Data Lake Insight (DLI)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
- For how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by DLI, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by DLI, see Conditions.
The following table lists the actions that you can define in custom SCP statements for DLI.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
dli::operateAuth |
Grants the permission to manage DLI permissions. |
permission_management |
dli::listAuth |
Grants the permission to query DLI permissions. |
list |
dli:variable:list |
Grants the permission to list global variables. |
list |
variable * |
dli:variable:create |
Grants the permission to create global variables. |
write |
variable * |
dli:variable:update |
Grants the permission to update global variables. |
write |
variable * |
dli:variable:delete |
Grants the permission to delete global variables. |
write |
variable * |
dli:catalog:list |
Grants the permission to list data catalogs. |
list |
dli:catalog:bind |
Grants the permission to bind data catalogs. |
write |
dli:catalog:get |
Grants the permission to query data catalog details. |
read |
dli:queue:list |
Grants the permission to list queues. |
list |
queue * |
dli:queue:create |
Grants the permission to create queues. |
write |
queue * |
dli:queue:get |
Grants the permission to query queue details. |
read |
queue * |
dli:queue:update |
Grants the permission to update queues. |
write |
queue * |
dli:queue:delete |
Grants the permission to delete queues. |
write |
queue * |
dli:queue:scale |
Grants the permission to scale out/in a queue. |
write |
queue * |
dli:queue:checkConnection |
Grants the permission to test the connectivity of an address. |
write |
queue * |
dli:queue:getConnection |
Grants the permission to query connectivity results. |
read |
queue * |
dli:queue:listPlans |
Grants the permission to list scheduled scaling plans of a queue. |
list |
queue * |
dli:queue:createPlan |
Grants the permission to create scheduled scaling plans for a queue. |
write |
queue * |
dli:queue:deletePlan |
Grants the permission to delete scheduled scaling plans from a queue. |
write |
queue * |
dli:queue:updatePlan |
Grants the permission to update scheduled scaling plans for a queue. |
write |
queue * |
dli:queue:createProperty |
Grants the permission to create configurations for a queue. |
write |
queue * |
dli:queue:listProperties |
Grants the permission to list queue configurations. |
list |
queue * |
dli:queue:updateProperty |
Grants the permission to update configurations for a queue. |
write |
queue * |
dli:queue:deleteProperty |
Grants the permission to delete configurations from a queue. |
write |
queue * |
dli:jobs:list |
Grants the permission to list jobs. |
list |
jobs * |
dli:queue:submitJob |
Grants the permission to submit jobs on a queue. |
write |
queue * |
dli:jobs:get |
Grants the permission to query job details. |
read |
jobs * |
g:ResourceTag/<tag-key> |
dli:table:select |
Grants the permission to query tables. |
read |
table * |
dli:table:insertInto |
Grants the permission to insert table data. |
write |
table * |
dli:queue:cancelJob |
Grants the permission to cancel jobs on a queue. |
write |
queue * |
dli:jobs:exportResult |
Grants the permission to export job results. |
read |
jobs * |
dli::checkSql |
Grants the permission to verify the SQL syntax. |
write |
dli:database:list |
Grants the permission to list databases. |
list |
database * |
dli:database:create |
Grants the permission to create databases. |
write |
database * |
dli:database:update |
Grants the permission to update databases. |
write |
database * |
dli:database:delete |
Grants the permission to delete databases. |
write |
database * |
dli:database:displayAllTables |
Grant the permission to display all tables in a database. |
list |
database * |
dli:database:createTable |
Grants the permission to create tables in a database. |
write |
database * |
dli:table:update |
Grants the permission to update tables. |
write |
table * |
dli:table:describe |
