Identity and Access Management (IAM)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by IAM, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by IAM, see Conditions.
The following table lists the actions that you can define in SCP statements for IAM. The actions without the V5 suffix are used to control access to the old IAM console, and the actions with the V5 suffix are used to control access to the new IAM console.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
iam::listAccessKeys |
Grants permission to list permanent access keys. |
List |
iam::createAccessKey |
Grants permission to create a permanent access key. |
Write |
iam::getAccessKey |
Grants permission to query a permanent access key. |
Read |
iam::updateAccessKey |
Grants permission to update a permanent access key. |
Write |
iam::deleteAccessKey |
Grants permission to delete a permanent access key. |
Write |
iam:projects:list |
Grants permission to list projects. |
List |
iam:projects:create |
Grants permission to create a project. |
Write |
iam:projects:listForUser |
Grants permission to list projects of a specified user. |
List |
iam:projects:update |
Grants permission to update a project. |
Write |
iam:groups:list |
Grants permission to list groups. |
List |
iam:groups:create |
Grants permission to create a group. |
Write |
iam:groups:get |
Grants permission to query a group. |
Read |
iam:groups:delete |
Grants permission to delete a group. |
Write |
iam:groups:update |
Grants permission to update a group. |
Write |
iam:groups:removeUser |
Grants permission to remove a user from a group. |
Write |
iam:groups:listUsers |
Grants permission to list users of a specified group. |
List |
iam:groups:checkUser |
Grants permission to query whether a user is in the group. |
Read |
iam:groups:addUser |
Grants permission to add a user to a group. |
Write |
iam:users:create |
Grants permission to create a user. |
Write |
iam:users:get |
Grants permission to query a user. |
Read |
iam:users:update |
Grants permission to update a user. |
Write |
iam:users:list |
Grants permission to list users. |
List |
iam:users:delete |
Grants permission to delete a user. |
Write |
iam:users:listGroups |
Grants permission to list groups of a specified user. |
List |
iam:users:listVirtualMFADevices |
Grants permission to list virtual MFA devices of a specified user. |
List |
iam:users:createVirtualMFADevice |
Grants permission to create a secret key for a virtual MFA device. |
Write |
iam:users:deleteVirtualMFADevice |
Grants permission to delete a virtual MFA device. |
Write |
iam:users:getVirtualMFADevice |
Grants permission to query a virtual MFA device. |
Read |
iam:users:bindVirtualMFADevice |
Grants permission to bind a virtual MFA device. |
Write |
iam:users:unbindVirtualMFADevice |
Grants permission to unbind a virtual MFA device. |
Write |
iam:identityProviders:list |
Grants permission to list identity providers. |
List |
iam:identityProviders:get |
Grants permission to query an identity provider. |
Read |
iam:identityProviders:create |
Grants permission to create an identity provider. |
Write |
iam:identityProviders:delete |
Grants permission to delete an identity provider. |
Write |
iam:identityProviders:update |
Grants permission to update an identity provider. |
Write |
iam:identityProviders:listMappings |
Grants permission to list mappings of an identity provider. |
List |
iam:identityProviders:getMapping |
Grants permission to query a mapping of an identity provider. |
Read |
iam:identityProviders:createMapping |
Grants permission to create a mapping for an identity provider. |
Write |
iam:identityProviders:deleteMapping |
Grants permission to delete a mapping of an identity provider. |
Write |
