Domain Name Service (DNS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This topic describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (such as list, read, or write). This classification helps you understand the level of access that an action grants when you use it in an SCP policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by DNS, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by DNS, see Conditions.
The following table lists the actions that you can define in SCP statements for DNS.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
dns:zone:list |
Grants permission to list the zones. |
list |
zone * |
dns:zone:create |
Grants permission to create a zone. |
write |
zone * |
dns:zone:createBatchPublicZonesByName |
Grants permission to create zones in batches. |
write |
zone * |
g:EnterpriseProjectId |
dns:zone:get |
Grants permission to query a zone. |
read |
zone * |
dns:zone:update |
Grants permission to update a zone. |
write |
zone * |
dns:zone:delete |
Grants permission to delete a zone. |
write |
zone * |
dns:zone:associaterouter |
Grants permission to associate VPCs with a private zone. |
write |
zone * |
dns:zone:disassociaterouter |
Grants permission to disassociate VPCs from a private zone. |
write |
zone * |
dns:zone:setProxyPattern |
Grants permission to set the recursive resolution proxy for a private zone. |
write |
zone * |
dns:zone:transfer |
Grants permission to transfer a public zone. |
write |
zone * |
dns:recordset:list |
Grants permission to list the record sets. |
list |
zone * |
dns:recordset:create |
Grants permission to create a record set. |
write |
zone * |
dns:recordset:get |
Grants permission to query a record set. |
read |
zone * |
dns:recordset:update |
Grants permission to update a record set. |
write |
zone * |
dns:recordset:delete |
Grants permission to delete a record set. |
write |
zone * |
dns:zone:setStatus |
Grants permission to set the zone status. |
write |
zone * |
dns:recordset:setStatus |
Grants permission to set the status of a record set. |
write |
zone * |
dns:ptr:list |
Grants permission to list the PTR records. |
list |
ptr * |
dns:ptr:get |
Grants permission to query a PTR record. |
read |
ptr * |
dns:ptr:create |
Grants permission to create a PTR record. |
write |
ptr * |
dns:ptr:update |
Grants permission to update a PTR record. |
write |
ptr * |
dns:ptr:delete |
Grants permission to delete a PTR record. |
write |
ptr * |
dns:tag:get |
Grants permission to query tags of a zone. |
read |
zone |
dns:tag:get |
read |
ptr |
dns:tag:set |
Grants permission to add a tag to a zone. |
tagging |
zone |
g:ResourceTag/<tag-key> |
dns:tag:set |
tagging |
ptr |
dns:zone:createRetrieval |
Grants permission to retrieve a domain name. |
write |
dns:zone:getRetrieval |
Grants permission to query the domain name retrieval status. |
read |
dns:customLine:create |
Grants permission to create a custom line. |
write |
customLine * |
dns:customLine:list |
Grants permission to list the custom lines. |
list |
customLine * |
dns:customLine:delete |
Grants permission to delete a custom line. |
write |
customLine * |
dns:customLine:update |
Grants permission to update a custom line. |
write |
customLine * |
dns:nameserver:list |
Grants permission to list name servers. |
list |
dns:nameserver:getZoneNameServer |
Grants permission to query DNS servers for public zones. |
read |
dns:quota:list |
Grants permission to list quotas. |
list |
dns:recordset:getPrivateRecordSetImport |
Grants permission to query private zone record set import. |
read |
zone * |
dns:recordset:getPrivateRecordSetImportTemplate |
Grants permission to download the template for importing private zone record sets. |
read |
dns:recordset:createPrivateRecordSetImport |
