On this page
Host Security Service (HSS)
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permission boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • Access Level indicates how the action is classified. The value can be list, read, or write. This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the resource URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table.
    For details about the resource types defined by HSS, see Resource.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key only takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by HSS, see Conditions.
The following table lists the actions that you can define in SCP statements for HSS.
Table 1 Actions supported by HSS
Action
Access Level
Resource Type (* required)
Condition Key
hss:host:addHostsGroup
Grants permission to create a server group.
write
host *
g:EnterpriseProjectId
hss:ars:addPWLPolicyHost
Grants permission to add servers to a whitelist policy.
write
host *
hss:rasp:addRaspPolicy
Grants permission to add protection policies.
write
hss:safetyReport:addSecurityReport
Grants permission to create or copy new reports.
write
hss:wtp:addTimingOffConfigInfo
Grants permission to add the configuration of scheduled protection disabling.
write
host *
hss:wtp:addWtpHostProtectDirInfo
Grants permission to add protected directories.
write
host *
hss:wtp:addWtpPrivilegedProcessInfo
Grants permission to add privileged processes.
write
host *
hss:setting:changeAutoKillVirusStatus
Grants permission to enable or disable automatic program isolation and killing.
write
hss:event:changeBlockedIp
Grants permissions for unblocking.
write
host *
hss:setting:changeMalwareCollectStatus
Grants permission to enable or disable the sample collection for malware cloud scans.
write
hss:ars:changePWLPolicy
Grants permission to modify whitelist policies.
write
hss:ars:changePWLPolicyProcessStatus
Grants permission to mark the whitelist policy identification processes.
write
hss:safetyReport:changeSecurityReport
Grants permission to modify reports.
write
hss:ars:createPWLPolicy
Grants permission to create whitelist policies.
write
host *
hss:ars:deletePWLPolicy
Grants permission to delete whitelist policies.
write
hss:ars:deletePWLPolicyHost
Grants permission to delete servers from a whitelist policy.
write
host *
hss:antiransomware:deleteRansomwareDuplicationInfo
Grants permission to delete backup copies.
write
hss:antiransomware:deleteRansomwareProtectionPolicy
Grants permission to delete protection policies.
write
hss:rasp:deleteRaspPolicy
write
hss:safetyReport:deleteSecurityReport
Grants permission to delete reports.
write
hss:wtp:deleteTimingOffConfigInfo
Grants permission to delete the configuration of scheduled protection disabling.
write
host *
hss:wtp:deleteWtpBackupHostInfo
Grants permission to delete the remote backup server.
write
host *
hss:wtp:deleteWtpHostProtectDirInfo
Grants permission to delete protected directories.
write
host *
hss:wtp:deleteWtpPrivilegedProcessInfo
Grants permission to delete privileged processes.
write
host *
hss:setting:getAgentInstallScript
Grants permission to query the agent installation script.
read
hss:setting:getAlarmConfig
Grants permission to query alarm configurations.
read
hss:rasp:getAppRaspSwitchStatus
Grants permission to query application protection status (enabled or disabled).
read
host *
hss:setting:getAutoKillVirusStatus
Grants permission to query the automatic isolation and killing status of programs.
read
hss:container:getContainerNodeStatistics
Grants permission to query container node protection overview statistics.
read
hss:keyfile:getFileStatistic
Grants permission to obtain server file statistics.
read
hss:setting:getMalwareCollectStatus
Grants permission to query the status of the sample collection configuration switch for malware cloud scans.
read
hss:setting:getMalwareReminders
Grants permission to obtain prompt information configurations.
read
hss:securitycheck:getManualSecurityCheckStatus
Grants permission to query the status and progress of manual health checks.
read
hss:overview:getOverviewAssetGroupsStatistics
Grants permission to obtain business group distribution statistics and identify regular, important, and core assets.
read
hss:overview:getOverviewAssetOsStatistics
Grants permission to obtain OS distribution statistics.
read
hss:overview:getOverviewAssetStatistics
Grants permission to obtain asset statistics, including servers, containers, and images.
read
hss:overview:getOverviewAttckMitre
Grants permission to investigate responses (ATT&CK attack path matrix).
read
hss:overview:getOverviewDefenseStatistics
Grants permission to obtain proactive defense statistics.
read
hss:overview:getOverviewProtectionStatusStatistics
Grants permission to query the protection status of the current cloud loads.
read
hss:overview:getOverviewQuotaStatistics
Grants permission to obtain server security statistics.
read
hss:overview:getOverviewRiskLists
Grants permission to query the risk list.
read
hss:overview:getOverviewRiskManageStatistics
Grants permission to obtain risk management information, including risk trends and type statistics.
read
hss:overview:getOverviewRiskScore
Grants permission to query risk scores.
read
hss:overview:getOverviewRiskStatistics
Grants permission to query risk statistics, security risks, security alarms, and proactive defense.
read
hss:overview:getOverviewTrialsStatistics
Grants permission to try server risk statistics.
read
hss:antiransomware:getRansomwareBackupInfoByBackupId
Grants permission to query specified backup information.
read
hss:antiransomware:getRansomwareHSSBackupPolicyInfo
Grants permission to query backup policy information.
read
hss:antiransomware:getRansomwareBackupStatistics
Grants permission to query backup statistics.
read
hss:antiransomware:getRansomwareProtectionStatistics
Grants permission to query protection statistics.
read
hss:antiransomware:getRansomwareVaultInfo
Grants permission to query backup vault information.
read
hss:rasp:getRaspPolicyDetail
Grants permission to query protection policy details.
read
hss:rasp:getRaspProtectStatistics
Grants permission to obtain protection data statistics.
read
hss:wtp:getRaspSwitchStatus
Grants permission to query whether the dynamic WTP is enabled.
read
host *
hss:securitycheck:getSecurityCheckConfig
Grants permission to query security check schedules.
read
hss:securitycheck:getSecurityCheckHostReport
Grants permission to query the security check report of a specified server.
read
host *
hss:securitycheck:getSecurityCheckOverview
Grants permission to query the security check overview.
read
hss:securitycheck:getSecurityCheckStatistic
Grants permission to query security check statistics.
read
hss:safetyReport:getSecurityReport
Grants permission to query the content of the security report.
read
hss:safetyReport:getSecurityReportSubscription
Grants permission to query the content of a report subscription.
read
hss:wtp:getTimingOffStatusInfo
Grants permission to query whether a protection configuration is in the scheduled disabling list.
read
host *
hss:wtp:getWtpDashboardProtectStatistics
read
hss:wtp:getWtpDirectory
Grants permission to query the Tomcat bin directory for dynamic WTP.
read
host *
hss:wtp:getWtpDirectoryMonitorOnlyStatus
Grants permission to query the status of the monitoring-only switch.
read
host *
hss:wtp:getWtpPrivilegedProcessesChildStatus
Grants permission to display the trust status of privileged subprocesses.
read
host *
hss:wtp:getWtpRemoteBackupHostInfo
Grants permission to query information about the remote backup server.
read
host *
hss:setting:listAgentVersion
Grants permission to query agent versions.
list
hss:container:listContainerNodes
Grants permission to query the container node list.
list
hss:keyfile:listFileEvents
Grants permission to obtain the list of changed files.