iam:identityProviders:updateMapping |
Grants permission to update a mapping of an identity provider. |
Write |
iam:identityProviders:listProtocols |
Grants permission to list protocols of an identity provider. |
List |
iam:identityProviders:getProtocol |
Grants permission to query a protocol of an identity provider. |
Read |
iam:identityProviders:createProtocol |
Grants permission to create a protocol for an identity provider. |
Write |
iam:identityProviders:deleteProtocol |
Grants permission to delete a protocol of an identity provider. |
Write |
iam:identityProviders:updateProtocol |
Grants permission to update a protocol of an identity provider. |
Write |
iam:identityProviders:getSAMLMetadata |
Grants permission to query a SAML metadata file of an identity provider. |
Read |
iam:identityProviders:createSAMLMetadata |
Grants permission to create a SAML metadata file for an identity provider. |
Write |
iam:identityProviders:getOIDCConfig |
Grants permission to query the OIDC configuration of an identity provider. |
Read |
iam:identityProviders:createOIDCConfig |
Grants permission to create the OIDC configuration of an identity provider. |
Write |
iam:identityProviders:updateOIDCConfig |
Grants permission to update the OIDC configuration of an identity provider. |
Write |
iam:securityPolicies:getProtectPolicy |
Grants permission to query an operation protection policy. |
Read |
iam:securityPolicies:updateProtectPolicy |
Grants permission to update an operation protection policy. |
Write |
iam:securityPolicies:getPasswordPolicy |
Grants permission to query a password policy. |
Read |
iam:securityPolicies:updatePasswordPolicy |
Grants permission to update a password policy. |
Write |
iam:securityPolicies:getLoginPolicy |
Grants permission to query a login policy. |
Read |
iam:securityPolicies:updateLoginPolicy |
Grants permission to update a login policy. |
Write |
iam:securityPolicies:getConsoleAclPolicy |
Grants permission to query a console access policy. |
Read |
iam:securityPolicies:updateConsoleAclPolicy |
Grants permission to update a console access policy. |
Write |
iam:securityPolicies:getApiAclPolicy |
Grants permission to query an API access policy. |
Read |
iam:securityPolicies:updateApiAclPolicy |
Grants permission to update an API access policy. |
Write |
iam:users:listLoginProtectSettings |
Grants permission to list user login protection settings under a tenant. |
List |
iam:users:getLoginProtectSetting |
Grants permission to query login protection settings. |
Read |
iam:users:updateLoginProtectSetting |
Grants permission to update login protection settings. |
Write |
iam:quotas:list |
Grants permission to list quotas. |
List |
iam:quotas:listForProject |
Grants permission to list quotas of a specified project. |
List |
iam:agencies:pass |
Grants permission to pass an agency to a cloud service. |
Permission_management |
agency * |
iam:roles:list |
Grants permission to query a permission list. |
List |
iam:roles:get |
Grants permission to query permission details. |
Read |
iam::listRoleAssignments |
Grants permission to query authorization records of a tenant. |
List |
iam:groups:listRolesOnDomain |
Grants permission to query group permissions in global services. |
List |
iam:groups:listRolesOnProject |
Grants permission to query group permissions in project services. |
List |
iam:groups:grantRoleOnDomain |
Grants permission to grant global service permissions to a group. |
Write |
iam:groups:grantRoleOnProject |
Grants permission to grant project service permissions to a group. |
Write |
iam:groups:checkRoleOnDomain |
Grants permission to query whether a group has global service permissions. |
Read |
iam:groups:checkRoleOnProject |
