Status Check
GSL provides the SIM card status check for network diagnosis and fault locating.
- Log in to the GSL console and choose SIM Cards > Status Check in the navigation pane.
- Enter a container ID, MSISDN, or IMEI, and click Check.
Figure 1 SIM card status check page
- The result page is displayed. You can view the basic information and check results of the SIM card.
Figure 2 Result page
Table 1 Result parameters Parameter
SIM Card Status
The SIM card status.
Connection Status
The status of the bound device.
Device-SIM Status
Whether the SIM card is bound to a device IMEI.
Network Disconnection Status
Network status of the SIM card (connected or disconnected).
Causes: policy-based restriction, data use-up, data pool/shared data (remaining allocation) use-up, proactive disconnection (CMIOT system), proactive disconnection (third-party system), abnormal data, usage limit, IoV control, auto disconnection threshold, manual disconnection, customer-level device-SIM rebinding, device-SIM rebinding, transfer to a non-restricted area, and first-call device-SIM rebinding.
Restricted Area Status
Whether the SIM card is used in a restricted area.
Restricted Area
The restricted area of the SIM card.
Frozen
Only available for China Unicom and China Mobile SIM cards.
- China Unicom: You cannot change the status of a frozen card.
- China Mobile: You cannot use a frozen card or change its status.
