Cloud Firewall (CFW)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to an organizational unit (OU) or a member account, the SCPs do not directly grant permissions to that OU or member account. Instead, the SCPs only determine what permissions are available for that member account or those member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to edit a custom SCP policy, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of an SCP statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CFW, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by CFW, see Conditions.
The following table lists the actions that you can define in SCP statements for CFW
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cfw:acl:createAclRule |
Grants permission to create an acl rule. |
write |
instance * |
cfw:acl:deleteAclRule |
Grants permission to delete an acl rule. |
write |
acl * |
instance * |
cfw:acl:deleteHitCount |
Grants permission to delete acl rule hit count. |
write |
acl * |
instance * |
cfw:instance:listDomainParseServers |
Grants permission to get domain parse server. |
list |
instance * |
cfw:instance:getDomainParseResult |
Grants permission to parse domain. |
read |
instance * |
cfw:acl:getExportStatus |
Grants permission to get acl export status. |
read |
instance * |
cfw:acl:getImportStatus |
Grants permission to get acl import status. |
read |
instance * |
cfw:acl:getImportTemplate |
Grants permission to get acl import template. |
read |
instance * |
cfw:acl:listAclRules |
Grants permission to list acl rules. |
list |
instance * |
cfw:acl:listAclTags |
Grants permission to list acl rule tags. |
list |
instance * |
cfw:acl:updateAclRule |
Grants permission to update acl rule. |
write |
acl * |
instance * |
cfw:acl:updateAclRuleAction |
Grants permission to update acl rule action. |
write |
acl * |
instance * |
cfw:instance:updateDomainParseServer |
Grants permission to update domain parse server. |
write |
instance * |
cfw:acl:setPriority |
Grants permission to set acl rule priority. |
write |
acl * |
instance * |
cfw:blackWhiteList:create |
Grants permission to create blackwhite list. |
write |
instance * |
cfw:blackWhiteList:delete |
Grants permission to delete blackwhite list. |
write |
blackWhiteList * |
instance * |
cfw:blackWhiteList:list |
Grants permission to list blackwhite lists. |
list |
instance * |
cfw:blackWhiteList:update |
Grants permission to update blackwhite list. |
write |
blackWhiteList * |
instance * |
cfw:domainGroup:update |
Grants permission to update domainGroup. |
write |
domainGroup * |
instance * |
cfw:domainGroup:create |
Grants permission to create domainGroup. |
write |
instance * |
cfw:domainGroup:delete |
Grants permission to delete domainGroup. |
write |
domainGroup * |
instance * |
cfw:domainGroup:list |
Grants permission to list domainGroup. |
list |
instance * |
cfw:eip:count |
Grants permission to get eip statistics. |
read |
instance * |
cfw:eip:list |
Grants permission to list eip. |
list |
instance * |
g:ResourceTag/<tag-key> |
cfw:eip:updateProtectStatus |
Grants permission to change eip protect status. |
write |
eip * |
g:EnterpriseProjectId |
cfw:instance:checkNameRepeat |
Grants permission to check if cfw name repeat. |
read |
cfw:instance:listAdvanceIpsRules |
Grants permission to list cfw advance ips rules. |
list |
instance * |
cfw:instance:listUsedEr |
Grants permission to list used er. |
list |
cfw:instance:listUsedInspectionVpc |
Grants permission to list used vpc. |
list |
cfw:instance:addLogConfig |
Grants permission to add CFW log config. |
write |
instance * |
cfw:LogGroupId |
cfw:instance:updateCustomRule |
Grants permission to update CFW custom ips rule. |
write |
instance * |
cfw:instance:updateCustomRuleAction |
Grants permission to update CFW custom ips rule action. |
write |
instance * |
cfw:instance:updateLogConfig |
Grants permission to update CFW LTS log config. |
write |
instance * |
cfw:LogGroupId |
cfw:instance:createInstance |
Grants permission to create an CFW instance. |
write |
instance * |
cfw:instance:deletePostPaidInstance |
Grants permission to delete post paid CFW instance. |
write |
instance * |
cfw:instance:createCaptureTask |
Grants permission to create CFW capture task. |