Grants the permission to display the table structure. |
read |
table * |
dli:table:delete |
Grants the permission to delete tables. |
write |
table * |
dli:table:showPartitions |
Grants the permission to display all partitions of a table. |
read |
table * |
dli:sqldefendrule:create |
Grants the permission to create SQL inspection rules. |
write |
dli:sqldefendrule:list |
Grants the permission to list SQL inspection rules. |
list |
dli:sqldefendrule:update |
Grants the permission to update SQL inspection rules. |
write |
dli:sqldefendrule:delete |
Grants the permission to delete SQL inspection rules. |
write |
dli:sqldefendrule:get |
Grants the permission to query details about SQL inspection rules. |
read |
dli:resource:create |
Grants the permission to create resource packages. |
write |
resource * |
dli:resource:get |
Grants the permission to query resource package details. |
read |
resource * |
dli:resource:delete |
Grants the permission to delete resource packages. |
write |
resource * |
dli:resource:list |
Grants the permission to list resource packages. |
list |
resource * |
dli:resource:update |
Grants the permission to update resource packages. |
write |
resource * |
dli:jobs:update |
Grants the permission to update jobs. |
write |
jobs * |
dli:jobs:delete |
Grants the permission to delete jobs. |
write |
jobs * |
dli:jobs:create |
Grants the permission to create jobs. |
write |
jobs * |
dli:jobs:startFlinkJob |
Grants the permission to start a job. |
write |
jobs * |
dli:jobs:stopFlinkJob |
Grants the permission to stop a job. |
write |
jobs * |
dli:jobs:export |
Grants the permission to export jobs. |
write |
jobs * |
dli::createEdgeChannel |
Grants the permission to create IEF message channels. |
write |
dli::reportEdgeJob |
Grants the permission to report statuses of Flink edge jobs. |
write |
dli::callbackEdgeJobAction |
Grants the permission to call back action statuses of Flink edge jobs. |
write |
dli::createEdgeSystemEvent |
Grants the permission to report IEF system events. |
write |
dli:template:list |
Grants the permission to list templates. |
list |
template * |
dli:template:create |
Grants the permission to create templates. |
write |
template * |
dli:template:update |
Grants the permission to update templates. |
write |
template * |
dli:template:delete |
Grants the permission to delete templates. |
write |
template * |
dli:template:get |
Grants the permission to query template details. |
read |
template * |
dli:elasticresourcepool:resourceManagement |
Grants the permission to manage resources to an elastic resource pool. |
write |
elasticresourcepool * |
dli:elasticresourcepool:list |
Grants the permission to list elastic resource pools. |
list |
dli:elasticresourcepool:create |
Grants the permission to create elastic resource pools. |
write |
dli:elasticresourcepool:update |
Grants the permission to update elastic resource pools. |
write |
dli:elasticresourcepool:delete |
Grants the permission to delete elastic resource pools. |
write |
dli:elasticresourcepool:scale |
Grants the permission to scale out/in an elastic resource pool. |
list |
dli::createLakehouse |
Grants the permission to create lakehouses. |
write |
dli::getLakehouse |
Grants the permission to query lakehouses. |
read |
dli:connection:list |
Grants the permission to list basic datasource connections. |
list |
dli:connection:create |
Grants the permission to create basic datasource connections. |
write |
dli:connection:get |
Grants the permission to query basic datasource connections. |
read |
dli:connection:delete |
Grants the permission to delete basic datasource connections. |
write |
dli:edsconnection:get |
Grants the permission to query details about an enhanced datasource connection. |
read |
edsconnection * |
dli:edsconnection:update |
Grants the permission to update enhanced datasource connections. |
write |
edsconnection * |
dli:edsconnection:delete |
Grants the permission to delete enhanced datasource connections. |
write |
edsconnection * |
