Updated on 2025-08-22 GMT+08:00
Elastic Cloud Server (ECS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (such as list, read, or write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by ECS, see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by ECS, see Conditions.
The following table lists the actions that you can define in SCP statements for ECS.
Table 1 Actions supported by ECS
Action
Access Level
Resource Type (*: required)
Condition Key
ecs:cloudServers:createServers
Grants permission to create ECSs.
write
  • g:RequestTag/<tag-key>
  • g:EnterpriseProjectId
  • g:TagKeys
  • ecs:imageID
  • ecs:FlavorId
  • ecs:VpcId
  • ecs:SubnetId
  • ecs:PortId
  • ecs:KmsKeyId
  • eip:AssociatePublicIp
  • ecs:AvailabilityZone
  • evs:Encrypted
  • cbr:VaultId
  • ecs:SSHKeyPairName
  • ecs:SupportAgentType
  • ecs:ImageSupportAgentType
  • ecs:ImageType
  • ecs:OsVersion
  • ecs:OsType
  • ecs:ImagePlatform
ecs:cloudServers:deleteServers
Grants permission to delete ECSs.
write
instance *
ecs:cloudServers:resize
Grants permission to modify ECS specifications.
write
instance *
ecs:FlavorId
ecs:cloudServers:attachSharedVolume
Grants permission to attach a specified shared EVS disk to multiple ECSs in a batch.
write
instance *
  • evs:Encrypted
  • ecs:KmsKeyId
  • ecs:VolumeId
ecs:cloudServers:showServer
Grants permission to query ECS details.
read
instance *
Grants permission to attach disks to an ECS.
write
instance *
  • evs:Encrypted
  • ecs:KmsKeyId
  • ecs:VolumeId
ecs:cloudServers:listServerBlockDevices
Grants permission to query information about the disks attached to an ECS.
list
instance *
ecs:cloudServers:showServerBlockDevice
Grants permission to query information about a single disk attached to an ECS.
read
instance *
ecs:cloudServers:updateServerBlockDevice
Grants permission to modify information about a single disk attached to an ECS.
write
instance *
ecs:cloudServers:changeOS
Grants permission to change the ECS OS.
write
instance *
  • ecs:imageID
  • evs:Encrypted
  • ecs:KmsKeyId
  • ecs:ImageType
  • ecs:OsVersion
  • ecs:OsType
  • ecs:ImagePlatform
ecs:cloudServers:detachVolume
Grants permission to detach disks from an ECS.
write
instance *
ecs:cloudServers:updateMetadata
Grants permission to update ECS metadata.
write
instance *
ecs:cloudServers:deleteMetadata
Grants permission to delete ECS metadata.
write
instance *
ecs:cloudServers:migrate
Grants permission to cold migrate ECSs.
write
instance *
ecs:cloudServers:listServerInterfaces
Grants permission to query NICs of an ECS.
list
instance *
ecs:cloudServers:showResetPasswordFlag
Grants permission to query whether one-click password reset is supported.
read
instance *
ecs:cloudServers:showServerPassword
Grants permission to get the password for logging in to an ECS.
read
instance *
ecs:cloudServers:deletePassword
Grants permission to delete the password for logging in to an ECS.
write
instance *
ecs:cloudServers:listServerVolumeAttachments
Grants permission to query disks attached to an ECS.
list
instance *
ecs:cloudServers:rebuild
Grants permission to reinstall the ECS OS.
write
instance *
  • evs:Encrypted
  • ecs:KmsKeyId
ecs:cloudServers:vnc
Grants permission to obtain the VNC login address.
read
instance *
Grants permission to modify ECS information.
write
instance *
ecs:cloudServers:addNics
Grants permission to add NICs to an ECS in a batch.
write
instance *
  • ecs:SubnetId
  • ecs:PortId
ecs:cloudServerNics:delete
Grants permission to delete NICs from an ECS in a batch.
write
instance *
ecs:cloudServers:showServerTags
Grants permission to query ECS tags.
list
instance *
ecs:cloudServers:batchCreateServerTags
Grants permission to add tags to an ECS in a batch.
write
instance *
  • g:TagKeys
ecs:cloudServers:batchDeleteServerTags
Grants permission to delete tags from an ECS in a batch.
