Updated on 2025-04-25 GMT+08:00
Watermarking Images
Public Parameters
You can use the GUI or code mode on OBS Console or make an API call to configure public parameters for watermarking.
You can add a text or image watermark to the original image.
The Base64 code for URL transmission applies to paths of content and fonts of text watermarks, or paths of image watermarks. It is not advisable to put standard Base64 code directly into the URL for transmission. In Base64 encoding for URL transmission, contents are coded into character strings by standard Base64 code. After verifying these strings, replace the plus sign (+) with hyphen (-), and slash (/) with underline (_). For details about encoding, see those specified in RFC4648.
This operation is represented by watermark.
Public parameters are those applicable to both image watermarks and text watermarks. You can add these two types of watermarks to the same image. Table 1 describes the parameters.
Table 1 Public parameters
Value Description
Code Example
g
Optional. g represents the watermark location. It can be set to tl, top, tr, left, center, right, bl, bottom, or br. The default value is tl.
Figure 1 shows a 3×3 grid illustrating these values. Each value locates at the top left corner of the cell.
image/watermark,image_aW1hZ2UtZGVtby
9sb2dvLnBuZw==,g_br,t_90,x_10,y_10
x
Optional. x represents the horizontal distance from the image edge. By default, the origin is at the top left corner. The value ranges from 0 to 4096, in pixels. The default value is 10.
y
Optional. y represents the vertical distance from the image edge. By default, the origin is at the top left corner. The value ranges from 0 to 4096, in pixels. The default value is 10.
voffset
Optional. voffset represents the vertical offset from the horizontal centerline of the image. It moves a watermark upward or downward from the horizontal centerline of the image. The value ranges from -1000 to 1000, in pixels. The default value is 0.
voffset is meaningful only when g is set to left, center, or right.
align
Optional. align represents the alignment of the text and image watermarks. The value can be 0 (default value), 1, or 2.
  • 0: top alignment
  • 1: center alignment
  • 2: bottom alignment
order
Optional. order represents the placement order of the text and image watermarks. The value can be 0 (default value) or 1.
  • 0: image watermark in front of the text watermark
  • 1: text watermark in front of the image watermark
t
Optional. It represents the transparency of a watermark. Its value ranges from 0 to 100. The default value is 100, indicating the watermark is not transparent at all.
interval
Optional. It represents the distance between a text watermark and an image watermark. Its value ranges from 0 to 1000.
Figure 1 shows a 3×3 grid illustrating the watermark locations.
Figure 1 3×3 grid of watermark locations
If both a text watermark and an image watermark are added to the same image, you can configure x, y, and voffset to adjust the watermark locations and their layout.
Image Watermarks
You can pre-process an image watermark before adding it to an image.
The pre-processing operations include those described in Resizing Images, Rotating Images, and Cropping Images, but cropping an image watermark into an inscribed circle is not allowed. When resizing an image watermark, you can scale it to a specific percentage of the original image size.
Table 2 describes the image watermark parameters.
Table 2 Image watermark parameters
Value Description
Code Example
Mandatory. It indicates the watermark image path.
The watermark image path is bucketName/objectName (encoding required) or bucketName/objectName?x-image-process=image/command (encoding required).
NOTICE:
The content must be URL-safe Base64 encoded in the encodedObject = url_safe_base64_encode(object) format. For example, object panda.png will be encoded as cGFuZGEucG5n.
image/resize,w_400/watermark,image_aW1h
Z2UtZGVtby9sb2dvLnBuZz94LWltYWdlLXByb
2Nlc3M9aW1hZ2UvcmVzaXplLFBfMzA=,t_90,
g_br,x_10,y_10
P
It indicates the percentage of the original image the image watermark will be scaled to. The value ranges from 1 to 100.
NOTICE:
P used here for resizing is case-sensitive. To adjust the size of an image watermark, see Resizing Images (except the p parameter).
image-demo/logo.png?x-image-process=image/resize,P_50
Text Watermarks
You can configure the size, font, and color for text images. Table 3 describes the parameters.
