Distributed Cache Service (DCS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by DCS, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by DCS, see Conditions.
The following table lists the actions that you can define in SCP statements for DCS.
Action |
Description |
Access Level |
Resource Type (* required) |
Condition Key |
dcs:instance:create |
Grants permission to create DCS instances. |
write |
dcs:instance:list |
Grants permission to list DCS instances. |
list |
g:EnterpriseProjectId |
dcs:instance:exportListFile |
Grants permission to download the exported DCS instance list file. |
list |
dcs:instance:delete |
Grants permission to delete DCS instances. |
write |
instance |
dcs:instance:get |
Grants permission to query DCS instances. |
read |
instance * |
dcs:instance:modify |
Grants permission to modify DCS instances. |
write |
instance * |
dcs:instance:scale |
Grants permission to increase DCS instance specifications. |
write |
instance * |
dcs:instance:swap |
Grants permission to perform master/replica switchovers on DCS instances. |
write |
instance * |
dcs:instance:modifyAuthInfo |
Grants permission to modify the passwords of DCS instances. |
write |
instance * |
dcs:instance:modifyStatus |
Grants permission to restart DCS instances or clear their data. |
write |
instance * |
dcs:instance:getConfiguration |
Grants permission to query DCS instance configuration parameters. |
read |
instance * |
dcs:instance:modifyConfiguration |
Grants permission to modify DCS instance configuration parameters. |
write |
instance * |
dcs:instance:deleteDataBackupFile |
Grants permission to delete DCS instance backup data. |
write |
instance * |
dcs:instance:restoreData |
Grants permission to restore DCS instance data. |
write |
instance * |
dcs:instance:getDataRestoreLog |
Grants permission to query DCS instance restoration records. |
read |
instance * |
dcs:instance:downloadBackupData |
Grants permission to obtain backup file URLs. |
read |
instance * |
dcs:instance:backupData |
Grants permission to back up DCS instance data. |
write |
instance * |
dcs:instance:getDataBackupLog |
Grants permission to query DCS instance backup records. |
read |
instance * |
dcs:migrationTask:create |
Grants permission to create data migration tasks. |
write |
dcs:migrationTask:list |
Grants permission to list data migration tasks. |
list |
dcs:migrationTask:delete |
Grants permission to delete data migration tasks. |
write |
migrationTask |
dcs:migrationTask:get |
Grants permission to query data migration tasks. |
read |
migrationTask * |
dcs:migrationTask:modify |
Grants permission to configure and stop data migration tasks. |
write |
migrationTask * |
dcs:instance:listBigKey |
Grants permission to query big keys. |
list |
instance * |
dcs:instance:getBigKey |
Grants permission to query big key details. |
read |
instance * |
dcs:instance:deleteBigKeyScanTask |
Grants permission to delete big key scan tasks. |
write |
instance |
dcs:instance:updateBigKeyAutoScanConfig |
Grants permission to reconfigure big key scan tasks. |
write |
instance * |
dcs:instance:getBigKeyAutoScanConfig |
Grants permission to query configurations of big key scan tasks. |
read |
instance * |
dcs:instance:analyzeHotKey |
Grants permission to perform hot key analysis. |
write |
instance * |
dcs:instance:listHotKey |
Grants permission to list hot keys. |
list |
instance * |
dcs:instance:getHotKey |
Grants permission to query hot key details. |
read |
instance * |
dcs:instance:deleteHotKeyScanTask |
Grants permission to delete hot key scan tasks. |
write |
instance |
dcs:instance:updateHotKeyAutoScanConfig |