write
instance *
  • g:TagKeys
ecs:cloudServers:start
Grants permission to start ECSs in a batch.
write
instance *
ecs:cloudServers:stop
Grants permission to stop ECSs in a batch.
write
instance *
ecs:cloudServers:reboot
Grants permission to restart ECSs in a batch.
write
instance *
ecs:cloudServers:batchUpdateServersName
Grants permission to modify ECS information in a batch.
write
instance *
ecs:cloudServers:listServersDetails
list
ecs:cloudServerFlavors:get
Grants permission to query specifications and expansion details about ECSs.
read
ecs:cloudServerQuotas:get
Grants permission to query tenant quotas.
read
ecs:cloudServers:resetServerPwd
Grants permission to reset the password of an ECS.
write
instance *
ecs:cloudServers:listServerGroups
Grants permission to query ECS groups.
list
ecs:cloudServers:createServerGroup
Grants permission to create ECS groups.
write
ecs:cloudServers:showServerGroup
read
ecs:cloudServers:deleteServerGroup
Grants permission to delete ECS groups.
write
ecs:cloudServers:addServerGroupMember
Grants permission to add ECSs to an ECS group.
write
ecs:cloudServers:deleteServerGroupMember
Grants permission to delete ECSs from an ECS group.
write
ecs:cloudServers:listResizeFlavors
Grants permission to query the target ECS flavors to which a flavor can be changed.
list
ecs:cloudServers:listServerTags
Grants permission to query project tags.
list
ecs:cloudServers:changeVpc
Grants permission to change the VPC of an ECS.
write
instance *
  • ecs:VpcId
  • ecs:SubnetId
  • ecs:PortId
ecs:cloudServers:changeChargeMode
Grants permission to change the billing mode of an ECS.
write
instance *
Each API of ECS usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by ECS APIs
API
Action
Dependencies
POST /v1.1/{project_id}/cloudservers
  • eip:publicIps:create
  • eip:publicIps:associateInstance
  • iam:agencies:pass
  • eip:bandwidths:insertPublicIps
POST /v1/{project_id}/cloudservers
  • iam:agencies:pass
POST /v1/{project_id}/cloudservers/delete
POST /v1.1/{project_id}/cloudservers/{server_id}/resize
POST /v1/{project_id}/batchaction/attachvolumes/{volume_id}
evs:volumes:use
GET /v1/{project_id}/cloudservers/{server_id}
POST /v1/{project_id}/cloudservers/{server_id}/attachvolume
evs:volumes:use
GET /v1/{project_id}/cloudservers/{server_id}/block_device
GET /v1/{project_id}/cloudservers/{server_id}/block_device/{volume_id}
PUT /v1/{project_id}/cloudservers/{server_id}/block_device/{volume_id}
POST /v1/{project_id}/cloudservers/{server_id}/changeos
DELETE /v1/{project_id}/cloudservers/{server_id}/detachvolume/{volume_id}
POST /v1/{project_id}/cloudservers/{server_id}/metadata
iam:agencies:pass
DELETE /v1/{project_id}/cloudservers/{server_id}/metadata/{key}
POST /v1/{project_id}/cloudservers/{server_id}/migrate
GET /v1/{project_id}/cloudservers/{server_id}/os-interface
GET /v1/{project_id}/cloudservers/{server_id}/os-resetpwd-flag
GET /v1/{project_id}/cloudservers/{server_id}/os-server-password
DELETE /v1/{project_id}/cloudservers/{server_id}/os-server-password
GET /v1/{project_id}/cloudservers/{server_id}/os-volume_attachments
POST /v1/{project_id}/cloudservers/{server_id}/reinstallos
POST /v2/{project_id}/cloudservers/{server_id}/reinstallos
POST /v1/{project_id}/cloudservers/{server_id}/remote_console
POST /v1/{project_id}/cloudservers/{server_id}/resize
GET /v1/{project_id}/cloudservers/detail?flavor={flavor}&name={name}&status={status}&limit={limit}&offset={offset}&not-tags={not-tags}&reservation_id={reservation_id}&enterprise_project_id={enterprise_project_id}&tags={tags}&ip={ip}
POST /v1/{project_id}/cloudservers/{server_id}/nics
POST /v1/{project_id}/cloudservers/{server_id}/nics/delete
GET /v1/{project_id}/cloudservers/{server_id}/tags
POST /v1/{project_id}/cloudservers/{server_id}/tags/action
POST /v1/{project_id}/cloudservers/action
GET /v1/{project_id}/cloudservers/flavors?availability_zone={availability_zone}&flavor_id={flavor_id}&limit={limit}&marker={marker}
GET /v1/{project_id}/cloudservers/limits
