Organizations provides your with Service Control Policies for access control.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to an organizational unit (OU) or a member account, the SCPs do not directly grant permissions to that OU or member account. Instead, the SCPs only determine what permissions are available for that member account or those member accounts in that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the resource URN in the Resource element of your policy statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by Config, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If this column is empty (-), the action does not support any condition keys.
For details about the condition keys defined by Config, see Conditions.
The following table lists the actions that you can define in SCP statements for Config.
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
rms:organizationConformancePacks:create |
Grants permission to create organization conformance packages. |
write |
rms:organizationConformancePacks:get |
Grants permission to view organization conformance packages. |
read |
organizationConformancePacks * |
rms:organizationConformancePacks:delete |
Grants permission to delete organization conformance packages. |
write |
rms:organizationConformancePacks:update |
Grants permission to update organization conformance packages. |
write |
rms:organizationConformancePacks:list |
Grants permission to list organization conformance packages. |
list |
rms:conformancePacks:create |
Grants permission to create conformance packages. |
write |
rms:conformancePacks:get |
Grants permission to view conformance packages. |
read |
conformancePacks * |
rms:conformancePacks:delete |
Grants permission to delete conformance packages. |
write |
rms:conformancePacks:update |
Grants permission to update conformance packages. |
write |
rms:conformancePacks:list |
Grants permission to list conformance packages. |
list |
rms:storedQueries:create |
Grants permission to save new advanced queries. |
write |
rms:storedQueries:update |
Grants permission to modify advanced queries. |
write |
storedQueries * |
rms:storedQueries:delete |
Grants permission to delete advanced query statements. |
write |
storedQueries * |
rms:storedQueries:get |
Grants permission to view advanced query details. |
read |
storedQueries * |
rms:storedQueries:list |
Grants permission to list advanced queries. |
list |
rms:policyAssignments:create |
Grants permission to create rules. |
write |
rms:policyAssignments:update |
Grants permission to update rules. |
write |
policyAssignments * |
g:ResourceTag/<tag-key> |
rms:policyAssignments:delete |
Grants permission to delete rules and their evaluation results. |
write |
rms:policyAssignments:get |
Grants permission to view rule details. |
read |
rms:organizationPolicyAssignments:put |
Grants permission to create or update organization rules. |
write |
rms:organizationPolicyAssignments:delete |
Grants permission to delete specific organization rules and their evaluation results. |
write |
organizationPolicyAssignments * |
rms:organizationPolicyAssignments:get |
Grants permission to view organization rule details. |
read |
rms:organizationPolicyAssignments:list |
Grants permission to list organization rules. |
list |
rms:policyStates:get |
Grants permission to list rule evaluation results. |
read |
policyAssignments |
rms:policyStates:runEvaluation |
Grants permission to run specific rules. |
write |
policyAssignments |
rms:policyStates:update |
Grants permission to deliver evaluation results from FunctionGraph Config. |
write |
rms:aggregators:create |
Grants permission to create aggregators. |
write |
rms:aggregators:update |
Grants permission to update aggregators. |
write |
aggregators * |
rms:aggregators:delete |
Grants permission to delete specific aggregators. |
write |
aggregators * |
rms:aggregators:list |
Grants permission to list aggregators. |
list |
rms:aggregators:get |
Grants permission to view aggregator details. |
read |
aggregators * |
rms:aggregatorResources:list |
Grants permission to view aggregated resources. |
list |
rms:aggregatorResources:runQuery |
Grants permission to run advanced queries for querying attributes of aggregated resources. |
list |
rms:aggregatorResources:get |
Grants permission to view details of aggregated resources |
read |
rms:aggregationAuthorizations:create |
