Resource Access Manager (RAM)
The Organizations service provides Service Control Policies (SCPs)Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to an organizational unit (OU) or a member account, the SCPs do not directly grant permissions to that OU or member account. Instead, the SCPs only determine what permissions are available for that member account or those member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by RAM, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by RAM, see Conditions.
The following table lists the actions that you can define in SCP statements for RAM.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
Alias |
ram:permissions:list |
Grants permission to list RAM permissions. |
List |
permission * |
ram:permissions:get |
Grants permission to get the details of an RAM permission. |
Read |
permission * |
ram:resourceShares:create |
Grants permission to create a resource share with provided resources and/or principals. |
Write |
ram:resourceShares:search |
Grants permission to search for a set of resource shares from a provided list or with a specified state. |
Read |
ram:resourceShares:update |
Grants permission to update the attributes of a resource share. |
Write |
resourceShare * |
ram:resourceShares:delete |
Grants permission to delete a resource share. |
Write |
resourceShare * |
ram:resourceShares:associate |
Grants permission to associate resources and/or principals with a resource share. |
Write |
resourceShare * |
ram:resourceShares:disassociate |
Grants permission to disassociate resources and/or principals from a resource share. |
Write |
resourceShare * |
ram:resourceShares:searchResourceShareAssociations |
Grants permission to search for a set of resource share associations from a provided list or with a specified state of the specified type. |
Read |
ram:resourceShares:associatePermission |
Grants permission to associate a permission with a resource share. |
Write |
resourceShare * |
ram:resourceShares:disassociatePermission |
Grants permission to disassociate a permission from a resource share. |
Write |
resourceShare * |
ram:resourceShares:listAssociatedPermissions |
Grants permission to list the permissions associated with a resource share. |
List |
resourceShare * |
ram:resourceShares:tag |
Grants permission to tag the specified resource share. |
Tagging |
resourceShare * |
ram:resourceShares:untag |
Grants permission to untag the specified resource share. |
Tagging |
resourceShare * |
ram:resourceShares:listTags |
Grants permission to list tags attached to a resource share. |
List |
ram:resourceShares:listResourceSharesByTag |
Grants permission to list resource shares by tag. |
List |
ram:resourceShares:searchResourceShareCountByTag |
Grants permission to search for the number of resource shares by tag. |
Read |
ram:sharedResources:search |
Grants permission to search for the resources that you added to a resource share or that are shared with you. |
List |
ram:sharedPrincipals:search |
Grants permission to search for the principals that you have shared resources with or that have shared resources with you. |
List |
ram:resourceShareInvitations:accept |
Grants permission to accept the specified resource sharing invitation. |
Write |
resourceShareInvitation * |
ram:resourceShareInvitations:reject |
Grants permission to reject the specified resource sharing invitation. |
Write |
ram:resourceShareInvitations:search |
Grants permission to search for resource sharing invitations by the specified invitation ID or resource share ID. |
Read |
ram:resourceShares:enableSharingWithOrganization |
Grants permission to enable sharing with Organizations. |
Permission_management |
ram:resourceShares:disableSharingWithOrganization |
Grants permission to disable sharing with Organizations. |
ram:resourceShares:searchEnableSharingWithOrganization |
Grants permission to check whether sharing with Organizations is enabled. |
Read |
ram:sharedResources:searchDistinctResource |
Grants permission to search for the distinct resources that you added to a resource share or that are shared with you. |
List |
ram:sharedPrincipals:searchDistinctPrincipal |
Grants permission to search for the distinct principals that you have shared resources with or that have shared resources with you. |
List |
ram:resourceShares:listQuota |
Grants permission to list the quotas of resource sharing. |
List |
ram:resourceTypes:list |
Grants permission to list the resource types of cloud services. |
List |
ram:permission:listVersions |
Grants permission to list all versions of the specified RAM permission. |
List |
Each API of RAM usually supports one or more actions. #org_20_0042/en-us_topic_0000001865665109_en-us_topic_0000001679340620_api_relation_table lists the supported actions and dependencies.
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 2, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for RAM.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name as the prefix, for example, ram:) apply only to operations of the RAM service. For details, see #org_20_0042/en-us_topic_0000001865665109_en-us_topic_0000001679340620_condition_table.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Operators.
The following table lists the condition keys that you can define in SCPs for RAM. You can include these condition keys to specify conditions for when your SCP is in effect.
