{instance_id}/tags |
Permission |
API |
Action |
Dependencies |
Querying the storage usage of a DB instance |
GET /v3/{project_id}/instances/{instance_id}/volume-usage |
Querying the database disk type |
GET /v3/{project_id}/storage-type?version={version}&ha_mode={ha_mode} |
Permission |
API |
Action |
Dependencies |
Modifying enterprise project quotas |
PUT /v3/{project_id}/enterprise-projects/quotas |
Querying enterprise project quotas |
GET /v3/{project_id}/enterprise-projects/quotas |
Permission |
API |
Action |
Dependencies |
Obtaining task information |
GET /v3/{project_id}/jobs?id={id} |
gaussdb:task:get |
Querying tasks |
GET /v3/{project_id}/tasks |
Deleting a task record |
DELETE /v3/{project_id}/jobs/{job_id} |
Permission |
API |
Action |
Dependencies |
Modifying the recycling policy |
PUT /v3/{project_id}/recycle-policy |
Querying the recycling policy |
GET /v3/{project_id}/recycle-policy |
Querying all DB engine instances in the recycle bin |
GET /v3/{project_id}/recycle-instances |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 12, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for GaussDB.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, gaussdb:) apply only to operations of the GaussDB service. For details, see Table 13.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for GaussDB. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
boolean |
Single-valued |
Filters access by the tag key that specifies whether to enable the backup policy in the request. |
gaussdb:Encrypted |
boolean |
Single-valued |
Filters access by the tag key that specifies whether to enable disk encryption in the request. |
string |
Single-valued |
Filters access by the download policy type name that is passed in the request. |
gaussdb:AvailabilityZone |
string |
Multivalued |
Filters access by the AZs that are passed in the request. |
gaussdb:VpcId |
string |
Single-valued |
Filters access by the VPC ID that is passed in the request. |
gaussdb:Subnet |
string |
Single-valued |
Filters access by the subnet ID that is passed in the request. |
gaussdb:KmsId |
string |
Single-valued |
Filters access by the disk encryption ID that is passed in the request. |
gaussdb:FlavorType |
string |
Single-valued |
Filters access by the specification type that is passed in the request. |
