SoftWare Repository for Container (SWR)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by SWR, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by SWR, see Conditions.
The following table lists the actions that you can define in SCP statements for SWR.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
swr:namespace:createNamespace |
(Shared Edition) Grants permission to create an organization. |
Write |
namespace * |
swr:namespace:deleteNamespace |
(Shared Edition) Grants permission to delete an organization. |
Write |
namespace * |
swr:namespace:listNamespaces |
(Shared Edition) Grants permission to list organizations. |
List |
namespace * |
swr:namespace:getNamespace |
(Shared Edition) Grants permission to query details about an organization. |
Read |
namespace * |
swr:repo:createRepo |
(Shared Edition) Grants permission to create a repository. |
Write |
repo * |
swr:repo:deleteRepo |
(Shared Edition) Grants permission to delete a repository. |
Write |
repo * |
swr:repo:listRepos |
(Shared Edition) Grants permission to list repositories. |
List |
repo * |
swr:repo:listSharedRepos |
(Shared Edition) Grants permission to list shared images. |
List |
repo * |
swr:repo:getRepo |
(Shared Edition) Grants permission to query brief information about a repository. |
Read |
repo * |
swr:repo:updateRepo |
(Shared Edition) Grants permission to update brief information about a repository. |
Write |
repo * |
swr:repo:deleteRepoTag |
(Shared Edition) Grants permission to delete images with specified tags. |
Write |
repo * |
swr:repo:createRepoTag |
(Shared Edition) Grants permission to create an image tag. |
Write |
repo * |
swr:repo:listRepoTags |
(Shared Edition) Grants permission to list image tags. |
List |
repo * |
swr:repo:createRepoDomain |
(Shared Edition) Grants permission to share images with other accounts. |
Permission_management |
repo * |
swr:repo:deleteRepoDomain |
(Shared Edition) Grants permission to delete accounts from an image sharing list. |
repo * |
swr:repo:listRepoDomains |
(Shared Edition) Grants permission to list accounts an image is shared with. |
List |
repo * |
swr:repo:getRepoDomain |
(Shared Edition) Grants permission to check whether images are shared with an account. |
Read |
repo * |
swr:repo:updateRepoDomain |
(Shared Edition) Grants permission to update an account images are shared with. |
repo * |
swr:repo:createRepoShare |
(Shared Edition) Grants permission to create an image sharing policy. |
repo * |
swr:repo:deleteRepoShare |
(Shared Edition) Grants permission to delete an image sharing policy. |
repo * |
swr:repo:listRepoShares |
(Shared Edition) Grants permission to list image sharing policies. |
List |
repo * |
swr:repo:getRepoShare |
(Shared Edition) Grants permission to query details about an image sharing policy. |
Read |
repo * |
swr:repo:updateRepoShare |
(Shared Edition) Grants permission to update an image sharing policy. |
repo * |
swr:repo:createAutoSyncRepoJob |
(Shared Edition) Grants permission to create an automatic image synchronization task. |
Write |
repo * |
swr:repo:createManualSyncRepoJob |
(Shared Edition) Grants permission to manually synchronize images. |
Write |
repo * |
swr:repo:deleteAutoSyncRepoJob |
(Shared Edition) Grants permission to delete an automatic image synchronization task. |
Write |
repo * |
swr:repo:listAutoSyncRepoJobs |
(Shared Edition) Grants permission to list automatic image synchronization tasks. |
List |
repo * |
swr:repo:getSyncRepoJobInfo |
(Shared Edition) Grants permission to query details about an image synchronization task. |
Read |
repo * |
swr:repo:createTrigger |
(Shared Edition) Grants permission to create a trigger. |
Write |
repo * |
swr:repo:deleteTrigger |
(Shared Edition) Grants permission to delete a trigger. |
Write |
repo * |
swr:repo:listTriggers |
(Shared Edition) Grants permission to list triggers. |
List |
repo * |
swr:repo:getTrigger |
(Shared Edition) Grants permission to query details about a trigger. |
Read |
repo * |
swr:repo:updateTrigger |
(Shared Edition) Grants permission to update a trigger. |
Write |
repo * |
swr:repo:createRetention |
(Shared Edition) Grants permission to create an image retention policy. |
Write |
repo * |
swr:repo:deleteRetention |
(Shared Edition) Grants permission to delete an image retention policy. |
Write |
repo * |
swr:repo:listRetentionHistories |
(Shared Edition) Grants permission to list image retention records. |
List |
repo * |
swr:repo:listRetentions |
(Shared Edition) Grants permission to list image retention policies. |
List |
repo * |
swr:repo:getRetention |
(Shared Edition) Grants permission to query details about an image retention policy record. |
Read |
repo * |
swr:repo:updateRetention |
(Shared Edition) Grants permission to modify an image retention policy. |
Write |
repo * |
swr::createLoginSecret |
(Shared Edition) Grants permission to generate a temporary login command. |
Write |
swr::createAuthorizationToken |
(Shared Edition) Grants permission to generate a new temporary login command. |
Write |
swr::listQuotas |
(Shared Edition) Grants permission to list quotas. |
List |
swr::getDomainOverview |
(Shared Edition) Grants permission to query brief resource information of a tenant. |
Read |
swr::getDomainResourceReports |
(Shared Edition) Grants permission to query resource statistics of a tenant. |
Read |
swr:namespace:multipartUpload |
(Shared Edition) Grants permission to upload an image in multipart mode. |
Write |
namespace * |
swr:namespace:createNamespaceAccess |
(Shared Edition) Grants permission to grant organization permissions. |
namespace * |
swr:namespace:deleteNamespaceAccess |
(Shared Edition) Grants permission to cancel organization permissions. |
namespace * |
swr:namespace:getNamespaceAccess |
(Shared Edition) Grants permission to query organization permissions. |
Read |
namespace * |
swr:namespace:updateNamespaceAccess |
(Shared Edition) Grants permission to update organization permissions. |
namespace * |
swr:repo:createRepoAccess |
(Shared Edition) Grants permission to grant image permissions. |