Grants permission to create aggregation authorization. |
write |
aggregationAuthorizations * |
rms:AuthorizedAccountOrgPath |
rms:aggregationAuthorizations:list |
Grants permission to list aggregator authorization. |
list |
rms:aggregationAuthorizations:delete |
Grants permission to revoke aggregation authorization. |
write |
rms:aggregationRequests:delete |
Grants permission to delete aggregation requests from other accounts. |
write |
rms:aggregationRequests:list |
Grants permission to list aggregation requests from other accounts. |
list |
rms:trackerConfig:put |
Grants permission to enable the resource recorder or modify resource recorder configurations. |
write |
rms:trackerConfig:delete |
Grants permission to disable the resource recorder. |
write |
rms:trackerConfig:get |
Grants permission to view resource recorder configurations. |
read |
rms:schemas:list |
Grants permission to view schemas of advanced queries. |
list |
rms:policyDefinitions:get |
Grants permission to view built-in policies. |
list |
rms:resources:getHistory |
Grants permission to view resource configuration history. |
list |
rms:resources:getRelation |
Grants permission to view resource relationships. |
list |
rms:resources:get |
Grants permission to view details of specific resources. |
read |
rms:resources:list |
Grants permission to list resources. |
list |
rms:resources:runQuery |
Grants permission to run advanced queries. |
list |
rms:resources:summarize |
Grants permission to view resource overview. |
list |
rms::tagResource |
Grants permission to batch create resource tags. |
tagging |
policyAssignments |
rms::unTagResource |
Grants permission to batch delete resource tags. |
tagging |
policyAssignments |
rms::listTagsForResource |
Grants permission to query resource tags. |
list |
policyAssignments |
rms::listTags |
Grants permission to query project tags. |
list |
rms::listResourcesByTag |
Grants permission to query resources by tag. |
list |
g:TagKeys |
rms:policyAssignmentsRemediation:putRemediationConfiguration |
Grants permission to add remediation configurations. |
write |
policyAssignmentsRemediation * |
rms:policyAssignmentsRemediation:deleteRemediationConfiguration |
Grants permission to delete remediation configurations. |
write |
rms:policyAssignmentsRemediation:getRemediationConfiguration |
Grants permission to check remediation configurations. |
read |
rms:policyAssignmentsRemediation:runRemediation |
Grants permission to run remediation execution. |
write |
rms:policyAssignmentsRemediation:listRemediationExecutionStatuses |
Grants permission to check remediation execution status. |
list |
rms:policyAssignmentsRemediation:createRemediationExceptions |
Grants permission to create remediation exceptions. |
write |
rms:policyAssignmentsRemediation:deleteRemediationExceptions |
Grants permission to delete remediation exceptions. |
write |
rms:policyAssignmentsRemediation:listRemediationExceptions |
Grants permission to check remediation exceptions. |
list |
A Config API usually supports one or more actions. Table 2 lists actions supported by each API and dependencies of actions.
API |
Action |
Dependencies |
POST /v1/resource-manager/organizations/{organization_id}/conformance-packs |
DELETE /v1/resource-manager/organizations/{organization_id}/conformance-packs/{conformance_pack_id} |
organizations:organizations:get |
GET /v1/resource-manager/organizations/{organization_id}/conformance-packs |
GET /v1/resource-manager/organizations/{organization_id}/conformance-packs/{conformance_pack_id} |
GET /v1/resource-manager/organizations/{organization_id}/conformance-packs/statuses |
GET /v1/resource-manager/organizations/{organization_id}/conformance-packs/detailed-statuses |
POST /v1/resource-manager/domains/{domain_id}/conformance-packs |
DELETE /v1/resource-manager/domains/{domain_id}/conformance-packs/{conformance_pack_id} |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs/{conformance_pack_id} |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs/{conformance_pack_id}/compliance |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs/{conformance_pack_id}/compliance/details |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs/compliance/summary |
GET /v1/resource-manager/domains/{domain_id}/conformance-packs/scores |
POST /v1/resource-manager/domains/{domain_id}/stored-queries |