dli:edsconnection:list |
Grants the permission to list enhanced datasource connections. |
list |
edsconnection * |
dli:edsconnection:create |
Grants the permission to create enhanced datasource connections. |
write |
edsconnection * |
dli:edsconnection:unbindQueue |
Grants the permission to unbind an enhanced datasource connection from a queue. |
write |
edsconnection * |
dli:edsconnection:bindQueue |
Grants the permission to bind an enhanced datasource connection to a queue. |
write |
edsconnection * |
dli:datasourceauth:list |
Grants the permission to list datasource authentication connections. |
list |
datasourceauth * |
dli:datasourceauth:update |
Grants the permission to update security authentication information. |
write |
datasourceauth * |
dli:datasourceauth:create |
Grants the permission to create security authentication information. |
write |
datasourceauth * |
dli:datasourceauth:delete |
Grants the permission to delete security authentication information. |
write |
datasourceauth * |
dli:edsconnection:deleteRoute |
Grants the permission to delete routes from enhanced datasource connections. |
write |
edsconnection * |
dli:edsconnection:createRoute |
Grants the permission to create routes for enhanced datasource connections. |
write |
edsconnection * |
dli::getQuota |
Grants the permission to query quotas. |
read |
dli:queue:restart |
Grants the permission to restart a queue. |
write |
queue * |
dli:table:insertOverwriteTable |
Grants the permission to overwrite data to a table. |
write |
table * |
dli:catalog:unbind |
Grants the permission to unbind data catalogs. |
write |
dli::listTags |
Grants the permission to list tags. |
list |
dli::listResourcesByTag |
Grants the permission to query resources by tag. |
list |
dli::unTagResource |
Grants the permission to delete tags. |
tagging |
queue |
resource |
database |
elasticresourcepool |
edsconnection |
jobs |
dli::listTagsForResource |
Grants the permission to query the tags of a specified resource. |
list |
queue |
resource |
database |
edsconnection |
jobs |
dli::createDownloader |
Grants the permission to create download tasks. |
write |
dli::tagResource |
Creates resource tags. |
tagging |
queue |
resource |
database |
edsconnection |
jobs |
dli:jobs:check |
Verifies if jobs exist. |
read |
dli:jobs:import |
Imports jobs. |
write |
jobs |
dli:template:check |
Verifies if templates exist. |
read |
Each API of DLI usually supports one or more actions. Table 2 lists the actions and dependencies supported by DLI APIs.
API |
Action |
Dependency |
PUT /v1.0/{project_id}/queues/user-authorization |
dli::operateAuth |
PUT /v1.0/{project_id}/user-authorization |
dli::operateAuth |
GET /v1.0/{project_id}/databases/{database_name}/tables/{table_name}/users |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/tables/{table_name}/users/{user_name} |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/users |
dli::listAuth |
GET /v1.0/{project_id}/queues/{queue_name}/users |
dli::listAuth |
GET /v1.0/{project_id}/authorization/privileges |
dli::listAuth |
PUT /v1.0/{project_id}/authorization |
dli::operateAuth |
GET /v1.0/{project_id}/variables |
dli:variable:list |
POST /v1.0/{project_id}/variables |
PUT /v1.0/{project_id}/variables/{var_name} |
DELETE /v1.0/{project_id}/variables/{var_name} |
GET /v3/{project_id}/catalogs |
dli:catalog:list |
POST /v3/{project_id}/catalogs/action |
dli:catalog:bind |
GET /v3/{project_id}/catalogs/{catalog_name} |
dli:catalog:get |
GET /v1.0/{project_id}/queues |
dli:queue:list |
POST /v1.0/{project_id}/queues |
dli:queue:create |
GET /v1.0/{project_id}/queues/{queue_name} |
dli:queue:get |
PUT /v1.0/{project_id}/queues/{queue_name} |
dli:queue:update |
DELETE /v1.0/{project_id}/queues/{queue_name} |
dli:queue:delete |
PUT /v1.0/{project_id}/queues/{queue_name}/action |
dli:queue:scale |
dli:queue:restart |
POST /v1.0/{project_id}/queues/{queue_name}/connection-test |
GET /v1.0/{project_id}/queues/{queue_name}/connection-test/{task_id} |
GET /v1/{project_id}/queues/{queue_name}/plans |