Grants permission to reconfigure hot key scan tasks. |
write |
instance * |
dcs:instance:getHotKeyAutoScanConfig |
Grants permission to query configurations of hot key scan tasks. |
read |
instance * |
dcs:instance:analyzeExpiredKey |
Grants permission to perform expired key analysis. |
write |
instance * |
dcs:instance:getAutoExpiredKeyScanTask |
Grants permission to query expired key scan tasks. |
read |
instance * |
dcs:instance:updateExpiredKeyScanConfig |
Grants permission to reconfigure expired key scan tasks. |
write |
instance * |
dcs:instance:getExpiredKeyScanConfig |
Grants permission to query configurations of expired key scan tasks. |
read |
instance * |
dcs:slowlog:list |
Grants permission to query slow query logs. |
list |
instance * |
dcs:aclaccount:create |
Grants permission to create ACL accounts. |
write |
instance * |
dcs:aclaccount:list |
Grants permission to query ACL accounts. |
list |
instance * |
dcs:aclaccount:modify |
Grants permission to modify the passwords of ACL accounts. |
write |
instance * |
dcs:aclaccount:delete |
Grants permission to delete ACL accounts. |
write |
instance * |
dcs:whitelist:modify |
Grants permission to configure IP address whitelist groups. |
write |
instance * |
dcs:whitelist:list |
Grants permission to query the IP address whitelist of instances. |
list |
instance * |
dcs:instance:getBackgroundTask |
Grants permission to query background tasks. |
read |
instance * |
dcs:instance:deleteBackgroundTask |
Grants permission to delete background tasks. |
write |
instance * |
dcs:instance:createDiagnosisTask |
Grants permission to diagnose instances. |
write |
instance * |
dcs:instance:listDiagnosisTask |
Grants permission to query diagnosis tasks. |
list |
instance * |
dcs:instance:getDiagnosisTask |
Grants permission to query diagnosis details. |
read |
instance * |
dcs:instance:deleteDiagnosisTask |
Grants permission to delete diagnosis records. |
write |
instance * |
dcs:template:list |
Grants permission to list parameter templates. |
list |
dcs:template:create |
Grants permission to customize templates. |
write |
dcs:template:get |
Grants permission to query parameter templates. |
read |
dcs:template:modify |
Grants permission to modify custom templates. |
write |
dcs:template:delete |
Grants permission to delete custom templates. |
write |
dcs:tag:list |
Grants permission to query all tags in your tenant account. |
list |
dcs:tag:modify |
Grants permission to add or delete tags in batches. |
write |
instance * |
dcs:tag:get |
Grants permission to query tags of an instance. |
read |
instance * |
dcs:redisLog:get |
Grants permission to obtain log download URLs. |
read |
instance * |
dcs:quota:get |
Grants permission to query tenant quotas. |
read |
dcs:instance:webcli |
Grants permission to connect to DCS Redis instances using Web CLI. |
write |
instance * |
dcs:clientIpTrans:modify |
Grants permission to enable or disable client IP pass-through. |
write |
instance * |
dcs:clients:list |
Grants permission to list Redis sessions. |
read |
instance * |
dcs:clients:kill |
Grants permission to kill Redis sessions. |
write |
instance * |
dcs:ssl:get |
Grants permissions to obtain SSL certificate information. |
read |
instance * |
dcs:ssl:modify |
Grants permissions to modify the SSL setting. |
write |
instance * |
dcs:job:get |
Grants permission to obtain the pre-check result. |
read |
dcs:task:list |
Grants permission to list background tasks. |
list |
dcs:task:delete |
write |
Each API of DCS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v2/{project_id}/instances |
dcs:instance:list |
DELETE /v2/{project_id}/instances |