PUT /v1/resource-manager/domains/{domain_id}/stored-queries/{query_id} |
DELETE /v1/resource-manager/domains/{domain_id}/stored-queries/{query_id} |
GET /v1/resource-manager/domains/{domain_id}/stored-queries/{query_id} |
GET /v1/resource-manager/domains/{domain_id}/stored-queries |
PUT /v1/resource-manager/domains/{domain_id}/policy-assignments |
DELETE /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id} |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id} |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments |
PUT /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id} |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/disable |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/enable |
PUT /v1/resource-manager/organizations/{organization_id}/policy-assignments |
GET /v1/resource-manager/organizations/{organization_id}/policy-assignments |
GET /v1/resource-manager/organizations/{organization_id}/policy-assignments/{organization_policy_assignment_id} |
GET /v1/resource-manager/organizations/{organization_id}/policy-assignment-statuses |
GET /v1/resource-manager/organizations/{organization_id}/policy-assignment-detailed-status |
DELETE /v1/resource-manager/organizations/{organization_id}/policy-assignments/{organization_policy_assignment_id} |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/policy-states |
GET /v1/resource-manager/domains/{domain_id}/policy-states |
GET /v1/resource-manager/domains/{domain_id}/resources/{resource_id}/policy-states |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/policy-states/run-evaluation |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/policy-states/evaluation-state |
PUT /v1/resource-manager/domains/{domain_id}/policy-states |
PUT /v1/resource-manager/domains/{domain_id}/aggregators |
PUT /v1/resource-manager/domains/{domain_id}/aggregators/{aggregator_id} |
DELETE /v1/resource-manager/domains/{domain_id}/aggregators/{aggregator_id} |
GET /v1/resource-manager/domains/{domain_id}/aggregators |
GET /v1/resource-manager/domains/{domain_id}/aggregators/{aggregator_id} |
GET /v1/resource-manager/domains/{domain_id}/aggregators/{aggregator_id}/aggregator-sources-status |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/policy-states/compliance-summary |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/policy-assignments/compliance |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/policy-states/compliance-details |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/policy-assignment/detail |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-resource-config |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/aggregate-discovered-resources |
POST /v1/resource-manager/domains/{domain_id}/aggregators/{aggregator_id}/run-query |
POST /v1/resource-manager/domains/{domain_id}/aggregators/aggregate-data/aggregate-discovered-resource-counts |
GET /v1/resource-manager/domains/{domain_id}/aggregators/aggregation-authorization |
PUT /v1/resource-manager/domains/{domain_id}/aggregators/aggregation-authorization |
DELETE /v1/resource-manager/domains/{domain_id}/aggregators/aggregation-authorization/{authorized_account_id} |
DELETE /v1/resource-manager/domains/{domain_id}/aggregators/pending-aggregation-request/{requester_account_id} |
GET /v1/resource-manager/domains/{domain_id}/aggregators/pending-aggregation-request |
PUT /v1/resource-manager/domains/{domain_id}/tracker-config |
DELETE /v1/resource-manager/domains/{domain_id}/tracker-config |
GET /v1/resource-manager/domains/{domain_id}/tracker-config |
GET /v1/resource-manager/domains/{domain_id}/schemas |
rms:schemas:list |
GET /v1/resource-manager/policy-definitions |
GET /v1/resource-manager/policy-definitions/{policy_definition_id} |
GET /v1/resource-manager/domains/{domain_id}/resources/{resource_id}/history |
GET /v1/resource-manager/domains/{domain_id}/all-resources/{resource_id}/relations |
GET /v1/resource-manager/domains/{domain_id}/provider/{provider}/type/{type}/resources/{resource_id} |
rms:resources:get |
GET /v1/resource-manager/domains/{domain_id}/all-resources |
GET /v1/resource-manager/domains/{domain_id}/provider/{provider}/type/{type}/resources |
POST /v1/resource-manager/domains/{domain_id}/run-query |
GET /v1/resource-manager/domains/{domain_id}/all-resources/summary |
GET /v1/resource-manager/domains/{domain_id}/all-resources/tags |
GET /v1/resource-manager/domains/{domain_id}/all-resources/count |
