Cloud Backup and Recovery (CBR)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to an organizational unit (OU) or a member account, the SCPs do not directly grant permissions to that OU or member account. Instead, the SCPs only determine what permissions are available for that member account or those member accounts under that OU. The granted IAM permissions can be applied only if they are allowed by the SCPs.
This section describes the elements (Action, Resource, and Condition) used by Organizations SCPs.
- For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP policy.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP policy statements.
- If this column includes a resource type, you must specify the resource URN in the Resource element of your policy statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CBR, see Resources.
- The Condition Key column includes keys that you can specify in the Condition element of an SCP policy statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column of an action is empty (-), the action does not support any condition keys.
For details about the condition keys defined by CBR, see Conditions.
The following table lists the actions that you can define in SCP statements for CBR.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cbr:tasks:list |
Grants permission to query the task list. |
list |
task * |
g:EnterpriseProjectId |
cbr:tasks:get |
Grants permission to query a task. |
read |
task * |
cbr:member:create |
Grants permission to add a share member. |
permission_management |
backup * |
cbr:TargetOrgPaths |
cbr:member:update |
Grants permission to update the share member status. |
write |
backup * |
cbr:member:get |
Grants permission to query share member details. |
read |
backup * |
cbr:member:list |
Grants permission to obtain the share member list. |
list |
backup * |
cbr:member:delete |
Grants permission to delete a share member. |
backup * |
cbr:vaults:showCheckpoint |
Grants permission to query a restore point. |
read |
cbr:vaults:showSummary |
Grants permission to query the vault overview. |
list |
cbr:vaults:replicate |
Grants permission to replicate a restore point. |
write |
vault * |
cbr:vaults:backup |
Grants permission to create a restore point. |
write |
vault * |
cbr:vaults:sync |
Grants permission to synchronize a restore point. |
write |
vault * |
cbr:vaults:create |
Grants permission to create a vault. |
write |
vault * |
cbr:vaults:get |
Grants permission to query a specified vault. |
read |
vault * |
cbr:vaults:list |
Grants permission to query the vault list. |
list |
vault * |
cbr:vaults:update |
Grants permission to modify a vault. |
write |
vault * |
cbr:vaults:delete |
Grants permission to delete a vault. |
write |
vault * |
cbr:vaults:removeResources |
Grants permission to dissociate resources. |
write |
vault * |
cbr:vaults:addResources |
Grants permission to associate resources. |
write |
vault * |
cbr:vaults:setResources |
Grants permission to set auto backup for a vault. |
write |
vault * |
cbr:vaults:associatePolicy |
Grants permission to apply a policy to a vault. |
write |
vault * |
cbr:vaults:dissociatePolicy |
Grants permission to remove a policy from a vault. |
write |
vault * |
cbr:vaults:listExternalVaults |
Grants permission to query the vault list in other regions. |
list |
vault * |
cbr:vaults:migrateResources |
Grants permission to migrate resources. |
write |
vault * |
cbr:backups:sync |
Grants permission to synchronize a backup. |
write |
vault * |
cbr:backups:get |
Grants permission to query a specified backup. |
read |
backup * |
cbr:backups:showMetadata |
Grants permission to query backup metadata. |
read |
backup * |
cbr:backups:list |
Grants permission to query all backups. |
list |
backup * |
cbr:backups:delete |
Grants permission to delete a backup. |
write |
backup * |
cbr:backups:replicate |
Grants permission to replicate a backup. |
write |
backup * |
cbr:backups:restore |
Grants permission to restore data from a backup. |
write |
backup * |
cbr:backups:update |
Grants permission to update a backup. |
write |
backup * |
cbr:policies:list |
Grants permission to query the policy list. |
list |