Grants permission to query whether a group has project service permissions. |
Read |
iam:groups:listRoles |
Grants permission to query permissions of a group. |
List |
iam:groups:checkRole |
Grants permission to query whether a group has specified permissions. |
Read |
iam:groups:revokeRole |
Grants permission to remove specified permissions from a group. |
Write |
iam:groups:revokeRoleOnDomain |
Grants permission to remove global service permissions from a group. |
Write |
iam:groups:revokeRoleOnProject |
Grants permission to remove project service permissions from a group. |
Write |
iam:groups:grantRole |
Grants permission to grant specified permissions to a group. |
Write |
iam:roles:create |
Grants permission to create a custom policy. |
Write |
iam:roles:update |
Grants permission to update a custom policy. |
Write |
iam:roles:delete |
Grants permission to delete a custom policy. |
Write |
iam:agencies:list |
Grants permission to list agencies. |
List |
iam:agencies:get |
Grants permission to query details of a specified agency. |
Read |
iam:agencies:create |
Grants permission to create an agency. |
Write |
iam:agencies:update |
Grants permission to update an agency. |
Write |
iam:agencies:delete |
Grants permission to delete an agency. |
Write |
iam:agencies:listRolesOnDomain |
Grants permission to query global service permissions of an agency. |
List |
iam:agencies:listRolesOnProject |
Grants permission to query the permissions of a specified project for an agency. |
List |
iam:agencies:grantRoleOnDomain |
Grants permission to grant global service permissions to an agency. |
Write |
iam:agencies:grantRoleOnProject |
Grants permission to grant project service permissions to an agency. |
Write |
iam:agencies:checkRoleOnDomain |
Grants permission to query whether an agency has global service permissions. |
Read |
iam:agencies:checkRoleOnProject |
Grants permission to query whether an agency has project service permissions. |
Read |
iam:agencies:revokeRoleOnDomain |
Grants permission to remove global service permissions from an agency. |
Write |
iam:agencies:revokeRoleOnProject |
Grants permission to remove project service permissions from an agency. |
Write |
iam:agencies:listRoles |
Grants permission to query permissions of an agency. |
List |
iam:agencies:grantRole |
Grants permission to grant specified permissions to an agency. |
Write |
iam:agencies:checkRole |
Grants permission to query whether an agency has specified permissions. |
Read |
iam:agencies:revokeRole |
Grants permission to remove specified permissions from an agency. |
Write |
iam::listGroupsAssignedEnterpriseProject |
Grants permission to query permissions of a group associated with an enterprise project. |
List |
iam:groups:listRolesOnEnterpriseProject |
List |
iam:groups:grantRoleOnEnterpriseProject |
Grants permission to grant permissions to an enterprise project based on groups. |
Write |
iam:groups:revokeRoleOnEnterpriseProject |
Grants permission to delete permissions of a group associated with an enterprise project. |
Write |
iam:groups:listAssignedEnterpriseProjects |
Grants permission to query enterprise projects associated with a group. |
List |
iam:users:listAssignedEnterpriseProjects |
Grants permission to query enterprise projects associated with a user. |
List |
iam::listUsersAssignedEnterpriseProject |
Grants permission to query users associated with an enterprise project. |
List |
iam:users:listRolesOnEnterpriseProject |
Grants permission to query permissions of a user associated with an enterprise project. |
List |
iam:users:grantRoleOnEnterpriseProject |
Grants permission to grant permissions to an enterprise project based on users. |
Write |
iam:users:revokeRoleOnEnterpriseProject |