write |
instance * |
cfw:instance:createCustomRule |
Grants permission to create CFW custom rule. |
write |
instance * |
cfw:instance:createTags |
Grants permission to create CFW tags. |
tagging |
instance * |
cfw:instance:deleteInstance |
Grants permission to delete CFW instance. |
write |
instance * |
cfw:instance:deleteCaptureTask |
Grants permission to delete CFW capture task. |
write |
instance * |
cfw:instance:deleteCustomRule |
Grants permission to delete CFW custom ips rule. |
write |
instance * |
cfw:instance:deleteLogSearchHistory |
Grants permission to delete CFW log search history. |
write |
instance * |
cfw:instance:deleteTags |
Grants permission to delete CFW tags. |
tagging |
instance * |
g:TagKeys |
cfw:instance:exportLog |
Grants permission to export log. |
read |
instance * |
cfw:instance:listInstanceByTags |
Grants permission to list cfw by tags. |
list |
instance * |
g:TagKeys |
cfw:instance:getBaseVersion |
Grants permission to get cfw base version. |
read |
instance * |
cfw:instance:getCaptureTaskResult |
Grants permission to get cfw capture task result. |
read |
instance * |
cfw:instance:getCustomRule |
Grants permission to get cfw custom rule. |
read |
instance * |
cfw:instance:getDomainParseServerStatus |
Grants permission to get cfw domain parse server status. |
read |
instance * |
cfw:instance:getIpsMode |
Grants permission to get cfw ips mode. |
read |
instance * |
cfw:instance:getIpsStatus |
Grants permission to get cfw ips status. |
read |
instance * |
cfw:instance:getLogConfig |
Grants permission to get cfw log config. |
read |
instance * |
cfw:instance:getMaxCapturePacketNum |
Grants permission to get cfw user max capture packet number. |
read |
cfw:instance:getPolicyStatistics |
Grants permission to get cfw policy statistics. |
read |
instance * |
cfw:instance:listProjectTags |
Grants permission to list project tags. |
list |
cfw:instance:getRegionDb |
Grants permission to get cfw region db. |
read |
instance * |
cfw:instance:listInstanceTags |
Grants permission to list cfw tags. |
list |
instance * |
cfw:instance:listInstance |
Grants permission to list CFW instances. |
list |
instance * |
cfw:instance:getInstance |
Grants permission to get CFW instances detail. |
read |
instance * |
cfw:instance:listAccessControlLog |
Grants permission to list CFW access control log. |
list |
instance * |
cfw:instance:listAttackLog |
Grants permission to list CFW attack log. |
list |
instance * |
cfw:instance:listCaptureTask |
Grants permission to list CFW capture tasks. |
list |
instance * |
cfw:instance:listCustomRule |
Grants permission to list CFW custom ips rule. |
list |
instance * |
cfw:instance:getEw |
Grants permission to get cfw east-west firewall. |
read |
instance * |
cfw:instance:listFlowLog |
Grants permission to list cfw flow log. |
list |
instance * |
cfw:instance:listIpsRule |
Grants permission to list cfw ips rules. |
list |
instance * |
cfw:instance:listProtectedVpc |
Grants permission to list cfw protect vpcs. |
list |
instance * |
cfw:instance:updateIpsMode |
Grants permission to update cfw ips mode. |
write |
instance * |
cfw:instance:updateAdvanceIpsRule |
Grants permission to update cfw advance ips rule. |
write |
instance * |
cfw:instance:updateIpsRuleAction |
Grants permission to update cfw ips rule mode. |
write |
instance * |
cfw:instance:updateIpsStatus |
Grants permission to update cfw ips status. |
write |
instance * |
cfw:instance:updateEwProtectedStatus |
Grants permission to update cfw east-west firewall protect status. |
write |
instance * |
cfw:instance:saveTags |
Grants permission to save cfw tags. |
tagging |
instance * |
cfw:instance:startBaseVersion |
Grants permission to start cfw base version. |
write |
instance * |
cfw:instance:stopBaseVersion |
Grants permission to stop cfw base version. |
write |
instance * |
cfw:instance:stopCaptureTask |
Grants permission to stop cfw capture task. |
write |
instance * |
cfw:instance:updateAlarmConfig |
Grants permission to update cfw alarm config. |
write |
instance * |
cfw:instance:getAlarmConfig |
Grants permission to get cfw alarm config. |
read |
instance * |
cfw:instance:upgradeInstance |
Grants permission to upgrade cfw. |
write |
