Configuring WORM for Objects
If you want to prevent any user (including the bucket or object owner) from modifying or deleting specific objects in an OBS bucket for a specified period, you can configure object-level WORM.
This section describes how to configure WORM for objects when uploading them or after they are uploaded.
- A bucket-level WORM policy applies only to objects uploaded after the policy is configured. To protect existing objects, configure object-level WORM separately.
- The metadata of a WORM-protected object can still be modified.
Important Notes
- Before configuring object-level WORM, you must enable bucket-level WORM. If an object is protected by both bucket-level and object-level WORM, the object-level WORM policy takes precedence.
- The retention period of object-level WORM can only be extended but cannot be shortened.
- If you have deregistered your account or your account has been frozen, the WORM-protected objects will be permanently deleted.
- WORM does not protect parts generated during multipart uploads.
- If a bucket has WORM enabled, an append upload on this bucket will fail, with a 403 error returned.
- Only the compliance mode is supported.
Access Control
To configure an object-level WORM policy, you must be the object owner or have the required permission. For authorization details, see Object-Level WORM Authorization Settings.
WORM has been enabled for the bucket.
Configuring WORM When Uploading Objects
You can configure object-level WORM using OBS Console or APIs, but not using SDKs, OBS Browser+, or obsutil.
Configuring WORM or Extending the Retention Period After Objects Are Uploaded
You can configure object-level WORM using OBS Console, APIs, or SDKs, but not using OBS Browser+ or obsutil.
If an object does not have WORM configured or its retention period needs to be extended, perform the following steps:
