Elastic IP (EIP)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permission to that member account or OU. Instead, the SCPs determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by EIP, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by EIP, see Conditions.
The following table lists the actions that you can define in SCP statements for EIP.
Action |
Description |
Access Level |
Resource Type (*: Required) |
Condition Key |
eip:publicIps:create |
Grants permission to assign an EIP. |
write |
publicip * |
g:EnterpriseProjectId |
eip:publicIps:batchCreate |
Grants permission to assign EIPs in batches. |
write |
publicip * |
eip:publicIps:list |
Grants permission to query EIPs. |
list |
publicip * |
eip:publicIps:count |
Grants permission to query the number of EIPs. |
list |
publicip * |
eip:publicIps:get |
Grants permission to query a specific EIP. |
read |
publicip * |
eip:publicIps:update |
Grants permission to modify an EIP. |
write |
publicip * |
eip:publicIps:enableNat64 |
Grants permission to enable NAT64 for an EIP. |
write |
publicip * |
eip:publicIps:disableNat64 |
write |
publicip * |
eip:publicIps:associateInstance |
Grants permission to bind an EIP to a network interface. |
write |
publicip * |
eip:publicIps:disassociateInstance |
Grants permission to unbind an EIP from a network interface. |
write |
publicip * |
eip:publicIps:attachBandwidth |
Grants permission to associate an EIP with a bandwidth. |
write |
publicip * |
bandwidth * |
eip:publicIps:detachBandwidth |
Grants permission to remove an EIP from a shared bandwidth. |
write |
publicip * |
bandwidth * |
eip:publicIps:delete |
Grants permission to release an EIP. |
write |
publicip * |
eip:publicIps:createTags |
Grants permission to add tags to an EIP. |
tagging |
publicip * |
eip:publicIps:listTags |
Grants permission to query tags of an EIP. |
list |
publicip * |
eip:publicIps:deleteTags |
Grants permission to delete tags from an EIP. |
tagging |
publicip * |
g:TagKeys |
eip:bandwidths:insertPublicIps |
Grants permission to add EIPs to a shared bandwidth. |
write |
bandwidth * |
eip:bandwidths:removePublicIps |
Grants permission to remove EIPs from a shared bandwidth. |
write |
bandwidth * |
eip:bandwidths:create |
Grants permission to create a shared bandwidth. |
write |
bandwidth * |
eip:bandwidths:batchCreate |
Grants permission to create shared bandwidths in batches. |
write |
bandwidth * |
eip:bandwidths:list |
Grants permission to query bandwidths. |
list |
bandwidth * |
eip:bandwidths:update |
Grants permission to modify a bandwidth. |
write |
bandwidth * |
eip:bandwidths:get |
Grants permission to query a bandwidth. |
read |
bandwidth * |
eip:bandwidths:delete |
Grants permission to delete a shared bandwidth. |
write |
bandwidth * |
eip:bandwidthPkgs:list |
Grants permission to query bandwidth add-on packages. |
list |
bandwidthPkg * |
eip:publicipPools:get |
Grants permission to query an EIP pool. |
read |
publicipPool * |
Each API of EIP usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v2.0/{project_id}/publicips |
POST /v1/{project_id}/publicips |
POST /v2/{project_id}/batchpublicips |
GET /v1/{project_id}/publicips |
GET /v2/{project_id}/elasticips |
GET /v2/{project_id}/publicip/instances |
GET /v1/{project_id}/publicips/{publicip_id} |
eip:publicIps:get |
PUT /v1/{project_id}/publicips/{publicip_id} |
POST /v2.0/{project_id}/publicips/change-to-period |
bss:renewal:update |
PATCH /v2/{project_id}/batchpublicips |
POST /v3/{project_id}/eip/publicips/{publicip_id}/associate-instance |
POST /v3/{project_id}/eip/publicips/{publicip_id}/disassociate-instance |
POST /v3/{project_id}/eip/publicips/attach-share-bandwidth |
POST /v3/{project_id}/eip/publicips/{publicip_id}/attach-share-bandwidth |
POST /v3/{project_id}/eip/publicips/detach-share-bandwidth |
POST /v3/{project_id}/eip/publicips/{publicip_id}/detach-share-bandwidth |
DELETE /v1/{project_id}/publicips/{publicip_id} |
DELETE /v2/{project_id}/batchpublicips |
POST /v2.0/{project_id}/publicips/{publicip_id}/tags/action |
POST 01 /v2.0/{project_id}/publicips/{publicip_id}/tags/action |
POST /v2.0/{project_id}/publicips/{publicip_id}/tags |
DELETE /v2.0/{project_id}/publicips/{publicip_id}/tags/{key} |
POST /v2.0/{project_id}/publicips/resource_instances/action |
GET /v2.0/{project_id}/publicips/tags |
GET /v2.0/{project_id}/publicips/{publicip_id}/tags |
POST /v2.0/{project_id}/bandwidths/{bandwidth_id}/insert |
POST /v2.0/{project_id}/bandwidths/{bandwidth_id}/remove |
POST /v2.0/{project_id}/bandwidths |
POST /v2.0/{project_id}/batch-bandwidths |
GET /v1/{project_id}/bandwidths |
DELETE /v2.0/{project_id}/bandwidths/{bandwidth_id} |
GET /v1/{project_id}/bandwidths/{bandwidth_id} |
PUT /v1/{project_id}/bandwidths/{bandwidth_id} |
PUT /v2.0/{project_id}/bandwidths/{bandwidth_id} |
POST /v2.0/{project_id}/bandwidths/change-to-period |
GET /v2/{project_id}/bandwidthpkgs |
PUT /v2/{project_id}/bandwidthpkgs/{id} |
eip:bandwidthPkgs:update |
GET /v3/{project_id}/eip/publicip-pools/{publicip_pool_id} |
POST /v3/{project_id}/eip/publicips/{publicip_id}/enable-nat64 |
POST /v3/{project_id}/eip/publicips/{publicip_id}/disable-nat64 |
Resources
A resource type indicates the resources that an SCP is applied. If you specify a resource type for any action in Table 3, a resource URN must be specified in the SCP policy statements using that action, and the SCP policy applies only to the resource. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP policy applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in an SCP for EIP.
Resource Type |
URN |
bandwidthPkg |
eip:<region>:<account-id>:bandwidthPkg:<bandwidthPkg-id> |
publicipPool |
eip:<region>:<account-id>:publicipPool:<publicipPool-id> |
publicip |
eip:<region>:<account-id>:publicip:<publicip-id> |
bandwidth |
eip:<region>:<account-id>:bandwidth:<bandwidth-id> |
Conditions
EIP does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