policy * |
cbr:policies:create |
Grants permission to create a policy. |
write |
policy * |
cbr:EnabledPolicy |
cbr:policies:get |
Grants permission to query a policy. |
read |
policy * |
cbr:policies:update |
Grants permission to modify a policy. |
write |
policy * |
cbr:EnabledPolicy |
cbr:policies:delete |
Grants permission to delete a policy. |
write |
policy * |
cbr:vaults:listProtectables |
Grants permission to query protectable resources. |
list |
cbr:vaults:getProtectables |
Grants permission to query a protectable resource. |
read |
cbr:backups:queryReplicationCapability |
Grants permission to query the replication capability. |
list |
cbr:backups:checkAgent |
Grants permission to query the Agent status. |
read |
cbr:vaults:listResourceInstances |
Grants permission to query vault resources. |
list |
vault * |
cbr:vaults:bulkCreateOrDeleteTags |
Grants permission to batch add or delete tags of a vault resource. |
write |
vault * |
g:ResourceTag/<tag-key> |
cbr:vaults:setTags |
Grants permission to add a tag to a vault resource. |
write |
vault * |
cbr:vaults:deleteTags |
Grants permission to delete a tag of a vault resource. |
write |
vault * |
g:TagKeys |
cbr:vaults:getTags |
Grants permission to query tags of a vault resource. |
read |
vault * |
cbr:vaults:listProjectTags |
Grants permission to query tags of a vault project. |
list |
vault * |
cbr:backups:listStorageUsage |
Grants permission to query capacity statistics. |
list |
cbr:vaults:updateOrder |
Grants permission to update order information. |
write |
vault * |
cbr:agents:addPath |
Grants permission to add file paths. |
write |
agent * |
cbr:agents:get |
Grants permission to query a specified client. |
read |
agent * |
cbr:agents:update |
Grants permission to modify a client. |
write |
agent * |
cbr:agents:register |
Grants permission to register a client. |
write |
agent * |
cbr:agents:delete |
Grants permission to remove a client. |
write |
agent * |
cbr:agents:removePath |
Grants permission to remove file paths. |
write |
agent * |
cbr:agents:list |
Grants permission to query the client list. |
list |
agent * |
cbr:backups:migratesCreate |
Grants permission to migrate resources of a tenant. |
write |
cbr:backups:migratesIndex |
Grants permission to query the migration results. |
read |
cbr:organizationPolicies:create |
Grants permission to create an organizational policy. |
write |
cbr:organizationPolicies:listPolicyDetail |
Grants permission to query organizational policy delivery info. |
read |
cbr:organizationPolicies:delete |
Grants permission to delete an organizational policy. |
write |
cbr:organizationPolicies:update |
Grants permission to modify an organizational policy. |
write |
cbr:organizationPolicies:list |
Grants permission to query the organizational policy list. |
list |
cbr:organizationPolicies:get |
Grants permission to query an organizational policy. |
read |
A CBR API usually supports one or more actions. Table 2 lists actions supported by each API and dependencies of actions.
API |
Action |
Dependencies |
GET /v3/{project_id}/operation-logs |
cbr:tasks:list |
GET /v3/{project_id}/operation-logs/{operation_log_id} |
cbr:tasks:get |
POST /v3/{project_id}/backups/{backup_id}/members |
cbr:member:create |
PUT /v3/{project_id}/backups/{backup_id}/members/{member_id} |
cbr:member:update |
GET /v3/{project_id}/backups/{backup_id}/members/{member_id} |
cbr:member:get |
GET /v3/{project_id}/backups/{backup_id}/members |
cbr:member:list |
DELETE /v3/{project_id}/backups/{backup_id}/members/{member_id} |
cbr:member:delete |
GET /v3/{project_id}/checkpoints/{checkpoint_id} |
GET /v3/{project_id}/vaults/summary |
POST /v3/{project_id}/checkpoints/replicate |
POST /v3/{project_id}/checkpoints |
cbr:vaults:backup |
POST /v3/{project_id}/checkpoints/sync |
cbr:vaults:sync |
POST /v3/{project_id}/vaults |
cbr:vaults:create |
POST /v3/{project_id}/vaults/order |
cbr:vaults:create |
GET /v3/{project_id}/vaults/{vault_id} |
cbr:vaults:get |
GET /v3/{project_id}/vaults |
cbr:vaults:list |
PUT /v3/{project_id}/vaults/{vault_id} |
cbr:vaults:update |
PUT /v3/{project_id}/vaults/batch-update |
cbr:vaults:update |
