On this page
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by IAM custom identity policies and Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an identity policy SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by ServiceStage, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by ServiceStage, see Conditions.
The following table lists the actions that you can define in identity policy SCP statements for ServiceStage.
Table 1 Actions supported by ServiceStage
Action
Access Level
Resource Type
Condition Key
servicestage:app:getApplication
Querying an application
read
app
servicestage:app:createApplication
Creating an application
write
app
servicestage:app:modifyApplication
Updating an application
write
app
servicestage:app:deleteApplication
Deleting an application
write
app
servicestage:app:listApplication
Querying the application list
list
servicestage:app:getConfiguration
Querying application configuration
read
app
servicestage:app:deleteConfiguration
Deleting application configuration
write
app
servicestage:app:modifyConfiguration
Updating application configuration
write
app
servicestage:app:getComponent
Querying an application component
read
app
servicestage:app:createComponent
Creating an application component
write
app
servicestage:app:modifyComponent
Updating an application component
write
app
servicestage:app:deleteComponent
Deleting an application component
write
app
servicestage:app:listComponent
Querying the application component list
list
servicestage:environment:create
Creating an environment
write
environment
servicestage:environment:get
Querying an environment
read
environment
servicestage:environment:list
Querying the environment list
list
servicestage:environment:modify
Updating an environment
write
environment
servicestage:environment:delete
Deleting an environment
write
environment
servicestage:environment:tag
(TMS users) Creating an environment tag
tagging
environment
servicestage:app:tag
(TMS users) Creating an application tag
tagging
app
servicestage:environment:listResourcesByTag
(TMS users) Querying environments by tag
read
environment
servicestage:app:listResourcesByTag
(TMS users) Querying applications by tag
read
app
servicestage:environment:unTagResource
(TMS users) Deleting an environment tag
tagging
environment
servicestage:app:unTagResource
(TMS users) Deleting an application tag
tagging
app
servicestage:environment:listTags
(TMS users) Querying the environment tag list
read
servicestage:app:listTags
(TMS users) Querying the application tag list
read
servicestage:pipeline:get
Querying a pipeline
read
pipeline
servicestage:pipeline:create
Creating a pipeline
write
pipeline
servicestage:pipeline:modify
Updating a pipeline
write
pipeline
servicestage:pipeline:delete
Deleting a pipeline
write
pipeline
servicestage:pipeline:list
Querying the pipeline list
list
servicestage:assembling:runtimeList
Querying the technology stack list
read
servicestage:assembling:getInfo
Querying a build task
list
servicestage:assembling:create
Creating a build task
write
assembling
servicestage:assembling:modify
Updating a build task
write
assembling
servicestage:assembling:delete
Deleting a build task
write
assembling
servicestage:assembling:list
Querying the build task list
list
servicestage:repositoryAuth:list
Obtaining the repository authorization list
list
servicestage:repositoryAuth:get
Obtaining repository authorization
read
repositoryAuth
servicestage:repositoryAuth:create
Creating repository authorization
write
repositoryAuth
servicestage:repositoryAuth:delete
Deleting repository authorization
write
repositoryAuth
servicestage:environment:listTagsForResource
(EPS users) Querying the environment tag list
read
environment
servicestage:app:listTagsForResource
(EPS users) Querying the application tag list
read
app
Each API of ServiceStage usually supports one or more actions. Table 2 lists the actions and dependencies supported by ServiceStage APIs.