POST /v1/{project_id}/queues/{queue_name}/plans |
POST /v1/{project_id}/queues/{queue_name}/plans/batch-delete |
DELETE /v1/{project_id}/queues/{queue_name}/plans/{plan_id} |
POST /v3/{project_id}/queues/{queue_name}/properties |
GET /v3/{project_id}/queues/{queue_name}/properties |
PUT /v3/{project_id}/queues/{queue_name}/properties |
DELETE /v3/{project_id}/queues/{queue_name}/properties |
GET /v1.0/{project_id}/jobs |
dli:jobs:list |
POST /v1.0/{project_id}/jobs/submit-job |
GET /v1.0/{project_id}/jobs/{job_id}/status |
dli:jobs:get |
GET /v1.0/{project_id}/jobs/{job_id}/detail |
dli:jobs:get |
DELETE /v1.0/{project_id}/jobs/{job_id} |
GET /v1.0/{project_id}/jobs/{job_id}/preview |
dli:jobs:get |
POST /v1.0/{project_id}/jobs/check-sql |
dli::checkSql |
GET /v1/{project_id}/jobs/{job_id}/progress |
dli:jobs:get |
POST /v1/{project_id}/sql-defend-rules |
GET /v1/{project_id}/sql-defend-rules |
PUT /v1/{project_id}/sql-defend-rules/{rule_id} |
DELETE /v1/{project_id}/sql-defend-rules/{rule_id} |
GET /v1/{project_id}/sql-defend-rules/{rule_id} |
POST /v1.0/{project_id}/streaming/jobs/{job_id}/import-savepoint |
dli:jobs:update |
POST /v1.0/{project_id}/streaming/jobs/{job_id}/savepoint |
dli:jobs:update |
GET /v1.0/{project_id}/streaming/jobs/{job_id} |
dli:jobs:get |
DELETE /v1.0/{project_id}/streaming/jobs/{job_id} |
dli:jobs:delete |
GET /v1.0/{project_id}/streaming/jobs |
dli:jobs:list |
POST /v1.0/{project_id}/streaming/sql-jobs |
dli:jobs:create |
PUT /v1.0/{project_id}/streaming/sql-jobs/{job_id} |
dli:jobs:update |
POST /v1.0/{project_id}/streaming/flink-jobs |
dli:jobs:create |
PUT /v1.0/{project_id}/streaming/flink-jobs/{job_id} |
dli:jobs:update |
POST /v1.0/{project_id}/streaming/jobs/run |
POST /v1.0/{project_id}/streaming/jobs/stop |
POST /v1.0/{project_id}/streaming/jobs/delete |
dli:jobs:delete |
GET /v1.0/{project_id}/streaming/jobs/{job_id}/execute-graph |
dli:jobs:get |
POST /v1.0/{project_id}/streaming/jobs/export |
dli:jobs:export |
POST /v1.0/{project_id}/streaming/jobs/import |
dli:jobs:import |
POST /v3/{project_id}/streaming/jobs/{job_id}/gen-graph |
dli:jobs:get |
GET /v1.0/{project_id}/streaming/job-templates |
dli:template:list |
POST /v1.0/{project_id}/streaming/job-templates |
PUT /v1.0/{project_id}/streaming/job-templates/{template_id} |
DELETE /v1.0/{project_id}/streaming/job-templates/{template_id} |
POST /v1.0/{project_id}/sqls |
GET /v1.0/{project_id}/sqls |
dli:template:list |
GET /v1.0/{project_id}/sqls/sample |
dli:template:list |
PUT /v1.0/{project_id}/sqls/{template_id} |
POST /v1.0/{project_id}/sqls-deletion |
POST /v3/{project_id}/templates |
GET /v3/{project_id}/templates |
dli:template:list |
PUT /v3/{project_id}/templates/{template_id} |
GET /v3/{project_id}/templates/{template_id} |
dli:template:get |
GET /v2.0/{project_id}/batches |
dli:jobs:list |
POST /v2.0/{project_id}/batches |
GET /v2.0/{project_id}/batches/{batch_id} |
dli:jobs:get |
DELETE /v2.0/{project_id}/batches/{batch_id} |
GET /v2.0/{project_id}/batches/{batch_id}/log |
dli:jobs:get |
GET /v2.0/{project_id}/batches/{batch_id}/state |
dli:jobs:get |
POST /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/notebook/action |
POST /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/notebook/instances |
GET /v3/{project_id}/elastic-resource-pools |
POST /v3/{project_id}/elastic-resource-pools |
PUT /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name} |
DELETE /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name} |
GET /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/queues |
POST /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/queues |
PUT /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/queues/{queue_name} |
GET /v3/{project_id}/elastic-resource-pools/{elastic_resource_pool_name}/scale-records |
POST /v3/{project_id}/orders/elastic-resource-pools |
POST /v3/{project_id}/orders/elastic-resource-pools/specification-change |
POST /v3/{project_id}/lakehouse |
GET /v3/{project_id}/lakehouse |
dli::getLakehouse |