DELETE /v3/{project_id}/vaults/{vault_id} |
cbr:vaults:delete |
POST /v3/{project_id}/vaults/{vault_id}/removeresources |
POST /v3/{project_id}/vaults/{vault_id}/addresources |
PUT /v3/{project_id}/vaults/{vault_id}/set-resources |
POST /v3/{project_id}/vaults/{vault_id}/associatepolicy |
POST /v3/{project_id}/vaults/{vault_id}/dissociatepolicy |
GET /v3/{project_id}/vaults/external |
POST /v3/{project_id}/vaults/{vault_id}/migrateresources |
POST /v3/{project_id}/backups/sync |
cbr:backups:sync |
GET /v3/{project_id}/backups/{backup_id} |
cbr:backups:get |
GET /v3/{project_id}/backups/{backup_id}/metadata |
GET /v3/{project_id}/backups |
cbr:backups:list |
DELETE /v3/{project_id}/backups/{backup_id} |
POST /v3/{project_id}/backups/{backup_id}/replicate |
POST /v3/{project_id}/backups/{backup_id}/restore |
PUT /v3/{project_id}/backups/{backup_id} |
GET /v3/{project_id}/policies |
cbr:policies:list |
POST /v3/{project_id}/policies |
GET /v3/{project_id}/policies/{policy_id} |
cbr:policies:get |
PUT /v3/{project_id}/policies/{policy_id} |
DELETE /v3/{project_id}/policies/{policy_id} |
GET /v3/{project_id}/protectables/{protectable_type}/instances |
GET /v3/{project_id}/protectables/{protectable_type}/instances/{instance_id} |
GET /v3/{project_id}/replication-capabilities |
POST /v3/{project_id}/agent/check |
POST /v3/{project_id}/vault/resource_instances/action |
POST /v3/{project_id}/vault/{vault_id}/tags/action |
POST /v3/{project_id}/vault/{vault_id}/tags |
DELETE /v3/{project_id}/vault/{vault_id}/tags/{key} |
GET /v3/{project_id}/vault/{vault_id}/tags |
GET /v3/{project_id}/vault/tags |
GET /v3/{project_id}/storage_usage |
PUT /v3/{project_id}/orders/{order_id} |
POST /v3/{project_id}/agents/{agent_id}/add-path |
GET /v3/{project_id}/agents/{agent_id} |
cbr:agents:get |
PUT /v3/{project_id}/agents/{agent_id} |
cbr:agents:update |
POST /v3/{project_id}/agents |
DELETE /v3/{project_id}/agents/{agent_id} |
cbr:agents:delete |
POST /v3/{project_id}/agents/{agent_id}/remove-path |
GET /v3/{project_id}/agents |
cbr:agents:list |
POST /v3/migrates |
GET /v3/migrates |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, a resource URN must be specified in the SCP policy statements using that action, and the SCP policy applies only to the resource. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP policy applies to all resources. You can also set condition keys in an SCP policy to define resource types.
The following table lists the resource types that you can define in SCP policy statements for CBR.
Resource Type |
URN |
Vault |
cbr:<region>:<account-id>:vault:<vault-id> |
Policy |
cbr:<region>:<account-id>:policy:<policy-id> |
Task |
cbr:<region>:<account-id>:task:<task-id> |
Backup |
cbr:<region>:<account-id>:backup:<backup-id> |
Agent |
cbr:<region>:<account-id>:agent:<agent-id> |
Conditions
A Condition element lets you specify conditions for when an SCP policy is in effect. It contains condition keys and operators.
- A key in the Condition element of a statement can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, IAM automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, cbr:) apply only to operations of the CBR service. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- An operator, a condition key, and a condition value constitute a complete condition statement. An SCP policy applies only when its conditions are met. For supported condition operators, see condition operators.
The following table lists the condition keys that you can define in custom SCP policies for CBR. You can include these condition keys to specify conditions for when your SCP policy is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
Description |
string |
Single-valued |
Organization path to which the target account specified in the API request for adding a share member of CBR belongs. |
cbr:VaultId |
string |
Single-valued |
Filters access based on the vault ID specified in the request parameter. |
cbr:PolicyId |
string |
Single-valued |
Filters access based on the policy ID specified in the request parameter. |
cbr:EnabledPolicy |
boolean |
Single-valued |
Whether to enable access filtering based on the policy. |
