Cloud Native Anti-DDoS Basic (Anti-DDoS)
The Service Control Policies (SCPs) in the Organizations service can use these authorization elements to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permission boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in a policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP policy statements.
- If this column includes a resource type, you must specify a URN for the Resource element in your identity policy statements.
- Required resources are marked with asterisks (*) in the table.
For details about resource types defined by Anti-DDoS, see Resources.
- The Condition Key column includes keys that you can specify in the Condition element of a SCP policy statement.
- If the Resource Type column has values for an action, the condition key only takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about condition keys defined by Anti-DDoS, see Conditions.
The following table lists the actions that you can define in SCP statements for Anti-DDoS.
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
anti-ddos:task:list |
Grant permission to query Anti-DDoS tasks. |
list |
anti-ddos:quota:list |
Grant permission to query quotas. |
list |
anti-ddos:optionalDefensePolicy:list |
Grant permission to query Anti-DDoS protection specifications. |
list |
anti-ddos:logConfig:update |
Grant permission to update LTS configurations. |
write |
anti-ddos:logConfig:get |
Grant permission to query LTS configurations. |
read |
anti-ddos:ip:updateDefensePolicy |
Grant permission to update Anti-DDoS. |
write |
ip * |
anti-ddos:ip:untagResource |
Grant permission to delete tags in batches. |
write |
ip * |
anti-ddos:ip:tagResource |
Grant permission to add tags in batches. |
write |
ip * |
anti-ddos:ip:listTagsForResource |
Grant permission to query resource tags. |
list |
ip * |
anti-ddos:ip:listDefenseStatuses |
Grant permission to query EIP protection statuses. |
list |
ip * |
anti-ddos:ip:getWeeklyReport |
Grant permission to query weekly protection statistics. |
read |
ip * |
anti-ddos:ip:getDefenseStatus |
Grant permission to query the protection status of an EIP. |
read |
ip * |
anti-ddos:ip:getDefensePolicy |
Grant permission to query Anti-DDoS. |
read |
ip * |
anti-ddos:ip:getDailyTrafficReport |
Grant permission to query protected traffic of an EIP. |
read |
ip * |
anti-ddos:ip:getDailyEventReport |
Grant permission to query abnormal events of an EIP. |
read |
ip * |
anti-ddos:ip:enableDefensePolicy |
Grant permission to enable Anti-DDoS. |
write |
ip * |
anti-ddos:defaultDefensePolicy:get |
Grant permission to query default Anti-DDoS protection policies. |
read |
anti-ddos:defaultDefensePolicy:delete |
Grant permission to delete default Anti-DDoS protection policies. |
write |
anti-ddos:defaultDefensePolicy:create |
Grant permission to configure default Anti-DDoS protection policies. |
write |
anti-ddos:alertConfig:update |
Grant permission to update alarm configurations. |
write |
anti-ddos:alertConfig:get |
Grant permission to query alarm configurations. |
read |
An Anti-DDoS API usually corresponds to one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependency |
GET /v1/{project_id}/query-task-status |
GET /v1/{project_id}/antiddos/quotas |
GET /v1/{project_id}/antiddos/query-config-list |
PUT /v1/{project_id}/antiddos/lts-config |
GET /v1/{project_id}/antiddos/lts-config |
PUT /v1/{project_id}/antiddos/{floating_ip_id} |
DELETE /v1/{project_id}/antiddos-ip/{resource_id}/tags/delete |
POST /v1/{project_id}/antiddos-ip/{resource_id}/tags/create |
GET /v1/{project_id}/antiddos-ip/{resource_id}/tags |
GET /v1/{project_id}/antiddos-ip/tags |
GET /v1/{project_id}/antiddos |
POST /v1/{project_id}/antiddos-ip/resource-instances/count |
POST /v1/{project_id}/antiddos-ip/resource-instances/filter |
GET /v1/{project_id}/antiddos/weekly |
GET /v1/{project_id}/antiddos/weekly-export |
GET /v1/{project_id}/antiddos/{floating_ip_id}/status |
GET /v1/{project_id}/antiddos/{floating_ip_id} |
GET /v1/{project_id}/antiddos/queryIsEnabledResult/query |
GET /v1/{project_id}/antiddos/{floating_ip_id}/daily |
GET /v1/{project_id}/antiddos/{floating_ip_id}/daily-export |
GET /v1/{project_id}/antiddos/{floating_ip_id}/logs |
POST /v1/{project_id}/antiddos/{floating_ip_id} |
GET /v1/{project_id}/antiddos/immediate_protection |
DELETE /v1/{project_id}/antiddos/{floating_ip_id} |
anti-ddos:ip:disableDefensePolicy |
GET /v1/{project_id}/antiddos/{floating_ip_id}/closeAndReason |
GET /v1/{project_id}/antiddos/default/config |
DELETE /v1/{project_id}/antiddos/default/config |
POST /v1/{project_id}/antiddos/default/config |
POST /v2/{project_id}/warnalert/alertconfig/update |
GET /v2/{project_id}/warnalert/alertconfig/query |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP policy statements using that action, and the policy applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the policy applies to all resources. You can also set condition keys in a policy to define resource types.
The following table lists the resource types that you can define in SCP policy statements for Anti-DDoS.
Conditions
Anti-DDoS does not support service-specific condition keys in SCP policies.
Anti-DDoS can use global condition keys applicable to all services. For details, see Global Condition Keys.