Table 2 Actions and dependencies supported by ServiceStage APIs
API
Action
Dependencies
GET /v2/{project_id}/cas/metadata/runtimes
GET /v2/{project_id}/cas/metadata/flavors
POST /v2/{project_id}/cas/environments
GET /v2/{project_id}/cas/environments
PUT /v2/{project_id}/cas/environments/{environment_id}
DELETE /v2/{project_id}/cas/environments/{environment_id}
GET /v2/{project_id}/cas/environments/{environment_id}
PATCH /v2/{project_id}/cas/environments/{environment_id}/resources
POST /v2/{project_id}/cas/applications
GET /v2/{project_id}/cas/applications
PUT /v2/{project_id}/cas/applications/{application_id}
DELETE /v2/{project_id}/cas/applications/{application_id}
GET /v2/{project_id}/cas/applications/{application_id}
PUT /v2/{project_id}/cas/applications/{application_id}/configuration
DELETE /v2/{project_id}/cas/applications/{application_id}/configuration
GET /v2/{project_id}/cas/applications/{application_id}/configuration
POST /v2/{project_id}/cas/applications/{application_id}/components
GET /v2/{project_id}/cas/applications/{application_id}/components
PUT /v2/{project_id}/cas/applications/{application_id}/components/{component_id}
DELETE /v2/{project_id}/cas/applications/{application_id}/components/{component_id}
GET /v2/{project_id}/cas/applications/{application_id}/components/{component_id}
POST /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances
GET /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances
POST /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances/{instance_id}/action
PUT /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances/{instance_id}
DELETE /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances/{instance_id}
GET /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances/{instance_id}
GET /v2/{project_id}/cas/applications/{application_id}/components/{component_id}/instances/{instance_id}/snapshots
GET /v2/{project_id}/cas/jobs/{job_id}
POST /v3/{project_id}/cas/environments
GET /v3/{project_id}/cas/environments
PUT /v3/{project_id}/cas/environments/{environment_id}
DELETE /v3/{project_id}/cas/environments/{environment_id}
GET /v3/{project_id}/cas/environments/{environment_id}
PUT /v3/{project_id}/cas/environments/{environment_id}/resources
GET /v3/{project_id}/cas/environments/{environment_id}/resources
POST /v3/{project_id}/cas/applications
GET /v3/{project_id}/cas/applications
PUT /v3/{project_id}/cas/applications/{application_id}
GET /v3/{project_id}/cas/applications/{application_id}
GET /v3/{project_id}/cas/applications/{application_id}/configuration
PUT /v3/{project_id}/cas/applications/{application_id}/configuration
DELETE /v3/{project_id}/cas/applications/{application_id}/configuration
POST /v3/{project_id}/cas/applications/{application_id}/components
GET /v3/{project_id}/cas/applications/{application_id}/components
GET /v3/{project_id}/cas/components
PUT /v3/{project_id}/cas/applications/{application_id}/components/{component_id}
DELETE /v3/{project_id}/cas/applications/{application_id}/components/{component_id}
GET /v3/{project_id}/cas/applications/{application_id}/components/{component_id}
POST /v3/{project_id}/cas/applications/{application_id}/components/{component_id}/action
GET /v3/{project_id}/cas/applications/{application_id}/components/{component_id}/records
GET /v3/{project_id}/cas/runtimestacks
GET /v1/{project_id}/git/auths
GET /v1/{project_id}/git/auths/{repo_type}/redirect
POST /v1/{project_id}/git/auths/{repo_type}/oauth
POST /v1/{project_id}/git/auths/{repo_type}/personal
POST /v1/{project_id}/git/auths/{repo_type}/password
DELETE /v1/{project_id}/git/auths/{name}
GET /v2/{project_id}/servicestage-environment/{environment_id}/tags
GET /v2/{project_id}/servicestage-application/{app_id}/tags
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for ServiceStage.
Table 3 Resource types supported by ServiceStage
Resource Type
URN
app
servicestage:<region>:<account-id>:app:<app-id>
environment
servicestage:<region>:<account-id>:environment:<environment-id>
pipeline
servicestage:<region>:<account-id>:pipeline:<pipeline-id>
assembling
servicestage:<region>:<account-id>:assembling:<assembling-id>
repositoryAuth
servicestage:<region>:<account-id>:repositoryAuth:<repositoryAuth-id>
Conditions
ServiceStage does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