GET /v1/resource-manager/domains/{domain_id}/all-resources/{resource_id} |
rms:resources:get |
GET /v1/resource-manager/domains/{domain_id}/resources/{resource_id}/relations |
GET /v1/resource-manager/domains/{domain_id}/tracked-resources |
GET /v1/resource-manager/domains/{domain_id}/tracked-resources/count |
GET /v1/resource-manager/domains/{domain_id}/tracked-resources/tags |
GET /v1/resource-manager/domains/{domain_id}/tracked-resources/summary |
GET /v1/resource-manager/domains/{domain_id}/tracked-resources/{resource_id} |
rms:resources:get |
POST /v1/resource-manager/{resource_type}/{resource_id}/tags/create |
rms::tagResource |
POST /v1/resource-manager/{resource_type}/{resource_id}/tags/delete |
GET /v1/resource-manager/{resource_type}/{resource_id}/tags |
GET /v1/resource-manager/{resource_type}/tags |
rms::listTags |
POST /v1/resource-manager/{resource_type}/resource-instances/count |
POST /v1/resource-manager/{resource_type}/resource-instances/filter |
PUT /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-configuration |
DELETE /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-configuration |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-configuration |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-execution |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-execution-statuses |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-execution-statuses/summary |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-exception/create |
POST /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-exception/delete |
GET /v1/resource-manager/domains/{domain_id}/policy-assignments/{policy_assignment_id}/remediation-exception |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for Config.
Resource Type |
URN |
conformancePacks |
rms::<account-id>:conformancePacks:<conformance-pack-id> |
storedQueries |
rms::<account-id>:storedQueries:<query-id> |
policyAssignments |
rms::<account-id>:policyAssignments:<policy-assignment-id> |
organizationPolicyAssignments |
rms::<account-id>:organizationPolicyAssignments:<organization-id>/<organization-policy-assignments-id> |
organizationConformancePacks |
rms::<account-id>:organizationConformancePacks:<organization-id>/<organization-conformance-pack-id> |
aggregators |
rms::<account-id>:aggregators:<aggregator-id> |
aggregationAuthorizations |
rms::<account-id>:aggregationAuthorizations:<authorized-account-id> |
policyAssignmentsRemediation |
rms::<account-id>:policyAssignmentsRemediation:<policy-assignment-id> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- A key in the Condition element of a statement Condition keys are classified into global condition keys and service-specific condition keys based on the application scope.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- A service-specific condition key is prefixed by the service name (such as config:) and applies only to a specific service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- An operator, a condition key, and a condition value constitute a complete condition statement. An SCP takes effect only when the statement meets related requirements. For supported condition operators, see SCP Syntax.
The following table lists the condition keys that you can define in SCPs for Config. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-Level Condition Key |
Type |
Single-valued/Multi-valued |
Description |
string |
Single-valued |
Access is controlled based on the Organizations Path of the specified aggregator account. |
string |
Single-valued |
Access is controlled based on the specified bucket name. |
string |
Single-valued |
Access is controlled based on the prefix of the specified OBS bucket. |
Condition Key Examples
- rms:TrackerBucketName
Preventing the resource recorder from storing resource data to unexpected OBS buckets
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
{ "Version": "5.0", "Statement": [ { "Effect": "Deny", "Action": [ "rms:trackerConfig:put" ], "Resource": [ "*" ], "Condition": { "StringNotMatch": { "rms:TrackerBucketName": [ "BucketName" ] } } } ] }
- rms:TrackerBucketPathPrefix
Preventing storing resource data to unexpected OBS paths
{ "Version": "5.0", "Statement": [ { "Effect": "Deny", "Action": [ "rms:trackerConfig:put" ], "Resource": [ "*" ], "Condition": { "StringNotMatch": { "rms:TrackerBucketPathPrefix": [ "BucketFolder" ] } } } ] }
