Direct Connect (DC)
The Organizations service provides Service Control Policies to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by Direct Connect, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by Direct Connect, see Conditions.
The following table lists the actions that you can define in SCP statements for Direct Connect.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
dcaas:directConnect:create |
Grants permission to create a connection. |
write |
directConnect * |
dcaas:directConnect:update |
Grants permission to update a connection. |
write |
directConnect * |
dcaas:directConnect:delete |
Grants permission to delete a connection. This action can only be used by pay-per-use connections. You can only unsubscribe from yearly/monthly connections. |
write |
directConnect * |
dcaas:directConnect:get |
Grants permission to query details of a connection. |
read |
directConnect * |
dcaas:directConnect:list |
Grants permission to list the connections. |
list |
directConnect * |
g:EnterpriseProjectId |
dcaas:directConnect:createHostedDirectConnect |
Grants permission to allow a partner to create a hosted connection. |
write |
directConnect * |
dcaas:directConnect:updateHostedDirectConnect |
Grants permission to allow a partner to update a hosted connection. |
write |
directConnect * |
dcaas:directConnect:deleteHostedDirectConnect |
Grants permission to allow a partner to delete a hosted connection. |
write |
directConnect * |
dcaas:directConnect:getHostedDirectConnect |
Grants permission to allow a partner to query details of a hosted connection. |
read |
directConnect * |
dcaas:directConnect:listHostedDirectConnect |
Grants permission to allow a partner to list the hosted connections. |
list |
directConnect * |
dcaas:directConnect:createOnestopDirectConnect |
Grants permission to create a full-service connection. |
write |
directConnect * |
dcaas:directConnect:updateOnestopDirectConnect |
Grants permission to update a full-service connection. |
write |
directConnect * |
dcaas:directConnect:createOrder |
Grants permission to create an order for a connection. |
write |
directConnect * |
dcaas:directConnect:updateOrder |
Grants permission to modify the order for changing the specifications of a connection. |
write |
directConnect * |
dcaas:vgw:create |
Grants permission to create a virtual gateway. |
write |
vgw * |
vpc |
instances |
dcaas:vgw:update |
Grants permission to update a virtual gateway. |
write |
vgw * |
dcaas:vgw:delete |
Grants permission to delete a virtual gateway. |
write |
vgw * |
dcaas:vgw:get |
Grants permission to query details of a virtual gateway. |
read |
vgw * |
dcaas:vgw:list |
Grants permission to list the virtual gateways. |
list |
vgw * |
dcaas:vif:create |
Grants permission to create a virtual interface. |
write |
vif * |
directConnect |
lag |
vgw |
gdgw |
connectGateway |
lgw |
dcaas:vif:update |
Grants permission to update a virtual interface. |
write |
vif * |
dcaas:vif:delete |
Grants permission to delete a virtual interface. |
write |
vif * |
dcaas:vif:get |
Grants permission to query details of a virtual interface. |
read |
vif * |
dcaas:vif:list |
Grants permission to list the virtual interfaces. |
list |
vif * |
dcaas:vif:updateVifExtendAttribute |
Grants permission to update extended attributes of a virtual interface. |
write |
vif * |
dcaas:vifPeer:create |
Grants permission to create a virtual interface peer. |
write |
vifPeer * |
vif * |
dcaas:vifPeer:update |
Grants permission to update a virtual interface peer. |
write |
vifPeer * |
dcaas:vifPeer:delete |
Grants permission to delete a virtual interface peer. |
write |
vifPeer * |
dcaas:vifPeer:get |
Grants permission to query details of a virtual interface peer. |
read |
vifPeer * |
dcaas:vifPeer:list |
Grants permission to list the virtual interface peers. |
list |
vifPeer * |
dcaas:gdgw:create |
Grants permission to create a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:update |
Grants permission to update a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:delete |
Grants permission to delete a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:get |
Grants permission to query details of a global DC gateway. |
read |
gdgw * |
dcaas:gdgw:list |
Grants permission to list the global DC gateways. |
list |
gdgw * |
dcaas:gdgw:createPeerlink |
Grants permission to create a peer link for a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:updatePeerlink |
Grants permission to update a peer link of a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:deletePeerlink |
