The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resources. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resources defined by IAM Identity Center, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource column has values for an action, the condition key takes effect only for the listed resources.
- If the Resource column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by IAM Identity Center, see Conditions.
The following table lists the actions that you can define in SCP statements for IAM Identity Center.
Action |
Description |
Access Level |
Resource (*: required) |
Condition Key |
IdentityCenter:permissionSet:create |
Grants permission to create a permission set. |
write |
instance * |
IdentityCenter:permissionSet:attachManagedPolicy |
Grants permission to attach system-defined identity policies to a permission set. |
permission_management |
instance * |
permissionSet * |
IdentityCenter:permissionSet:detachManagedPolicy |
Grants permission to detach system-defined identity policies from a specified permission set. |
instance * |
permissionSet * |
IdentityCenter:permissionSet:update |
Grants permission to update the permission set of a specified instance. |
instance * |
permissionSet * |
IdentityCenter:permissionSet:delete |
Grants permission to delete the permission set of a specified instance. |
write |
instance * |
permissionSet * |
IdentityCenter:permissionSet:list |
Grants permission to list the permission sets of a specified instance. |
list |
instance * |
IdentityCenter:permissionSet:listAccountsForProvisioned |
Grants permission to list all the accounts provisioned by a specified permission set. |
list |
permissionSet * |
instance * |
IdentityCenter:permissionSet:listProvisioningStatus |
Grants permission to list the status of the permission set attachment request for a specified instance. |
list |
instance * |
IdentityCenter:permissionSet:listManagedPolicies |
Grants permission to list the system-defined identity policies attached to a specified permission set. |
list |
instance * |
permissionSet * |
IdentityCenter:permissionSet:listProvisionedToAccount |
Grants permission to list all permission sets associated with a specified account. |
list |
account * |
instance * |
IdentityCenter:permissionSet:describeProvisioningStatus |
Grants permission to obtain the details of the permission set attachment status. |
read |
instance * |
IdentityCenter:permissionSet:describe |
Grants permission to obtain the permission set details of a specified instance. |
read |
instance * |
permissionSet * |
IdentityCenter:permissionSet:provision |
Grants permission to attach a specified permission set to a specified principal. |
write |
account * |
instance * |
permissionSet * |
IdentityCenter:instance:getIdentityCenterStatus |
Grants permission to query the IAM Identity Center service status. |
read |
IdentityCenter:instance:registerRegion |
Grants permission to register a region. |
write |
IdentityCenter:instance:describeRegisteredRegions |
Grants permission to query regions enabled in IAM Identity Center. |
read |
IdentityCenter:instance:startIdentityCenter |
Grants permission to enable IAM Identity Center. |
write |
IdentityCenter:instance:deleteIdentityCenter |
Grants permission to disable IAM Identity Center. |
write |
IdentityCenter:instance:list |
Grants permission to query the IAM Identity Center instance list. |
list |
IdentityCenter:accountAssignment:create |
Grants permission to assign access to principals for a specified account using a specified permission set. |
write |
instance * |
account * |
permissionSet * |
IdentityCenter:accountAssignment:delete |
Grants permission to delete a principal's access from a specified account using a specified permission set. |
write |
instance * |
account * |
permissionSet * |
IdentityCenter:accountAssignment:list |
Grants permission to list the assignee of the specified account with the specified permission set. |
list |
instance * |
account * |
permissionSet * |
IdentityCenter:accountAssignment:describeDeletionStatus |
Grants permission to obtain the details about the status of the assignment deletion request. |
read |
instance * |
IdentityCenter:accountAssignment:describeCreationStatus |
Grants permission to obtain the details about the status of the assignment creation request. |
read |
instance * |
IdentityCenter:accountAssignment:listCreationStatus |
Grants permission to list the status of the account assignment creation request for a specified IAM Identity Center instance. |
list |
instance * |
IdentityCenter:accountAssignment:listDeletionStatus |
Grants permission to list the status of the account assignment deletion request for a specified IAM Identity Center instance. |
