Data Security Center (DSC)
The Service Control Policies (SCPs) in the Organizations service can use these authorization elements to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permission boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in a policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP policy statements.
- If this column includes a resource type, you must specify a URN for the Resource element in your identity policy statements.
- Required resources are marked with asterisks (*) in the table.
For details about resource types defined by DSC, see Resources.
- The Condition Key column includes keys that you can specify in the Condition element of an SCP policy statement.
- If the Resource Type column has values for an action, the condition key only takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about condition keys defined by DSC, see Conditions.
The following table lists the actions that you can define in SCP statements for DSC.
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
dsc:asset:delete |
Grants permission to delete data assets. |
write |
asset * |
dsc:asset:list |
Grants permission to query the data asset list. |
list |
asset * |
dsc:asset:create |
Grants permission to add data assets. |
write |
asset * |
dsc:asset:update |
Grants permission to update data asset information. |
write |
asset * |
dsc:maskTask:operate |
Grants permission to perform operations on masking tasks (such as starting, stopping, enabling, and disabling masking tasks). |
write |
maskTask * |
dsc:maskTask:listSubTasks |
Grants permission to query the subtask list of a masking task. |
list |
maskTask * |
dsc:common:operate |
Grants permission to operate DSC generic resources. |
write |
dsc:common:list |
Grants permission to query the DSC generic resource list. |
list |
dsc:scanTask:create |
Grants permission to create sensitive data scanning tasks. |
write |
scanTask * |
dsc:scanTask:list |
Grants permission to query the list of sensitive data scanning tasks or subtasks. |
list |
scanTask * |
dsc:scanTask:getResults |
Grants permission to query the scan result of a single scan job. |
read |
scanTask * |
dsc:scanRuleGroup:list |
Grants permission to query the list of scan rule groups. |
list |
dsc:scanRuleGroup:create |
Grants permission to create scan rule groups. |
write |
dsc:scanRuleGroup:delete |
Grants permission to delete scan rule groups. |
write |
dsc:scanRule:list |
Grants permission to query the scan rule list. |
list |
scanRule * |
dsc:scanRule:create |
Grants permission to create scan rules. |
write |
scanRule * |
dsc:scanRule:update |
Grants permission to update scan rules. |
write |
scanRule * |
dsc:scanRule:delete |
Grants permission to delete scan rules. |
write |
scanRule * |
dsc:watermark:embed |
Grants permission to embed watermarks into documents, images, or databases. |
write |
dsc:watermark:extract |
Grant permission to extract watermarks from documents, images, or databases. |
write |
A DSC API usually corresponds to one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependency |
DELETE/v1/{project_id}/sdg/asset/obs/bucket/{bucket_id} |
dsc:asset:delete |
obs:bucket:GetBucketLogging |
obs:bucket:PutBucketLogging |
GET/v1/{project_id}/sdg/asset/obs/buckets |
dsc:asset:list |
obs:bucket:listAllMyBuckets |
POST/v1/{project_id}/sdg/asset/obs/buckets |
dsc:asset:create |
obs:bucket:GetBucketStorage |
PUT/v1/{project_id}/sdg/asset/{asset_id}/name |
dsc:asset:update |
POST/v1/{project_id}/period/order |
bss:renewal:update |
bss:order:update |
GET/v1/{project_id}/period/product/specification |
dsc:common:list |
POST/v1/{project_id}/sdg/server/mask/dbs/templates/{template_id}/operation |
GET/v1/{project_id}/sdg/server/mask/dbs/templates/{template_id}/tasks |
PUT/v1/{project_id}/sdg/smn/topic |
GET/v1/{project_id}/sdg/smn/topics |
dsc:common:list |
smn:topic:list |
GET/v1/{project_id}/openapi/called-records |
dsc:common:list |
POST/v1/{project_id}/sdg/scan/job |
GET/v1/{project_id}/sdg/scan/jobs |
dsc:scanTask:list |
GET/v1/{project_id}/sdg/server/scan/groups |
POST/v1/{project_id}/sdg/server/scan/groups |
DELETE/v1/{project_id}/sdg/server/scan/groups/{group_id} |
GET/v1/{project_id}/sdg/server/scan/rules |
dsc:scanRule:list |
POST/v1/{project_id}/sdg/server/scan/rules |
PUT/v1/{project_id}/sdg/server/scan/rules |
DELETE/v1/{project_id}/sdg/server/scan/rules/{rule_id} |
GET/v1/{project_id}/sdg/scan/job/{job_id}/results |
GET/v1/{project_id}/sdg/server/relation/jobs/{job_id}/dbs |
dsc:common:list |
GET/v1/{project_id}/sdg/server/relation/jobs/{job_id}/dbs/{db_id}/tables |
dsc:common:list |
GET/v1/{project_id}/sdg/server/relation/jobs/{job_id}/dbs/{table_id}/columns |
dsc:common:list |
GET/v1/{project_id}/sdg/server/relation/jobs/{job_id}/obs/buckets |
dsc:common:list |
GET/v1/{project_id}/sdg/server/relation/jobs/{job_id}/obs/{bucket_id}/files |
dsc:common:list |
POST/v1/{project_id}/data/mask |
dsc:sensitiveData:mask |
POST/v1/{project_id}/doc-address/watermark/embed |
POST/v1/{project_id}/doc-address/watermark/extract |
POST/v1/{project_id}/image-address/watermark/embed |
POST/v1/{project_id}/image-address/watermark/extract |
POST/v1/{project_id}/image-address/watermark/extract-image |
POST/v1/{project_id}/image/watermark/embed |
POST/v1/{project_id}/image/watermark/extract |
POST/v1/{project_id}/image/watermark/extract-image |
POST/v1/{project_id}/sdg/database/watermark/embed |
POST/v1/{project_id}/sdg/database/watermark/extract |
POST/v1/{project_id}/sdg/doc/watermark/embed |
POST/v1/{project_id}/sdg/doc/watermark/extract |
GET/v1/{project_id}/sdg/asset/{asset_type}/{asset_id}/detail |
dsc:common:list |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP policy statements using that action, and the policy applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the policy applies to all resources. You can also set condition keys in a policy to define resource types.
The following table lists the resource types that you can define in SCP policy statements for DSC.
Resource Type |
URN |
scanTask |
dsc:<region>:<account-id>:scanTask:<task-id> |
scanRule |
dsc:<region>:<account-id>:scanRule:<rule-id> |
scanTemplate |
dsc:<region>:<account-id>:scanTemplate:<template-id> |
maskTask |
dsc:<region>:<account-id>:maskTask:<task-id> |
asset |
dsc:<region>:<account-id>:asset:<asset-id> |
Conditions
DSC does not support service-specific condition keys in SCP policies.
DSC can use global condition keys applicable to all services. For details, see Global Condition Keys.