list
hss:keyfile:listFileHostEventDetails
Grants permission to obtain details about change files on a server.
list
host *
hss:keyfile:listFileHosts
Grants permission to obtain the ECS change list.
list
hss:host:listHostGroups
Grants permission to query the server group list.
list
hss:setting:listLoginCommonIp
Grants permission to query common login IP addresses.
list
hss:setting:listLoginCommonLocation
Grants permission to query common login locations.
list
hss:setting:listLoginWhiteIp
Grants permission to query the login IP address whitelist.
list
hss:policy:listPolicyGroup
Grants permission to query the policy group list.
list
hss:asset:listPortHost
Grants permission to query asset fingerprints - port - server list.
list
hss:asset:listProcessesHost
Grants permission to query asset fingerprints - process - server list.
list
hss:ars:listPWLEvent
Grants permission to query process whitelist events.
list
hss:ars:listPwlPolicy
Grants permission to query the process whitelist policy list.
list
hss:ars:listPwlPolicyHost
Grants permission to query the servers associated with a process whitelist policy.
list
hss:ars:listPwlPolicyProcess
Grants permission to query the process whitelist policy identification processes.
list
hss:antiransomware:listRansomwareBackedupByHostId
Grants permission to query the vulnerability list.
list
host *
hss:antiransomware:listRansomwareOperationLogsByVaultName
Grants permission to query the backup and restoration task list.
list
hss:antiransomware:listRansomwareProtectionOptionalServer
Grants permission to query the servers under ransomware protection.
list
hss:antiransomware:listRansomwareProtectionPolicy
Grants permission to query protection policies.
list
hss:antiransomware:listRansomwareProtectionServer
Grants permission to query servers protected against ransomware.
list
hss:rasp:listRaspCheckFeatureRule
Grants permission to query detection rules.
list
hss:rasp:listRaspEvents
Grants permission to query application protection events.
list
hss:rasp:listRaspPolicies
list
hss:rasp:listRaspProtectionServers
Grants permission to query protected servers.
list
hss:securitycheck:listSecurityCheckHostReportHistory
Grants permission to query historical security check reports of a specified server.
list
host *
hss:securitycheck:listSecurityCheckHostResult
Grants permission to query the security check results of servers.
list
hss:safetyReport:listSecurityReport
Grants permission to query the list on the report overview page.
list
hss:safetyReport:listSecurityReportHistoryPeriod
Grants permission to query the statistical period list of historical reports.
list
hss:safetyReport:listSecurityReportSendingRecord
Grants permission to query report sending records.
list
hss:wtp:listTimingOffConfigInfo
Grants permission to query the scheduled disabling list.
list
host *
hss:setting:listTwoFactorLoginHost
Grants permission to query the list of servers with 2FA enabled.
list
hss:wtp:listWtpBackupHostsInfo
Grants permission to query the remote backup server.
list
hss:wtp:listWtpHostProtectDirInfo
Grants permission to query protected directories.
list
host *
hss:wtp:listWtpHostProtectHistoryInfo
Grants permission to query the static WTP status of the server.
list
hss:wtp:listWtpHostRaspProtectHistoryInfo
Grants permission to query the dynamic WTP status of the server.
list
hss:wtp:listWtpPrivilegedProcessesInfo
Grants permission to query privileged process configurations.
list
host *
hss:wtp:listWtpProtectHost
Grants permission to query the protection list.
list
hss:setting:modifyLoginCommonIp
Grants permission to add, edit, or delete common login IP addresses.
write
host *
hss:setting:modifyLoginCommonLocation
Grants permission to add, edit, or delete common login locations.
write
host *
hss:setting:modifyLoginWhiteIp
Grants permission to add, edit, or delete the login IP address whitelist.
write
host *
hss:ars:operatePWLEvent
Grants permission to handle events.
write
hss:ars:relearnPWLPolicy
Grants permission to relearn whitelist policies.
write
host *
hss:overview:resetOverviewRiskScore
Grants permission to reset risk scores and perform health checks again.
write
hss:antiransomware:restoreRansomwareDuplicationInfo
Grants permission to back up and restore data.
write
hss:safetyReport:sendSecurityReport
Grants permission to send security reports.
write
hss:setting:setAlarmConfig
Grants permission to configure prompt information.
write
hss:setting:setMalwareReminders
write
hss:wtp:setRemoteWtpBackupInfo
Grants permission to enable or disable remote backup.
write
host *
hss:wtp:setTimingOffSwitchInfo
Grants permission to set the status of the scheduled protection disabling.
write
host *
hss:setting:setTwoFactorLoginConfig
Grants permission to configure 2FA login.
write
host *
hss:wtp:setWtpDirectoryMonitorOnlyStatus
Grants permission to configure the monitoring-only switch.
write
host *
hss:wtp:setWtpPrivilegedProcessesChildStatus
Grants permission to set the trust status of privileged subprocesses.
write
host *
hss:wtp:setWtpProtectionStatusInfo
Grants permission to enable or disable WTP.
write
host *
hss:wtp:setWtpProtectSwitch
Grants permission to enable or disable dynamic WTP.
write
host *
hss:wtp:setWtpScheduledProtectionDateOffConfigInfo
Grants permission to configure the frequency and period for automatically disabling protection.
write
host *
hss:securitycheck:startManualSecurityCheck
Grants permission to start a manual health check.
write
hss:antiransomware:startRansomwareBackupSingle
Grants permission to enable the backup function for a single server.
write
host *
hss:antiransomware:startRansomwareProtection
Grants permission to enable ransomware protection.
write
host *
hss:antiransomware:startRansomwareProtectionSingle
Grants permission to enable ransomware protection for a single server.
write
host *
hss:securitycheck:stopManualSecurityCheck
Grants permission to cancel a manual health check.
write
hss:antiransomware:stopRansomwareProtection
Grants permission to disable ransomware protection.
write
host *
hss:container:switchContainerProtectStatus
Grants permission to switch the protection status.
write
host *
hss:ars:switchPWLPolicyHost
Grants permission to enable or disable a server whitelist policy.
write
host *
hss:rasp:switchRasp
Grants permission to enable or disable application protection.
write
host *
hss:safetyReport:switchSecurityReportStatus
Grants permission to enable or disable security reports.
write
hss:wtp:switchWtpHostProtectDirInfo
Grants permission to enable or disable directory protection.
write
host *
hss:host:uninstallAgents
Grants permission to uninstall the agent.
write
host *
hss:setting:updateAlarmConfig
Grants permission to configure alarm configurations.
write
hss:antiransomware:updateRansomwareBackupPolicyInfo
Grants permission to modify backup policies.
write
hss:antiransomware:updateRansomwareProtectionPolicy
Grants permission to modify protection policies.
write
hss:rasp:updateRaspPolicy
write
hss:securitycheck:updateSecurityCheckConfig
Grants permission to modify security check schedules.
write
hss:wtp:updateTimingOffConfigInfo
Grants permission to modify the configuration of scheduled protection disabling.
write
host *
hss:wtp:updateWtpBackupHostInfo
Grants permission to add or modify a remote backup server.
write
host *
hss:wtp:updateWtpDirectoryInfo
Grants permission to modify the Tomcat bin directory of dynamic WTP.