instance * |
cfw:instance:updateName |
Grants permission to update cfw name. |
write |
instance * |
cfw:instance:getAccessControlLogStatistics |
Grants permission to get cfw access control log statistics. |
read |
instance * |
cfw:instance:getAttackLogStatistics |
Grants permission to get cfw attack log statistics. |
read |
instance * |
cfw:instance:getLogSearchHistory |
Grants permission to get cfw log search history. |
read |
instance * |
cfw:instance:getEngineLogStatistics |
Grants permission to get cfw engine log statistics. |
read |
instance * |
cfw:instance:getFlowLogStatistics |
Grants permission to get cfw flow log statistics. |
read |
instance * |
cfw:instance:getIpLogStatistics |
Grants permission to get cfw ip log statistics. |
read |
instance * |
cfw:ipGroup:updateIpGroupMember |
Grants permission to update cfw ip group member. |
write |
ipGroup * |
instance * |
cfw:ipGroup:createIpGroup |
Grants permission to change cfw ip group member. |
write |
instance * |
cfw:ipGroup:createIpGroupMember |
Grants permission to create cfw ip group member. |
write |
ipGroup * |
instance * |
cfw:ipGroup:deleteIpGroup |
Grants permission to delete cfw ip group. |
write |
ipGroup * |
instance * |
cfw:ipGroup:deleteIpGroupMember |
Grants permission to delete cfw ip group member. |
write |
ipGroup * |
instance * |
cfw:ipGroup:getIpGroup |
Grants permission to get cfw ip group. |
read |
ipGroup * |
instance * |
cfw:ipGroup:listIpGroups |
Grants permission to list cfw ip groups. |
list |
instance * |
cfw:ipGroup:listIpGroupMember |
Grants permission to list cfw ip group members. |
list |
ipGroup * |
instance * |
cfw:ipGroup:updateIpGroup |
Grants permission to update cfw ip group. |
write |
ipGroup * |
instance * |
cfw:serviceGroup:updateServiceGroupMember |
Grants permission to update cfw service group member. |
write |
serviceGroup * |
instance * |
cfw:serviceGroup:create |
Grants permission to create cfw service group member. |
write |
instance * |
cfw:serviceGroup:createServiceGroupMember |
write |
serviceGroup * |
instance * |
cfw:serviceGroup:delete |
Grants permission to delete cfw service group. |
write |
serviceGroup * |
instance * |
cfw:serviceGroup:deleteServiceGroupMember |
Grants permission to delete cfw service group member. |
write |
serviceGroup * |
instance * |
cfw:serviceGroup:get |
Grants permission to get cfw service group. |
read |
serviceGroup * |
instance * |
cfw:serviceGroup:list |
Grants permission to list cfw service groups. |
list |
instance * |
cfw:serviceGroup:listServiceGroupMember |
Grants permission to list cfw service group members. |
list |
serviceGroup * |
instance * |
cfw:serviceGroup:update |
Grants permission to update cfw service group. |
write |
serviceGroup * |
instance * |
cfw:instance:enableMultiAccount |
Grants permission to enable multi account. |
write |
instance * |
cfw:instance:listAccounts |
Grants permission to list accounts. |
list |
instance * |
cfw:instance:listOrganizationTree |
Grants permission to list organization tree. |
list |
instance * |
cfw:instance:addAccount |
Grants permission to add account. |
write |
instance * |
cfw:instance:deleteAccount |
Grants permission to delete account. |
write |
instance * |
cfw:instance:getProtectedVpc |
Grants permission to get protected vpc. |
read |
instance * |
cfw:instance:deleteProtectedVpc |
Grants permission to delete protected vpc. |
write |
instance * |
cfw:instance:addProtectedVpc |
Grants permission to add protected vpc. |
write |
instance * |
cfw:instance:updateProtectedVpc |
Grants permission to update protected vpc. |
write |
instance * |
cfw:instance:updateAntiVirusStatus |
Grants permission to update cfw anti virus status. |
write |
instance * |
cfw:instance:getAntiVirusStatus |
Grants permission to get cfw anti virus status. |
read |
instance * |
cfw:instance:updateAntiVirusRule |
Grants permission to update cfw anti virus rule. |
write |
instance * |
cfw:instance:getAntiVirusRule |
Grants permission to get cfw anti virus rule. |
read |
instance * |
cfw:instance:listReportProfile |
Grants permission to list cfw report profile rules. |
list |
instance * |
cfw:instance:createReportProfile |
Grants permission to create cfw report profile rule. |