Grants permission to create a private zone record set import task. |
write |
zone * |
dns:recordset:deletePrivateRecordSetImportTask |
Grants permission to delete a private zone record set import task. |
write |
zone * |
dns:recordset:createPublicRecordSetImport |
Grants permission to create a public zone record set import task. |
write |
zone * |
dns:recordset:getPublicRecordSetImport |
Grants permission to query public zone record set import. |
read |
zone * |
dns:recordset:getPublicRecordSetImportTemplate |
Grants permission to download the template for importing public zone record sets. |
read |
dns:recordset:deletePublicRecordSetImportTask |
Grants permission to delete a public zone record set import task. |
write |
zone * |
dns:zone:getExport |
Grants permission to export zones. |
read |
zone * |
dns:lineGroup:create |
Grants permission to create a line group. |
write |
lineGroup * |
dns:lineGroup:list |
Grants permission to list the line groups. |
list |
lineGroup * |
dns:lineGroup:get |
Grants permission to query a line group. |
read |
lineGroup * |
dns:lineGroup:delete |
Grants permission to delete a line group. |
write |
lineGroup * |
dns:lineGroup:update |
Grants permission to update a line group. |
write |
lineGroup * |
dns:endpoint:create |
Grants permission to create an endpoint. |
write |
endpoint * |
dns:endpoint:list |
Grants permission to list the endpoints. |
list |
endpoint * |
dns:endpoint:get |
Grants permission to query an endpoint. |
read |
endpoint * |
dns:endpoint:update |
Grants permission to update an endpoint. |
write |
endpoint * |
dns:endpoint:delete |
Grants permission to delete an endpoint. |
write |
endpoint * |
dns:endpoint:createIpaddress |
Grants permission to bind an IP address to an endpoint. |
write |
endpoint * |
dns:endpoint:deleteIpaddress |
Grants permission to unbind an IP address from an endpoint. |
write |
endpoint * |
dns:endpoint:listIpaddresses |
Grants permission to list IP addresses bound to an endpoint. |
list |
endpoint * |
dns:endpoint:listVpcs |
Grants permission to list the VPCs associated with an endpoint. |
list |
endpoint * |
dns:resolverRule:create |
Grants permission to create an endpoint rule to route queries originating from your VPC out of the VPC. |
write |
resolverRule * |
dns:resolverRule:list |
Grants permissions to list endpoint rules. |
list |
resolverRule * |
dns:resolverRule:get |
Grants permission to query an endpoint rule. |
read |
resolverRule * |
dns:resolverRule:update |
Grants permissions to update an endpoint rule. |
write |
resolverRule * |
dns:resolverRule:delete |
Grants permissions to delete an endpoint rule. |
write |
resolverRule * |
dns:resolverRule:associaterouter |
Grants permission to associate a VPC with an endpoint rule. |
write |
resolverRule * |
dns:resolverRule:disassociaterouter |
Grants permission to disassociate a VPC from an endpoint rule. |
write |
resolverRule * |
dns:zone:enableDnssecConfig |
Grants permission to enable DNSSEC for a zone. |
write |
zone * |
dns:zone:disableDnssecConfig |
Grants permission to disable DNSSEC for a zone. |
write |
zone * |
dns:zone:getDnssecConfig |
Grants permission to query DNSSEC for a zone. |
read |
zone * |
dns:zone:listPublicZoneBatchOperationRecords |
Grants permission to list batch operation records of public zones. |
list |
dns:zone:getPublicZoneBatchOperationResult |
Grants permission to download failed batch operations on public zones. |
read |
dns:recordset:batchImportPublicRecordSet |
Grants permission to import public zone record sets in batches. |
write |
dns:zone:createAuthorizeTxtRecord |
Grant permissions to authorize a domain name. |
write |
dns:zone:getAuthorizeTxtRecord |
Grants permission to query the authorization status of a domain name. |
read |