write
host *
hss:wtp:updateWtpHostProtectDirInfo
Grants permission to modify protected directories.
write
host *
hss:wtp:updateWtpPrivilegedProcessInfo
Grants permission to modify privileged processes.
write
host *
hss:asset:addValuesLevel
Grants permission to configure asset management - server management - asset importance.
write
host *
hss:asset:batchModifyPortStatus
Grants permission to change port status.
write
host *
hss:asset:deleteToolConditionHistory
Grants permission to clear the search records of tools (operation tool).
write
hss:asset:executeTool
Grants permission to perform search with tools (operation tools).
write
hss:asset:getAccountTop
Grants permission to obtain asset management - overview - top accounts.
read
hss:asset:getAgentStatisticsStatus
Grants permission to obtain asset management - overview - asset status - server agent status.
read
hss:asset:getAssetStatistic
Grants permission to obtain asset statistics, including accounts, ports, and processes.
read
hss:asset:getAssetType
Grants permission to obtain asset management - overview - asset status - asset distribution.
read
hss:asset:getAutoLaunchTop
Grants permission to obtain asset management - overview - top auto-started items.
read
hss:asset:getCommonPort
Grants permission to display details about a port.
read
hss:asset:getContainerProtectionStatus
Grants permission to obtain asset management - overview - asset status - container protection status.
read
hss:asset:getCoreConfFileTop
Grants permission to obtain asset management - overview - top key configurations.
read
hss:asset:getEnvironmentTop
Grants permission to obtain asset management - overview - top environment variables.
read
hss:asset:getHostAssetManualCollectStatus
Grants permission to obtain the status of the API for immediately collecting the asset fingerprints of a server.
read
host *
hss:asset:getHostProtectionStatus
Grants permission to obtain asset management - overview - asset status - agent status.
read
hss:asset:getJarPackageTop
Grants permission to obtain asset management - overview - top JAR packages.
read
hss:asset:getKernelModuleTop
Grants permission to obtain asset management - overview - top kernel modules.
read
hss:asset:getOsStatisticsInfo
Grants permission to obtain asset management - overview - asset status - OS statistics.
read
hss:asset:getPorcessTop
Grants permission to obtain asset management - overview - top processes.
read
hss:asset:getPortTop
Grants permission to obtain asset management - overview - top ports.
read
hss:asset:getQuotaStatisticsInfo
Grants permission to obtain asset management - overview - asset status - protection quota statistics.
read
hss:asset:getSoftwareTop
Grants permission to obtain asset management - overview - top software.
read
hss:asset:getWebAppAndServiceTop
Grants permission to obtain asset management - overview - top web apps and services.
read
hss:asset:getWebAppTop
Grants permission to obtain asset management - overview - top web applications.
read
hss:asset:getWebFrameworkTop
Grants permission to obtain asset management - overview - top web frameworks.
read
hss:asset:getWebServiceTop
Grants permission to obtain asset management - overview - top web services.
read
hss:asset:getWebSiteTop
Grants permission to obtain asset management - overview - top websites.
read
hss:asset:listAppChangeHistories
Grants permission to obtain asset fingerprints – software information – operation history.
list
hss:asset:listApps
Grants permission to obtain asset fingerprints of a single server – software.
list
hss:asset:listAppStatistics
Grants permission to obtain asset fingerprints – software information.
list
hss:asset:listAutoLaunchChangeHistories
Grants permission to obtain asset fingerprints - auto-started items - change history.
list
hss:asset:listAutoLaunchs
Grants permission to obtain asset fingerprints of a server - auto-started items.
list
hss:asset:listAutoLaunchStatistics
Grants permission to obtain asset fingerprints - auto-start items.
list
hss:asset:listCoreConfFileHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of key configuration files.
list
hss:asset:listCoreConfFileInfo
Grants permission to obtain asset management - server management - fingerprint type - key configurations.
list
host *
hss:asset:listCoreConfFileStatistics
Grants permission to obtain asset management - asset fingerprints - key configuration file navigation tree on the left.
list
hss:asset:listEnvironmentHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of key environment variables (on the right of asset fingerprints).
list
hss:asset:listEnvironmentInfo
Grants permission to obtain asset management - server management - fingerprint type - environment variables.
list
host *
hss:asset:listEnvironmentStatistics
Grants permission to obtain asset management - asset fingerprints - environment variable file navigation tree on the left.
list
hss:asset:listJarPackageHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of JAR packages.
list
hss:asset:listJarPackageInfo
Grants permission to obtain asset management - server management - fingerprint type - JAR packages.
list
host *
hss:asset:listJarPackageStatistics
Grants permission to obtain asset management - asset fingerprints - JAR package navigation tree on the left.
list
hss:asset:listKernelModuleHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of kernel modules.
list
hss:asset:listKernelModuleInfo
Grants permission to obtain asset management - server management - fingerprint type - kernel modules.
list
host *
hss:asset:listKernelModuleStatistics
Grants permission to obtain asset management - asset fingerprints - kernel module navigation tree on the left.
list
hss:asset:listPorts
Grants permission to obtain single-server asset fingerprint (open port information).
list
host *
hss:asset:listPortStatistics
Grants permission to obtain asset fingerprints (open port information).
list
Grants permission to obtain the process list.
list
host *
hss:asset:listProcessStatistics
Grants permission to obtain asset fingerprints (process information).
list
hss:asset:listResult
Grants permission to obtain execution results (operation tools).
list
hss:asset:listTool
Grants permission to obtain the tool list (operation tools).
list
hss:asset:listToolConditionHistory
Grants permission to obtain the search records of tools (operation tools).
list
hss:asset:listUserChangeHistories
Grants permission to obtain the account change history.
list
hss:asset:listUserGroup
Grants permission to obtain the user group list.
list
hss:asset:listUsers
Grants permission to obtain the account list of assets.
list
hss:asset:listUserStatistics
Grants permission to obtain asset fingerprints - software information.
list
hss:asset:listWebAppAndServices
Grants permission to obtain asset management - asset fingerprints - web app and service assets on the right.
list
hss:asset:listWebAppAndServiceStatistics
Grants permission to obtain asset management - asset fingerprints - web app and service navigation tree on the left.
list
hss:asset:listWebAppHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of web applications.
list
hss:asset:listWebAppInfo
Grants permission to obtain asset management - server management - fingerprint type - web applications.
list
host *
hss:asset:listWebAppStatistics
Grants permission to obtain asset management - asset fingerprints - web application navigation tree on the left.
list
hss:asset:listWebFrameworkHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of web frameworks.
list
hss:asset:listWebFrameworkInfo
Grants permission to obtain asset management - server management - fingerprint type - web frameworks.
list
host *
hss:asset:listWebFrameworkStatistics
Grants permission to obtain asset management - asset fingerprints - web framework navigation tree on the left.
list
hss:asset:listWebServiceHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of web servers.
list
hss:asset:listWebServiceInfo
Grants permission to obtain asset management - server management - fingerprint type - web services.
list
host *
hss:asset:listWebServiceStatistics
Grants permission to obtain asset management - asset fingerprints - web services navigation tree on the left.
list
hss:asset:listWebSiteHostInfo
Grants permission to obtain asset management - asset fingerprints - the server list of websites.