Grants permission to delete permissions of a user associated with an enterprise project. |
Write |
iam:agencies:grantRoleOnEnterpriseProject |
Grants permission to grant permissions to an enterprise project based on agencies. |
Write |
iam:agencies:revokeRoleOnEnterpriseProject |
Grants permission to delete permissions of an agency associated with an enterprise project. |
Write |
iam:mfa:listVirtualMFADevicesV5 |
Grants permission to list virtual MFA devices. |
List |
mfa * |
iam:mfa:createVirtualMFADeviceV5 |
Grants permission to create a virtual MFA device. |
Write |
mfa * |
iam:mfa:deleteVirtualMFADeviceV5 |
Write |
mfa * |
iam:mfa:enableV5 |
Grants permission to enable a virtual MFA device. |
Write |
mfa * |
iam:mfa:disableV5 |
Grants permission to disable a virtual MFA device. |
Write |
mfa * |
iam:securitypolicies:getPasswordPolicyV5 |
Grants permission to obtain password policy information. |
Read |
iam:securitypolicies:updatePasswordPolicyV5 |
Write |
iam:securitypolicies:getLoginPolicyV5 |
Grants permission to obtain login policy information. |
Read |
iam:securitypolicies:updateLoginPolicyV5 |
Write |
iam:credentials:listCredentialsV5 |
Grants permission to list permanent access keys for an IAM user. |
List |
user * |
iam:credentials:showAccessKeyLastUsedV5 |
Grants permission to obtain the last usage time of a specified permanent access key. |
Read |
user * |
iam:credentials:createCredentialV5 |
Grants permission to create a permanent access key for an IAM user. |
Write |
user * |
iam:credentials:updateCredentialV5 |
Grants permission to update a permanent access key for an IAM user. |
Write |
user * |
iam:credentials:deleteCredentialV5 |
Grants permission to delete a permanent access key for an IAM user. |
Write |
user * |
iam:users:changePasswordV5 |
Grants permission to change their own passwords for an IAM user. |
Write |
user * |
iam:users:showLoginProfileV5 |
Grants permission to obtain login information of an IAM user. |
Read |
user * |
iam:users:createLoginProfileV5 |
Grants permission to create login information for an IAM user. |
Write |
user * |
iam:users:updateLoginProfileV5 |
Grants permission to update login information for an IAM user. |
Write |
user * |
iam:users:deleteLoginProfileV5 |
Grants permission to delete login information for an IAM user. |
Write |
user * |
iam:users:listUsersV5 |
Grants permission to list IAM users. |
List |
user * |
iam:users:getUserV5 |
Grants permission to obtain information of an IAM user. |
Read |
user * |
iam:users:showUserLastLoginV5 |
Grants permission to obtain the last login time of an IAM user. |
Read |
user * |
iam:users:createUserV5 |
Grants permission to create an IAM user. |
Write |
user * |
iam:users:updateUserV5 |
Grants permission to update an IAM user. |
Write |
user * |
iam:users:deleteUserV5 |
Grants permission to delete an IAM user. |
Write |
user * |
iam:groups:listGroupsV5 |
List |
group * |
iam:groups:getGroupV5 |
Grants permission to obtain group information. |
Read |
group * |
iam:groups:createGroupV5 |
Write |
group * |
iam:groups:updateGroupV5 |
Write |
group * |
iam:groups:deleteGroupV5 |
Write |
group * |
iam:permissions:addUserToGroupV5 |
Grants permission to add an IAM user to a group. |
Write |
group * |
iam:permissions:removeUserFromGroupV5 |
Grants permission to remove an IAM user from a group. |
Write |
group * |
iam:policies:listV5 |
Grants permission to list identity policies. |
List |
policy * |
iam:policies:getV5 |
Grants permission to obtain identity policy information. |
Read |
policy * |
iam:policies:createV5 |
Grants permission to create a custom identity policy. |
policy * |
iam:policies:deleteV5 |
Grants permission to delete a custom identity policy. |
policy * |
iam:policies:listVersionsV5 |
