On this page
Private Certificate Authority (PCA)
Updated on 2025-02-25 GMT+08:00
The Organizations service also provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN for the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table.
    For details about the resource types defined by the PCA, see Table 3.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by PCA, see Conditions.
The following table lists the actions that you can define in SCP statements for PCA.
Table 1 Actions supported by PCA
Action
Access Level
Resource Type (*: Required)
Condition Key
pca:ca:create
Grants the permission to create a private CA.
write
ca *
g:EnterpriseProjectId
pca:ca:delete
Grants the permission to delete a private CA.
write
ca *
g:ResourceTag/<tag-key>
pca:ca:disable
Grants the permission to disable a private CA.
write
ca *
pca:ca:enable
Grants the permission to enable a private CA.
write
ca *
pca:ca:export
Grants the permission to export a private CA certificate.
read
ca *
pca:ca:getCsr
Grants the permission to export the certificate signing request (CSR) of a private CA.
read
ca *
pca:ca:import
Grants the permission to import a certificate as a private CA certificate.
write
ca *
pca:ca:activate
Grants the permission to activate a private CA.
write
ca *
pca:ca:list
Grants the permission to query the private CA list.
list
ca *
pca:ca:restore
Grants the permission to restore a private CA.
write
ca *
pca:ca:revoke
Grants the permission to revoke a private CA.
write
ca *
pca:ca:get
Grants the permission to query private CA details.
read
ca *
pca:ca:quota
Grants the permission to query the private CA quota.
read
pca:ca:createTag
Grants the permission to create or update tags for a private CA.
tagging
ca *
  • g:EnterpriseProjectId
  • g:RequestTag/<tag-key>
  • g:TagKeys
pca:ca:deleteTag
Grants the permission to delete a private CA tag.
tagging
ca *
  • g:TagKeys
pca:ca:listTags
Grants the permission to query the tag list of a private CA.
list
ca *
pca:ca:listAllTags
Grants the permission to query the private CA tag list.
list
ca *
pca:ca:listByTag
Grants the permission to query the private CA list by tag.
list
ca *
  • g:TagKeys
pca:ca:issueCert
Grants the permission to issue a private certificate.
write
ca *
  • pca:CommonName
pca:ca:issueCertByCsr
Grants the permission to issue private certificates based on CSRs.
write
ca *
  • pca:CommonName
pca:cert:delete
Grants the permission to delete a private certificate.
write
pca:cert:export
Grants the permission to export a private certificate.
read
pca:cert:list
Grants the permission to query the private certificate list.
list
pca:ca:revokeCert
Grants the permission to revoke a private certificate.
write
ca *
pca:cert:get
Grants the permission to query private certificate details.
read
pca:cert:quota
Grants the permission to query the private certificate quota.
read
pca:cert:createTag
Grants the permission to create or update private certificate tags.
tagging
  • g:TagKeys
pca:cert:deleteTag
Grants the permission to delete a private certificate tag.
tagging
  • g:TagKeys
pca:cert:listTags
Grants the permission to query the tag list of a private certificate.
list
pca:cert:listAllTags
Grants the permission to query the private certificate tag list.
list
pca:cert:listByTag
Grants the permission to query the private certificate list by tag.
list
  • g:TagKeys
pca:ca:disableCrl
Grants the permission to disable CRLs.
write
ca *
pca:ca:enableCrl
Grants the permission to enable CRLs.
write
ca *
Each API of PCA usually supports one or more actions. Table 2 lists the actions and dependencies supported by PCA APIs.
Table 2 Actions and dependencies supported by PCA APIs
API
Action
Dependencies
POST /v1/private-certificate-authorities
pca:ca:create
POST /v1/private-certificate-authorities/order
pca:ca:create
DELETE /v1/private-certificate-authorities/{ca_id}
pca:ca:delete
POST /v1/private-certificate-authorities/{ca_id}/disable
pca:ca:disable
POST /v1/private-certificate-authorities/{ca_id}/enable
pca:ca:enable
POST /v1/private-certificate-authorities/{ca_id}/export
pca:ca:export
GET /v1/private-certificate-authorities/{ca_id}/csr
pca:ca:getCsr
POST /v1/private-certificate-authorities/{ca_id}/import
pca:ca:import
POST /v1/private-certificate-authorities/{ca_id}/activate
pca:ca:activate
pca:ca:list
POST /v1/private-certificate-authorities/{ca_id}/restore
pca:ca:restore
POST /v1/private-certificate-authorities/{ca_id}/revoke
pca:ca:revoke
pca:ca:get
GET /v1/private-certificate-authorities/quotas
pca:ca:quota
POST /v1/private-certificate-authorities/{ca_id}/tags/create
pca:ca:createTag
DELETE /v1/private-certificate-authorities/{ca_id}/tags/delete
pca:ca:deleteTag
pca:ca:createTag
GET /v1/private-certificate-authorities/{ca_id}/tags
pca:ca:listTags
GET /v1/private-certificate-authorities/tags
pca:ca:listAllTags
POST /v1/private-certificate-authorities/resource-instances/filter
pca:ca:listByTag
POST /v1/private-certificates
pca:ca:issueCert
POST /v1/private-certificates/csr
DELETE /v1/private-certificates/{certificate_id}
pca:cert:delete
POST /v1/private-certificates/{certificate_id}/export
pca:cert:export
GET /v1/private-certificates
pca:cert:list
POST /v1/private-certificates/{certificate_id}/revoke
pca:ca:revokeCert
GET /v1/private-certificates/{certificate_id}
pca:cert:get
GET /v1/private-certificates/quotas
pca:cert:quota
POST /v1/private-certificates/{certificate_id}/tags/create
pca:cert:createTag
DELETE /v1/private-certificates/{certificate_id}/tags/delete
pca:cert:deleteTag
pca:cert:createTag
GET /v1/private-certificates/{certificate_id}/tags
pca:cert:listTags
GET /v1/private-certificates/tags
POST /v1/private-certificates/resource-instances/filter
pca:cert:listByTag
POST /v1/private-certificate-authorities/{ca_id}/crl/disable
pca:ca:disableCrl
POST /v1/private-certificate-authorities/{ca_id}/crl/enable
pca:ca:enableCrl
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for PCA.
Table 3 Resource types supported by PCA
Resource Type
URN
ca
pca:<region>:<account-id>:ca:<ca-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, pca:) apply only to operations of the corresponding service. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for PCA. You can include these condition keys to specify conditions for when your SCP is in effect.
Table 4 Service-specific condition keys supported by PCA
Service-specific Condition Key
Type
Single-valued/Multivalued
pca:CommonName
string
Single-valued
Filters access based on the common name of the certificate in the request parameters.
