Updated on 2026-09-24 GMT+08:00
MRS 1.9.3.1 Patch Description
Basic Information
Table 1 Basic information
Patch Version
MRS 1.9.3.1
Release Date
2020-09-04
Resolved Issues
MRS Manager
Solved the problem that Task nodes fail to be removed from a custom cluster.
MRS big data components
Solved the problem that the version of the adapter-hadoop-wrapper-file-system package in the Hive and Spark paths is incorrect.
Solved the problem that multiple namespaces saved on FusionInsight Manager of HBase do not take effect in the background.
Added HDFSWrapper to support AbstractFileSystem.
Compatibility with Other Patches
None
Impact of Patch Installation
  • During the installation of the MRS 1.9.3.1 patch, MRS Manager is restarted, and Hadoop, HDFS, Hive, Spark, and related dependent services are restarted in rolling mode. During the restart of MRS Manager, services are temporarily unavailable but services are not interrupted during the rolling restart.
  • After installing the MRS 1.9.3.1 patch, you need to download and install all clients again, including the original clients of the Master node and the clients used by other nodes of VPC (that is, the clients that you set up).
    • You are advised to back up the old clients before reinstalling the new ones.
    • If you have modified client configurations based on the service scenario, modify them again after reinstalling the clients.