dns:zone:getDomainDetection |
Grants permission to query public domain name resolution diagnosis results. |
read |
zone * |
Each API of DNS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v2/zones |
dns:zone:list |
POST /v2/zones |
dns:zone:create |
GET /v2/zones/{zone_id} |
dns:zone:get |
PATCH /v2/zones/{zone_id} |
dns:zone:update |
DELETE /v2/zones/{zone_id} |
dns:zone:delete |
GET /v2/zones/{zone_id}/nameservers |
dns:zone:get |
GET /v2/zones |
dns:zone:list |
POST /v2/zones |
dns:zone:create |
dns:zone:get |
dns:zone:update |
dns:zone:delete |
dns:zone:get |
POST /v2/zones/{zone_id}/associaterouter |
vpc:vpcs:get |
POST /v2/zones/{zone_id}/disassociaterouter |
vpc:vpcs:get |
GET /v2/zones/{zone_id}/recordsets |
POST /v2/zones/{zone_id}/recordsets |
dns:quota:list |
GET /v2/zones/{zone_id}/recordsets/{recordset_id} |
dns:recordset:get |
PUT /v2/zones/{zone_id}/recordsets/{recordset_id} |
DELETE /v2/zones/{zone_id}/recordsets/{recordset_id} |
GET /v2/recordsets |
PUT /v2/zones/{zone_id}/statuses |
GET /v2.1/recordsets |
POST /v2.1/zones/{zone_id}/recordsets |
dns:quota:list |
GET /v2.1/zones/{zone_id}/recordsets |
GET /v2.1/zones/{zone_id}/recordsets/{recordset_id} |
dns:recordset:get |
PUT /v2.1/zones/{zone_id}/recordsets/{recordset_id} |
DELETE /v2.1/zones/{zone_id}/recordsets/{recordset_id} |
PUT /v2.1/recordsets/{recordset_id}/statuses/set |
POST /v2.1/zones/{zone_id}/recordsets/batch/lines |
dns:quota:list |
PUT /v2.1/zones/{zone_id}/recordsets |
DELETE /v2.1/zones/{zone_id}/recordsets |
GET /v2/reverse/floatingips |
dns:ptr:list |
GET /v2/reverse/floatingips/{region}:{floatingip_id} |
dns:ptr:get |
PATCH /v2/reverse/floatingips/{region}:{floatingip_id} |
dns:ptr:create |
dns:ptr:update |
dns:ptr:delete |
GET /v2/{project_id}/{resource_type}/tags |
dns:tag:get |
GET /v2/{project_id}/{resource_type}/{resource_id}/tags |
dns:tag:get |
POST /v2/{project_id}/{resource_type}/{resource_id}/tags |
dns:tag:set |
DELETE /v2/{project_id}/{resource_type}/{resource_id}/tags/{key} |
dns:tag:set |
POST /v2/{project_id}/{resource_type}/{resource_id}/tags/action |
dns:tag:set |
POST /v2/{project_id}/{resource_type}/resource_instances/action |
dns:tag:get |
POST /v2.1/customlines |
dns:quota:list |
GET /v2.1/customlines |
DELETE /v2.1/customlines/{line_id} |
PUT /v2.1/customlines/{line_id} |
GET /v2/nameservers |
GET /v2/quotamg/dns/quotas |
dns:quota:list |
POST /v2.1/linegroups |
dns:quota:list |
GET /v2.1/linegroups |
GET /v2.1/linegroups/{linegroup_id} |
dns:lineGroup:get |
PUT /v2.1/linegroups/{linegroup_id} |
DELETE /v2.1/linegroups/{linegroup_id} |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for DNS.
Resource Type |
URN |
resolverRule |
dns:<region>:<account-id>:resolverRule:<resolver-rule-id> |
lineGroup |
dns::<account-id>:lineGroup:<line-group-id> |
customLine |
dns::<account-id>:customLine:<custom-line-id> |
zone |
dns::<account-id>:zone:<zone-id> |
endpoint |
dns:<region>:<account-id>:endpoint:<endpoint-id> |
ptr |
dns:<region>:<account-id>:ptr:<ptr-id> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- A key in the Condition element of a statement Condition keys are classified into global condition keys and service-specific condition keys based on the application scope.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, dns:) only apply to operations of the DNS service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for DNS. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
dns:RecordSetNames |
string |
Multivalued |
Filters access by record set name. All letters in the record set name must be lowercase and cannot contain a period at the end. |
dns:RecordSetTypes |
string |
Multivalued |
Filters access by record set type. The value can be A, AAAA, MX, CNAME, TXT, NS, CAA, or SRV. |
