Updated on 2025-04-09 GMT+08:00
Constraints of PFS
Operations
  • An existing OBS bucket cannot be changed to a parallel file system. For details about how to create a parallel file system, see Creating a Parallel File System.
  • Custom domain names of parallel file systems cannot be configured on OBS Console. You can configure them using APIs by referring to Configuring a Custom Domain Name.
Functions
  • Image processing cannot be used to process (such as slim, resize, or watermark) images stored in parallel file systems.
  • Server-side encryption is not supported.
  • Cross-region replication is not supported.
  • Versioning is not supported.
  • Bucket inventory is not supported.
  • Static website hosting is not supported.
  • Configuration of default storage class for a parallel file system is not supported.
  • Deep Archive storage is not supported.
  • A parallel file system can be mounted to multiple Linux servers for concurrent reads, but this is not recommended for concurrent writes.
Performance
  • A parallel file system provides a maximum bandwidth of 16 Mbit/s per TB by default.
Naming
  • In a parallel file system, a file name cannot contain two consecutive slashes (//). For example, if you name a file as test//123.txt, an error will be reported.