list
hss:asset:listWebSiteInfo
Grants permission to obtain asset management - server management - fingerprint type - websites.
list
host *
hss:asset:listWebSiteStatistics
Grants permission to obtain asset management - asset fingerprints - website navigation tree on the left.
list
hss:asset:runHostAssetManualCollect
Grants permission to immediately collect the asset fingerprints of a server.
write
host *
hss:baseline:addSecurityCheckPolicyGroup
Grants permission to create a configuration detection policy.
write
hss:baseline:changeCheckRuleState
Grants permission to ignore, unignore, repair, and verify failed configuration check items.
write
baseline *
hss:baseline:deleteSecurityCheckPolicyGroup
Grants permission to delete a specified configuration detection policy.
write
hss:baseline:exportSecurityCheckReport
Grants permission to export the configuration detection report.
list
hss:baseline:getBaselineOverview
Grants permission to query baseline check statistics.
read
hss:baseline:getBaselineScanStatus
Grants permission to query the progress of a baseline check task.
read
hss:baseline:getBaselineStatistic
Grants permission to query baseline check statistics, including weak passwords, password complexity, and configuration detection.
read
hss:baseline:getCheckRuleDetail
Grants permission to query the check report of a configuration check item.
read
baseline *
hss:baseline:getCheckRuleFixFailDetail
Grants permission to query the cause of the check item repair failure.
read
baseline *
hss:baseline:getDefaultSecurityCheckPolicy
Grants permission to query the default baseline of a configuration detection policy.
read
hss:baseline:getDefaultSecurityCheckPolicyDetails
Grants permission to query detailed baseline check items.
read
hss:baseline:getRiskConfigDetail
Grants permission to query the check result of a specified security configuration item.
read
hss:baseline:listCheckRuleHost
Grants permission to query servers covered by a configuration check item.
list
baseline *
hss:baseline:listPasswordComplexity
Grants permission to query the password complexity policy check report.
list
hss:baseline:listRiskConfigCheckRules
Grants permission to query the check item list of a specified security configuration item.
list
hss:baseline:listRiskConfigHosts
Grants permission to query servers affected by a specified security configuration item.
list
hss:baseline:listRiskConfigs
Grants permission to query the server security configuration check result list of a tenant.
list
hss:baseline:listSecurityCheckPolicyGroup
Grants permission to query the list of configuration detection policy groups.
list
hss:baseline:listWeakPasswordUsers
Grants permission to query the weak password detection results.
list
hss:baseline:runBaselineDetect
Grants manual detection permissions. Performs configuration detection and weak password detection on the servers specified in the policy.
write
hss:baseline:updateSecurityCheckPolicyGroup
Grants permission to modify a specified configuration detection policy.
write
hss:event:addLoginWhiteList
Grants permission to add a login whitelist.
write
hss:event:batchChangeEvent
Grants permission to handle alarm events in batches.
write
hss:event:changeEvent
Grants permission to handle alarm events.
write
event *
hss:event:changeIsolatedFile
Grants permission to restore isolated files.
write
host *
hss:event:exportAlarmWhiteList
Grants permission to export the alarm whitelist.
list
hss:event:exportEmergency
Grants permissions to export emergency malware interfaces.
list
hss:event:getEmergencyStatistics
Grants permission to obtain emergency event statistics.
read
hss:event:getEventAttackTag
Grants permission to query the list of attack ID distribution statistics.
read
hss:event:getEventSeverity
Grants permission to query the list of threat level statistics.
read
hss:event:getEventStatistics
Grants permission to query alarm event statistics.
read
hss:event:getMalwareInfo
Grants permission to obtain the list of unexpected malicious program events.
read
event *
hss:event:handleMalwareEvent
Grants permission to handle malware.
write
event *
hss:event:importAlarmWhiteList
Grants permission to import an alarm whitelist.
write
hss:event:isolateOperateEmergency
Grants permission to enable or disable the isolation box.
write
hss:event:listAlarmWhiteList
Grants permission to query the alarm whitelist.
list
hss:event:listBlockedIp
Grants permission to query the list of blocked IP addresses.
list
hss:event:listEventOperates
Grants permission to query the handling types supported by events.
list
hss:event:listEventTopRisk
Grants permission to query the list of top 10 event type statistics.
list
hss:event:listEventType
Grants permission to query the list of event type statistics.
list
hss:event:listFileIsolateList
Grants permission to obtain the list of files isolated due to unexpected malware events.
list
hss:event:listIsolatedFile
Grants permission to query the isolated file list.
list
hss:event:listLoginWhiteList
Grants permission to query the login whitelist.
list
hss:event:listMalware
list
hss:event:listSecurityEvents
Grants permission to query the intrusion event list.
list
hss:event:recoverIsolateFile
Grants permission to restore the file isolation box.
write
hss:event:removeAlarmWhiteList
Grants permission to delete an alarm whitelist.
write
hss:event:removeLoginWhiteList
Grants permission to delete a login whitelist.
write
hss:host:associateHostAssetValue
Grants permission to associate asset importance.
write
host *
hss:host:associateHostsGroup
Grants permission to allocate servers to a server group.
write
host *
hss:host:batchInstallAgent
Grants permission to install agents in batches.
write
host *
hss:host:changeHostsGroup
Grants permission to edit a server group.
write
hss:host:deleteHostsGroup
Grants permission to delete a server group.
write
hss:host:getHostsStatistics
Grants permission to collect server statistics.
read
hss:host:listFirewallStatus
Grants permission to query the firewall status of a server.
read
host *
hss:host:listHostGroupAssetValue
Grants permission to query the list of server groups by asset importance.
list
hss:host:listHostsRisk
Grants permission to obtain ECS risk status.
read
host *
hss:host:listHostStatus
Grants permission to query the list of protected servers.
list
hss:host:listHostsUpgrade
Grants permission to obtain the agent upgrade status of a server.
read
host *
hss:host:manualCheckVul
Grants permission to manually detect vulnerabilities.
write
hss:host:switchFirewallStatus
Grants permission to modify the firewall authorization status.
write
host *
hss:host:switchHostsProtectStatus
write
host *
hss:host:upgradeAgent
Grants permission to upgrade the agent from 1.0 to 2.0.
write
host *
hss:host:upgradeAgents
Grants permission to upgrade the agent.
write
host *
hss:image:batchScanLocalImage
Grants permission to perform local image scanning.
write
hss:image:batchScanPrivateImage
Grants permission to scan images in private image repositories in batches.
write
hss:image:getImageFilesStat
Grants permission to query image file statistics.
read
hss:image:getImageLocalVulOverview
Grants permission to query local vulnerabilities.
read
hss:image:getImageVulOverview
Grants permission to query repository vulnerabilities.
read
hss:image:listCfgCheckAffectedImage
Grants permission to query the list of images affected by a tenant image that failed baseline checks.
list
hss:image:listGlobalCfgCheck
Grants permission to query container image baseline inspection results.
list
hss:image:listGlobalMalware
Grants permission to query the list of malicious tenant files.
list
hss:image:listGlobalVul
Grants permission to query vulnerability details about a tenant image.
list
hss:image:listImageApps
Grants permission to query the image software list.
list
hss:image:listImageAppVul
Grants permission to query the software vulnerability list.
