- User Guide
- Best Practices
- FAQs
Show all
Viewing Whitelist Details
This section describes how to view the details about an imported whitelist, including the file name, object type, file format, and upload time.
You have imported a whitelist. For details about how to import a whitelist, see Importing a Whitelist.
- Click
in the upper left corner of the management console and select a region or project.
- Click
in the navigation pane on the left and choose Security & Compliance > Managed Threat Detection.
Figure 1 Home page of MTD - Choose Settings > Threat Intelligence in the left navigation pane.
- Click the Whitelist tab and view details about the whitelist file.
Table 1 Whitelist file Parameter
File Name
Name of a whitelist file
Intelligence Type
Content type of the whitelist file, which can be IP or domain name.
Format
Format of the whitelist file. Currently, only plaintext files are supported. For details, see How Do I Edit and Upload a Plaintext File to OBS?
Uploaded
Time when a whitelist file is uploaded