write |
instance * |
cfw:instance:updateReportProfile |
Grants permission to update cfw report profile rule. |
write |
instance * |
cfw:instance:getReportProfile |
Grants permission to show cfw report profile rule. |
read |
instance * |
cfw:instance:deleteReportProfile |
Grants permission to delete cfw report profile rule. |
write |
instance * |
Each API of CFW usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v1/{project_id}/cfw/logs/flow |
GET /v1/{project_id}/cfw/logs/access-control |
GET /v1/{project_id}/cfw/logs/attack |
PUT /v1/{project_id}/cfw/logs/configuration |
POST /v1/{project_id}/firewall/east-west |
DELETE /v2/{project_id}/firewall/{resource_id} |
GET /v1/{project_id}/firewall/east-west |
POST /v2/{project_id}/cfw-cfw/{fw_instance_id}/tags/create |
DELETE /v2/{project_id}/cfw-cfw/{fw_instance_id}/tags/delete |
GET /v1/{project_id}/capture-task |
POST /v1/{project_id}/capture-task |
POST /v1/{project_id}/capture-task/stop |
POST /v1/{project_id}/capture-task/batch-delete |
GET /v1/{project_id}/capture-task/capture-result |
GET /v1/{project_id}/dns/servers |
PUT /v1/{project_id}/dns/servers |
PUT /v1/{project_id}/domain-set/{set_id} |
DELETE /v1/{project_id}/domain-set/{set_id} |
GET /v1/{project_id}/domain-sets |
DELETE /v1/{project_id}/address-items |
GET /v1/{project_id}/address-sets/{set_id} |
GET /v1/{project_id}/address-items |
GET /v1/{project_id}/address-sets |
DELETE /v1/{project_id}/domain-set/domains/{set_id} |
GET /v1/{project_id}/service-items |
DELETE /v1/{project_id}/service-items/{item_id} |
POST /v1/{project_id}/black-white-list |
DELETE /v1/{project_id}/service-sets/{set_id} |
POST /v1/{project_id}/firewalls/list |
PUT /v1/{project_id}/service-sets/{set_id} |
POST /v1/{project_id}/eip/protect |
POST /v1/{project_id}/domain-set |
GET /v1/{project_id}/firewall/exist |
DELETE /v1/{project_id}/acl-rule |
GET /v1/{project_id}/domain/parse/{domain_name} |
POST /v1/{project_id}/acl-rule/count |
DELETE /v1/{project_id}/address-sets/{set_id} |
POST /v1/{project_id}/firewall/east-west/protect |
POST /v1/{project_id}/domain-set/domains/{set_id} |
GET /v1/{project_id}/service-sets |
GET /v2/{project_id}/cfw-acl/tags |
POST /v1/{project_id}/service-set |
DELETE /v1/{project_id}/service-items |
POST /v1/{project_id}/ips/switch |
POST /v1/{project_id}/ips/protect |
GET /v1/{project_id}/service-sets/{set_id} |
DELETE /v1/{project_id}/acl-rule/count |
PUT /v1/{project_id}/address-sets/{set_id} |
DELETE /v1/{project_id}/acl-rule/{acl_rule_id} |
PUT /v1/{project_id}/acl-rule/action |
POST /v1/{project_id}/address-set |
PUT /v1/{project_id}/black-white-list/{list_id} |
DELETE /v1/{project_id}/address-items/{item_id} |
GET /v1/{project_id}/ips/switch |
PUT /v1/{project_id}/acl-rule/{acl_rule_id} |
GET /v1/{project_id}/vpcs/protection |
GET /v1/{project_id}/eip-count/{object_id} |
cfw:eip:count |
GET /v1/{project_id}/black-white-lists |
GET /v1/{project_id}/eips/protect |
cfw:eip:list |
DELETE /v1/{project_id}/black-white-list/{list_id} |
GET /v1/{project_id}/acl-rules |
GET /v1/{project_id}/domain-set/domains/{set_id} |
POST /v1/{project_id}/acl-rule |
PUT /v1/{project_id}/acl-rule/order/{acl_rule_id} |
POST /v1/{project_id}/address-items |
GET /v1/{project_id}/ips/protect |
POST /v1/{project_id}/service-items |
GET /v1/{project_id}/cfw/logs/configuration |
POST /v1/{project_id}/cfw/logs/configuration |
POST /v2/{project_id}/firewall |
GET /v3/{project_id}/jobs/{job_id} |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for CFW.
Resource Type |
URN |
blackWhiteList |
cfw:<region>:<account-id>:blackWhiteList:<blackWhiteList-id> |
acl |
cfw:<region>:<account-id>:acl:<acl-id> |
instance |
cfw:<region>:<account-id>:instance:<fwInstance-id> |
serviceGroup |
cfw:<region>:<account-id>:serviceGroup:<serviceGroup-id> |
domainGroup |
cfw:<region>:<account-id>:domainGroup:<domainGroup-id> |
ipGroup |
cfw:<region>:<account-id>:ipGroup:<ipGroup-id> |
eip |
cfw:<region>:<account-id>:eip:<eip-id> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, cfw) apply only to operations of the xx service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCP for CFW. You can include these condition keys to specify conditions for when your SCP is in effect.