list
hss:image:listImageCfgCheck
Grants permission to query configuration baseline check results of an image.
list
hss:image:listImageFiles
Grants permission to query the list of image files that have no owners.
list
hss:image:listImageLocal
Grants permission to query the local image list.
list
hss:image:listImageMalware
Grants permission to query the list of malicious image files.
list
hss:image:listImageNamespace
Grants permission to query the namespace of an image.
list
hss:image:listImageRepository
Grants permission to query the list of images in a private image repository.
list
hss:image:listImageVul
Grants permission to query image vulnerability details.
list
hss:image:listInstanceImageVul
Grants permission to query vulnerability details about enterprise images.
list
hss:image:listLocalImageApp
Grants permission to query the local software image list.
list
hss:image:listLocalImageAppVuls
Grants permission to query the vulnerability list of a piece of software in a local image.
list
hss:image:listLocalImageContainers
Grants permission to query the container information about a local image.
list
hss:image:listLocalImageHosts
Grants permission to query the server information about a local image.
list
hss:image:listLocalImageMalware
Grants permission to query malicious file information about local images.
list
hss:image:listLocalImageVuls
Grants permission to query vulnerability information about a local image.
list
hss:image:listLocalVulRepoImage
Grants permission to query details about images and containers affected by local image vulnerabilities.
list
hss:image:listPrivateImageRepository
list
hss:image:listSharedImageRepository
Grants permission to query the list of images in the shared image repository.
list
hss:image:listVulCve
Grants permission to query CVE details about a vulnerability.
list
hss:image:listVulRepoImage
Grants permission to query details about images in the image repository affected by a vulnerability.
list
hss:image:runImageScan
Grants permission to scan images.
write
hss:image:runImageSynchronizeTask
Grants permission to synchronize the free image list from SWR.
write
hss:image:runSwrImageScan
Grants permission to update and scan SWR images and to access SWR.
write
hss:image:sharedImageSynchronization
Grants permission to update images shared from SWR.
write
hss:policy:addPolicyGroup
Grants permission to copy server policy groups.
write
policy *
hss:policy:associatePolicyGroup
Grants permission to deploy a policy.
write
policy *
host *
hss:policy:changePolicyDetail
Grants permission to modify a policy.
write
policy *
hss:policy:changePolicyGroup
Grants permission to modify policy groups.
write
policy *
hss:policy:deletePolicyGroup
Grants permission to delete policy groups.
write
policy *
hss:policy:getPolicyDetail
Grants permission to query details about a specified policy.
read
policy *
hss:policy:listPolicyGroupDetail
Grants permission to query the policy information list of a policy group.
list
policy *
hss:quota:addResourceInstanceTag
Grants permission to add tags to a resource.
tagging
  • g:RequestTag/<tag-key>
  • g:TagKeys
hss:quota:batchCreateTags
Grants permission to create tags in batches.
write
  • g:TagKeys
hss:quota:batchDeleteTags
Grants permission to delete tags in batches.
write
  • g:TagKeys
hss:quota:cancelHostsQuota
Grants permission to unbind quotas.
write
hss:quota:changeTmsResourceTagInfo
Grants permission to add or delete resource tags in batches.
write
  • g:TagKeys
hss:quota:countResourceInstances
Grants permission to query the number of purchased resources by tag.
list
  • g:TagKeys
hss:quota:dealOrder
Grants permission to subscribe to HSS.
write
hss:quota:deleteResourceInstanceTag
Grants permission to delete tags from a resource.
tagging
  • g:TagKeys
hss:quota:filterResourceInstanceList
Grants permission to search for purchased resources by tag.
list
  • g:TagKeys
hss:quota:getResourceInstanceTag
Grants permission to query tags of a resource.
read
hss:quota:getResourceQuotas
Grants permission to query quota information.
read
hss:quota:getTmsResourceTagsInfo
Grants permission to query resource tags.
read
hss:quota:listProjectTags
Grants permission to query all used tags in the current project.
list
hss:quota:listQuotasDetail
Grants permission to query quota details.
list
hss:quota:listResourceIds
Grants permission to query quota IDs in batches.
list
hss:quota:listTmsResourceInstancesInfo
Grants permission to query resource instances.
list
  • g:TagKeys
hss:quota:upgradeOrder
Grants permission to change specifications.
write
hss:vulnerability:changeVulStatus
Grants permission to modify the status of a vulnerability.
write
host *
hss:vulnerability:exportEmergencyVulnerabilities
Grants permission to export emergency vulnerabilities.
list
hss:vulnerability:exportVulsList
Grants permission to export information about vulnerabilities and their affected servers.
list
hss:vulnerability:getCmsVulDetail
Grants permission to query basic information about the Web-CMS vulnerabilities.
read
hss:vulnerability:getEmergencySummary
Grants permission to query the event overview.
read
hss:vulnerability:getEmergencyVulDetail
Grants permission to query vulnerability details in events.
read
hss:vulnerability:getLinuxVulDetail
Grants permission to query basic information about Linux vulnerabilities.
read
hss:vulnerability:getVulCheckStatus
Grants permission to query the status of server vulnerability scanning.
read
hss:vulnerability:getVulSummary
Grants permission to query vulnerability statistics.
read
hss:vulnerability:getWindosVulDetail
Grants permission to query basic information about Windows vulnerabilities.
read
hss:vulnerability:getWindowsVulNum
Grants permission to query the number of Windows vulnerabilities on a server.
list
hss:vulnerability:listEmergencyVul
Grants permission to query vulnerabilities in events.
list
hss:vulnerability:listHostVuls
Grants permission to query vulnerability information about a single server.
list
host *
hss:vulnerability:listHostVulSummary
Grants permission to query server statistics and top 5 risky servers.
list
hss:vulnerability:listTopVulSummary
Grants permission to query top 5 vulnerabilities.
list
hss:vulnerability:listVulHosts
Grants permission to query ECSs affected by a specific vulnerability.
list
hss:vulnerability:listVulnerabilities
list
hss:vulnerability:listVulRepairFailedDetail
Grants permission to query information about vulnerability fixing failures.
list
host *
hss:vulnerability:listVulTypeSummary
Grants permission to query vulnerability type distribution.
list
hss:vulnerability:operateEmergency
Grants permission to operate vulnerabilities in events.
write
hss:host:getScanStatus
Grants permission to query the manual scan status.
read
host *
hss:host:setManualDetect
Grants permission to deliver a manual scan.
write
host *
hss::getTrustServiceStatus
Grants permission to obtain the status of trusted services.
read
hss::enableTrustService
Grants permission to enable trusted services.
permission_management
hss::validateAdmin
Grants permission to check whether the current account is an administrator account (organization administrator or agency administrator).
tagging
hss::listAccounts
Grants permission to display the account list.
list
hss::batchAddAccounts
Grant permission to add accounts in batches.
write
hss::deleteAccount
Grants permission to delete accounts.
write
hss::listOrganizationTree
Grants permission to display the account tree structure.
list
hss::listDelegatedAccounts
Grants permission to query the tree structure of delegated accounts.
list
hss:antiransomware:listBackupVaults
Grants permission to query the backup vault list.
