Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to edit a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by CodeArts Pipeline, see Resources.
  • The Condition Key column includes keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column of an action is empty (-), the condition key takes effect for all resources.
    • If this column does not have any values (-), the action does not support any condition keys.
    For details about the condition keys defined by CodeArts Pipeline, see Condition.
The following table lists the actions that you can define in SCP statements for CodeArts Pipeline.
Table 1 Actions supported by CodeArts Pipeline
Item
Access Level
Resource Type (*: required)
Condition Key
codeartspipeline:pipelinetemplate:create
Grants permission to create pipeline templates.
write
codeartspipeline:pipelinetemplate:update
Grants permission to update pipeline templates.
write
codeartspipeline:pipelinetemplate:delete
Grants permission to delete pipeline templates.
write
codeartspipeline:pipelinetemplate:get
Grants permission to view pipeline templates.
read
codeartspipeline:pipelinetemplate:list
Grants permission to view the pipeline template list.
list
codeartspipeline:rule:create
Grants permission to create rules.
write
codeartspipeline:rule:update
Grants permission to update rules.
write
codeartspipeline:rule:delete
Grants permission to delete rules.
write
codeartspipeline:rule:get
Grants permission to view rules.
read
codeartspipeline:rule:list
Grants permission to view the rule list.
list
codeartspipeline:strategy:create
Grants permission to create policies.
write
codeartspipeline:strategy:update
Grants permission to update policies.
write
codeartspipeline:strategy:delete
Grants permission to delete policies.
write
codeartspipeline:strategy:get
Grants permission to view policies.
read
codeartspipeline:strategy:list
Grants permission to query the policy list.
list
codeartspipeline:extension:create
Grants permission to create extensions.
write
codeartspipeline:extension:update
Grants permission to update extensions.
write
codeartspipeline:extension:delete
Grants permission to delete extensions.
write
codeartspipeline:extension:get
Grants permission to view extensions.
read
codeartspipeline:extension:list
Grants permission to view the extension list.
list
Each API of CodeArts Pipeline usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies of CodeArts Pipeline APIs
API
Action
Dependency
POST /v5/{tenant_id}/api/pipeline-templates
PUT /v5/{tenant_id}/api/pipeline-templates/{template_id}
DELETE /v5/{tenant_id}/api/pipeline-templates/{template_id}
GET /v5/{tenant_id}/api/pipeline-templates/{template_id}
POST /v5/{tenant_id}/api/pipeline-templates/list
POST /v2/{domain_id}/rules/create
PUT /v2/{domain_id}/rules/{rule_id}/update
DELETE /v2/{domain_id}/rules/{rule_id}/delete
GET /v2/{domain_id}/rules/{rule_id}/detail
GET /v2/{domain_id}/rules/query
POST /v2/{domain_id}/tenant/rule-sets/create
PUT /v2/{domain_id}/tenant/rule-sets/{rule_set_id}/update
DELETE /v2/{domain_id}/tenant/rule-sets/{rule_set_id}/delete
GET /v2/{domain_id}/tenant/rule-sets/{rule_set_id}/detail
GET /v2/{project_id}/rule-sets/{rule_set_id}/gray/detail
GET /v2/{domain_id}/tenant/rule-sets/query
GET /v2/{project_id}/rule-sets/query
PUT /v2/{domain_id}/tenant/rule-sets/{rule_set_id}/switch
POST /v1/{domain_id}/agent-plugin/create
POST /v1/{domain_id}/agent-plugin/create-draft
POST /v1/{domain_id}/publisher/create
POST /v1/{domain_id}/agent-plugin/edit-draft
POST /v1/{domain_id}/agent-plugin/publish-draft
POST /v1/{domain_id}/agent-plugin/update-info
POST /v1/{domain_id}/agent-plugin/publish-plugin-bind
POST /v1/{domain_id}/common/upload-plugin-icon
POST /v1/{domain_id}/common/upload-publisher-icon
DELETE /v1/{domain_id}/agent-plugin/delete-draft
GET /v1/{domain_id}/publisher/query-all
GET /v1/{domain_id}/publisher/optional-publisher
POST /v1/{domain_id}/relation/stage-plugins
GET /v1/{domain_id}/relation/plugin/single
POST /v1/{domain_id}/agent-plugin/query-all
POST /v1/{domain_id}/agent-plugin/plugin-metrics
POST /v1/{domain_id}/agent-plugin/plugin-input
POST /v1/{domain_id}/agent-plugin/plugin-output
GET /v1/{domain_id}/agent-plugin/query
GET /v1/{domain_id}/agent-plugin/detail
GET /v1/{domain_id}/agent-plugin/all-version
DELETE /v1/{domain_id}/publisher/delete
POST /v1/{domain_id}/publisher/detail
POST /v3/{domain_id}/extension/info/add
POST /v3/{domain_id}/extension/info/update
DELETE /v3/{domain_id}/extension/info/delete
POST /v3/{domain_id}/extension/upload
GET /v3/{domain_id}/extension/detail
POST /v1/{domain_id}/relation/plugins
Resources
CodeArts Pipeline does not support resource-level authorization. To allow access to CodeArts Pipeline, use a wildcard (*) in the Resource element of the SCP, indicating that the SCP will be applied to all resources.
Condition
CodeArts Pipeline does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Conditions Keys.
