- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing Modes
- Billing Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- Why Do I Get Additional Charges or Arrears After Purchasing a Package?
- Why Can I Still Call the Service and Incur Arrears When My Account Balance Is Zero?
- Why Do I Get Additional Charges or Arrears After Unsubscribing from an OCR Service?
- Can I Refund a Package After I Buy It?
- How Is Billing Handled When a Package Is Used Up? And How Can I Check the Remaining Quota and Receive Alerts for My Package?
- How Does a Member Account Use a Package Purchased by an Enterprise Master Account?
- What Is Fee Deduction Order for Multiple Packages?
- What are Grace Period and Retention Period?
- What Is Considered Valid Billing for OCR?
- Can Different API Packages Be Shared?
- Can OCR Be Charged by Project?
- Getting Started
- User Guide
- SDK Reference
- API Reference
- Subscription
Token-based Authentication
- What Are the Username, Domain Name, and Project Name in the Token Message Body?
- Why Is the Error Message "The account is locked." Displayed?
- Why Is the Error Message "The username or password is wrong." Displayed?
- Why Does the Token Retrieval Process Return a 401 Status Code?
- Why Does the Token Fail to Be Obtained When I Use Postman to Call an ORC API?
- Why Don't I Have Programming Access Permissions?
- Why Does the Header Overflow When I Use Postman to Call an OCR API?
API
- How Do I View the API Usage?
- Why Is the Actual Number of API Calls Inconsistent with the Record Displayed on the Management Console?
- Does OCR Support Batch Processing?
- Can the OCR Results Be Converted into Word, TXT, or PDF Files?
- How Do I Obtain the Base64 Code of an Image?
- What Is the Number of Concurrent OCR API Calls?
- How Do I Use OCR APIs?
- Can the Region Where OCR Is Called Be Different from the Region Where OBS Resources Are Located?
- Can the Input Data of OCR Be Stored Locally?
- How Do I Improve the Recognition Speed?
- How Do I Convert a PDF to an Image?
- Can OCR Read Images from Non-Huawei Cloud Storage?
SDK
- Do OCR SDKs Need to Be Purchased?
- Do OCR SDKs Need Maven to Manage Dependency Packages?
- How Do I Change the Response Type in Returned Results?
- How Can I Fix an SSL Configuration Error?
- How Can I Fix a "connect timed out" Error?
- Why Does the Project ID Fail to Be Obtained?
- What Should I Do if I Forget My AK and SK?
Error Code
- Why Do I Fail to Call an OCR API?
- How Do I Handle the Error APIG.0301?
- How Do I Handle the Error APIG.0201?
- How Do I Handle the Error APIG.0101?
- How Do I Handle the Error APIG.0106?
- How Do I Handle the Error APIG.0308?
- How Do I Handle the Error ModelArts.0212?
- How Do I Handle the Error ModelArts.4603 or ModelArts.4704?
- How Do I Handle the Error ModelArts.4204?
- Permissions
- Data Security and Privacy
- Regions and AZs
- General Consulting
- Videos
- Glossary
- More Documents
On this page
Show all
Viewing Metrics
To view metrics, perform the following operations:
- In the navigation pane on the left, choose Service Monitoring.
Figure 1 Service Monitoring page
Parent topic: Monitoring
