Content Delivery Network (CDN)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CDN, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by CDN, see Conditions.
The following table lists the actions that you can define in SCP statements for CDN.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cdn:statistics:queryStats |
Querying domain name statistics |
list |
domain * |
g:EnterpriseProjectId |
cdn:statistics:downloadExcel |
Downloading domain name statistics |
list |
domain * |
cdn:log:queryLogs |
Querying logs |
read |
domain * |
cdn:charge:modifyChargeMode |
Creating or modifying the billing option |
write |
cdn:charge:queryChargeMode |
Querying the billing option |
list |
cdn:statistics:querySubscriptionTasks |
Listing operations reports |
list |
cdn:statistics:createSubscriptionTasks |
Creating an operations report |
write |
domain * |
cdn:statistics:updateSubscriptionTasks |
Modifying an operations report |
write |
domain * |
cdn:statistics:deleteSubscriptionTasks |
Deleting an operations report |
write |
cdn:configuration:queryDomainList |
Listing domain names |
list |
domain * |
cdn:configuration:queryDomains |
Querying details about a domain name |
read |
domain * |
cdn:configuration:modifyDomainConfigs |
Modifying domain name configuration |
write |
domain * |
cdn:configuration:modifyOriginConfInfo |
Modifying the origin server settings |
write |
domain * |
cdn:log:queryLogs |
Querying logs |
read |
domain * |
list |
domain * |
list |
domain * |
cdn:configuration:createDomains |
Creating a domain name |
write |
domain * |
read |
domain * |
cdn:configuration:deleteDomains |
Deleting a domain name |
write |
domain * |
cdn:configuration:disableDomains |
Disabling CDN for a domain name |
write |
domain * |
cdn:configuration:enableDomains |
Enabling CDN for a domain name |
write |
domain * |
cdn:configuration:modifyOriginServerInfo |
Modifying the origin server information |
write |
domain * |
write |
domain * |
cdn:configuration:queryOriginConfInfo |
Querying the origin server settings |
read |
domain * |
cdn:configuration:modifyReferConf |
Modifying the referer whitelist |
write |
domain * |
cdn:configuration:queryReferConf |
Querying the referer whitelist |
read |
domain * |
cdn:configuration:queryIpAcl |
Querying the IP ACL |
list |
domain * |
cdn:configuration:modifyIpAcl |
Modifying the IP ACL |
write |
domain * |
cdn:configuration:queryCacheRule |
Listing cache rules |
list |
domain * |
cdn:configuration:modifyCacheRule |
Modifying a cache rule |
write |
domain * |
cdn:configuration:modifyHttpsConf |
Modifying the certificate of a domain name |
write |
domain * |
cdn:configuration:queryHttpsConf |
Querying the HTTPS settings |
read |
domain |
cdn:configuration:queryIpInfo |
Querying the IP address information |
list |
cdn:configuration:createResHeader |
Creating a response header |
write |
domain * |
cdn:configuration:queryResponseHeaderList |
Querying response headers |
read |
domain * |
cdn:configuration:batchModifyHttpsConf |
Modifying certificates of domain names |
write |
domain * |
cdn:configuration:queryTags |
Listing domain name tags |
list |
domain * |
cdn:configuration:modifyTags |
Modifying resource tags |
tagging |
domain * |
cdn:configuration:deleteTags |
Deleting resource tags |
tagging |
domain * |
cdn:configuration:refreshCache |
Purging the cache |
write |
cdn:configuration:queryRefreshAndPreheatHistoryTask |
Querying a cache purge or prefetch task |
list |
cdn:configuration:queryCacheHistoryTask |
Querying historical cache tasks |
list |
cdn:configuration:preheatCache |
Modifying cache prefetch settings |
write |
cdn:configuration:queryQuota |
Querying quotas of domain names, cache purge by file, cache purge by directory, and cache prefetch |
list |
Each API of CDN usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v1.0/cdn/domains |
POST /v1.0/cdn/domains |
DELETE /v1.0/cdn/domains/{domain_id} |
PUT /v1.0/cdn/domains/{domain_id}/disable |
PUT /v1.0/cdn/domains/{domain_id}/enable |
GET /v1.0/cdn/ip-info |
PUT /v1.0/cdn/domains/{domain_id}/private-bucket-access |
PUT /v1.0/cdn/domains/config-https-info |
GET /v1.0/cdn/domains/https-certificate-info |
PUT /v1.1/cdn/configuration/domains/{domain_name}/configs |
GET /v1.1/cdn/configuration/domains/{domain_name}/configs |
GET /v1.0/cdn/configuration/tags |
POST /v1.0/cdn/configuration/tags |
POST /v1.0/cdn/configuration/tags/batch-delete |
POST /v1.0/cdn/content/refresh-tasks |
POST /v1.0/cdn/content/preheating-tasks |
GET /v1.0/cdn/historytasks |
GET /v1.0/cdn/historytasks/{history_tasks_id}/detail |
GET /v1.0/cdn/contentgateway/url-tasks |
GET /v1.0/cdn/quota |
GET /v1.0/cdn/statistics/top-url |
GET /v1.0/cdn/statistics/domain-location-stats |
GET /v1.0/cdn/statistics/domain-stats |
GET /v1.0/cdn/logs |
cdn:log:queryLogs |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for CDN.
Conditions
CDN does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
