OCR Monitoring Metrics
Function
This section describes metrics reported by OCR to Cloud Eye, as well as their namespaces, list, and dimensions. You can use the management console or APIs provided by Cloud Eye to query the metric information and alarms generated for OCR.
Namespace
SYS.OCR
Monitoring Metrics
Metric ID |
Metric |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object & Dimension |
Monitoring Period (Raw Data) |
successful_call_times_of_service |
Successful Calls |
Times that a service is successfully called. |
≥ 0 |
times/min |
N/A |
API |
1 minute |
failed_call_times_of_service |
Failed Calls |
Times that a service fails to be called. |
≥ 0 |
times/min |
N/A |
API |
1 minute |
Dimensions
Key |
Value |
call_of_interface |
API |