list
hss:antiransomware:listRansomwareProtectionNodes
list
hss:antiransomware:getBackupsStatistics
list
hss:antiransomware:startSingleBackup
write
host *
hss:antiransomware:getBackupPolicyInfo
Grants permission to query a backup policy.
read
hss:hostGroup:getOutsideGroupStatus
Grants permission to query whether data center server groups can be created.
read
hss:hostGroup:getOutsideHostGroup
Grants permission to query off-cloud data center server groups.
read
hss:hostGroup:addOutsideHostGroup
Grants permission to create off-cloud data center server groups.
write
hss:hostGroup:changeOutsideHostGroup
Grants permission to edit off-cloud data center server groups.
write
hss:images:listImageTag
Grant the permission to query the image tag version list.
list
hss:images:listImageSensitive
Grants permission to query sensitive image information.
list
hss:images:getFilePathWhiteDetail
Grants permission to query the sensitive information file path whitelist of images.
read
hss:images:changeFilePathWhiteDetail
Grants permission to modify the sensitive information file path whitelist of images.
write
hss:images:changeSensitiveInfo
Grants permission to perform operations on sensitive information.
write
hss:event:listTopEventType
Grants permission to query the statistics about the top 5 events.
list
hss:vulnerability:getVulScanPolicy
Grants permission to query a vulnerability scan policy.
read
hss:vulnerability:changeVulScanPolicy
Grants permission to modify a vulnerability scan policy.
write
host *
hss:vulnerability:listVulWhiteList
Grants permission to query the vulnerability whitelist.
list
hss:vulnerability:getVulWhiteListDetail
Grants permission to query vulnerability whitelist details.
read
hss:vulnerability:changeVulWhiteList
Grants permission to modify the vulnerability whitelist.
write
host *
hss:vulnerability:deleteVulWhiteList
Grants permission to delete an item from the vulnerability whitelist.
write
hss:vulnerability:addVulWhiteList
Grants permission to add an item to the vulnerability whitelist.
write
host *
hss:vulnerability:listVulWhiteListVulOptions
Grants permission to query vulnerability options when adding a whitelist item.
list
hss:vulnerability:listVulScanTask
Grants permission to query the vulnerability scan task list.
list
hss:vulnerability:listVulScanTaskHost
Grants permission to query the list of servers corresponding to a vulnerability scan task.
list
hss:vulnerability:rescanVulScanTask
Grants permission to rescan servers in a vulnerability scan task.
write
host *
hss:vulnerability:getVulScanTaskStatistics
Grants permission to query vulnerability scan task statistics.
read
hss:vulnerability:listHostVulStatistics
Grants permission to query vulnerability management statistics.
list
hss:vulnerability:listVulHostApps
Grants permission to query details about the software list of servers affected by vulnerabilities.
list
host *
hss:vulnerability:listVulHostProcess
Grants permission to query details about the process list of servers affected by vulnerabilities.
list
host *
hss:vulnerability:listVulHandleHistory
Grants permission to query historical vulnerability handling records.
list
hss:vulnerability:listVulHostHosts
Grants permission to query the list of servers with vulnerabilities.
list
hss:vulnerability:listVulHostVuls
Grants permission to query emergency fixes and unfixed vulnerabilities.
list
hss:vulnerability:listVulHostHandleVuls
Grants permission to query vulnerabilities handled today and the total vulnerabilities handled.
list
hss:image:listImageNonCompliantApp
Grants permission to query the non-compliant software information of an image.
list
hss:image:batchExportSWRVulList
Grants permission to export vulnerabilities from an SWR image repository in batches.
write
hss:image:batchExportLocalVulList
Grants permission to export local image vulnerabilities in batches.
write
hss:image:getExtendedWeakPassword
Grants permission to query the user-defined weak passwords of an image.
list
hss:image:changeExtendedWeakPassword
Grants permission to modify the user-defined weak passwords of an image.
write
hss:image:listImageBasicImage
Grants permission to query basic image information.
list
hss:image:listImagePwdComplexity
Grants permission to query the password complexity check report of an image.
list
hss:image:listImageWeakPwdUsers
Grants permission to query the image weak password check results of an image.
list
hss:image:listImageRiskConfigs
Grants permission to query the security configuration check results of an image.
list
hss:image:listImageRiskConfigCheckRules
Grants permission to query the check items of a specified image security configuration item.
list
hss:image:getImageRiskConfigDetail
Grants permission to query the check results of a specified image security configuration item.
read
hss:image:getImageCheckRuleDetail
Grants permission to query the check reports of an image configuration check item.
read
hss:image:getImageBaselineStatistic
read
hss:event:addSystemUserWhiteList
Grants permission to add users to the system user whitelist.
write
hss:event:updateSystemUserWhiteList
Grants permission to modify the system user whitelist.
write
hss:event:listSystemUserWhiteList
Grants permission to query the system user whitelist.
list
hss:event:removeSystemUserWhiteList
Grants permission to remove users from the system user whitelist.
write
hss:container:saveClusters
Grants permission to synchronize cluster information.
write
hss:container:listClusterInfo
Grants permission to query the Kubernetes cluster list.
list
hss:container:listPodInfo
Grants permission to query the basic pod information list.
list
hss:container:showPodDetail
Grants permission to query pod details.
read
hss:container:listContainerInfo
Grants permission to query the basic container information list.
list
hss:container:showContainerDetail
Grants permission to query container details.
list
hss:container:listServiceInfo
Grants permission to query the Kubernetes service list.
list
hss:container:showServiceDetail
Grants permission to query Kubernetes service details.
read
hss:container:listEndpointInfo
Grants permission to query the Kubernetes endpoint list.
list
hss:container:showEndpointDetail
Grants permission to query Kubernetes endpoint details.
read
hss:container:listDeployments
Grants permission to query the Kubernetes Deployment list.
list
hss:container:listStatefulSets
Grants permission to query the Kubernetes StatefulSet list.
list
hss:container:listDaemonSets
Grants permission to query the Kubernetes daemon list.
list
hss:container:listJobs
Grants permission to query the Kubernetes common job list.
list
hss:container:listCronJobs
Grants permission to query the Kubernetes scheduled task list.
list
hss:vulnerability:showVulAffectedStatics
Grants permission to count the servers affected by vulnerabilities.
list
hss:vulnerability:listVulHandleTask
Grants permission to query the vulnerability handling task list.
list
hss:vulnerability:listVulHandleTaskDetail
Grants permission to query vulnerability handling task details.
list
hss:container:isolateK8sContainer
Grants permission to modify the running status of the container.
write
hss:container:getNetworkStatistics
Grants permission to query the container firewall statistics status.
list
hss:container:getClusters
Grants permission to query the cluster list.
list
hss:container:getClusterNetworkInfo
Grants permission to query cluster network information.
read
hss:container:getClusterPolicyList
Grants permission to query the container network policy list.
list
hss:container:deletePolicy
Grants permission to delete container network policies.
write
hss:container:createPolicy
Grants permission to create container network policies.
write
hss:container:updatePolicy
Grants permission to update container network policies.
write
hss:container:syncClusterPolicyList
Grants permission to synchronize container network policies.
read
hss:container:syncClusterList
Grants permission to synchronize cluster namespace information.
read
hss:container:getNamespaceList
Grants permission to query the cluster namespace list.