Grants permission to list identity policy versions. |
List |
policy * |
iam:policies:getVersionV5 |
Grants permission to obtain identity policy version information. |
Read |
policy * |
iam:policies:createVersionV5 |
Grants permission to create another version for a custom identity policy. |
policy * |
iam:policies:deleteVersionV5 |
Grants permission to delete a version for a custom identity policy. |
policy * |
iam:policies:setDefaultVersionV5 |
Grants permission to set the default version for a custom identity policy. |
policy * |
iam:agencies:attachPolicyV5 |
Grants permission to attach an identity policy to an agency or trust agency. |
agency * |
iam:groups:attachPolicyV5 |
Grants permission to attach an identity policy to a group. |
group * |
iam:users:attachPolicyV5 |
Grants permission to attach an identity policy to an IAM user. |
user * |
iam:agencies:detachPolicyV5 |
Grants permission to detach an identity policy from an agency or trust agency. |
agency * |
iam:groups:detachPolicyV5 |
Grants permission to detach an identity policy from a group. |
group * |
iam:users:detachPolicyV5 |
Grants permission to detach an identity policy from an IAM user. |
user * |
iam:policies:listEntitiesV5 |
Grants permission to list all entities attached to an identity policy. |
List |
policy * |
iam:agencies:listAttachedPoliciesV5 |
Grants permission to list the identity policies attached to an agency or trust agency. |
List |
agency * |
iam:groups:listAttachedPoliciesV5 |
Grants permission to list the identity policies attached to a group. |
List |
group * |
iam:users:listAttachedPoliciesV5 |
Grants permission to list the identity policies attached to an IAM user. |
List |
user * |
iam:agencies:createServiceLinkedAgencyV5 |
Grants permission to create a service-linked agency to allow the cloud service to perform operations on your behalf. |
Write |
agency * |
iam:agencies:deleteServiceLinkedAgencyV5 |
Grants permission to delete a service-linked agency. |
Write |
agency * |
iam:agencies:getServiceLinkedAgencyDeletionStatusV5 |
Grants permission to obtain the deletion status of a service-linked agency. |
Read |
agency * |
iam:agencies:listV5 |
Grants permission to list agencies and trust agencies. |
List |
agency * |
iam:agencies:getV5 |
Grants permission to obtain agencies and trust agencies. |
Read |
agency * |
iam:agencies:createV5 |
Grants permission to create a trust agency. |
Write |
agency * |
iam:agencies:updateV5 |
Grants permission to update a trust agency. |
Write |
agency * |
iam:agencies:deleteV5 |
Grants permission to delete a trust agency. |
Write |
agency * |
iam:agencies:updateTrustPolicyV5 |
Grants permission to update the trust policy of a trust agency. |
Write |
agency * |
iam::listTagsForResourceV5 |
Grants permission to list resource tags. |
List |
agency |
user |
iam::tagForResourceV5 |
Grants permission to set resource tags. |
Tagging |
agency |
user |
iam::untagForResourceV5 |
Grants permission to delete resource tags. |
Tagging |
agency |
user |
iam::getAccountSummaryV5 |
Grants permission to obtain the IAM entity usage and IAM quotas of an account. |
List |
iam::getAsymmetricSignatureSwitchV5 |
Grants permission to obtain the asymmetric signature switch status of a temporary token. |
Read |
iam::setAsymmetricSignatureSwitchV5 |
Grants permission to set the asymmetric signature switch status of a temporary token. |
Write |
Each API of IAM usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v3.0/OS-CREDENTIAL/credentials |
POST /v3.0/OS-CREDENTIAL/credentials |
GET /v3.0/OS-CREDENTIAL/credentials/{access_key} |
iam::getAccessKey |
PUT /v3.0/OS-CREDENTIAL/credentials/{access_key} |
DELETE /v3.0/OS-CREDENTIAL/credentials/{access_key} |