list |
instance * |
IdentityCenter:accountAssignment:listProfileAssociation |
Grants permission to query all users or groups associated with an account or permission set. |
read |
IdentityCenter:accountAssignment:disassociationProfile |
Grants permission to disassociate all authorizations from a user or group. |
write |
IdentityCenter:instance:listIdentityStoreAssociations |
Grants permission to query details about the identity source configured in IAM Identity Center. |
read |
IdentityCenter:ssoConfiguration:update |
Grants permission to update the configuration for the current IAM Identity Center instance. |
write |
IdentityCenter:ssoConfiguration:describe |
Grants permission to obtain the configuration for the current IAM Identity Center instance. |
read |
IdentityCenter:mfaDevices:describeManagementSettings |
Grants permission to obtain MFA settings. |
read |
IdentityCenter:mfaDevices:updateManagementSettings |
Grants permission to update MFA settings. |
write |
IdentityCenter:instance:createAlias |
Grants permission to create an alias for a specified identity source. |
write |
IdentityCenter:user:create |
Grants permission to create a user. |
write |
IdentityCenter:user:list |
Grants permission to query the user list. |
read |
IdentityCenter:user:describe |
Grants permission to query user details. |
read |
IdentityCenter:user:describeUsers |
Grants permission to obtain user details in batch. |
read |
IdentityCenter:user:update |
Grants permission to update a user. |
write |
IdentityCenter:user:delete |
Grants permission to delete a user. |
write |
IdentityCenter:user:getUserId |
Grants permission to obtain the user ID. |
read |
IdentityCenter:user:enableUser |
Grants permission to enable a user. |
write |
IdentityCenter:user:disableUser |
Grants permission to disable a user. |
write |
IdentityCenter:group:create |
Grants permission to create a group. |
write |
IdentityCenter:group:list |
Grants permission to query the group list. |
read |
IdentityCenter:group:describe |
Grants permission to query group details. |
read |
IdentityCenter:group:describeGroups |
Grants permission to obtain group details in batch. |
read |
IdentityCenter:group:update |
Grants permission to update a group. |
write |
IdentityCenter:group:delete |
Grants permission to delete a group. |
write |
IdentityCenter:group:getGroupId |
Grants permission to obtain the group ID. |
read |
IdentityCenter:groupMembership:create |
Grants permission to add a member to a group. |
write |
IdentityCenter:groupMemberships:list |
Grants permission to query all members in a group. |
read |
IdentityCenter:groupMembership:listForMember |
Grants permission to query all groups that a user is added to. |
read |
IdentityCenter:groupMembership:describe |
Grants permission to query the group membership. |
read |
IdentityCenter:groupMembership:delete |
Grants permission to disassociate users and groups. |
write |
IdentityCenter:groupMembership:getGroupMembershipId |
Grants permission to query the membership ID. |
read |
IdentityCenter:groupMembership:isMembershipInGroup |
Grants permission to query whether a user is in a group. |
read |
IdentityCenter:externalIdp:create |
Grants permission to create an external identity provider. |
write |
IdentityCenter:externalIdp:list |
Grants permission to obtain the identity source configuration of the external identity provider. |
read |
IdentityCenter:externalIdp:enable |
Grants permission to enable an external identity provider. |
write |
IdentityCenter:externalIdp:disable |
Grants permission to disable an external identity provider. |
write |
IdentityCenter:externalIdp:getSpConfiguration |
Grants permission to obtain the configuration of the IAM Identity Center service provider. |
read |
IdentityCenter:externalIdp:update |
Grants permission to update the configuration of the external identity provider. |
write |
IdentityCenter:externalIdp:delete |
Grants permission to delete the configuration of the external identity provider. |
write |
IdentityCenter:externalIdp:importCertificate |
Grants permission to import a certificate. |
write |
IdentityCenter:externalIdp:deleteCertificate |
Grants permission to delete a certificate. |
write |
IdentityCenter:externalIdp:listCertificates |
Grants permission to obtain the certificate list. |
read |
IdentityCenter:externalIdp:createProvisioningTenant |
Grants permission to create a tenant. |
write |
IdentityCenter:externalIdp:listProvisioningTenant |
Grants permission to query the tenant list. |
read |
IdentityCenter:externalIdp:deleteProvisioningTenant |
Grants permission to delete a tenant. |
write |
IdentityCenter:externalIdp:createBearerToken |
Grants permission to create a bearer token. |