Table 3 Text watermark parameters
Value Description
Code Example
text
Mandatory for adding text watermarks
NOTICE:
The content must be URL-safe Base64 encoded in the encodeText = url_safe_base64_encode(fontText) format, with a maximum of 64 characters (16 full-width characters at most).
image/watermark,text_SGVsbG8g5Zu-
54mH5pyN5YqhIQ,size_60,color_FF0000,type_
ZmFuZ3poZW5nc2h1c29uZw==,g_center,rotate_30
size
Optional. It represents the size of a text watermark, ranging from 0 (exclusive) to 1000 (inclusive). The default value is 40.
type
Optional. It represents the font of a text watermark. Available values are those shown in Table 4. The default value is wqy-zenhei (d3F5LXplbmhlaQ after encoding).
NOTICE:
- The content must be URL-safe Base64 encoded in the encodeText = url_safe_base64_encode(fontType) format.
- Line breaks are currently not supported.
color
Optional. It represents the color of a text watermark.
The value is a six-digit hexadecimal code, from 000000 (default value, representing black) to FFFFFF.
shadow
Optional. It represents the transparency of a text watermark. The value ranges from 0 (exclusive) to 100 (inclusive).
fill
Optional. It represents the filling effect of a text watermark. The value can be 0 or 1.
  • 0: filling not applied
  • 1: filling applied
rotate
Optional. It represents the clockwise rotation angle of a text watermark. The value ranges from 0 (exclusive) to 360 (exclusive).
Table 4 Text font encoding
Value After URL-Safe Base64 Encoding
Value Description
Remarks
droidsansfallback
ZHJvaWRzYW5zZmFsbGJhY2s=
DroidSansFallback
According to Request for Comments (RFC), the fuller "=" can be omitted, and the value becomes ZHJvaWRzYW5zZmFsbGJhY2s.
fangzhengfangsong
ZmFuZ3poZW5nZmFuZ3Nvbmc=
FZFongSong
According to RFC, the fuller "=" can be omitted, and the value becomes ZmFuZ3poZW5nZmFuZ3Nvbmc.
fangzhengheiti
ZmFuZ3poZW5naGVpdGk=
FZSimHei
According to RFC, the fuller "=" can be omitted, and the value becomes ZmFuZ3poZW5naGVpdGk.
fangzhengkaiti
ZmFuZ3poZW5na2FpdGk=
FZKaiTi
According to RFC, the fuller "=" can be omitted, and the value becomes ZmFuZ3poZW5na2FpdGk.
fangzhengshusong
FZShuSong
According to RFC, the fuller "=" can be omitted, and the value becomes ZmFuZ3poZW5nc2h1c29uZw.
wqy-microhei
d3F5LW1pY3JvaGVp
WenQuanYi Micro Hei
wqy-zenhei
d3F5LXplbmhlaQ==
WenQuanYi Zen Hei
According to RFC, the fuller "=" can be omitted, and the value becomes d3F5LXplbmhlaQ.
Adding a Text Watermark in the GUI Mode on OBS Console
This case describes how to add a FZShuSong text watermark to the top left of an image in the GUI mode on OBS Console.
  1. On the console homepage, click Service List in the upper left corner and choose Storage > Object Storage Service.
  2. In the bucket list, click the bucket you want to go to the Objects page.
  3. Click Upload Object to open the Upload Object dialog box.
  4. Click add files marked by red box in Figure 6 to open the local file browser.
    Figure 6 Uploading an image
  5. Select the image that you want to upload and click Open.
  6. Click Upload to upload the image. The uploaded image is displayed in the object list.
  7. In the navigation pane, choose Data Processing > Image Processing.
  8. Click Create to go to the style editing page shown in Figure 7.
    Figure 7 Creating a style
  9. Set Style Name to obs-111 and choose GUI for Edit Mode.
  10. Expand Watermark.
    1. Choose Text watermark for Watermark Type.
    2. Specify Content to Hello.
    3. Choose FZShuSong for Text Font.
    4. Set Text Size to 600.
    5. Keep the default value 100 for Watermark Transparency.
    6. Select the top left sign () for Watermark Position.
    7. Keep Text Shadow () disabled.
    8. Keep the default value 10 for both Vertical Margin and Horizontal Margin.
    The style effect will be displayed on the right in real time. Figure 8 shows the final style effect.
    Figure 8 Effect of style obs-111
  11. Click OK to save the style. The new style obs-111 will be displayed in the style list.
  12. In the navigation pane, choose Objects. Click mountain.jpg in the object list to go to the file details page.
  13. Click the Preview Image tab to preview the effect of the image with style obs-111 applied.
    Figure 9 Preview Image
  14. In the image style card, click Copy Link. When Copied successfully. is prompted, you will have the address for accessing the image with the style applied.
