Cloud Container Engine (CCE)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CCE, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by CCE, see Conditions.
The following table lists the actions that you can define in SCP statements for CCE.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cce:cluster:createCluster |
Grants permission to create a cluster. |
write |
cluster * |
cce:cluster:delete |
Grants permission to delete a cluster. |
write |
cluster * |
cce:cluster:updateCluster |
Grants permission to update a cluster. |
write |
cluster * |
cce:cluster:upgrade |
Grants permission to upgrade the version of a cluster. |
write |
cluster * |
cce:cluster:start |
Grants permission to wake up a hibernated cluster. |
write |
cluster * |
cce:cluster:stop |
Grants permission to hibernate a cluster. |
write |
cluster * |
cce:cluster:list |
Grants permission to view the cluster details list. |
list |
cluster * |
cce:cluster:getCluster |
Grants permission to view details about a specified cluster. |
read |
cluster * |
cce:cluster:getEndpoints |
Grants permission to view the access address of a specified cluster. |
read |
cluster * |
cce:cluster:resize |
Grants permission to modify the specifications of a cluster. |
write |
cluster * |
cce:cluster:eipBinding |
Grants permission to bind or unbind a public IP address to or from a cluster. |
write |
cluster * |
cce:cluster:generateClientCredential |
Grants permission to generate cluster client access credentials. |
read |
cluster * |
cce:cluster:addTags |
Grants permission to add tags to a cluster. |
tagging |
cluster * |
cce:cluster:removeTags |
Grants permission to delete tags from a cluster. |
tagging |
cluster * |
cce:cluster:getConfigurationTemplate |
Grants permission to obtain the configuration template information about a cluster. |
read |
cluster * |
cce:cluster:getLogConfig |
Grants permission to obtain the current log collection configurations of a cluster. |
read |
cluster * |
cce:cluster:updateLogConfig |
Grants permission to update the log collection configurations of a cluster. |
write |
cluster * |
cce:partition:create |
Grants permission to access a partition. |
write |
cluster * |
cce:partition:update |
Grants permission to update a partition. |
write |
cluster * |
g:EnterpriseProjectId |
cce:partition:get |
Grants permission to obtain details about a specified partition. |
read |
cluster * |
cce:partition:list |
Grants permission to view the partition list in a specified cluster. |
list |
cluster * |
cce:nodepool:create |
Grants permission to create a node pool. |
write |
cluster * |
cce:nodepool:delete |
Grants permission to delete a node pool. |
write |
cluster * |
cce:nodepool:updateNodepool |
Grants permission to update a node pool. |
write |
cluster * |
cce:nodepool:getNodepool |
Grants permission to obtain details about a specified node pool. |
read |
cluster * |
cce:nodepool:list |
Grants permission to view the node pool list in a specified cluster. |
list |
cluster * |
cce:nodepool:getConfigurationTemplate |
Grants permission to obtain node pool configuration templates. |
read |
cluster * |
cce:nodepool:getConfiguration |
Grants permission to obtain the configurations of a node pool. |
read |
cluster * |
cce:nodepool:updateConfiguration |
Grants permission to update the configurations of a node pool. |
write |
cluster * |
cce:node:createNode |
Grants permission to create a node. |
write |
cluster * |
cce:node:delete |
Grants permission to delete a node. |
write |
cluster * |
cce:node:update |
Grants permission to update a node. |
write |
cluster * |
cce:node:getNode |
Grants permission to obtain details about a specified node. |
read |
cluster * |
cce:node:list |
Grants permission to view the node list in a specified cluster. |
list |
cluster * |
cce:node:reset |
Grants permission to reset a node. |
write |
cluster * |
cce:node:add |
Grants permission to manage a node. |
write |
cluster * |
cce:node:remove |
Grants permission to release a node. |
write |
cluster * |
cce:node:migrate |
Grants permission to migrate nodes between clusters. |
write |
cluster * |
cce:node:sync |
Grants permission to synchronize infrastructure and resource status between nodes. |
read |
cluster * |
cce:quota:get |
Grants permission to obtain resource quotas of cloud services used in a CCE cluster. |
read |
cce:addonInstance:create |
Grants permission to create an add-on instance. |
write |
cluster * |
cce:addonInstance:delete |
Grants permission to delete an add-on instance. |
write |
cluster * |
cce:addonInstance:update |
Grants permission to update an add-on instance. |
write |
cluster * |
cce:addonInstance:get |
Grants permission to obtain details about a specified add-on instance. |
read |
cluster * |
cce:addonInstance:list |
Grants permission to view the add-on instance list in a specified cluster. |
list |
cluster * |
cce:addonInstance:rollback |
Grants permission to roll back a specified add-on instance. |
write |
cluster * |
cce:chart:upload |
Grants permission to upload an application chart. |
write |
cce:chart:delete |
Grants permission to delete an application chart. |
write |
cce:chart:update |
Grants permission to update an application chart. |
write |
cce:chart:listChart |
Grants permission to view the application chart details list. |
list |
cce:chart:getChart |
Grants permission to view details about an application chart specified by a user. |
read |
cce:chart:download |
Grants permission to view the application charts downloaded by a user. |
read |
cce:chart:getQuota |
Grants permission to view the application chart quota. |
read |
cce:release:create |
Grants permission to create a release. |
write |
cce:release:delete |
Grants permission to delete a release. |
write |
cluster * |
cce:release:update |
Grants permission to update a release. |
write |
cluster * |
cce:release:get |
Grants permission to obtain details about a specified release. |
read |
cluster * |
cce:release:list |
Grants permission to view the release list in a specified cluster. |
list |
cluster * |
Each API of CCE usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /api/v3/projects/{project_id}/quotas |
cce:quota:get |
POST /api/v3/projects/{project_id}/clusters |