GET /v2/{project_id}/instances/{instance_id} |
dcs:instance:get |
DELETE /v2/{project_id}/instances/{instance_id} |
PUT /v2/{project_id}/instances/{instance_id} |
POST /v2/{project_id}/instances/{instance_id}/resize |
POST /v2/{project_id}/instances/{instance_id}/resize/check-job |
POST /v2/{project_id}/instances/{instance_id}/swap |
dcs:instance:swap |
PUT /v2/{project_id}/instances/{instance_id}/password |
POST /v2/{project_id}/instances/{instance_id}/password/reset |
GET /v2/{project_id}/instances/status |
dcs:instance:list |
PUT /v2/{project_id}/instances/status |
GET /v2/{project_id}/instances/statistic |
dcs:instance:list |
POST /v2/{project_id}/instances/{instance_id}/groups/{group_id}/replications/{node_id}/slave-priority |
DELETE /v2/{project_id}/instances/{instance_id}/groups/{group_id}/replications/{node_id}/remove-ip |
GET /v2/{project_id}/instance/{instance_id}/groups |
dcs:instance:get |
GET /v2/{project_id}/instances/{instance_id}/configs |
PUT /v2/{project_id}/instances/{instance_id}/configs |
PUT /v2/{project_id}/instances/{instance_id}/async-configs |
DELETE /v2/{project_id}/instances/{instance_id}/backups/{backup_id} |
POST /v2/{project_id}/instances/{instance_id}/restores |
GET /v2/{project_id}/instances/{instance_id}/restores |
POST /v2/{project_id}/instances/{instance_id}/backups/{backup_id}/links |
POST /v2/{project_id}/instances/{instance_id}/backups |
GET /v2/{project_id}/instances/{instance_id}/backups |
POST /v2/{project_id}/migration-task |
GET /v2/{project_id}/migration-tasks |
DELETE /v2/{project_id}/migration-tasks/delete |
GET /v2/{project_id}/migration-task/{task_id} |
POST /v2/{project_id}/migration-task/{task_id}/stop |
GET /v2/{project_id}/migration-task/{task_id}/stats |
POST /v2/{project_id}/migration/instance |
POST /v2/{project_id}/migration/{task_id}/task |
POST /v2/{project_id}/migration-task/batch-stop |
POST /v2/{project_id}/migration-task/{task_id}/sync-stop |
GET /v2/{project_id}/dcs/tags |
dcs:tag:list |
POST /v2/{project_id}/dcs/{instance_id}/tags/action |
dcs:tag:modify |
GET /v2/{project_id}/instances/{instance_id}/tags |
dcs:tag:get |
GET /v2/{project_id}/instances/{instance_id}/bigkey-tasks |
PUT /v2/{project_id}/instances/{instance_id}/bigkey/autoscan |
GET /v2/{project_id}/instances/{instance_id}/bigkey/autoscan |
POST /v2/{project_id}/instances/{instance_id}/hotkey-task |
GET /v2/{project_id}/instances/{instance_id}/hotkey-tasks |
GET /v2/{project_id}/instances/{instance_id}/hotkey-task/{hotkey_id} |
DELETE /v2/{project_id}/instances/{instance_id}/hotkey-task/{hotkey_id} |
PUT /v2/{project_id}/instances/{instance_id}/hotkey/autoscan |
GET /v2/{project_id}/instances/{instance_id}/hotkey/autoscan |
POST /v2/{project_id}/instances/{instance_id}/scan-expire-keys-task |
GET /v2/{project_id}/instances/{instance_id}/auto-expire/histories |
POST /v2/{project_id}/instances/{instance_id}/auto-expire/scan |
GET /v2/{project_id}/instances/{instance_id}/scan-expire-keys/autoscan-config |
PUT /v2/{project_id}/instances/{instance_id}/scan-expire-keys/autoscan-config |
GET /v2/{project_id}/instances/{instance_id}/slowlog |
dcs:slowlog:list |
GET /v2/{project_id}/instances/{instance_id}/redislog |
dcs:redisLog:get |
POST /v2/{project_id}/instances/{instance_id}/redislog |
dcs:redisLog:get |
POST /v2/{project_id}/instances/{instance_id}/redislog/{id}/links |
dcs:redisLog:get |
POST /v2/{project_id}/instances/{instance_id}/accounts |
GET /v2/{project_id}/instances/{instance_id}/accounts |
PUT /v2/{project_id}/instances/{instance_id}/accounts/{account_id}/password/modify |
PUT /v2/{project_id}/instances/{instance_id}/accounts/{account_id}/password/reset |