GET /v2.0/{project_id}/datasource/enhanced-connections/{connection_id} |
PUT /v2.0/{project_id}/datasource/enhanced-connections/{connection_id} |
DELETE /v2.0/{project_id}/datasource/enhanced-connections/{connection_id} |
GET /v2.0/{project_id}/datasource/enhanced-connections |
POST /v2.0/{project_id}/datasource/enhanced-connections |
POST /v2.0/{project_id}/datasource/enhanced-connections/{connection_id}/disassociate-queue |
POST /v2.0/{project_id}/datasource/enhanced-connections/{connection_id}/associate-queue |
GET /v2.0/{project_id}/datasource/enhanced-connections/{connection_id}/privileges |
dli::listAuth |
GET /v3/{project_id}/datasource/auth-infos |
PUT /v3/{project_id}/datasource/auth-infos |
POST /v3/{project_id}/datasource/auth-infos |
DELETE /v3/{project_id}/datasource/auth-infos/{auth_info_name} |
POST /v3/{project_id}/datasource/enhanced-connections/{connection_id}/routes |
DELETE /v3/{project_id}/datasource/enhanced-connections/{connection_id}/routes/{name} |
GET /v3/{project_id}/quotas |
dli::getQuota |
GET /v3/{project_id}/{resource_type}/tags |
dli::listTags |
POST /v3/{project_id}/{resource_type}/resource-instances/filter |
POST /v3/{project_id}/{resource_type}/resource-instances/count |
POST /v3/{project_id}/{resource_type}/{resource_id}/tags/delete |
GET /v3/{project_id}/{resource_type}/{resource_id}/tags |
API |
Action |
Dependency |
GET /v1.0/{project_id}/logs/transfer |
dli::getLogTransfer |
POST /v1.0/{project_id}/logs/history |
dli::getLog |
POST /v1.0/{project_id}/logs/runtime |
dli::getLog |
GET /v1.0/{project_id}/logs/pods |
dli::getLog |
GET /v1.0/{project_id}/logs/pods/{pod_name} |
dli::getLog |
PUT /v1.0/{project_id}/databases/{database_name}/name |
POST /v1/{project_id}/streaming/jobs/check |
dli:jobs:check |
POST /v1/{project_id}/streaming/sql/validate |
dli::checkSql |
GET /v1/{project_id}/streaming/jobs/{job_id}/log |
dli:jobs:get |
GET /v1/{project_id}/streaming/jobs/{job_id}/log/{tm_id} |
dli:jobs:get |
GET /v1/{project_id}/streaming/jobs/{job_id}/submitlog |
dli:jobs:get |
POST /v1/{project_id}/streaming/templates/check |
GET /v1.0/{project_id}/databases/{database_name}/projects |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/tables/{table_name}/projects |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/tables/{table_name}/projects/{projectId} |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/projects/{projectId} |
dli::listAuth |
GET /v1.0/{project_id}/databases/{database_name}/tables/{table_name}/columns/{column_name}/projects/{projectId} |
dli::listAuth |
POST /v1.0/{project_id}/logs/transfer |
dli::createLogTransfer |
POST /v1.0/{project_id}/orders/queues |
dli:queue:create |
PUT /v1.0/{project_id}/orders/queues |
dli:queue:scale |
PUT /v3/{project_id}/queues/{queue_name}/scale-range |
dli:queue:scale |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 4, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for DLI.
Resource Type |
URN |
variable |
dli:<region>:<account-id>:variable:<variable-name-with-prefix> |
queue |
dli:<region>:<account-id>:queue:<queue-name-with-prefix> |
jobs |
dli:<region>:<account-id>:jobs:<job-id-with-prefix> |
table |
dli:<region>:<account-id>:table:<table-name-with-prefix> |
database |
dli:<region>:<account-id>:database:<database-name-with-prefix> |
resource |
dli:<region>:<account-id>:resource:<resource-name-with-prefix> |
template |
dli:<region>:<account-id>:template:<template-name-with-prefix> |
dli:<region>:<account-id>:elasticresourcepool:<elasticresourcepool-name-with-prefix> |
edsconnection |
dli:<region>:<account-id>:edsconnection:<edsconnection-id-with-prefix> |
datasourceauth |
dli:<region>:<account-id>:datasourceauth:<datasourceauth-name-with-prefix> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name as the prefix, for example, dli:) apply only to DLI operations. For details, see Table 5.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for DLI. You can include these condition keys to specify conditions for when your SCP is in effect.
