The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by NAT Gateway, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by NAT Gateway, see Conditions.
The following table lists the actions that you can define in SCP statements for NAT Gateway.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
nat:privateNatGateways:list |
Grants permission to query private NAT gateways. |
list |
privateGateway * |
g:EnterpriseProjectId |
nat:privateNatGateways:create |
Grants permission to create a private NAT gateway. |
write |
privateGateway * |
subnet * |
nat:privateNatGateways:delete |
Grants permission to delete a private NAT gateway. |
write |
privateGateway * |
nat:privateNatGateways:get |
Grants permission to query a private NAT gateway. |
read |
privateGateway * |
nat:privateNatGateways:update |
Grants permission to update a private NAT gateway. |
write |
privateGateway * |
nat:privateNatDnatRules:list |
Grants permission to query DNAT rules on a private NAT gateway. |
list |
privateDnatRule * |
nat:privateNatDnatRules:create |
Grants permission to create a DNAT rule on a private NAT gateway. |
write |
privateGateway * |
g:ResourceTag/<tag-key> |
privateDnatRule * |
privateTransitIp * |
port |
nat:privateNatDnatRules:delete |
Grants permission to delete a DNAT rule on a private NAT gateway. |
write |
privateGateway * |
privateDnatRule * |
nat:privateNatDnatRules:get |
Grants permission to query a DNAT rule on a private NAT gateway. |
read |
privateGateway * |
privateDnatRule * |
nat:privateNatDnatRules:update |
Grants permission to update a DNAT rule on a private NAT gateway. |
write |
privateGateway * |
privateDnatRule * |
privateTransitIp |
port |
nat:privateNatSnatRules:list |
Grants permission to query SNAT rules on a private NAT gateway. |
list |
privateSnatRule * |
nat:privateNatSnatRules:create |
Grants permission to create an SNAT rule on a private NAT gateway. |
write |
privateGateway * |
privateSnatRule * |
subnet |
nat:privateNatSnatRules:delete |
Grants permission to delete an SNAT rule on a private NAT gateway. |
write |
privateGateway * |
privateSnatRule * |
nat:privateNatSnatRules:get |
Grants permission to query an SNAT rule on a private NAT gateway. |
read |
privateGateway * |
privateSnatRule * |
nat:privateNatSnatRules:update |
Grants permission to update an SNAT rule on a private NAT gateway. |
write |
privateGateway * |
privateSnatRule * |
privateTransitIp |
nat:privateNatTransitIps:list |
Grants permission to query transit IP addresses. |
list |
nat:privateNatTransitIps:create |
Grants permission to assign a transit IP address. |
write |
subnet |
nat:privateNatTransitIps:delete |
Grants permission to release a transit IP address. |
write |
nat:privateNatTransitIps:get |
Grants permission to query a transit IP address. |
read |
nat:natGateways:list |
Grants permission to query public NAT gateways. |
list |
gateway * |
nat:natGateways:create |
Grants permission to create a public NAT gateway. |
write |
gateway * |
vpc * |
subnet * |
nat:natGateways:delete |
Grants permission to delete a public NAT gateway. |
write |
gateway * |
nat:natGateways:get |
Grants permission to query a public NAT gateway. |
read |
gateway * |
nat:natGateways:update |
Grants permission to update a public NAT gateway. |
write |
gateway * |
nat:dnatRules:list |
Grants permission to query DNAT rules on a public NAT gateway. |
list |
dnatRule * |
nat:dnatRules:create |
Grants permission to create a DNAT rule on a public NAT gateway. |
write |
gateway * |
dnatRule * |
publicip |
globalEip |
port |
nat:dnatRules:get |
Grants permission to query a DNAT rule on a public NAT gateway. |
read |
gateway * |
dnatRule * |
nat:dnatRules:update |
Grants permission to update a DNAT rule on a public NAT gateway. |
write |
gateway * |
dnatRule * |
publicip |
globalEip |
port |
nat:dnatRules:delete |
Grants permission to delete a DNAT rule on a public NAT gateway. |
write |
gateway * |
dnatRule * |
nat:snatRules:list |
Grants permission to query SNAT rules on a public NAT gateway. |
list |
snatRule * |
nat:snatRules:create |
Grants permission to create an SNAT rule on a public NAT gateway. |
write |
gateway * |
snatRule * |
publicip |
globalEip |
subnet |
nat:snatRules:get |
Grants permission to query an SNAT rule on a public NAT gateway. |
read |
gateway * |
snatRule * |
nat:snatRules:update |
Grants permission to update an SNAT rule on a public NAT gateway. |
write |
gateway * |
snatRule * |
publicip |
globalEip |
nat:snatRules:delete |
Grants permission to delete an SNAT rule on a public NAT gateway. |
write |
gateway * |
snatRule * |
nat:privateNatGateways:createTags |
Grants permission to add a tag to a private NAT gateway. |
tagging |
privateGateway * |
nat:privateNatGateways:deleteTags |
Grants permission to delete a tag of a private NAT gateway. |
tagging |
privateGateway * |
nat:privateNatGateways:listTags |
