Viewing Tracing Logs
After you subscribe to CTS, CTS starts recording operations on cloud servers. You can view operation records in the last seven days on the CTS management console.
This section describes how to view operation records of the last 7 days on the CTS management console.
- Log in to the CTS console.
- On the Cloud Trace Service page that is displayed, choose Trace List from the navigation pane.
- Set the filter criteria to query traces. The following four filter criteria are available:
- Trace Source, Resource Type, and Search By
Select your desired criteria from the three drop-down lists one by one.
When you select Trace name for Search By, select a trace name.
When you select Resource ID for Search By, enter a resource ID.
When you select Resource name for Search By, select or enter a resource name.
- Operator: Select a specific operator (a user other than the tenant).
- Trace Status: Select All trace statuses, Normal, Warning, or Incident.
- Time Range: You can view traces generated during any time range of the last seven days.
- Expand your desired trace to view its details. Figure 1 Expanding a trace for details
- Locate your desired trace and click View Trace in the Operation column.
