On this page
SSL Certificate Manager (SCM)
Updated on 2025-02-25 GMT+08:00
The Organizations service also provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN for the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table.
    For details about the resource types defined by the SCM, see Table 3.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by SCM, see Conditions.
The following table lists the actions that you can define in SCP statements for SCM.
Table 1 Actions supported by SCM
Action
Access Level
Resource Type (*: Required)
Condition Key
scm:cert:subscribe
Grants the permission to buy a certificate.
write
cert *
g:EnterpriseProjectId
scm:cert:update
Grants the permission to update a certificate.
write
cert *
g:ResourceTag/<tag-key>
scm:cert:delete
Grants the permission to delete a certificate.
write
cert *
scm:cert:apply
Grants the permission to request a certificate.
write
cert *
  • g:EnterpriseProjectId
  • scm:DomainNames
  • scm:ValidationMethod
  • scm:KeyAlgorithm
scm:cert:revoke
Grants the permission to revoke a certificate.
write
cert *
scm:cert:cancel
Grants the permission to cancel a certificate request.
write
cert *
scm:cert:reissue
Grants the permission to re-issue a certificate.
write
cert *
  • scm:DomainNames
scm:cert:push
Grants the permission to push a certificate to other service.
write
cert *
scm:cert:import
Grants the permission to import a certificate.
write
cert *
scm:cert:export
Grants the permission to export a certificate.
read
cert *
scm:cert:upload
Grants the permission to upload a certificate to SCM.
write
cert *
scm:cert:download
Grants the permission to download a certificate.
read
cert *
scm:cert:save
Grants the permission to supplement certificate information.
write
cert *
scm:cert:addDomain
Grants the permission to add more domain names for a certificate.
write
cert *
  • scm:DomainNames
scm:cert:expandQuota
Grants the permission to expand the certificate quota.
write
scm:cert:renew
Grants the permission to renew a certificate.
write
cert *
scm:cert:unsubscribe
Grants the permission to unsubscribe from a certificate.
write
cert *
scm:cert:autoRenew
Grants the permission to enable automatic certificate renewal.
write
cert *
scm:cert:list
Grants the permission to query the certificate list.
list
cert *
scm:cert:get
Grants the permission to query certificate details.
read
cert *
scm:cert:getApplicationInfo
Grants the permission to query certificate supplementation information.
read
cert *
scm:cert:listPushHistory
Grants the permission to query certificate push records.
list
cert *
scm:cert:getDomainValidation
Grants the permission to query domain name verification information.
read
cert *
scm:cert:checkDomain
Grants the permission to verify the certificate domain name ownership.
write
cert *
scm:cert:listDeployedResources
Grants the permission to obtain the resources associated with the certificate.
list
cert *
scm:cert:deletePrivacyAuthorization
Grants the permission to cancel privacy authorization.
write
cert *
scm:cert:enableAutoDeploy
Grants the permission to automatically deploy a certificate.
write
cert *
scm:cert:listAutoDeployedResources
Grants the permission to query the list of certificates that are automatically deployed.
list
cert *
scm:cert:listCertificatesByTag
Grants the permission to query the certificate list by tag.
list
cert *
  • g:RequestTag/<tag-key>
  • g:TagKeys
scm:cert:createTag
Grants the permission to create or update a tag.
tagging
cert *
  • g:TagKeys
scm:cert:listTagsByCertificate
Grants the permission to query the certificate tag list.
list
cert *
scm:cert:listAllTags
Grants the permission to query the list of all tags.
list
cert *
scm:cert:seekHelp
Grants the permission to send a help-seeking email.
write
cert *
scm:cert:uploadAuthentication
Grants the permission to upload authentication information.
write
cert *
scm::createCsr
Grants the permission to create a CSR.
write
scm::listCsr
Grants the permission to query the CSR list.
list
scm::getCsr
Grants the permission to query CSR details.
read
scm::getCsrPrivateKey
Grants the permission to obtain the CSR private key.
read
scm::updateCsr
Grants the permission to update a CSR.
write
scm::deleteCsr
Grants the permission to delete a CSR.
write
scm::uploadCsr
Grants the permission to upload a CSR.
write
scm::createDomainMonitor
Grants the permission to add a domain name to be monitored.
write
scm::updateDomainMonitor
Grants the permission to update domain names to be monitored.
write
scm::updateDomainMonitorSwitch
Grants the permission to enable or disable domain name monitoring.
write
scm::deleteDomainMonitor
Grants the permission to delete a monitored domain name.
write
scm::getDomainMonitor
Grants the permission to query details about the domain name to be monitored.
read
scm::listDomainMonitors
Grants the permission to query the list of domain names to be monitored.
list
scm:cert:operateNotification
Grants the permission to configure certificate notifications.
write
cert *
scm::orderDomainMonitor
Grants the permission to buy the domain name monitoring quota.
write
scm:cert:deployResources
Grants the permission to deploy the certificate to other service resources.
write
cert *
scm:cert:listDeployResourcesHistory
Grants permission to query the deployment history of a certificate.
list
cert *
scm:cert:getDeployQuota
Grants the permission to obtain the certificate deployment quota.
read
cert *
Each API of SCM usually supports one or more actions. Table 2 lists the actions and dependencies supported by SCM APIs.
Table 2 Actions and dependencies supported by SCM APIs
API
Action
Dependencies
GET /v3/scm/certificates
scm:cert:list
POST /v3/scm/certificates/import
scm:cert:import
GET /v3/scm/certificates/{certificate_id}
scm:cert:get
POST /v3/scm/certificates/{certificate_id}/export
scm:cert:export
POST /v3/scm/certificates/{certificate_id}/push
scm:cert:push
DELETE /v3/scm/certificates/{certificate_id}
scm:cert:delete
POST /v3/scm/certificates/{certificate_id}/read
POST /v3/scm/domain/monitor/subscribe
PUT /v3/scm/domain/monitor/change
POST /v3/scm/certificates/{certificate_id}/deploy
GET /v3/scm/certificates/{certificate_id}/deploy-history
GET /v3/scm/certificates/{certificate_id}/deploy-quota
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for SCM.
Table 3 Resource types supported by SCM
Resource Type
URN
cert
scm:<region>:<account-id>:cert:<cert-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, scm:) apply only to operations of EVS. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for SCM. You can include these condition keys to specify conditions for when your SCP is in effect.
Table 4 Service-specific condition keys supported by SCM
Service-specific Condition Key
Type
Single-valued/Multivalued
scm:DomainNames
string
Multivalued
This API is used to filter access requests based on the domain name in the request.
string
Single-valued
This API is used to filter access requests based on the authentication mode in the request.
scm:KeyAlgorithm
string
Single-valued
This API is used to filter access requests based on the key algorithm in the request.