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id} |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id} |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgradeworkflows |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgradeworkflows |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgradeworkflows/{upgrade_workflow_id} |
PATCH /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgradeworkflows/{upgrade_workflow_id} |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade/retry |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade/tasks/{task_id} |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade/continue |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade/pause |
GET /api/v3/clusterupgradefeaturegates |
GET /api/v3/clusterupgradepaths |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/upgradeinfo |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/postcheck |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/precheck |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/precheck/tasks |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/precheck/tasks/{task_id} |
GET /api/v3.1/projects/{project_id}/clusters/{cluster_id}/operation/snapshot/tasks |
POST /api/v3.1/projects/{project_id}/clusters/{cluster_id}/operation/snapshot |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/upgrade/tasks |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/awake |
cce:cluster:start |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/hibernate |
cce:cluster:stop |
GET /api/v3/projects/{project_id}/clusters |
cce:cluster:list |
GET /api/v3/projects/{project_id}/clusters/{cluster_id} |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/openapi |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/operation/resize |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/mastereip |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/clustercert |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/tags/create |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/tags/delete |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/configuration/detail |
GET /api/v3/projects/{project_id}/cluster/{cluster_id}/log-configs |
PUT /api/v3/projects/{project_id}/cluster/{cluster_id}/log-configs |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions/{partition_name} |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions/{partition_name} |
cce:partition:get |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/partitions |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools |
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id} |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id} |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id} |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools |
cce:nodepool:list |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}/configuration/detail |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}/configuration |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodepools/{nodepool_id}/configuration |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes |
DELETE /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id} |
cce:node:delete |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id} |
cce:node:update |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id} |
cce:node:getNode |
GET /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes |
cce:node:list |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/reset |
cce:node:reset |
POST /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/add |
cce:node:add |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/operation/remove |
cce:node:remove |
PUT /api/v3/projects/{project_id}/clusters/{cluster_id}/nodes/operation/migrateto/{target_cluster_id} |
cce:node:migrate |
GET /api/v2/projects/{project_id}/clusters/{cluster_id}/nodes/{node_id}/sync |
cce:node:sync |
POST /api/v3/addons |
DELETE /api/v3/addons/{id} |
PUT /api/v3/addons/{id} |
GET /api/v3/addons/{id} |
GET /api/v3/addons |
POST /api/v3/addons/{id}/operation/rollback |
POST /v2/charts |
cce:chart:upload |
DELETE /v2/charts/{chart_id} |
cce:chart:delete |
PUT /v2/charts/{chart_id} |
cce:chart:update |
GET /v2/charts/{chart_id} |
GET /v2/charts |
GET /v2/charts/{chart_id}/archive |
GET /v2/charts/{project_id}/quotas |
POST /cce/cam/v3/clusters/{cluster_id}/releases |
DELETE /cce/cam/v3/clusters/{cluster_id}/namespace/{namespace}/releases/{name} |
PUT /cce/cam/v3/clusters/{cluster_id}/namespace/{namespace}/releases/{name} |
GET /cce/cam/v3/clusters/{cluster_id}/namespace/{namespace}/releases/{name} |
cce:release:get |
GET /cce/cam/v3/clusters/{cluster_id}/releases |
cce:release:list |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for CCE.
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- The condition key that you specify can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, cce:) only apply to operations of the CCE service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for CCE. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
cce:ClusterId |
string |
Single-valued |
Obtains access permissions based on the cluster ID transferred in a request. |
cce:nodeTransferSourceCluster |
string |
Single-valued |
Obtains access permissions based on the ID of the source cluster from which a node is migrated. |
cce:nodeTransferTargetCluster |
string |
Single-valued |
Obtains access permissions based on the ID of the destination cluster to which a node is migrated. |
cce:AssociatePublicIp |
string |
Single-valued |
Obtains access permissions based on whether the ECS creation involves automatic EIP creation. To restrict the permission to bind or unbind EIPs to or from a cluster, use the cce:cluster:eipBinding action. |
cce:VpcId |
string |
Single-valued |
Obtains access permissions based on the VPC selected during cluster creation. |
cce:SubnetId |
string |
Single-valued |
Obtains access permissions based on the subnet selected during cluster, node, or node pool creation. |
cce:Subnets |
array |
Single-valued |
Obtains access permissions based on the subnets selected during node pool creation or updates. |
cce:KmsKeys |
string |
Single-valued |
Obtains access permissions based on the KMS key selected for disk encryption during node or node pool creation. |
