- Billing
- Getting Started
User Guide
- Before You Start
- Buying an Instance
- Instance Management
Enterprise Administrator Guide
- Logging In to the OneAccess Administrator Portal
- User Management
Resources
- Overview
Applications
- Adding an Application
- Enabling, Disabling, or Deleting an Application
- General Information
- Authentication Integration
- Synchronization Integration
- Login Configuration
- Access Control
- Object Models
- Authorization Management
- API Permission Management
- Application Permission Management
- Security Settings
- Audit Logs
- APIs
- Authentication
- Security
- Audit
- Settings
- Common User Guide
- Key Operations Recorded by CTS
Best Practices
- OneAccess Best Practices
- Identity Source Integration
Application Integration
Logging In to the Huawei Cloud Through User Portal
- Introduction
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - Virtual User SSO)
- Logging In to Single Huawei Cloud Account via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Multiple Huawei Cloud Accounts via OneAccess Without Password (SAML - IAM User SSO)
- Logging In to Huawei Cloud via OneAccess Without Password (OIDC)
- SSO Access to Applications Through SAML
- SSO Access to Applications Through OAuth 2.0
- SSO Access to Applications Through OIDC
- SSO Access to Applications Through CAS
- SSO Access to Applications Through Plug-in Autocompletion
- Data Synchronization
- Authentication Provider Integration
- Authorizing IAM Users to Access a OneAccess Instance Administrator Portal
- API Usage
- Configuring MFA for User Login
- Developer Guide
API Reference
- Before You Start
- API Overview
OneAccess APIs
Management APIs
- Calling APIs
- Access Credentials
User Management
- Creating a User
- Modifying a User
- Deleting a User
- Enabling a User
- Disabling a User
- Changing a User Password
- Verifying and Modifying the Original User Password
- Querying User Details by User ID
- Querying User Details by Username
- Querying the User List
- Authorizing an Application Account
- Querying All Authorized Application Accounts of a User
- Organization Management
- Application Organization Management
- Application Account Management
- Application Role Management
- User APIs
- Application Integration APIs
Management APIs
- Appendix
- FAQs
Dictionaries
Dictionaries enable you to efficiently manage business-related information, such as mobile numbers, state/province and city codes, and supplier regions. Dictionaries can be displayed in list and tree modes.
Adding a Dictionary
- Log in to the administrator portal.
- On the top navigation bar, choose Settings > Dictionaries.
- On the Dictionaries page, click
at the bottom of the page.
- In the Add Dictionary dialog box, enter dictionary information and click Save. The dictionary then appears in the list.
Table 1 Adding a dictionary Parameter
* Dictionary Code
The dictionary code must be unique. To facilitate dictionary management, set this parameter by following a unified rule.
* Dictionary Name
The dictionary name must be unique.
Tree Structure
Indicates whether to display the dictionary in list or tree mode. If you select this option, the dictionary is displayed in tree mode. Otherwise, the dictionary is displayed in list mode.
Describes the usage and application scenarios of the dictionary.
- Select a dictionary in the left pane.
- Dictionary items are subsets of a dictionary. Create a dictionary before adding dictionary items.
- Only dictionaries for which you have configured dictionary items can be used when you add custom user attributes.
- On the right of the Dictionaries page, click Add Dictionary Item. In the displayed dialog box, enter the dictionary item information.
Table 2 Adding a dictionary item Parameter
* Dictionary Name
Parent node of the dictionary item. This parameter is not editable.
* Dictionary Item Code
Unique identifier of the dictionary item. To facilitate dictionary management, set this parameter by following a unified rule.
* Dictionary Item Name
Name of the dictionary item. Different dictionary items can have the same name.
Describes the usage and application scenarios of the dictionary item.
- Click Save. The dictionary item then appears in the list.
Modifying a Dictionary
If the user attribute associated with a dictionary changes, you can modify the dictionary to adapt for the change.
- Modifying a dictionary
The dictionary code and whether to display the dictionary in tree mode cannot be modified.
- On the right side of the target dictionary, click
and select Edit from the drop-down list. The Modify Dictionary dialog box is displayed.
- Modify the dictionary name and description, and click Save.
- Modifying a dictionary item
- Click the target dictionary. On the right side of the dictionary item list, click Modify in the Operation column of the dictionary item to be modified.
- Modify the dictionary item name and description, and click Save.
Deleting a Dictionary
Before you delete a dictionary, ensure that it is not associated with any user attributes.
and select Delete from the drop-down list.
