Updated on 2025-05-23 GMT+08:00
Tags
You can create, modify, and delete tags and attach them to SIM cards. A tag that is attached to a SIM card is In use.
Precautions
- Up to 10,000 tags can be created for an account.
- Up to 10 tags can be attached to a single SIM card.
- After a tag is deleted, information about the tag is deleted from all SIM cards to which the tag is attached.
- Log in to the GSL console.
- In the navigation pane, choose Tags.
- Perform the following operations as required.
- Adding a tag
- Modifying a tag
- Locate the target tag and click Modify in the Operation column.
- In the displayed dialog box, change the tag name.
- Click Submit.
- Deleting a tag
- Locate the target tag and click Delete in the Operation column.
- In the displayed dialog box, click OK to delete the tag.