GET /v3.0/OS-QUOTA/domains/{domain_id} |
iam:quotas:list |
GET /v3.0/OS-QUOTA/projects/{project_id} |
GET /v3/projects |
iam:projects:list |
POST /v3/projects |
GET /v3/users/{user_id}/projects |
PATCH /v3/projects/{project_id} |
PUT /v3-ext/projects/{project_id} |
GET /v3/groups |
iam:groups:list |
POST /v3/groups |
iam:groups:create |
GET /v3/groups/{group_id} |
iam:groups:get |
DELETE /v3/groups/{group_id} |
iam:groups:delete |
PATCH /v3/groups/{group_id} |
iam:groups:update |
GET /v3/groups/{group_id}/users |
HEAD /v3/groups/{group_id}/users/{user_id} |
PUT /v3/groups/{group_id}/users/{user_id} |
DELETE /v3/groups/{group_id}/users/{user_id} |
POST /v3.0/OS-USER/users |
iam:users:create |
GET /v3.0/OS-USER/users/{user_id} |
iam:users:get |
PUT /v3.0/OS-USER/users/{user_id} |
iam:users:update |
PUT /v3.0/OS-USER/users/{user_id}/info |
iam:users:update |
GET /v3/users |
iam:users:list |
POST /v3/users |
iam:users:create |
GET /v3/users/{user_id} |
iam:users:get |
DELETE /v3/users/{user_id} |
iam:users:delete |
PATCH /v3/users/{user_id} |
iam:users:update |
GET /v3/users/{user_id}/groups |
GET /v3.0/OS-MFA/virtual-mfa-devices |
POST /v3.0/OS-MFA/virtual-mfa-devices |
DELETE /v3.0/OS-MFA/virtual-mfa-devices |
GET /v3.0/OS-MFA/users/{user_id}/virtual-mfa-device |
PUT /v3.0/OS-MFA/mfa-devices/bind |
PUT /v3.0/OS-MFA/mfa-devices/unbind |
GET /v3.0/OS-USER/login-protects |
GET /v3.0/OS-USER/users/{user_id}/login-protect |
PUT /v3.0/OS-USER/users/{user_id}/login-protect |
GET /v3/OS-FEDERATION/identity_providers |
GET /v3/OS-FEDERATION/identity_providers/{id} |
PUT /v3/OS-FEDERATION/identity_providers/{id} |
DELETE /v3/OS-FEDERATION/identity_providers/{id} |
PATCH /v3/OS-FEDERATION/identity_providers/{id} |
GET /v3/OS-FEDERATION/mappings |
GET /v3/OS-FEDERATION/mappings/{id} |
PUT /v3/OS-FEDERATION/mappings/{id} |
DELETE /v3/OS-FEDERATION/mappings/{id} |
PATCH /v3/OS-FEDERATION/mappings/{id} |
GET /v3/OS-FEDERATION/identity_providers/{idp_id}/protocols |
GET /v3/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id} |
PUT /v3/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id} |
DELETE /v3/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id} |
PATCH /v3/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id} |
GET /v3-ext/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id}/metadata |
POST /v3-ext/OS-FEDERATION/identity_providers/{idp_id}/protocols/{protocol_id}/metadata |
GET /v3.0/OS-FEDERATION/identity-providers/{idp_id}/openid-connect-config |
POST /v3.0/OS-FEDERATION/identity-providers/{idp_id}/openid-connect-config |
PUT /v3.0/OS-FEDERATION/identity-providers/{idp_id}/openid-connect-config |
GET /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/protect-policy |
PUT /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/protect-policy |
GET /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/password-policy |
PUT /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/password-policy |
GET /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/login-policy |
PUT /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/login-policy |
GET /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/console-acl-policy |
PUT /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/console-acl-policy |
GET /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/api-acl-policy |
PUT /v3.0/OS-SECURITYPOLICY/domains/{domain_id}/api-acl-policy |
GET /v3/roles |
iam:roles:list |
GET /v3/roles/{role_id} |
iam:roles:get |
GET /v3.0/OS-PERMISSION/role-assignments |
GET /v3/domains/{domain_id}/groups/{group_id}/roles |
GET /v3/projects/{project_id}/groups/{group_id}/roles |
PUT /v3/domains/{domain_id}/groups/{group_id}/roles/{role_id} |
PUT /v3/projects/{project_id}/groups/{group_id}/roles/{role_id} |
