- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
Configuring synchronization integration includes Parameters and General. When the integration mode is Event callback, the operation also includes Full Synchronization.
Configuring Parameters
- Log in to the administrator portal.
- On the top navigation bar, choose Resources > Applications.
- Click an application to go to the information page.
- On the General Information page, click
next to Synchronization Integration to select an appropriate integration mode, and then click Save.
- On the displayed page, click Configure next to Synchronization Integration to set parameters, and then click Save. Configure the parameters based on synchronization integration modes.
- For details about configuring integration parameters for event callback synchronization, see Configuring Event Callback.
- For details about SCIM-based integration parameters, see Synchronization Configuration.
- For details about LDAP synchronization parameters, see Synchronization Configuration.
General Configuration
General Configuration: indicates the mapping during synchronization.
On the Synchronization Integration page, click General to enable it. The configuration mapping includes deleting and disabling an account and organization.
- Delete an account
After an application account is deleted from OneAccess, the downstream application system determines the operation (deleting and disabling accounts and asynchronization) to be performed based on the configuration.
- Delete an organization
After an organization is deleted from OneAccess, the downstream application system determines the operation (deleting and disabling organizations, and asynchronization) to be performed based on the configuration.
- Disable an account
After an application account is disabled in OneAccess, the downstream application system determines the operation (disabling accounts, and asynchronization) to be performed based on the configuration.
- Disable an organization
After an organization is disabled in OneAccess, the downstream application system determines the operation (disabling organizations, and asynchronization) to be performed based on the configuration.
If the integration mode is event callback, full synchronization can be implemented. For details, see Full Synchronization.