list
hss:container:getNodeList
Grants permission to query the cluster node list.
list
hss:container:syncClusterNodeList
Grants permission to synchronize cluster nodes.
read
hss:vulnerability:getVulScanTaskEstimatedTime
Grants permission to query the estimated time of a vulnerability scan.
read
hss:antiransomware:addRansomwareProtectionPolicy
Grants permission to add ransomware protection policies.
write
hss:antiransomware:associateBackupPolicy
Grants permission to apply backup policies to vaults.
write
hss:antiransomware:listBackupPolicy
Grants permission to query the backup policy list.
list
hss:antiransomware:associateProtectionPolicy
Grants permission to switch ransomware protection policies.
write
hss:antiransomware:batchStartProtection
write
hss:event:getEventAttCk
Grants permission to query the list of ATT&CK attack phase statistics.
list
event *
hss:event:downloadEventSourceFile
Grants permission to download alarm source files.
list
event *
hss:overview:showSecurityScore
Grants permission to query security scores.
list
hss:overview:listSecurityRisk
Grants permission to query the security risk list.
list
hss:overview:showQuotaHostStatistics
Grants permission to query server quota statistics.
list
hss:overview:showAgentStatistics
Grants permission to query the number of agents to be upgraded, online, and offline.
list
hss:overview:showHotInformation
Grants permission to query hot news.
list
hss:overview:showSecurityRisk
Grants permission to query security risk information.
list
hss:overview:showProtectStatistics
Grants permission to query the protection period, virus library update time, vulnerability library update time, and accumulated number of records of each module.
list
hss:overview:showStatistics
Grants permission to query the numbers of servers with enabled ransomware protection, application protection, web tamper protection, and two-factor authentication; and the number of isolated files.
list
hss:event:listEventHandleHistory
Grants permission to query the list of historical events handling.
list
event *
hss:image:listSwrImageRepository
Grants permission to query the image list in the SWR image repository.
list
hss:image:batchScanSwrImage
Grants permission to scan images in the image repository in batches.
write
hss:image:vulnerabilities
list
hss:image:listVulnerabilityCve
list
hss:image:listImageRiskConfigRules
list
Grants permission to synchronize the image list from SWR.
write
hss:event:listEventForensic
Grants permission to query event forensics information.
list
event *
hss:event:listSimilarHandledEvents
Grants permission to query similar handled alarms.
list
event *
hss:event:listSameEvent
Grants permission to query the same alarms.
list
event *
hss:container:getPolicies
Grants permission to query the policy list.
list
hss:container:getPolicyDetail
Grants permission to query policy details.
list
hss:container:getOverview
Grants permission to query cluster protection overview.
list
hss:container:getProtectEvents
Grants permission to query cluster protection events.
list
hss:container:getProtectClusters
Grants permission to query cluster protection information.
list
hss:container:changeProtectStatus
Grants permission to change the cluster protection status.
write
hss:container:addWhiteImage
Grants permission to add images to the whitelist.
write
hss:container:listDefaultPolicy
Grants permission to query the default policy template.
list
hss:container:listProtectionItem
Grants permission to query the protection scope.
list
hss:vulnerability:getVulBackupStatistics
Grants permission to query backup statistics of the server corresponding to the vulnerability handling.
read
hss:vulnerability:ListVulHostVaults
Grants permission to query the list of server vaults corresponding to vulnerability handling.
list
hss:vulnerability:ListVulHostBackups
Grants permission to query the list of backups that can be rolled back.
list
host *
hss:vulnerability:RestoreVulHostBackup
Grants permission to roll back with backups.
write
hss:event:exportEvent
Grants permission to export event alarms.
write
event *
hss:event:queryExportTask
Grants permission to query the task of exporting event alarms.
read
event *
Grants permission to download event alarms.
read
event *
hss:ars:createAppWhitelistPolicy
Grants permission to create an application process whitelist policy.
write
host *
hss:ars:listAppWhitelistPolicy
Grants permission to query the list of application process whitelist policies.
list
hss:ars:changeAppWhitelistPolicy
Grants permission to modify an application process whitelist policy.
write
host *
hss:ars:deleteAppWhitelistPolicy
Grants permission to delete an application process whitelist policy.
write
hss:ars:showAppWhitelistPolicy
Grants permission to query the application process whitelist policy information.
list
hss:ars:switchAppWhitelistPolicyHost
Grants permission to modify the protection status of an application process whitelist policy.
write
host *
hss:ars:addAppWhitelistPolicyHost
Grant permissions to add servers to an application process whitelist policy.
write
host *
hss:ars:listAppWhitelistPolicyHost
Grants permission to query the server list for an application process whitelist policy.
list
hss:ars:deleteAppWhitelistPolicyHost
Grants permission to remove servers from an application process whitelist policy.
write
host *
hss:ars:listAppWhitelistHostStatus
Grants permission to query the list of available servers for an application process whitelist policy.
list
hss:ars:listAppWhitelistPolicyProcess
Grants permission to query the list of processes that an application process whitelist policy applies to.
list
hss:ars:changeAppWhitelistPolicyProcessStatus
Grants permission to modify the process trust status of an application process whitelist policy.
write
hss:ars:addAppWhitelistPolicyProcess
Grants permission to add processes to an application process whitelist policy.
write
host *
hss:ars:listAppWhitelistPolicyProcessExtend
Grants permission to query the extended process list for an application process whitelist policy.
list
host *
hss:ars:exportAppWhitelistPolicyProcess
Grants permission to export the list of processes that an application process whitelist policy applies to.
list
host *
hss:ars:switchAppWhitelistPolicyLearnStatus
Grants permission to modify the learning status of an application process whitelist policy.
write
host *
hss:ars:showAppWhitelistAgentStatics
Grants permission to query the number of servers that are protected by the premium edition and do not support application process control.
list
hss:ars:listAppWhitelistEvent
Grants permission to query the list of suspicious process events detected by application process control.
list
hss:container:deleteSelfBuildK8sClusterDaemonsetInfo
Grants permission to delete a daemonset of the self-built cluster.
write
hss:container:saveSelfBuildK8sClusterDaemonsetInfo
Grants permission to save a daemonset of the self-built cluster.
write
hss:container:showSelfBuildK8sClusterDaemonsetInfo
Grants permission to query a daemonset of the self-built cluster.
read
hss:container:listSelfBuildK8sClusterInfo
Grants permission to query the self-built Kubernetes cluster list.
list
hss:container:createDaemonset
Grants permission to create a daemonset of CCE cluster.
write
hss:vulnerability:listVulRepairCmds
Grants permission to query vulnerability fixing commands.
list
hss:vulnerability:listUrgentVulnerabilities
Grants permission to query the emergency vulnerability list.
list
hss:antivirus:createAntivirusTask
Grants permission to create virus scan tasks.
write
host *
hss:antivirus:listAntivirusTask
Grants permission to query the virus scan task list.
list
hss:antivirus:switchAntivirusTask
Grants permission to cancel virus scan tasks.
write
host *
hss:antivirus:listAntivirusHost
Grants permission to query the list of servers available for virus scan.
list
hss:antivirus:createAntivirusPolicy
Grants permission to create custom virus scan policies.
