Creating a Parallel File System
You can create a parallel file system on OBS Console.
- Log in to the parallel file system console.
- In the upper right corner of the page, click Create Parallel File System.Figure 1 Creating a parallel file system
- Select a region and enter a name for the parallel file system.
- Once a parallel file system is created, its name cannot be changed.
- URLs do not support uppercase letters and cannot distinguish between names containing uppercase or lowercase letters. Therefore, a parallel file system name can contain only lowercase letters, digits, periods (.), and hyphens (-). For example, if you attempt to access the parallel file system MyFileSystem using a URL, the file system name will be resolved to myfilesystem, causing an access error.
- Configure a data redundancy policy. If you select multi-AZ storage, data will be stored in multiple AZs for a higher reliability.
Once a parallel file system is created, you cannot change the data redundancy policy, so take care when selecting a data redundancy policy.
- Configure a policy. You can select Private, Public Read, or Public Read/Write for the parallel file system.
- Configure direct reading. With direct reading enabled, you can directly download files in the Archive storage class without restoring them first. Direct reading is a billable function. For details, see Product Pricing Details.
- (Optional) Add tags. Tags are used to identify parallel file systems in OBS, for the purpose of classification. Each tag is represented by one key-value pair. For details about how to add a tag, see Tags.
- (Optional) Buy storage packages. By default, you are billed on a pay-per-use basis for using parallel file systems. You can also purchase storage packages to save more. After selecting a required package, go to the Confirm page to complete the purchase.
Storage packages can also be purchased after the parallel file system is created.
- Confirm the settings at the bottom of the page and click Create Now.
- Check that the file system you created just now is in the parallel file system list.
Then, you can use the parallel file system the same way you use a bucket. For details about how to use a parallel file system, see Using Parallel File Systems.