repo * |
swr:repo:deleteRepoAccess |
(Shared Edition) Grants permission to cancel image permissions. |
repo * |
swr:repo:getRepoAccess |
(Shared Edition) Grants permission to query image permissions. |
Read |
repo * |
swr:repo:updateRepoAccess |
(Shared Edition) Grants permission to update image permissions. |
repo * |
swr:repo:upload |
(Shared Edition) Grants permission to upload an image. |
Write |
repo * |
swr:repo:download |
(Shared Edition) Grants permission to download an image. |
Read |
repo * |
swr:repo:getRepoTag |
(Shared Edition) Grants permission to query images with specified tags. |
Read |
repo * |
Each API of SWR usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v2/manage/namespaces |
DELETE /v2/manage/namespaces/{namespace} |
GET /v2/manage/namespaces |
GET /v2/manage/namespaces/{namespace} |
POST /v2/manage/namespaces/{namespace}/repos |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository} |
GET /v2/manage/repos |
GET /v2/manage/shared-repositories |
GET /v2/manage/namespaces/{namespace}/repos/{repository} |
swr:repo:getRepo |
PATCH /v2/manage/namespaces/{namespace}/repos/{repository} |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/tags/{tag} |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/tags |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/tags |
POST /v2/manage/namespaces/{namespace}/repositories/{repository}/access-domains |
DELETE /v2/manage/namespaces/{namespace}/repositories/{repository}/access-domains/{access_domain} |
GET /v2/manage/namespaces/{namespace}/repositories/{repository}/access-domains |
GET /v2/manage/namespaces/{namespace}/repositories/{repository}/access-domains/{access_domain} |
PATCH /v2/manage/namespaces/{namespace}/repositories/{repository}/access-domains/{access_domain} |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/shares |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/shares/{share_id} |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/shares |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/shares/{share_id} |
PATCH /v2/manage/namespaces/{namespace}/repos/{repository}/shares/{share_id} |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/sync_repo |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/sync_images |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/sync_repo |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/sync_repo |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/sync_job |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/triggers |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/triggers/{trigger} |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/triggers |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/triggers/{trigger} |
PATCH /v2/manage/namespaces/{namespace}/repos/{repository}/triggers/{trigger} |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/retentions |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/retentions/{retention_id} |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/retentions/histories |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/retentions |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/retentions/{retention_id} |
PATCH /v2/manage/namespaces/{namespace}/repos/{repository}/retentions/{retention_id} |
POST /v2/manage/utils/secret |
POST /v2/manage/utils/authorizationtoken |
sts::createServiceBearerToken |
GET /v2/manage/projects/{project_id}/quotas |
swr::listQuotas |
GET /v2/manage/overview |
GET /v2/manage/reports/{resource_type}/{frequency} |
POST /v2/manage/namespaces/{namespace}/access |
DELETE /v2/manage/namespaces/{namespace}/access |
GET /v2/manage/namespaces/{namespace}/access |
PATCH /v2/manage/namespaces/{namespace}/access |
POST /v2/manage/namespaces/{namespace}/repos/{repository}/access |
DELETE /v2/manage/namespaces/{namespace}/repos/{repository}/access |
GET /v2/manage/namespaces/{namespace}/repos/{repository}/access |
PATCH /v2/manage/namespaces/{namespace}/repos/{repository}/access |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for SWR.
Resource Type |
URN |
repo |
swr:<region>:<account-id>:repo:<namespace-name>/<repo-name> |
repository |
swr:<region>:<account-id>:repository:<instance-name>/<repository-path> |
instance |
swr:<region>:<account-id>:instance:<instance-name> |
namespace |
swr:<region>:<account-id>:namespace:<namespace-name> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, swr:) only apply to operations of the SWR service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for SWR. You can include these condition keys to specify conditions for when your SCP is in effect.
Condition Key |
Value Type |
Single-valued/Multivalued |
Description |
swr:TargetOrgPath |
string |
Single-valued |
Controls permissions of target sharing accounts based on their organization paths. |
swr:TargetOrgId |
string |
Single-valued |
Controls permissions of target sharing accounts based on their organization IDs. |
swr:TargetAccountId |
string |
Single-valued |
Controls permissions of target sharing accounts based on their IDs. |
swr:VpcId |
string |
Single-valued |
Controls permissions based on VPC IDs. |
swr:SubnetId |
string |
Single-valued |
Controls permissions based on subnet IDs. |
swr:EnablePublicNameSpace |
boolean |
Single-valued |
Controls whether public organizations can be created in SWR Enterprise Edition. |
swr:EnableObsEncrypt |
boolean |
Single-valued |
Controls whether buckets must be encrypted in SWR Enterprise Edition. |
swr:AllowPublicAccess |
boolean |
Single-valued |
Controls whether images can be public. |
swr:TargetRegion |
string |
Single-valued |
Controls permissions based on destination regions. |
swr:SourceRegion |
string |
Single-valued |
Controls permissions based on source regions. |
swr:TargetUrls |
string |
Multivalued |
Controls permissions based on destination URLs. |
swr:SourceUrls |
string |
Multivalued |
Controls permissions based on source URLs. |
swr:AllowCredentialType |
string |
Single-valued |
Controls permissions based on the login command type (long-term login command or temporary login command). |