write
host *
hss:antivirus:listAntivirusPolicy
Grants permission to query the list of custom virus scan policies.
list
hss:antivirus:listAntivirusResult
Grants permission to query the list of virus scan results.
list
hss:antivirus:operateAntivirusResult
Grants permission to handle virus scan results.
write
hss:antivirus:exportAntivirusResult
Grants permission to export virus scan results.
write
hss:antivirus:showAntivirusStatistic
Grants permission to query virus scan statistics.
list
hss:image:showImageFullScanProgress
Grants permission to query the progress of a full image scan.
list
hss:host:changeHostIgnoreStatus
Grants permission to ignore or unignore servers.
write
host *
hss:host:listIgnoreHosts
Grants permission to query ignored servers.
list
host *
hss:image:batchExportBaselineTask
Grants permission to export image baseline check results.
write
hss:image:showImageSecurityReportStatistic
Grants permission to query the number of image scan results to be exported.
write
Grants permission to create vulnerability export tasks.
write
hss:exportTask:queryExportTask
Grants permission to query export tasks.
list
hss:file:downloadExportedFile
Grants permission to download files.
list
hss:image:listGlobalVulnerabilities
list
hss:image:listVulnerabilityImages
list
hss:setting:getPluginInstallScript
Grants permission to query server plug-in information.
list
hss:setting:getPluginList
Grants permission to query the plug-in installation guide.
list
hss:setting:getAutoOpenQuotaStatus
Grants permission to query the status of automatic quota binding.
read
hss:setting:changeAutoOpenQuotaStatus
Grants permission to modify the status of automatic quota binding.
write
hss:image:batchExportSWRVulTask
Grants permission to export SWR image vulnerability scan results.
write
hss:image:batchExportLocalVulTask
Grants permission to export local image vulnerability scan results.
write
hss:vulnerability:exportVulReport
Grants permission to export vulnerability reports in HTML format.
list
hss:vulnerability:getVulReportData
Grants permission to obtain vulnerability reports in PDF format.
list
hss:setting:getAgentAutoUpgradeStatus
Grants permission to query the status of automatic agent upgrade.
read
hss:setting:changeAgentAutoUpgradeStatus
Grants permission to modify the status of automatic agent upgrade.
write
hss:quota:showProductdataOfferingInfos
Grants permission to query product information.
list
hss:image:listLocalImageAppInfo
list
hss:image:listLocalImageAppVulnerabilities
list
Each API of HSS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by HSS APIs
API
Action
Dependencies
POST /v5/{project_id}/host-management/groups
eps:enterpriseProjects:list
PUT /v5/{project_id}/event/blocked-ip
GET /v5/{project_id}/backup/policy
GET /v5/{project_id}/container/nodes
GET /v5/{project_id}/host-management/groups
GET /v5/{project_id}/policy/groups
GET /v5/{project_id}/asset/ports/detail
GET /v5/{project_id}/asset/processes/detail
GET /v5/{project_id}/ransomware/protection/policy
GET /v5/{project_id}/ransomware/server
GET /v5/{project_id}/webtamper/static/protect-history
GET /v5/{project_id}/webtamper/rasp/protect-history
GET /v5/{project_id}/webtamper/hosts
  • eps:enterpriseProjects:list
  • vpc:ports:list
POST /v5/{project_id}/webtamper/static/status
POST /v5/{project_id}/webtamper/rasp/status
POST /v5/{project_id}/ransomware/protection/open
POST /v5/{project_id}/ransomware/protection/close
PUT /v5/{project_id}/backup/policy
PUT /v5/{project_id}/ransomware/protection/policy
GET /v5/{project_id}/asset/statistics
GET /v5/{project_id}/asset/app/change-history
GET /v5/{project_id}/asset/apps
hss:asset:listApps
GET /v5/{project_id}/asset/app/statistics
GET /v5/{project_id}/asset/auto-launch/change-history
GET /v5/{project_id}/asset/auto-launchs
GET /v5/{project_id}/asset/auto-launch/statistics
GET /v5/{project_id}/asset/midwares/detail
hss:asset:listPorts
GET /v5/{project_id}/asset/port/statistics
GET /v5/{project_id}/asset/process/statistics
GET /v5/{project_id}/asset/user/change-history
GET /v5/{project_id}/asset/users
hss:asset:listUsers
GET /v5/{project_id}/asset/user/statistics
GET /v5/{project_id}/baseline/check-rule/detail
GET /v5/{project_id}/baseline/risk-config/{check_name}/detail
GET /v5/{project_id}/baseline/password-complexity
GET /v5/{project_id}/baseline/risk-config/{check_name}/check-rules
GET /v5/{project_id}/baseline/risk-config/{check_name}/hosts
GET /v5/{project_id}/baseline/risk-configs
GET /v5/{project_id}/baseline/weak-password-users
POST /v5/{project_id}/event/operate
PUT /v5/{project_id}/event/isolated-file
GET /v5/{project_id}/event/white-list/alarm
GET /v5/{project_id}/event/blocked-ip
GET /v5/{project_id}/event/isolated-file
GET /v5/{project_id}/event/events
PUT /v5/{project_id}/host-management/groups
DELETE /v5/{project_id}/host-management/groups
GET /v5/{project_id}/host-management/hosts
  • vpc:ports:list
  • eip:publicIps:list
POST /v5/{project_id}/host-management/protection
POST /v5/{project_id}/policy/deploy
POST /v5/{project_id}/{resource_type}/{resource_id}/tags/create
DELETE /v5/{project_id}/{resource_type}/{resource_id}/tags/{key}
GET /v5/{project_id}/billing/quotas
GET /v5/{project_id}/billing/quotas-detail
PUT /v5/{project_id}/vulnerability/status
GET /v5/{project_id}/vulnerability/host/{host_id}
GET /v5/{project_id}/vulnerability/hosts
GET /v5/{project_id}/vulnerability/vulnerabilities
GET /v5/{project_id}/vulnerability/scan-policy
PUT /v5/{project_id}/vulnerability/scan-policy
GET /v5/{project_id}/vulnerability/scan-tasks
GET /v5/{project_id}/vulnerability/scan-task/{task_id}/hosts
GET /v5/{project_id}/vulnerability/statistics
GET /v5/{project_id}/image/baseline/risk-configs
GET /v5/{project_id}/image/baseline/check-rule/detail
GET /v5/{project_id}/image/swr-repository
POST /v5/{project_id}/image/batch-scan
GET /v5/{project_id}/image/{image_id}/vulnerabilities
GET /v5/{project_id}/image/vulnerability/{vul_id}/cve
GET /v5/{project_id}/image/baseline/risk-configs/{check_name}/rules
POST /v5/{project_id}/image/synchronize
GET /v5/{project_id}/product/productdata/offering-infos
Resource
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for HSS.
Table 3 Resource types supported by HSS
Resource Type
URN
host
hss:<region>:<account-id>:host:<host-id>
event
hss:<region>:<account-id>:event:<event-id>
baseline
hss:<region>:<account-id>:baseline:<type>/<check_rule_id>
policy
hss:<region>:<account-id>:policy:<resource-type>/<type-id>
Conditions
HSS does not support service-specific condition keys in SCP statements.
HSS can use global condition keys applicable to all services. For details, see Global Condition Keys.