write |
IdentityCenter:externalIdp:listBearerTokens |
Grants permission to query the bearer token list. |
read |
IdentityCenter:externalIdp:deleteBearerToken |
Grants permission to delete a bearer token. |
write |
IdentityCenter:user:updatePassword |
Grants permission to update a password by sending a password reset link via email or generating a one-time password for a user. |
write |
IdentityCenter:user:deleteUserMfaDevice |
Grants permission to delete an MFA device for a specified user. |
write |
IdentityCenter:user:updateMfaDevice |
Grants permission to update MFA device information. |
write |
IdentityCenter:user:listMfaDevice |
Grants permission to query the MFA device list. |
read |
IdentityCenter:user:registerVirtualMfaDevice |
Grants permission to begin the creation process of a virtual MFA device. |
write |
IdentityCenter:user:verifyEmail |
Grants permission to verify an email address of a user. |
write |
Each API of IAM Identity Center usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v1/instances/{instance_id}/permission-sets |
organizations:delegatedAdministrators:list |
POST /v1/instances/{instance_id}/permission-sets/{permission_set_id}/attach-managed-policy |
POST /v1/instances/{instance_id}/permission-sets/{permission_set_id}/detach-managed-policy |
PUT /v1/instances/{instance_id}/permission-sets/{permission_set_id} |
DELETE /v1/instances/{instance_id}/permission-sets/{permission_set_id} |
GET /v1/instances/{instance_id}/permission-sets |
GET /v1/instances/{instance_id}/permission-sets/{permission_set_id}/accounts |
GET /v1/instances/{instance_id}/permission-sets/provisioning-statuses |
GET /v1/instances/{instance_id}/permission-sets/{permission_set_id}/managed-policies |
GET /v1/instances/{instance_id}/permission-sets/provisioned-to-accounts |
GET /v1/instances/{instance_id}/permission-sets/provisioning-status/{request_id} |
GET /v1/instances/{instance_id}/permission-sets/{permission_set_id} |
POST /v1/instances/{instance_id}/permission-sets/{permission_set_id}/provision |
GET /v1/instances |
POST /v1/instances/{instance_id}/account-assignments/create |
POST /v1/instances/{instance_id}/account-assignments/delete |
GET /v1/instances/{instance_id}/account-assignments |
GET /v1/instances/{instance_id}/account-assignments/deletion-status/{request_id} |
GET /v1/instances/{instance_id}/account-assignments/creation-status/{request_id} |
GET /v1/instances/{instance_id}/account-assignments/creation-statuses |
GET /v1/instances/{instance_id}/account-assignments/deletion-statuses |
POST /v1/identity-stores/{identity_store_id}/users |
GET /v1/identity-stores/{identity_store_id}/users |
GET /v1/identity-stores/{identity_store_id}/users/{user_id} |
PUT /v1/identity-stores/{identity_store_id}/users/{user_id} |
DELETE /v1/identity-stores/{identity_store_id}/users/{user_id} |
POST /v1/identity-stores/{identity_store_id}/users/retrieve-user-id |
POST /v1/identity-stores/{identity_store_id}/groups |
GET /v1/identity-stores/{identity_store_id}/groups |
GET /v1/identity-stores/{identity_store_id}/groups/{group_id} |
PUT /v1/identity-stores/{identity_store_id}/groups/{group_id} |
DELETE /v1/identity-stores/{identity_store_id}/groups/{group_id} |
POST /v1/identity-stores/{identity_store_id}/groups/retrieve-group-id |
POST /v1/identity-stores/{identity_store_id}/group-memberships |
GET /v1/identity-stores/{identity_store_id}/group-memberships |
GET /v1/identity-stores/{identity_store_id}/group-memberships-for-member |
GET /v1/identity-stores/{identity_store_id}/group-memberships/{membership_id} |
DELETE /v1/identity-stores/{identity_store_id}/group-memberships/{membership_id} |
POST /v1/identity-stores/{identity_store_id}/group-memberships/retrieve-group-membership-id |
POST /v1/identity-stores/{identity_store_id}/is-member-in-groups |
Resources
A resource is what a policy applies to. If you specify a resource for any action in Table 3, the resource URN must be specified in the policy statements using that action, and the policy applies only to these resources. If no resources are specified, the Resource element is marked with an asterisk (*) and the policy applies to all resources. You can also set condition keys in a policy to define resources.
The following table lists the resources that you can define in SCP statements for IAM Identity Center.
Resource |
URN |
instance |
IdentityCenter::<management-account-id>:instance:<instance-id> |
account |
IdentityCenter::<management-account-id>:account:<account-id> |
permissionSet |
IdentityCenter::<management-account-id>:permissionSet:<instance-id>/<permission-set-id> |
Conditions
IAM Identity Center does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
