- What's New
- Function Overview
- Getting Started
- User Guide
Best Practices
- Overview
- Automatically Checking for and Retrying Failed Migration Tasks
- Best Practices for Service Cutover
- Special Migration Scenarios
Migration from Other Clouds to Huawei Cloud
- Migrating Data Between Huawei Cloud OBS Buckets
- Migrating Data from Huawei Cloud PFS to Huawei Cloud OBS or Between PFS Systems
- Migrating Data from Alibaba Cloud OSS to Huawei Cloud OBS
- Migrating Data from Tencent Cloud COS to Huawei Cloud OBS
- Migrating Data from UCloud US3 to Huawei Cloud OBS
- Migrating Data from Kingsoft Cloud KS3 to Huawei Cloud OBS
- Migrating Data from QingCloud QingStor to Huawei Cloud OBS
- Migrating Data from Google Cloud Storage to Huawei Cloud OBS
- Migrating Data from Amazon S3 to Huawei Cloud OBS
- Migrating Data from Azure Blob Storage to Huawei Cloud OBS
- Migrating Data from HTTP/HTTPS Sources to Huawei Cloud OBS
- Configuring Synchronization Requests on Source Platforms
Migrating Archived Data
- Migrating Archived Data in Huawei Cloud OBS
- Migrating Archived Data in Alibaba Cloud OSS
- Migrating Archived Data in Tencent Cloud COS
- Migrating Archived Data in Kingsoft Cloud KS3
- Migrating Archived Data in UCloud US3
- Migrating Archived Data in Amazon S3
- Migrating Archived Data in Azure Blob Storage
- Other Migration Scenarios
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
Out-of-Date APIs
- Querying the API Version
- Creating a Migration Task
- Deleting a Migration Task
- Restarting a Migration Task
- Stopping a Migration Task
- Modifying a Traffic Limiting Rule
- Querying All Migration Tasks of a Tenant
- Querying the Total Number of Migration Tasks of a Tenant
- Querying Migration Tasks by Task IDs
- Querying Quotas of a Tenant
- Appendix
- Change History
- SDK Reference
- Question Summary
Product Consulting
- When Do I Need to Perform Pre-migration Evaluation Before Creating Migration Tasks?
- How Do I Migrate OBS Bucket Data from One Region to Another?
- How Do I Migrate the OBS Bucket Data from One Account to Another?
- How Do I Migrate Data from Multiple Source Buckets to a Single OBS Bucket on Huawei Cloud?
- How Do I Migrate Data in the Root Directory?
- How Does Migration Affect My Source Data? What Are the Impacts on Migration If the Source Data Changes?
- How Do I Change the Storage Path of a Migrated Object?
- How Does OMS Ensure Data Consistency If Data Is Continuously Written to OBS?
- How Do I Obtain Required Permissions for the Source and Destination Platform Accounts?
- How Do I Review the Objects Migrated in a Migration Task?
- How Do I Review the Objects Migrated in a Migration Task Group?
- How Do I Review the Objects Migrated in a Synchronization Task?
- Can I Migrate Data in a Specified Period Using a Synchronization Task?
- Can OMS Only Migrate the Data Generated After a Specified Time?
- Can OMS Filter the Data to Be Migrated by Suffix?
- Does OMS Support Batch Bucket Migration?
- What Is the Storage Class of Archive Data Migrated to the Archive Destination Bucket?
- What Are the Application Scenarios of Migration Tasks and Migration Task Groups?
- If I Delete an Object from the Source Bucket, Will the Corresponding Object in the Destination Bucket Be Deleted?
- How Does OMS Ensure Data Consistency Between the Source and Destination Buckets?
- Why Is the Total Number or Size of Objects in the Destination Bucket Inconsistent with Those in the Source Bucket After the Migration?
- How Does Migration Affect Data in the Destination Bucket?
- Why Are the Migration Progress and the Transmitted Data Volume 0 After the Migration Is Complete?
- How Do I Choose Storage Classes?
Migration Constraints
- What Are the Constraints on Migrating Data to a Parallel File System with OMS?
- What Are the Restrictions on Migrating Data in a Parallel File System?
- How Do I Fix the Error "Destination bucket must be in the same region as OMS. Select a bucket that is located in region xxx, or change the OMS region to xxx" When I Create a Migration Task?
- How Do I Migrate Data from a Cloud Platform Not Supported by OMS?
Migration Duration
- How Can I Learn the Speed of a Migration Task?
- Why Is the Migration Progress Not Changing Even Though the Transferred Volume Is Increasing?
- Why Is the Migration Speed Slow Sometimes?
- What Can I Do If the Migration Speed Is Slow and a Large Number of Objects Failed to Be Migrated During a Cross-Region Migration on Huawei Cloud?
Exception Recovery
- What Can I Do If Migration Tasks Fail To Be Created After Evaluation?
- What Can I Do If the Migration Fails Because the Frequency of Accessing the Source Object Storage Exceeded the Upper Limit?
- What Can I Do If a Migration Task Fails?
- What Can I Do If a Migration Task Group Fails to Be Executed?
- What Can I Do If SMN Is Not Working Properly?
- What Can I Do If a Migration Task Fails Due to Inconsistent Encryption Status?
- What Can I Do If the Migration Task Failed Due to an Archive Data Read Failure?
- What Problems May I Encounter If CDN Is Enabled at the Source?
- What Do I Do If All Objects Whose Names Contain Slashes (/) Fail to be Migrated from Alibaba Cloud?
- How Do I Resolve the Error "Failed to access the object. Make sure that the object exists and you have the rights to access" When I Enter Object Prefixes?
- What Can I Do If Consistency Checks Fail During the Migration of Data in a Parallel File System?
- What Can I Do If the Migration Failed Because the Objects Cannot Be Downloaded from the Source Bucket?
- What Can I Do If a Migration Task Failed Due to Transmission Interruptions?
- Change History
- Videos
Show all
Creating a User and Assigning OMS Permissions
This chapter describes how to use IAM for fine-grained permissions control for your OMS resources. With IAM, you can:
- Create IAM users for employees based on your enterprise's organizational structure. Each IAM user will have their own security credentials for accessing OMS resources.
- Assign only the minimum permissions required for users to perform a given task.
- Entrust a Huawei Cloud account or cloud service to perform professional and efficient O&M on your OMS resources.
If your Huawei Cloud account does not need individual IAM users, skip over this chapter.
Figure 1 shows the procedure for granting permissions.
Before assigning permissions to user groups, you should learn about system policies supported by OMS and select the policies based on service requirements. For more information about system policies supported by OMS, see OMS Permissions. For the system policies of other services, see System-defined Permissions.
Process Flow
- Create a user group and assign permissions to it.
- If the IAM users who will be added to this group need all OMS permissions, attach the system-defined policies OMS Administrator and OBS Administrator to the group.
- If the IAM users only need specific OMS permissions, create custom policies and attach these policies to the user group. For details, see How Do I Obtain Required Permissions for the Source and Destination Platform Accounts?
- Create a user and add the user to the user group..
Create a user on the IAM console and add the user to the group created in 1.
CAUTION:
You must select both Programmatic access and Management console access for Access Type when creating an IAM user.
- Sign in to the console as the created user.
In the authorized region, perform the following operations:
- Choose Service List > Object Storage Migration Service. On the OMS console, click Create Migration Task in the upper right corner. If a migration task can be created, the OMS Administrator permission has already taken effect.
- Choose any service other than OMS in Service List. If a message appears indicating that you have insufficient permissions to access the service, the OMS Administrator permission has already taken effect.