Grants permission to delete a peer link of a global DC gateway. |
write |
gdgw * |
dcaas:gdgw:getPeerlink |
Grants permission to query details of a peer link of a global DC gateway. |
read |
gdgw * |
dcaas:gdgw:listPeerlink |
Grants permission to list the peer links of a global DC gateway. |
list |
gdgw * |
dcaas:vif:switchoverTest |
Grants permission to perform a switchover test. |
write |
vif * |
dcaas:vif:listSwitchoverTestRecord |
Grants permission to query switchover test execution records. |
list |
vif * |
dcaas:vif:getSwitchoverTestRecord |
Grants permission to query a switchover test execution record. |
read |
vif * |
dcaas:resources:batchTagUntag |
Grants permission to add tags to or delete tags from a resource in batches. |
tagging |
directConnect |
lag |
vgw |
vif |
gdgw |
dcaas:resources:listResourceTag |
Grants permission to query tags of a resource. |
list |
directConnect |
lag |
vgw |
vif |
gdgw |
dcaas:resources:listTag |
Grants permission to query tags by resource type. |
list |
directConnect |
lag |
vgw |
vif |
gdgw |
dcaas:resources:tag |
Grants permission to add a tag to a resource. |
tagging |
directConnect |
lag |
vgw |
vif |
gdgw |
dcaas:resources:unTag |
Grants permission to delete a tag from a resource. |
tagging |
directConnect |
lag |
vgw |
vif |
gdgw |
g:TagKeys |
dcaas:resources:listByTag |
Grants permission to query resources by tag. |
list |
directConnect |
lag |
vgw |
vif |
gdgw |
dcaas:gdgw:listGdgwRouteTable |
Grants permission to query a custom route table of a global DC gateway. |
list |
gdgw * |
dcaas:gdgw:updateGdgwRouteTable |
Grants permission to update a custom route table of a global DC gateway. |
write |
gdgw * |
dcaas:quota:listVgwUsage |
Grants permission to query the quota of VPCs that a virtual gateway can be associated with. |
list |
dcaas:quota:listUsage |
Grants permission to query the quotas. |
list |
Each API of Direct Connect usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v3/{project_id}/dcaas/direct-connects/{direct_connect_id} |
GET /v3/{project_id}/dcaas/direct-connects |
PUT /v3/{project_id}/dcaas/direct-connects/{direct_connect_id} |
DELETE /v3/{project_id}/dcaas/direct-connects/{direct_connect_id} |
GET /v3/{project_id}/dcaas/hosted-connects/{hosted_connect_id} |
GET /v3/{project_id}/dcaas/hosted-connects |
POST /v3/{project_id}/dcaas/hosted-connects |
PUT /v3/{project_id}/dcaas/hosted-connects/{hosted_connect_id} |
DELETE /v3/{project_id}/dcaas/hosted-connects/{hosted_connect_id} |
GET /v3/{project_id}/dcaas/virtual-gateways/{virtual_gateway_id} |
dcaas:vgw:get |
GET /v3/{project_id}/dcaas/virtual-gateways |
dcaas:vgw:list |
PUT /v3/{project_id}/dcaas/virtual-gateways/{virtual_gateway_id} |
dcaas:vgw:update |
DELETE /v3/{project_id}/dcaas/virtual-gateways/{virtual_gateway_id} |
dcaas:vgw:delete |
POST /v3/{project_id}/dcaas/virtual-gateways |
dcaas:vgw:create |
er:instances:get vpc:vpcs:get |
GET /v3/{project_id}/dcaas/virtual-interfaces/{virtual_interface_id} |
dcaas:vif:get |
GET /v3/{project_id}/dcaas/virtual-interfaces |
dcaas:vif:list |
PUT /v3/{project_id}/dcaas/virtual-interfaces/{virtual_interface_id} |
dcaas:vif:update |
DELETE /v3/{project_id}/dcaas/virtual-interfaces/{virtual_interface_id} |
dcaas:vif:delete |
POST /v3/{project_id}/dcaas/virtual-interfaces |
dcaas:vif:create |
PUT /v3/{project_id}/dcaas/vif-peers/{vif_peer_id} |
DELETE /v3/{project_id}/dcaas/vif-peers/{vif_peer_id} |
POST /v3/{project_id}/dcaas/vif-peers |
POST /v3/{project_id}/dcaas/switchover-test |
GET /v3/{project_id}/dcaas/switchover-test |
GET /v3/{project_id}/dcaas/quotas |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for Direct Connect.
Resource Type |
URN |
instances |
er:<region>:<account-id>:instances:<instance-id> |
lgw |
dcaas:<region>:<account-id>:lgw:<lgw-id> |
vif |
dcaas:<region>:<account-id>:vif:<vif-id> |
lgwTable |
dcaas:<region>:<account-id>:lgwTable:<lgwTable-id> |
gdgw |
dcaas:<region>:<account-id>:gdgw:<gdgw-id> |
vifPeer |
dcaas:<region>:<account-id>:vifPeer:<vifPeer-id> |
vpc |
vpc:<region>:<account-id>:vpc:<vpc-id> |
vgw |
dcaas:<region>:<account-id>:vgw:<vgw-id> |
directConnect |
dcaas:<region>:<account-id>:directConnect:<directConnect-id> |
lag |
dcaas:<region>:<account-id>:lag:<lag-id> |
connectGateway |
dcaas:<region>:<account-id>:connectGateway:<connectGateway-id> |
Conditions
Direct Connect does not support service-specific condition keys in SCPs. Direct Connect can only use global condition keys applicable to all services. For details, see Global Condition Keys.