Grants permission to query tags of a private NAT gateway. |
list |
privateGateway |
nat:privateNatTransitIps:createTags |
Grants permission to add a tag to a transit IP address. |
tagging |
nat:privateNatTransitIps:deleteTags |
Grants permission to delete a tag of a transit IP address. |
tagging |
nat:privateNatTransitIps:listTags |
Grants permission to query tags of a transit IP address. |
list |
privateTransitIp |
nat:natGateways:createTags |
Grants permission to add a tag to a public NAT gateway. |
tagging |
gateway * |
nat:natGateways:deleteTags |
Grants permission to delete a tag of a public NAT gateway. |
tagging |
gateway * |
nat:natGateways:listTags |
Grants permission to query tags of a public NAT gateway. |
list |
gateway |
Each API of NAT Gateway usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
GET /v3/{project_id}/private-nat/gateways |
POST /v3/{project_id}/private-nat/gateways |
DELETE /v3/{project_id}/private-nat/gateways/{gateway_id} |
GET /v3/{project_id}/private-nat/gateways/{gateway_id} |
PUT /v3/{project_id}/private-nat/gateways/{gateway_id} |
GET /v3/{project_id}/private-nat/dnat-rules |
POST /v3/{project_id}/private-nat/dnat-rules |
DELETE /v3/{project_id}/private-nat/dnat-rules/{dnat_rule_id} |
GET /v3/{project_id}/private-nat/dnat-rules/{dnat_rule_id} |
PUT /v3/{project_id}/private-nat/dnat-rules/{dnat_rule_id} |
GET /v3/{project_id}/private-nat/snat-rules |
POST /v3/{project_id}/private-nat/snat-rules |
DELETE /v3/{project_id}/private-nat/snat-rules/{snat_rule_id} |
GET /v3/{project_id}/private-nat/snat-rules/{snat_rule_id} |
PUT /v3/{project_id}/private-nat/snat-rules/{snat_rule_id} |
GET /v3/{project_id}/private-nat/transit-ips |
POST /v3/{project_id}/private-nat/transit-ips |
DELETE /v3/{project_id}/private-nat/transit-ips/{transit_ip_id} |
GET /v3/{project_id}/private-nat/transit-ips/{transit_ip_id} |
GET /v2/{project_id}/nat_gateways |
POST /v2/{project_id}/nat_gateways |
DELETE /v2/{project_id}/nat_gateways/{nat_gateway_id} |
GET /v2/{project_id}/nat_gateways/{nat_gateway_id} |
PUT /v2/{project_id}/nat_gateways/{nat_gateway_id} |
GET /v2/{project_id}/dnat_rules |
POST /v2/{project_id}/dnat_rules |
eip:publicIps:associateInstance |
GET /v2/{project_id}/dnat_rules/{dnat_rule_id} |
nat:dnatRules:get |
PUT /v2/{project_id}/dnat_rules/{dnat_rule_id} |
POST /v2/{project_id}/dnat_rules/batch |
DELETE /v2/{project_id}/nat_gateways/{nat_gateway_id}/dnat_rules/{dnat_rule_id} |
eip:publicIps:disassociateInstance |
GET /v2/{project_id}/snat_rules |
POST /v2/{project_id}/snat_rules |
GET /v2/{project_id}/snat_rules/{snat_rule_id} |
nat:snatRules:get |
PUT /v2/{project_id}/snat_rules/{snat_rule_id} |
DELETE /v2/{project_id}/nat_gateways/{nat_gateway_id}/snat_rules/{snat_rule_id} |
POST /v3/{project_id}/private-nat-gateways/resource_instances/action |
POST /v3/{project_id}/private-nat-gateways/{resource_id}/tags/action |
POST /v3/{project_id}/private-nat-gateways/{resource_id}/tags |
GET /v3/{project_id}/private-nat-gateways/{resource_id}/tags |
DELETE /v3/{project_id}/private-nat-gateways/{resource_id}/tags/{key} |
GET /v3/{project_id}/private-nat-gateways/tags |
POST /v3/{project_id}/transit-ips/resource_instances/action |
POST /v3/{project_id}/transit-ips/{resource_id}/tags/action |
POST /v3/{project_id}/transit-ips/{resource_id}/tags |
GET /v3/{project_id}/transit-ips/{resource_id}/tags |
DELETE /v3/{project_id}/transit-ips/{resource_id}/tags/{key} |
GET /v3/{project_id}/transit-ips/tags |
POST /v2.0/{project_id}/nat_gateways/resource_instances/action |
POST /v2.0/{project_id}/nat_gateways/{nat_gateway_id}/tags/action |
POST /v2.0/{project_id}/nat_gateways/{nat_gateway_id}/tags |
GET /v2.0/{project_id}/nat_gateways/{nat_gateway_id}/tags |
DELETE /v2.0/{project_id}/nat_gateways/{nat_gateway_id}/tags/{key} |
GET /v2.0/{project_id}/nat_gateways/tags |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for NAT Gateway.
Resource Type |
URN |
snatRule |
nat:<region>:<account-id>:snatRule:<snat-rule-id> |
privateSnatRule |
nat:<region>:<account-id>:privateSnatRule:<private-snat-rule-id> |
port |
vpc:<region>:<account-id>:port:<port-id> |
privateGateway |
nat:<region>:<account-id>:privateGateway:<private-gateway-id> |
vpc |
vpc:<region>:<account-id>:vpc:<vpc-id> |
publicip |
vpc:<region>:<account-id>:publicip:<publicip-id> |
gateway |
nat:<region>:<account-id>:gateway:<gateway-id> |
privateTransitIp |
nat:<region>:<account-id>:privateTransitIp:<private-transit-ip-id> |
dnatRule |
nat:<region>:<account-id>:dnatRule:<dnat-rule-id> |
globalEip |
eip:<region>:<account-id>:globalEip:<geip-id> |
privateDnatRule |
nat:<region>:<account-id>:privateDnatRule:<private-dnat-rule-id> |
subnet |
vpc:<region>:<account-id>:subnet:<subnet-id> |
Conditions
Only global condition keys applicable to all cloud services can be configured for NAT Gateway. For details, see Global Condition Keys.
