On this page
VPC Endpoint (VPCEP)
Updated on 2025-02-25 GMT+08:00
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by VPC Endpoint, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by VPC Endpoint, see Conditions.
The following table lists the actions that you can define in SCP statements for VPC Endpoint.
Table 1 Actions Supported by VPC Endpoint
Action
Access Level
Resource Type (*: required)
Condition Key
vpcep:endpoints:create
Grants permission to create a VPC endpoint for a specified service.
write
endpoints *
  • vpcep:VpceServiceName
  • vpcep:VpceServiceOrgPath
  • vpcep:VpceServiceOwner
vpc *
routeTable
subnet
  • g:RequestTag/<tag-key>
  • g:TagKeys
  • g:EnterpriseProjectId
vpcep:endpoints:delete
Grants permission to delete a VPC endpoint.
write
endpoints *
  • g:ResourceTag/<tag-key>
vpcep:endpoints:list
Grants permission to query VPC endpoints.
list
endpoints *
vpcep:endpoints:get
Grants permission to query details of a VPC endpoint.
read
endpoints *
vpcep:endpoints:update
Grants permission to update the whitelist of a VPC endpoint.
write
endpoints *
routeTable
subnet
vpcep:endpoints:updateRouteTables
Grants permission to modify route tables of a VPC endpoint.
write
endpoints *
routeTable *
vpcep:endpoints:updatePolicy
Grants permission to modify a VPC endpoint policy.
write
endpoints *
vpcep:endpoints:deletePolicy
Grants permission to delete a VPC endpoint policy.
write
endpoints *
vpcep:endpointServices:create
Grants permission to create a VPC endpoint service.
write
endpointServices *
vpcep:VpceServicePrivateDnsName
vpc *
  • g:TagKeys
vpcep:endpointServices:list
Grants permission to query VPC endpoint services.
list
endpointServices *
vpcep:endpointServices:get
Grants permission to query details of a VPC endpoint service.
read
endpointServices *
vpcep:endpointServices:update
Grants permission to modify a VPC endpoint service.
write
endpointServices *
vpcep:endpointServices:delete
Grants permission to delete a VPC endpoint service.
write
endpointServices *
vpcep:endpointServices:updateName
Grants permission to change the name of a VPC endpoint service.
write
endpointServices *
vpcep:endpointServices:describe
Grants permission to query basic information about a VPC endpoint service.
read
vpcep:endpointServices:listPublic
Grants permission to query public VPC endpoint services.
list
endpointServices *
vpcep:endpointServices:listPermissions
Grants permission to query whitelist records of a VPC endpoint service.
list
endpointServices *
vpcep:endpointServices:updatePermissions
Grants permission to batch add or delete whitelist records of a VPC endpoint service.
permission_management
endpointServices *
  • vpcep:VpceEndpointOrgPath
  • vpcep:VpceEndpointOwner
vpcep:endpointServices:createPermissions
Grants permission to batch add whitelist records of a VPC endpoint service.
endpointServices *
vpcep:endpointServices:deletePermissions
Grants permission to batch delete whitelist records of a VPC endpoint service.
endpointServices *
vpcep:endpointServices:updatePermissionsDescription
Grants permission to update the whitelist description of a VPC endpoint service.
write
endpointServices *
vpcep:endpointServices:listConnections
Grants permission to query connections of a VPC endpoint service.
list
endpointServices *
vpcep:endpointServices:updateConnections
Grants permission to accept or reject a VPC endpoint.
write
endpointServices *
vpcep:endpointServices:updateConnectionDescription
Grants permission to update the description of a VPC endpoint connection.
write
endpointServices *
vpcep::listResourceTags
Grants permission to query resources by tag.
list
endpoints
endpointServices
vpcep::updateResourceTags
Grants permission to batch add tags to or delete tags from a VPC endpoint service or VPC endpoint.
tagging
endpoints
endpointServices
vpcep::getProjectTags
Grants permission to query resource tags of a tenant.
read
endpoints
endpointServices
vpcep::listQuotas
Grants permission to query the quotas of your resources, including the quota of VPC endpoint services and the quota of VPC endpoints.
read
vpcep::listVersionDetails
Grants permission to query versions of VPC Endpoint APIs.
list
vpcep::listSpecifiedVersion
Grants permission to query information about a VPC Endpoint API version.
list
Each API of VPC Endpoint usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by VPC Endpoint APIs
API
Action
Dependencies
POST /v1/{project_id}/vpc-endpoints
DELETE /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}
GET /v1/{project_id}/vpc-endpoints
GET /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}
vpcep:endpoints:get
PUT /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}
PUT /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}/routetables
PUT /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}/policy
DELETE /v1/{project_id}/vpc-endpoints/{vpc_endpoint_id}/policy
POST /v1/{project_id}/vpc-endpoint-services
GET /v1/{project_id}/vpc-endpoint-services
GET /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}
PUT /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}
DELETE /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}
PUT /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/name
GET /v1/{project_id}/vpc-endpoint-services/describe
GET /v1/{project_id}/vpc-endpoint-services/public
GET /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/permissions
POST /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/permissions/action
POST /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/permissions/batch-create
POST /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/permissions/batch-delete
PUT /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/permissions/{permission_id}
GET /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/connections
POST /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/connections/action
PUT /v1/{project_id}/vpc-endpoint-services/{vpc_endpoint_service_id}/connections/description
POST /v1/{project_id}/{resource_type}/resource_instances/action
POST /v1/{project_id}/{resource_type}/{resource_id}/tags/action
GET /v1/{project_id}/{resource_type}/tags
GET /v1/{project_id}/quotas
vpcep::listQuotas
GET /
GET /{version}
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, a resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for VPC Endpoint.
Table 3 Resource types supported by VPC Endpoint
Resource Type
URN
routeTable
vpc:<region>:<account-id>:routeTable:<route-table-id>
vpc
vpc:<region>:<account-id>:vpc:<vpc-id>
endpointServices
vpcep:<region>:<account-id>:endpointServices:<endpoint-service-id>
subnet
vpc:<region>:<account-id>:subnet:<subnet-id>
endpoints
vpcep:<region>:<account-id>:endpoints:<endpoint-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, vpcep:) apply only to operations of VPC Endpoint. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for VPC Endpoint. You can include these condition keys to specify conditions for when your SCP is in effect.
Table 4 Service-specific condition keys supported by VPC Endpoint
Service-specific Condition Key
Type
Single-valued/Multivalued
string
Single-valued
Filters access by VPC endpoint service name.
string
Single-valued
Filters access by VPC endpoint service owner.
string
Single-valued
Filters access by the value of VpceServicePrivateDnsName that is passed in the request.
string
Single-valued
Filters access by the organization path of the VPC endpoint service owner.
string
Single-valued
Filters access by the organization path of the VPC endpoint owner.
string
Single-valued
Filters access by the value of accountId of the VPC endpoint owner.
vpcep:VpcId
string
Multivalued
Filters accesses by VPC ID.