PUT /v2/{project_id}/instances/{instance_id}/accounts/{account_id} |
PUT /v2/{project_id}/instances/{instance_id}/accounts/{account_id}/role |
DELETE /v2/{project_id}/instances/{instance_id}/accounts/{account_id} |
PUT /v2/{project_id}/instance/{instance_id}/whitelist |
GET /v2/{project_id}/instance/{instance_id}/whitelist |
GET /v2/{project_id}/instances/{instance_id}/tasks |
DELETE /v2/{project_id}/instances/{instance_id}/tasks/{task_id} |
GET /v2/{project_id}/quota |
dcs:quota:get |
GET /v2/{project_id}/dims/monitored-objects/{instance_id} |
dcs:instance:get |
GET /v2/{project_id}/dims/monitored-objects |
dcs:instance:list |
POST /v2/{project_id}/instances/{instance_id}/diagnosis |
GET /v2/{project_id}/instances/{instance_id}/diagnosis |
GET /v2/{project_id}/diagnosis/{report_id} |
DELETE /v2/{project_id}/instances/{instance_id}/diagnosis |
GET /v2/{project_id}/config-templates |
dcs:template:list |
POST /v2/{project_id}/config-templates |
GET /v2/{project_id}/config-templates/{template_id} |
dcs:template:get |
DELETE /v2/{project_id}/config-templates/{template_id} |
PUT /v2/{project_id}/config-templates/{template_id} |
GET /v2/{project_id}/instances-logical-nodes |
dcs:instance:list |
GET /v2/{project_id}/instances/{instance_id}/config-histories |
dcs:instance:get |
PUT /v2/{project_id}/instances/{instance_id}/bandwidth |
PUT /v2/{project_id}/instances/{instance_id}/async-swap |
dcs:instance:swap |
GET /v2/{project_id}/instances/{instance_id}/operations |
dcs:instance:get |
POST /v2/{project_id}/instances/{instance_id}/webcli/auth |
POST /v2/{project_id}/instances/{instance_id}/webcli/command |
POST /v2/{project_id}/instances/{instance_id}/webcli/logout |
PUT /v2/{project_id}/{instance_id}/client-ip-transparent-transmission |
GET /v2/{project_id}/instances/{instance_id}/bigkey-task/{bigkey_id} |
DELETE /v2/{project_id}/instances/{instance_id}/bigkey-task/{bigkey_id} |
POST /v2/{project_id}/instances/{instance_id}/clients |
dcs:clients:list |
GET /v2/{project_id}/instances/{instance_id}/clients |
dcs:clients:list |
POST /v2/{project_id}/instances/{instance_id}/clients/kill |
dcs:clients:kill |
POST /v2/{project_id}/instances/{instance_id}/clients/kill-all |
dcs:clients:kill |
GET /v2/{project_id}/instances/{instance_id}/config-histories/{history_id} |
dcs:instance:get |
GET /v2/{project_id}/instances/{instance_id}/deletable-replication |
POST /v2/{project_id}/instances/export |
dcs:instance:list |
GET /v2/{project_id}/instance/{instance_id}/groups/{group_id}/group-nodes-state |
dcs:instance:get |
POST /v2/{project_id}/instance/{instance_id}/groups/{group_id}/replications/{node_id}/async-switchover |
dcs:instance:swap |
GET /v2/{project_id}/instances/{instance_id}/ssl |
dcs:ssl:get |
PUT /v2/{project_id}/instances/{instance_id}/ssl |
dcs:ssl:modify |
POST /v2/{project_id}/instances/{instance_id}/ssl-certs/download |
dcs:ssl:modify |
GET /v2/{project_id}/instances/{instance_id}/tasks/{task_id}/progress |
GET /v2/{project_id}/instances/export-job |
GET /v2/{project_id}/jobs/{job_id} |
dcs:job:get |
PUT /v2/{project_id}/migration-task/{task_id} |
POST /v2/{project_id}/migration-task/{task_id}/exchange-ip |
GET /v2/{project_id}/tasks |
dcs:task:list |
DELETE /v2/{project_id}/tasks/{task_id} |
dcs:task:delete |
GET /v2/{project_id}/migration-task/{task_id}/logs |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for DCS.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, dcs:) only apply to operations of the DCS service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for DCS. You can include these condition keys to specify conditions for when your SCP is in effect.
