- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
On this page
Show all
Help Center/
OneAccess/
User Guide/
Enterprise Administrator Guide/
Resources/
APIs/
Modifying Built-in APIs
Modify the permission codes and descriptions of built-in APIs. The basic information cannot be modified.
- Log in to the administrator portal.
- On the top navigation bar, choose Resources > Enterprise APIs.
- On the displayed page, choose System APIs > Built-in APIs to go to the enterprise API details page.
- Switch to the Application Authorization tab page and modify application authorization. Click Authorize or Cancel Authorization in the Operation column of an application to authorize or cancel the authorization of the application to call the built-in APIs. For details about how to add an application, see Integrating Enterprise Applications.
- Click the Permissions tab to modify permissions. Click Modify in the Operation column of the row that contains the target permission, modify the permission description, and determine whether to set the permission as the default.
Table 1 Permission parameters Parameter
* Permission Code
Only letters and underscores (_) are allowed.
Description of the permission.
Default Permission
Deselected by default.
- If you select this option, authorized applications have this permission by default, and you do not need to grant the permission again.
- To remove a default permission of an application, change the default permission to a non-default one and then cancel the authorization.
- Switch to the Audit Logs tab page to view audit logs. You can view the operation records of the APIs.
Parent topic: APIs