PUT /v1/{project_id}/cloudservers/{server_id}/os-reset-password
GET /v1/{project_id}/cloudservers/os-server-groups?limit={limit}&marker={marker}
POST /v1/{project_id}/cloudservers/os-server-groups
GET /v1/{project_id}/cloudservers/os-server-groups/{server_group_id}
DELETE /v1/{project_id}/cloudservers/os-server-groups/{server_group_id}
POST /v1/{project_id}/cloudservers/os-server-groups/{server_group_id}/action
GET /v1/{project_id}/cloudservers/resize_flavors?instance_uuid={instance_uuid}&source_flavor_id={source_flavor_id}&source_flavor_name={source_flavor_name}
GET /v1/{project_id}/cloudservers/tags
POST /v2/{project_id}/cloudservers/{server_id}/changeos
PUT /v1/{project_id}/cloudservers/server-name
POST /v1/{project_id}/cloudservers/{server_id}/changevpc
POST /v1/{project_id}/cloudservers/actions/change-charge-mode
ChangeServerChargeMode
  • billing:order:pay
  • billing:subscription:renew
GET /v1/{project_id}/cloudservers/flavor-sell-policies?flavor_id={flavor_id}
GET /v1/{project_id}/cloudservers/{server_id}/autorecovery
ecs:cloudServers:getAutoRecovery
PUT /v1/{project_id}/cloudservers/{server_id}/autorecovery
ecs:cloudServers:setAutoRecovery
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for ECS.
Table 3 Resource types supported by ECS
Resource Type
URN
instance
ecs:<region>:<account-id>:instance:<server-id>
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
  • The condition key that you specify can be a global condition key or a service-specific condition key.
    • Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
    • Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, ecs:) only apply to operations of the ECS service. For details, see Table 4.
    • The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
  • A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For supported condition operators, see Condition operators.
The following table lists the condition keys that you can define in SCPs for ECS. You can include these condition keys to specify conditions for when your SCP is in effect.
Table 4 Service-specific condition keys supported by ECS
Condition Key
Type
Single-valued/Multivalued
ecs:imageID
string
Multivalued
Filters access based on the image ID specified in the request parameter.
ecs:FlavorId
string
Multivalued
Filters access based on the flavor ID specified in the request parameter.
ecs:VpcId
string
Multivalued
Filters access based on the VPC ID specified in the request parameter.
ecs:SubnetId
string
Multivalued
Filters access based on the subnet ID specified in the request parameter.
ecs:KmsKeyId
string
Multivalued
Filters access based on the KMS key ID specified in the request parameter.
ecs:ServerId
string
Single-valued
Filters access based on ECS ID.
ecs:SSHKeyPairName
string
Single-valued
Filters access based on the SSH key pair name specified in the request parameter.
string
Single-valued
Filters access based on the AZ name specified in the request parameter.
ecs:PortId
string
Multivalued
Filters access based on the port ID specified in the request parameter.
string
Multivalued
Filters access based on the agent type specified in the request parameter.
string
Multivalued
Filters access based on the supported image agent type in the request parameter.
ecs:VolumeId
string
Single-valued
Filters access based on the volume ID specified in the request parameter.
ecs:ImageType
string
Single-valued
Filters access based on the image type specified in the request parameter, for example, public images, private images, shared images, or KooGallery images.
ecs:OsType
string
Single-valued
Filters access based on the OS type of the image specified in the request parameter, for example, Linux or Windows.
ecs:OsVersion
string
Single-valued
Filters access based on the OS version of the image specified in the request, for example, CentOS 7.3 64bit.
ecs:ImagePlatform
string
Single-valued
Filters access based on the platform of the image specified in the request, for example, Windows, Ubuntu, Red Hat, SUSE or CentOS.