HEAD /v3/domains/{domain_id}/groups/{group_id}/roles/{role_id} |
HEAD /v3/projects/{project_id}/groups/{group_id}/roles/{role_id} |
GET /v3/OS-INHERIT/domains/{domain_id}/groups/{group_id}/roles/inherited_to_projects |
HEAD /v3/OS-INHERIT/domains/{domain_id}/groups/{group_id}/roles/{role_id}/inherited_to_projects |
DELETE /v3/OS-INHERIT/domains/{domain_id}/groups/{group_id}/roles/{role_id}/inherited_to_projects |
DELETE /v3/domains/{domain_id}/groups/{group_id}/roles/{role_id} |
DELETE /v3/projects/{project_id}/groups/{group_id}/roles/{role_id} |
PUT /v3/OS-INHERIT/domains/{domain_id}/groups/{group_id}/roles/{role_id}/inherited_to_projects |
GET /v3.0/OS-ROLE/roles |
iam:roles:list |
GET /v3.0/OS-ROLE/roles/{role_id} |
iam:roles:get |
POST /v3.0/OS-ROLE/roles |
iam:roles:create |
iam:roles:create |
PATCH /v3.0/OS-ROLE/roles/{role_id} |
iam:roles:update |
iam:roles:update |
DELETE /v3.0/OS-ROLE/roles/{role_id} |
iam:roles:delete |
GET /v3.0/OS-AGENCY/agencies |
iam:agencies:list |
GET /v3.0/OS-AGENCY/agencies/{agency_id} |
iam:agencies:get |
POST /v3.0/OS-AGENCY/agencies |
PUT /v3.0/OS-AGENCY/agencies/{agency_id} |
DELETE /v3.0/OS-AGENCY/agencies/{agency_id} |
GET /v3.0/OS-AGENCY/domains/{domain_id}/agencies/{agency_id}/roles |
GET /v3.0/OS-AGENCY/projects/{project_id}/agencies/{agency_id}/roles |
PUT /v3.0/OS-AGENCY/domains/{domain_id}/agencies/{agency_id}/roles/{role_id} |
PUT /v3.0/OS-AGENCY/projects/{project_id}/agencies/{agency_id}/roles/{role_id} |
HEAD /v3.0/OS-AGENCY/domains/{domain_id}/agencies/{agency_id}/roles/{role_id} |
HEAD /v3.0/OS-AGENCY/projects/{project_id}/agencies/{agency_id}/roles/{role_id} |
DELETE /v3.0/OS-AGENCY/domains/{domain_id}/agencies/{agency_id}/roles/{role_id} |
DELETE /v3.0/OS-AGENCY/projects/{project_id}/agencies/{agency_id}/roles/{role_id} |
GET /v3.0/OS-INHERIT/domains/{domain_id}/agencies/{agency_id}/roles/inherited_to_projects |
PUT /v3.0/OS-INHERIT/domains/{domain_id}/agencies/{agency_id}/roles/{role_id}/inherited_to_projects |
HEAD /v3.0/OS-INHERIT/domains/{domain_id}/agencies/{agency_id}/roles/{role_id}/inherited_to_projects |
DELETE /v3.0/OS-INHERIT/domains/{domain_id}/agencies/{agency_id}/roles/{role_id}/inherited_to_projects |
GET /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/groups |
GET /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/groups/{group_id}/roles |
PUT /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/groups/{group_id}/roles/{role_id} |
DELETE /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/groups/{group_id}/roles/{role_id} |
GET /v3.0/OS-PERMISSION/groups/{group_id}/enterprise-projects |
GET /v3.0/OS-PERMISSION/users/{user_id}/enterprise-projects |
GET /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/users |
GET /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/users/{user_id}/roles |
PUT /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/users/{user_id}/roles/{role_id} |
DELETE /v3.0/OS-PERMISSION/enterprise-projects/{enterprise_project_id}/users/{user_id}/roles/{role_id} |
PUT /v3.0/OS-PERMISSION/subjects/agency/scopes/enterprise-project/role-assignments |
DELETE /v3.0/OS-PERMISSION/subjects/agency/scopes/enterprise-project/role-assignments |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for IAM.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, iam:) only apply to operations of the IAM service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for IAM. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
iam:PolicyURN |
string |
Single-valued |
Filters access by the URN of the identity policy |
iam:ServicePrincipal |
string |
Single-valued |
Filters access by the service ID of the cloud service transferred by the service-linked agency |
