On this page
IAM Access Analyzer
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by IAM Access Analyzer, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by IAM Access Analyzer, see Conditions.
The following table lists the actions that you can define in SCP statements for IAM Access Analyzer.
Table 1 Actions supported by IAM Access Analyzer
Action
Access Level
Resource Type (*: required)
Condition Key
AccessAnalyzer:analyzer:create
Grants permission to create an access analyzer.
Write
analyzer *
AccessAnalyzer:analyzer:get
Grants permission to retrieve the access analyzer information.
Read
analyzer *
g:ResourceTag/<tag-key>
AccessAnalyzer:analyzer:list
Grants permission to list access analyzers.
List
analyzer *
AccessAnalyzer:analyzer:delete
Grants permission to delete the specified access analyzer.
Write
analyzer *
AccessAnalyzer:analyzer:scan
Grants permission to start a scan for the specified access analyzer.
Write
analyzer *
AccessAnalyzer:analyzer:getFinding
Grants permission to retrieve findings.
Read
analyzer *
AccessAnalyzer:analyzer:listFindings
Grants permission to list findings.
List
analyzer *
AccessAnalyzer:analyzer:updateFindings
Grants permission to update the findings.
Write
analyzer *
AccessAnalyzer::tagResource
Grants permission to add a tag to a resource.
Tagging
analyzer *
AccessAnalyzer::untagResource
Grants permission to remove a tag from a resource.
Tagging
analyzer *
g:TagKeys
AccessAnalyzer:archiveRule:create
Grants permission to create an archive rule for the specified access analyzer.
Write
archiveRule *
AccessAnalyzer:archiveRule:get
Grants permission to retrieve an archive rule for the specified access analyzer.
Read
archiveRule *
AccessAnalyzer:archiveRule:list
Grants permission to list archive rules for the specified access analyzer.
List
archiveRule *
AccessAnalyzer:archiveRule:update
Grants permission to modify an archive rule for the specified access analyzer.
Write
archiveRule *
AccessAnalyzer:archiveRule:delete
Grants permission to delete an archive rule for the specified access analyzer.
Write
archiveRule *
AccessAnalyzer:archiveRule:apply
Grants permission to apply an archive rule.
Write
archiveRule *
AccessAnalyzer:analyzer:createPreview
Grants permission to create an access preview for the specified access analyzer.
Write
analyzer *
AccessAnalyzer:analyzer:getPreview
Grants permission to retrieve an access preview for the specified access analyzer.
Read
analyzer *
AccessAnalyzer:analyzer:listPreviews
Grants permission to list access previews for the specified access analyzer.
List
analyzer *
AccessAnalyzer:analyzer:listPreviewFindings
Grants permission to list access preview findings for the specified access analyzer.
List
analyzer *
AccessAnalyzer:analyzer:createResourceConfigurations
Grants permission to create resource configurations.
Write
analyzer *
AccessAnalyzer:analyzer:listResourceConfigurations
Grants permission to list resource configurations.
List
analyzer *
AccessAnalyzer:analyzer:deleteResourceConfigurations
Grants permission to delete resource configurations.
Write
analyzer *
AccessAnalyzer::validatePolicy
Grants permission to validate a policy.
Read
AccessAnalyzer::checkNoNewAccess
Grants permission to check if the updated policy has new access.
Read
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 2, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for IAM Access Analyzer.
Table 2 Resource types supported by IAM Access Analyzer
Resource Type
URN
analyzer
AccessAnalyzer:<region>:<account-id>:analyzer:<analyzer-id>
archiveRule
AccessAnalyzer:<region>:<account-id>:archiveRule:<analyzer-id>/<archive-rule-id>
Conditions
IAM Access Analyzer does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global condition keys.
