- What's New
- Getting Started
User Guide
- Permissions Management
- Managing Organizations
- Managing OUs
- Managing Accounts
Managing SCPs
- Overview of an SCP
- Enabling or Disabling the SCP Type
- Creating an SCP
- Modifying or Deleting an SCP
- Attaching or Detaching an SCP
- Example SCPs
- System-defined SCPs
- Cloud Services for Using SCPs
- Regions for Using SCPs
Actions Supported by SCP-based Authorization
- Compute
- Storage
- Networking
- Containers
- Analytics
- Content Delivery & Edge Computing
- Databases
- Security & Compliance
- Internet of Things
- Middleware
- Developer Services
- Business Applications
- Simple Message Notification (SMN)
- Log Tank Service (LTS)
- Identity and Access Management (IAM)
- Security Token Service (STS)
- Resource Formation Service (RFS)
- IAM Identity Center
- Organizations
- Resource Access Manager (RAM)
- Enterprise Project Management Service (EPS)
- Tag Management Service (TMS)
- Config
- IAM Access Analyzer
- Cloud Trace Service (CTS)
- Resource Governance Center (RGC)
- Application Operations Management (AOM)
- Cloud Eye (CES)
- IAM Identity Broker
- User Support
- Migration
- Managing Tag Policies
- Managing Trusted Services
- Managing Tags
- CTS Auditing
- Adjusting Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Managing OUs
Managing Accounts
- Creating an account and adding it to your organization
- Creating an Account
- Listing Accounts in an Organization
- Closing an Account
- Getting Account Information
- Updating an Account
- Removing the Specified Account
- Moving an Account
- Inviting an Account to Join an Organization
- Querying Account Creation Requests in Specified State
- Querying Account Creation Status
- Querying CloseAccount Requests in Specified State
- Managing Invitations
- Managing Delegated Administrators
- Managing Policies
Managing Tags
- Listing Tags for the Specified Resource
- Adding Tags to the Specified Resource
- Removing Tags from the Specified Resource
- Listing Tags for the Specified Resource Type
- Adding Tags to the Specified Resource Type
- Deleting Tags with the Specified Key from the Specified Resource Type
- Querying Resource Instances by Resource Type and Tag
- Querying Number of Resource Instances by Resource Type and Tag
- Querying Resource Tags
- Others
- Appendixes
- Change History
- FAQs
Help Center/
Organizations/
User Guide/
Managing Tags/
Adding a Tag/
Adding a Tag for the Root, OUs, or Accounts
The following describes how to add a tag for the root, OUs, or accounts.
You add tags to the root, OUs, and accounts in the same way. The following uses adding tags to an OU as an example.
- Log in to Huawei Cloud as the organization administrator or using the management account, navigate to the Organizations console, and access the Organization page.
- Select the OU you want to add a tag to, click the Tags tab in the pane on the right, and click Add.
- Enter a tag key and a tag value, click Add, and click OK.
You can select a predefined tag created in TMS from the drop-down lists. For details, see Creating Predefined Tags.
Figure 1 Adding a tag
Parent topic: Adding a Tag
